Resources to learn and understand CAN configuration and programming
936件の閲覧回数
aquant
Greetings.
I have been looking for resources to learn CAN configuration, or perhaps how to program it myself. I couldn't find a resources for educating myself on that.
Do help me out.
Thanks and regard,
Aquant
914件の閲覧回数
Senlent
Hi@aquant
some routines about using Flexcan module in s32 ds for your reference.
for example:"flexcan_encrypted_s32k14x",this example will show the usage of the flexcan module with flexible data rate.
this routine require you to installl the sdk in advance, for example ,the version I am using is:S32DS_ARM_v2018.R1 & S32SDK_S32K1xx_RTM_3.0.0.
when you have installed the develop environment, you can find some API manuals under the ....S32DS_ARM_v2018.R1\S32DS\S32SDK_S32K1xx_RTM_3.0.0\doc path.
BR!
      Jim,
