HSE firmware installation
40,899 次查看
vikmonti7804
     I want to install the HSE firmware, but i am facing one error with the package given C:\NXP\S32K3_HSE_DemoExamples_1_0_0\S32K3_HSE_DemoExamples\Device_Configuration\S32K344_HSE_FW_INSTALL.
error
make: *** [makefile:38: S32K312_HSE_FW_INSTALL.elf] Error 1
Kindly let me know the solution.
is there any firmware available for s32k312 for HSE fw installation?
45 回复数
22,398 次查看
lukaszadrapa
I got new board right now. Here's the result of my test:
I was able to successfully install the firmware using your project. I just uncommented checking of the HSE feature flag. That was the only change I did.
After that, I could successfully erase the firmware using service HSE_SRV_ID_ERASE_FW.
I'm still not sure why it does not work on your side. Do you have more boards? Are all of them showing the same behavior?
Lukas
5,263 次查看
Sanjana_k
#Hello@lukaszadrapa ,
Please help us we need your help. Our HSE firmware is flashed successfully, but the firmware is not starting after flashing.
The system gets stuck at the same point every time and does not continue execution.
I am not sure why this is happening.
I have a few doubts:
  1. Before flashing the firmware, do we need to run any other project like the Key Catalog example or any prerequisite configuration?
  2. Earlier, we had flashed HSE Firmware version 2.1, but now we changed the firmware to version 2.55.
    Could this version change cause the issue?
  3. The SBUF version we are reading is 0x00500000.
    Is this expected for firmware version 2.55?
  4. Do we need to make any specific changes in the HSE_FW_INSTALL application code when updating to the new firmware version?
  5. we have API provided along with firmware where we need to use them ?
Please please guide us on what might be causing the firmware not to start.
Thank you
5,263 次查看
Sanjana_k
hello @lukaszadrapa
please help us our firmware code itself stucking at  i dont know why this is happening please help us
firmware flshing i did and verified i dont know why my firmware is not initiating ..please help us
Thank u
21,888 次查看
vikmonti7804
Hi Lucas,
       Which api you had used to erase the controller with HSE_SRV_ID_ERASE_FW?
Please provide the API .
21,295 次查看
vikmonti7804
I am trying to use FLASH_EraseBlock((uint32_t*)HSE_SRV_ID_ERASE_FW); but it goes into the hard fault.
Can you please explain the steps to erase the memory.
Should i comment the import of the hse fw file in linker file befor applying this erase?
how it will be done, please explain.
标记 (1)
14,839 次查看
lukaszadrapa
This is new feature and I didn't find API for that in RTD or in HSE DEMO examples. So, I used minimalist option and I simply triggered the service via MU in debugger. Here is the description of the service from API manual:
c:\NXP\HSE_FW_S32K312_0_2_40_0\docs\S32K312_HSE_Service_API_Reference_Manual.pdf
So, the service ID is 0x57 and no parameters are needed.
Just write 0x57 somewhere to RAM and then write address of this RAM word to Message Unit MU_0, register TR[1]. That's all. Then you will see the response in RR[1]. If the HSE FW was installed, you should get HSE_SRV_RSP_OK which is value 0x55A5AA33.
Here's how it looks in my debugger:
12,843 次查看
Yetkin
Hi @lukaszadrapa ,
I performed HSE FW erase as you mentioned, and it worked. However, I can not install it back. How to install HSE FW again?
Yetkin
14,476 次查看
vikmonti7804
Hi Lucas,
         I dont have debugger PE micro. Does this trace32 power view works with PE micro?
How to trigger the service via MU in debugger with PE micro and s32DS? is there any example code?
How can i erase the controller with S32DS? Is there any example code or should i use the API FLASH_EraseBlock(dst); ?
13,154 次查看
vikmonti7804
HI Lucas,
          I tried with different board with same firmware project what you shared but the result is same as earlier. Last bit of the HSE GPR register is not getting set.
Can you please try with PE Micro debugger and try to find the root cause of the problem.
We dont have lauterbach debugger here.
i am sharing the picture of the memory with different board.
vikmonti7804_0-1709101778843.pngvikmonti7804_1-1709101788067.pngvikmonti7804_2-1709101802879.png
11,810 次查看
lukaszadrapa
I used another brand new board for my test and I used exactly the same project I sent you earlier. I loaded the project by S32DS via in-built Pemicro OpenSDA interface, run the project, power cycled the board 2x and then I can see that the bit in HSE GPR is set and FW is installed.
Once the HSE FW is installed, it's necessary to change the flash algorithm in Pemicro settings:
That's because some parts of flash are allocated for HSE when the HSE feature flag is enabled or when AB swap FW is installed. Pemicro needs to be informed about this.
11,808 次查看
vikmonti7804
Hi Lucas,
           Thanks for your reply,
Can you please share your .elf file.
Why you power cycled the board 2 time, is it mandatory to reset is 2 time or power on 2 times?
what was the setting during flash, is it ab_sawp.arp or hse_enabled.arp in the advance setting? ?
11,807 次查看
lukaszadrapa
There's elf file in the project I already shared:
https://community.nxp.com/pwmxy87654/attachments/pwmxy87654/S32K/32120/1/HSE_Install_FW.zip
I compared the elf with my current project which I tested today and it's identical, no changes.
I had brand new chip, so I used default hse_disabled version. If HSE feature flash is already enabled but HSE FW is not installed yet, you should use hse_enabled. And once AB swap is installed, you should use ab_swap. But I don't think this could be wrong because Pemicro should show some error if it can't erase or program the flash. Even if you use hse_disabled when HSE feature flag is programmed, it will probably still work.
To install the firmware also to passive block, two resets are needed (or two power cycles, it doesn't matter):
11,804 次查看
vikmonti7804
Or you can create  video for the debug settings and debugging the firmware and then share with me.
11,805 次查看
vikmonti7804
Hi Lucas , i tried but its same.
Can we connect for a call hardly 10 minutes if possible? please let me know so i will share the invite.
11,801 次查看
lukaszadrapa
I'm running out of time today but tomorrow morning should be ok. I will let you know early in the morning when I'm available.
11,785 次查看
vikmonti7804
HI Lucas , when can we connect, please provide time and link to connect.
11,941 次查看
vikmonti7804
Dis you used the project which i shared with you?
Kindly share your main program with me.
12,041 次查看
vikmonti7804
I tried the firmware with the condition on the feature flag  but again the hse gpr resgiter is not getting updated.
12,137 次查看
vikmonti7804
Please debug it and check why hse gpr register bit is not getting set and installation is  not completing by sbaf.
12,210 次查看
vikmonti7804
   Actually i have created a project for s32k312  but when i am running it in debug mde i see it directly jumping to default hander not going into main, can you please help with this issue, why this is happening.
i see the binary is place in flash but utest is not enabled due to not going into main.
kindly help.
12,346 次查看
vikmonti7804
Hi ,
 The HSE firmware package foe the S32K312 is only having the bin files and some interface and host files for the creation of the project. It is not the complete project like HSE demo example for s32k344.
I am also facing the issue to flash this binary of HSE firmware with the eval board debugger as well as PE micro debugger because it supports only .elf and hex file. kindly help me to flash the binary to the eval board.
%3CLINGO-SUB%20id%3D%22lingo-sub-1808863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%AE%89%E8%A3%85%20HSE%20%E5%9B%BA%E4%BB%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1808863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E5%AE%89%E8%A3%85%20HSE%20%E5%9B%BA%E4%BB%B6%EF%BC%8C%E4%BD%86%E6%98%AF%E7%BB%99%E5%87%BA%E7%9A%84%E4%BB%A3%E7%A0%81%E5%8C%85%E5%87%BA%E7%8E%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%20C%3A%5CNXP%5CS32K3_HSE_DemoExamples_1_0_0%5CS32K3_HSE_DemoExamples%5CDevice_Configuration%5CS32K344_HSE_FW_INSTALL.%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3Emake%EF%BC%9A***%20%5Bmakefile%3A38%3A%20S32K312_HSE_FW_INSTALL.elf%5D%20%E9%94%99%E8%AF%AF%201%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E7%94%A8%E4%BA%8E%E5%AE%89%E8%A3%85%20HSE%20fw%20%E7%9A%84%20s32k312%20%E5%9B%BA%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2200576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E4%BB%AC%E5%A5%BD%EF%BC%8C%E4%BD%A0%E4%BB%AC%E8%83%BD%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E8%83%BD%EF%BC%8C%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172865%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172865%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%89%E4%BA%BA%E8%83%BD%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%8F%91%E5%B8%83%E4%B8%8E%E6%82%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E6%AD%A5%E9%AA%A4%E3%80%82%E6%88%91%E5%90%8C%E6%97%B6%E5%B0%9D%E8%AF%95%E4%BA%86%20full_mem%20%E5%92%8C%20ab_swap%E3%80%82%E9%83%BD%E5%A4%B1%E8%B4%A5%E4%BA%86%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990263%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990263%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%88%91%E6%83%B3%E6%88%91%E6%89%BE%E5%88%B0%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%E4%BA%86%E3%80%82%E5%9C%A8%E5%86%85%E5%AD%98%E8%A7%86%E5%9B%BE%E4%B8%AD%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E9%80%89%E6%8B%A9%20%22%20%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%20%22%20%E6%88%96%20%22%20%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E6%95%B4%E6%95%B0%20%22%EF%BC%8C%E5%88%99%E5%AD%97%E8%8A%82%E9%A1%BA%E5%BA%8F%E5%B0%86%E7%9B%B8%E5%8F%8D%E3%80%82%E7%99%BB%E8%AE%B0%E5%86%8C%E6%98%AF%E4%B8%BA%E6%88%91%E8%AE%BE%E7%BD%AE%E7%9A%84%EF%BC%8C%E4%BD%86%E8%BF%99%E4%BA%9B%E8%A7%82%E7%82%B9%E8%AE%A9%E6%88%91%E5%9B%B0%E6%83%91%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3EHSE_B%20%E5%9B%BA%E4%BB%B6%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E7%9A%84%20%22%203.3.1%20MU%20%E5%9C%A8%20AB_SWAP%20%E9%85%8D%E7%BD%AE%E4%B8%AD%E6%8C%89%E4%B8%BB%E6%9C%BA%E5%88%86%E5%88%97%E7%9A%84%E5%AE%89%E8%A3%85%E6%AD%A5%E9%AA%A4%20%22%20%E7%AB%A0%E8%8A%82%E4%BB%8E%E4%BB%A5%E4%B8%8B%E5%87%A0%E8%A1%8C%E5%BC%80%E5%A7%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%22%20%E5%9C%A8%E5%AF%84%E5%AD%98%E5%99%A8%20DCMRWP1%EF%BC%880x402AC400%EF%BC%8C%5B24%3A31%20%E4%BD%8D%5D%EF%BC%89%E4%B8%8A%E5%86%99%E5%85%A5%200xA5%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BF%9B%E8%A1%8C%E5%8A%9F%E8%83%BD%20RESET%E3%80%82%E8%BF%99%E5%B0%86%E8%AE%BE%E7%BD%AE%20HSE%20GPR%20(0x4039C028)%20%E4%B8%AD%E7%9A%84%E4%BD%8D%201%EF%BC%8C%E8%A1%A8%E6%98%8E%20SBAF%20%E5%B7%B2%E6%BF%80%E6%B4%BB%20MU0%20%E8%BF%9B%E8%A1%8C%E5%AE%89%E8%A3%85%E3%80%82%22%3C%2FP%3E%3CP%3E%E4%BD%86%E6%9C%AC%E4%B8%BB%E9%A2%98%E4%B8%AD%E5%B9%B6%E6%9C%AA%E6%8F%90%E5%8F%8A%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E5%BF%85%E9%A1%BB%E8%AE%BE%E7%BD%AE%20DCMRWP1%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E8%BF%98%E6%98%AF%E5%9C%A8%E7%A4%BA%E4%BE%8B%E4%B8%AD%E4%BB%A5%E6%9F%90%E7%A7%8D%E6%96%B9%E5%BC%8F%E5%AE%9E%E7%8E%B0%E4%BA%86%E8%AE%BE%E7%BD%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3ESandor%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990114%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990114%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%BF%99%E9%87%8C%E6%9C%89%E4%BB%80%E4%B9%88%E6%96%B0%E6%83%85%E5%86%B5%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1973145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1973145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%97%AE%E9%A2%98%E8%A7%A3%E5%86%B3%E4%BA%86%E5%90%97%EF%BC%9F%E8%BF%99%E6%98%AF%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E9%80%A0%E6%88%90%E7%9A%84%EF%BC%9F%E6%88%91%E8%BF%99%E8%BE%B9%E4%B9%9F%E6%98%AF%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8%E6%97%A0%E6%B3%95%E8%AE%BE%E7%BD%AE%221%22%20%EF%BC%8C%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1910374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E4%BD%A0%E6%8F%90%E5%88%B0%E7%9A%84%E6%96%B9%E6%B3%95%E8%BF%9B%E8%A1%8C%E4%BA%86%20HSE%20FW%20%E6%B8%85%E9%99%A4%EF%BC%8C%E7%BB%93%E6%9E%9C%E6%88%90%E5%8A%9F%E4%BA%86%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%B0%86%E5%85%B6%E5%AE%89%E8%A3%85%E5%9B%9E%E5%8E%BB%E3%80%82%E5%A6%82%E4%BD%95%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%20HSE%20FW%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E5%8F%B6%E7%89%B9%E9%87%91%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%85%B3%E4%BA%8E%E8%AE%A8%E8%AE%BA%EF%BC%8C%E6%88%91%E4%B9%9F%E5%9C%A8%E5%B0%9D%E8%AF%95%E6%9B%B4%E6%8D%A2%20S32K344%20%E6%9D%BF%E3%80%82%E6%88%91%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%93%8D%E4%BD%9C%EF%BC%9A%3CBR%20%2F%3E1)%20%E4%B8%8B%E8%BD%BD%20S32K3_HSE_DemoExamples_1_0_0%EF%BC%8C%E8%BF%9B%E8%A1%8C%20a%2Fb%20%E4%BA%A4%E6%8D%A2%EF%BC%8C%E9%80%9A%E8%BF%87%E6%B7%BB%E5%8A%A0%20.pink%20%E6%9D%A5%E6%9B%B4%E6%94%B9%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E3%80%82%E6%96%87%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E2)%20%E6%88%91%E7%BC%96%E8%AF%91%E4%BA%86%E9%A1%B9%E7%9B%AE%E5%B9%B6%E8%BF%90%E8%A1%8C%E4%BA%86%E5%AE%83%EF%BC%8C%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%97%B6%EF%BC%8C%E4%BB%A3%E7%A0%81%E4%BF%9D%E6%8C%81%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20%E5%AE%89%E8%A3%85%E5%90%8E%E7%AD%89%E5%BE%85%20HSE%20%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%88%E8%AF%BB%E5%8F%96%E7%8A%B6%E6%80%81%E4%BD%8D%EF%BC%89*%2F%20while%20((HSE_STATUS_INIT_OK%20%26amp%3B%20HSE_mu_gethseStatus%20(0))%20%3D%3D%200)%20%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3EginstallHSEFWTEST%20%3D%20FW_NOT_INSTALLED%3B%20%3CBR%20%2F%3E%20%2F*%20%E8%AF%B7%20RESET%20%E4%BB%A5%E5%85%81%E8%AE%B8%E5%AE%89%E8%A3%85%20*%2F%3CBR%20%2F%3E%7D%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%203)%20%E6%88%91%E8%AF%95%E7%9D%80%E6%97%A2%E6%8C%89%E4%B8%8B%E6%9D%BF%E4%B8%8A%E7%9A%84%20RST%20%E6%8C%89%E9%92%AE%EF%BC%8C%3CBR%20%2F%3E%E5%8F%88%E6%83%B3%E6%8A%8A%E5%AE%83%E5%85%B3%E6%8E%89%E7%84%B6%E5%90%8E%E5%86%8D%E6%89%93%E5%BC%80%EF%BC%8C%E4%BD%86%E6%98%BE%E7%84%B6%E5%AE%83%E5%B9%B6%E6%B2%A1%E6%9C%89%E6%94%B9%E5%8F%98%E4%BB%BB%E4%BD%95%E4%B8%9C%E8%A5%BF%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%BF%98%E4%BA%86%E4%B8%80%E4%B8%AA%E6%AD%A5%E9%AA%A4%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1818321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1818321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BB%80%E4%B9%88%E6%97%B6%E5%80%99%E8%83%BD%E8%81%94%E7%B3%BB%E4%B8%8A%EF%BC%8C%E8%AF%B7%E6%8F%90%E4%BE%9B%E8%81%94%E7%B3%BB%E7%9A%84%E6%97%B6%E9%97%B4%E5%92%8C%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817457%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817457%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BB%8A%E5%A4%A9%E6%B2%A1%E6%97%B6%E9%97%B4%E4%BA%86%EF%BC%8C%E4%BD%86%E6%98%8E%E5%A4%A9%E6%97%A9%E4%B8%8A%E5%BA%94%E8%AF%A5%E6%B2%A1%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E6%98%8E%E5%A4%A9%E4%B8%80%E6%97%A9%E6%9C%89%E7%A9%BA%E5%B0%B1%E4%BC%9A%E9%80%9A%E7%9F%A5%E4%BD%A0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817455%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817455%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%96%E8%80%85%E4%BD%A0%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%88%B6%E4%BD%9C%E8%B0%83%E8%AF%95%E8%AE%BE%E7%BD%AE%E5%92%8C%E8%B0%83%E8%AF%95%E5%9B%BA%E4%BB%B6%E7%9A%84%E8%A7%86%E9%A2%91%EF%BC%8C%E7%84%B6%E5%90%8E%E4%B8%8E%E6%88%91%E5%88%86%E4%BA%AB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817449%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817449%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%EF%BC%8C%E6%88%91%E8%AF%95%E8%BF%87%E4%BA%86%EF%BC%8C%E4%BD%86%E8%BF%98%E6%98%AF%E4%B8%80%E6%A0%B7%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E5%8F%AF%E8%83%BD%E7%9A%84%E8%AF%9D%EF%BC%8C%E6%88%91%E4%BB%AC%E8%83%BD%E5%9C%A8%2010%20%E5%88%86%E9%92%9F%E5%86%85%E9%80%9A%E8%AF%9D%E5%90%97%EF%BC%9F%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E5%88%86%E4%BA%AB%E9%82%80%E8%AF%B7%E5%87%BD%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%88%86%E4%BA%AB%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%E6%9C%89%E4%B8%80%E4%B8%AA%E7%B2%BE%E7%81%B5%E6%96%87%E4%BB%B6%EF%BC%9A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpwmxy87654%2Fattachments%2Fpwmxy87654%2FS32K%2F32120%2F1%2FHSE_Install_FW.zip%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fpwmxy87654%2Fattachments%2Fpwmxy87654%2FS32K%2F32120%2F1%2FHSE_Install_FW.zip%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B0%86%E5%B0%8F%E7%B2%BE%E7%81%B5%E4%B8%8E%E6%88%91%E4%BB%8A%E5%A4%A9%E6%B5%8B%E8%AF%95%E7%9A%84%E5%BD%93%E5%89%8D%E9%A1%B9%E7%9B%AE%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%AF%94%E8%BE%83%EF%BC%8C%E7%BB%93%E6%9E%9C%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%EF%BC%8C%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%98%E5%8C%96%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E7%9A%84%E8%8A%AF%E7%89%87%E6%98%AF%E5%85%A8%E6%96%B0%E7%9A%84%EF%BC%8C%E6%89%80%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%BA%86%E9%BB%98%E8%AE%A4%E7%9A%84%20hse_disabled%20%E7%89%88%E6%9C%AC%E3%80%82%E5%A6%82%E6%9E%9C%E5%B7%B2%E5%90%AF%E7%94%A8%20HSE%20%E5%8A%9F%E8%83%BD%E9%97%AA%E5%AD%98%EF%BC%8C%E4%BD%86%E5%B0%9A%E6%9C%AA%E5%AE%89%E8%A3%85%20HSE%20FW%EF%BC%8C%E5%88%99%E5%BA%94%E4%BD%BF%E7%94%A8%20hse_enabled%E3%80%82%E4%B8%80%E6%97%A6%E5%AE%89%E8%A3%85%E4%BA%86%20AB%20swap%EF%BC%8C%E5%B0%B1%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20ab_swap%E3%80%82%E4%BD%86%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E4%B8%8D%E5%8F%AF%E8%83%BD%E5%87%BA%E9%94%99%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%A6%82%E6%9E%9C%20Pemicro%20%E6%97%A0%E6%B3%95%E6%93%A6%E9%99%A4%E6%88%96%E7%BC%96%E7%A8%8B%E9%97%AA%E5%AD%98%EF%BC%8C%E5%AE%83%E5%BA%94%E8%AF%A5%E4%BC%9A%E6%98%BE%E7%A4%BA%E4%B8%80%E4%BA%9B%E9%94%99%E8%AF%AF%E3%80%82%E5%8D%B3%E4%BD%BF%E5%9C%A8%20HSE%20%E5%8A%9F%E8%83%BD%E6%A0%87%E5%BF%97%E7%BC%96%E7%A8%8B%E6%97%B6%E4%BD%BF%E7%94%A8%20hse_disabled%EF%BC%8C%E5%AE%83%E5%8F%AF%E8%83%BD%E4%BB%8D%E7%84%B6%E6%9C%89%E6%95%88%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E5%B0%86%E5%9B%BA%E4%BB%B6%E4%B9%9F%E5%AE%89%E8%A3%85%E5%88%B0%E8%A2%AB%E5%8A%A8%E6%A8%A1%E5%9D%97%EF%BC%8C%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E4%B8%A4%E6%AC%A1%20RESET%EF%BC%88%E6%88%96%E8%80%85%E4%B8%A4%E6%AC%A1%E9%80%9A%E7%94%B5%EF%BC%8C%E6%B2%A1%E5%85%B3%E7%B3%BB%EF%BC%89%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265542i88AD2B7FA35E3A27%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1709119050485.png%22%20alt%3D%22lukaszadrapa_0-1709119050485.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%E3%80%81%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%88%86%E4%BA%AB%E6%82%A8%E7%9A%84%20.elf%E9%94%89%E5%88%80%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BD%A0%E9%87%8D%E5%90%AF%E6%9D%BF%202%20%E6%AC%A1%EF%BC%8C%E6%98%AF%E5%BF%85%E9%A1%BB%20RESET%202%20%E6%AC%A1%E8%BF%98%E6%98%AF%E5%BC%80%E6%9C%BA%202%20%E6%AC%A1%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%97%AA%E5%AD%98%E6%97%B6%E7%9A%84%E8%AE%BE%E7%BD%AE%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%8C%E6%98%AF%E9%AB%98%E7%BA%A7%E8%AE%BE%E7%BD%AE%E4%B8%AD%E7%9A%84%20ab_sawp.arp%20%E8%BF%98%E6%98%AF%20hse_enabled.arp%EF%BC%9F%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%94%A8%E4%BA%86%E5%8F%A6%E4%B8%80%E4%B8%AA%E5%85%A8%E6%96%B0%E7%9A%84%E6%9D%BF%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%8E%E4%B9%8B%E5%89%8D%E5%8F%91%E7%BB%99%E4%BD%A0%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%AE%8C%E5%85%A8%E4%B8%80%E6%A0%B7%E3%80%82%E6%88%91%E9%80%9A%E8%BF%87%E5%86%85%E7%BD%AE%E7%9A%84%20Pemicro%20OpenSDA%20%E6%8E%A5%E5%8F%A3%E9%80%9A%E8%BF%87%20S32DS%20%E5%8A%A0%E8%BD%BD%E4%BA%86%E9%A1%B9%E7%9B%AE%EF%BC%8C%E8%BF%90%E8%A1%8C%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%AF%B9%E7%94%B5%E8%B7%AF%E6%9D%BF%E8%BF%9B%E8%A1%8C%E4%BA%86%E4%B8%A4%E6%AC%A1%E9%80%9A%E7%94%B5%EF%BC%8C%E7%84%B6%E5%90%8E%E6%88%91%E5%B0%B1%E8%83%BD%E7%9C%8B%E5%88%B0%20HSE%20GPR%20%E4%B8%AD%E7%9A%84%E4%BD%8D%E5%B7%B2%E7%BB%8F%E8%AE%BE%E7%BD%AE%E5%A5%BD%E4%BA%86%EF%BC%8C%E5%9B%BA%E4%BB%B6%E4%B9%9F%E5%AE%89%E8%A3%85%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AE%89%E8%A3%85%20HSE%20FW%20%E5%90%8E%EF%BC%8C%E9%9C%80%E8%A6%81%E5%9C%A8%20Pemicro%20%E8%AE%BE%E7%BD%AE%E4%B8%AD%E6%9B%B4%E6%94%B9%E9%97%AA%E5%AD%98%E7%AE%97%E6%B3%95%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265527iB7ECE6479C2728D4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1709113020433.png%22%20alt%3D%22lukaszadrapa_0-1709113020433.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E5%9B%A0%E4%B8%BA%E5%BD%93%E5%90%AF%E7%94%A8%20HSE%20%E5%8A%9F%E8%83%BD%E6%A0%87%E5%BF%97%E6%88%96%E5%AE%89%E8%A3%85%20AB%20swap%20FW%20%E6%97%B6%EF%BC%8C%E9%97%AA%E5%AD%98%E7%9A%84%E6%9F%90%E4%BA%9B%E9%83%A8%E5%88%86%E4%BC%9A%E8%A2%AB%E5%88%86%E9%85%8D%E7%BB%99%20HSE%E3%80%82%E9%9C%80%E8%A6%81%E5%90%91%20Pemicro%20%E9%80%9A%E6%8A%A5%E6%AD%A4%E4%BA%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E4%B8%8E%E6%82%A8%E5%85%B1%E4%BA%AB%E7%9A%84%E7%9B%B8%E5%90%8C%E5%9B%BA%E4%BB%B6%E9%A1%B9%E7%9B%AE%E7%9A%84%E4%B8%8D%E5%90%8C%E6%9D%BF%EF%BC%8C%E4%BD%86%E7%BB%93%E6%9E%9C%E4%B8%8E%E4%B9%8B%E5%89%8D%E7%9B%B8%E5%90%8C%E3%80%82HSE%20GPR%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E6%9C%80%E5%90%8E%E4%B8%80%E4%BD%8D%E6%9C%AA%E8%A2%AB%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E4%BD%BF%E7%94%A8%20PE%20Micro%20%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9B%E8%A1%8C%E5%B0%9D%E8%AF%95%EF%BC%8C%E6%89%BE%E5%87%BA%E9%97%AE%E9%A2%98%E7%9A%84%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%BF%99%E9%87%8C%E6%B2%A1%E6%9C%89%E5%8A%B3%E7%89%B9%E5%B7%B4%E8%B5%AB%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E7%94%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E6%9D%BF%E5%88%86%E4%BA%AB%E5%86%85%E5%AD%98%E7%9A%84%E5%9B%BE%E7%89%87%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265454i8351747C6E419CCD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_0-1709101778843.png%22%20alt%3D%22vikmonti7804_0-1709101778843.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265455iA1255ADD2EB4FAF8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_1-1709101788067.png%22%20alt%3D%22vikmonti7804_1-1709101788067.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265456iF2433A8B8FFF8C54%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_2-1709101802879.png%22%20alt%3D%22vikmonti7804_2-1709101802879.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1816474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1816474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%E6%88%91%E6%B2%A1%E6%9C%89%E8%B0%83%E8%AF%95%E5%99%A8%20PE%20micro%E3%80%82%E8%BF%99%E7%A7%8D%20trace32%20%E7%94%B5%E6%BA%90%E8%A7%86%E5%9B%BE%E6%98%AF%E5%90%A6%E9%80%82%E7%94%A8%E4%BA%8E%20PE%20micro%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%9C%A8%3CSPAN%3E%E5%B8%A6%E6%9C%89%20PE%20micro%20%E5%92%8C%20S32D%20%E7%9A%84%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%AD%E9%80%9A%E8%BF%87%20MU%20%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E6%9C%8D%E5%8A%A1%EF%BC%9F%E6%9C%89%E4%BB%BB%E4%BD%95%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20S32DS%20%E6%93%A6%E9%99%A4%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%9F%20%3C%2FSPAN%3E%3CSPAN%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%88%96%E8%80%85%E6%88%91%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20API%20FLASH_EraseBlock(dst)%3B%20%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1816382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1816382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%96%B0%E5%8A%9F%E8%83%BD%EF%BC%8C%E6%88%91%E5%9C%A8%20RTD%20%E6%88%96%20HSE%20DEMO%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%E9%83%BD%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E7%9B%B8%E5%85%B3%E7%9A%84%20API%E3%80%82%E6%89%80%E4%BB%A5%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E6%9E%81%E7%AE%80%E4%B8%BB%E4%B9%89%E9%80%89%E9%A1%B9%EF%BC%8C%E6%88%91%E5%8F%AA%E6%98%AF%E9%80%9A%E8%BF%87%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%AD%E7%9A%84MU%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E4%BA%86%E6%9C%8D%E5%8A%A1%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%20API%20%E6%89%8B%E5%86%8C%E4%B8%AD%E7%9A%84%E6%9C%8D%E5%8A%A1%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%0A%3CP%3Ec%3A%5CNXP%5CHSE_FW_S32K312_0_2_40_0%5Cdocs%5CS32K312_HSE_Service_API_Reference_Manual.pdf%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265258i86AB0A9FB93402DB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1709023598929.png%22%20alt%3D%22lukaszadrapa_0-1709023598929.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265259i11E1CBCABDAB8DF6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_1-1709023606522.png%22%20alt%3D%22lukaszadrapa_1-1709023606522.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%9C%8D%E5%8A%A1%20ID%20%E6%98%AF%200x57%EF%BC%8C%E4%B8%8D%E9%9C%80%E8%A6%81%E4%BB%BB%E4%BD%95%E5%8F%82%E6%95%B0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8F%AA%E9%9C%80%E5%B0%86%200x57%20%E5%86%99%E5%85%A5%20RAM%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%20RAM%20%E5%AD%97%E7%9A%84%E5%9C%B0%E5%9D%80%E5%86%99%E5%85%A5%E4%BF%A1%E6%81%AF%E5%8D%95%E5%85%83%20MU_0%EF%BC%8C%E5%AF%84%E5%AD%98%E5%99%A8%20TR%5B1%5D%E3%80%82%E4%BB%85%E6%AD%A4%E8%80%8C%E5%B7%B2%E3%80%82%E7%84%B6%E5%90%8E%E6%82%A8%E5%B0%86%E5%9C%A8%20RR%5B1%5D%20%E4%B8%AD%E7%9C%8B%E5%88%B0%E5%93%8D%E5%BA%94%E3%80%82%E5%A6%82%E6%9E%9C%E5%B7%B2%E5%AE%89%E8%A3%85%20HSE%20FW%EF%BC%8C%E5%88%99%E5%BA%94%E5%BE%97%E5%88%B0%20HSE_SRV_RSP_OK%EF%BC%8C%E5%85%B6%E5%80%BC%E4%B8%BA%200x55A5AA33%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E6%88%91%E7%9A%84%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%AD%E7%9A%84%E6%98%BE%E7%A4%BA%E6%95%88%E6%9E%9C%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265263i93C8A450B5ABE75B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_2-1709023848154.png%22%20alt%3D%22lukaszadrapa_2-1709023848154.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1816209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1816209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%AF%95%E5%9B%BE%E4%BD%BF%E7%94%A8%20FLASH_EraseBlock((uint32_t*)HSE_SRV_ID_ERASE_FW)%3B%EF%BC%8C%E4%BD%86%E5%AE%83%E8%BF%9B%E5%85%A5%E4%BA%86%E7%A1%AC%E6%95%85%E9%9A%9C%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E8%A7%A3%E9%87%8A%E6%B8%85%E9%99%A4%E5%86%85%E5%AD%98%E7%9A%84%E6%AD%A5%E9%AA%A4%E3%80%82%20%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%B8%85%E9%99%A4%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E6%98%AF%E5%90%A6%E5%BA%94%E8%AF%A5%E5%9C%A8%20linker%20%E6%96%87%E4%BB%B6%E4%B8%AD%E5%AF%B9%20hse%20fw%20%E6%96%87%E4%BB%B6%E7%9A%84%E5%AF%BC%E5%85%A5%E8%BF%9B%E8%A1%8C%E6%B3%A8%E9%87%8A%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%AE%9E%E7%8E%B0%EF%BC%8C%E8%AF%B7%E8%A7%A3%E9%87%8A%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1816190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1816190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%E6%82%A8%E4%BD%BF%E7%94%A8%3CSPAN%3EHSE_SRV_ID_ERASE_FW%3C%2FSPAN%3E%E6%93%A6%E9%99%A4%E6%8E%A7%E5%88%B6%E5%99%A8%E6%97%B6%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%20api%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AF%B7%E6%8F%90%E4%BE%9B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%99%84%E4%B8%8A%E6%95%B4%E4%B8%AA%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E8%BF%87%E6%88%91%E4%B8%8E%E6%82%A8%E5%88%86%E4%BA%AB%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%AF%B7%E4%B8%8E%E6%88%91%E5%88%86%E4%BA%AB%E4%BD%A0%E4%BB%AC%E7%9A%84%E4%B8%BB%E8%A6%81%E8%AE%A1%E5%88%92%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%E8%AF%B7%E4%BB%8B%E7%BB%8D%E4%B8%80%E4%B8%8B%E6%82%A8%E7%9A%84%E4%B8%BB%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%BA%AB%E4%B8%8A%E5%8F%AA%E6%9C%89%E4%B8%80%E5%9D%97%E6%A3%8B%E7%9B%98%E8%80%8C%E4%B8%94%E6%98%AF%E6%96%B0%E7%9A%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E6%9C%89%E4%BA%86%E6%96%B0%E8%91%A3%E4%BA%8B%E4%BC%9A%E3%80%82%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E7%9A%84%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265036i6562E61CB478184D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1708948550506.png%22%20alt%3D%22lukaszadrapa_0-1708948550506.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E6%88%90%E5%8A%9F%E5%AE%89%E8%A3%85%E4%BA%86%E5%9B%BA%E4%BB%B6%E3%80%82%E6%88%91%E5%88%9A%E5%88%9A%E5%8F%96%E6%B6%88%E4%BA%86%E5%AF%B9%20HSE%20%E5%8A%9F%E8%83%BD%E6%A0%87%E5%BF%97%E7%9A%84%E6%A3%80%E6%9F%A5%E3%80%82%E8%BF%99%E6%98%AF%E6%88%91%E5%81%9A%E7%9A%84%E5%94%AF%E4%B8%80%E6%94%B9%E5%8F%98%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20HSE_SRV_ID_ERASE_FW%20%E6%9C%8D%E5%8A%A1%E6%88%90%E5%8A%9F%E6%93%A6%E9%99%A4%E5%9B%BA%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%BF%98%E6%98%AF%E4%B8%8D%E6%98%8E%E7%99%BD%E4%B8%BA%E4%BB%80%E4%B9%88%E5%9C%A8%E4%BD%A0%E9%82%A3%E8%BE%B9%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E4%BD%A0%E8%BF%98%E6%9C%89%E6%9B%B4%E5%A4%9A%E7%9A%84%E6%9D%BF%E5%90%97%EF%BC%9F%E5%AE%83%E4%BB%AC%E9%83%BD%E8%A1%A8%E7%8E%B0%E5%87%BA%E5%90%8C%E6%A0%B7%E7%9A%84%E8%A1%8C%E4%B8%BA%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%3C%2FP%3E%3CP%3E%20%20%20%E6%9C%89%E4%BB%80%E4%B9%88%E6%96%B0%E8%BF%9B%E5%B1%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1814467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1814467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E5%9C%A8%E5%8A%9F%E8%83%BD%E6%A0%87%E5%BF%97%E4%B8%8A%E8%AE%BE%E7%BD%AE%E6%9D%A1%E4%BB%B6%E7%9A%84%E5%9B%BA%E4%BB%B6%EF%BC%8C%E4%BD%86%20hse%20gpr%20resgiter%20%E8%BF%98%E6%98%AF%E6%B2%A1%E6%9C%89%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264721iA4F29D438A1284BD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_0-1708676777819.png%22%20alt%3D%22vikmonti7804_0-1708676777819.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1814437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1814437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%BF%99%E8%BE%B9%E6%9C%89%E4%B8%AA%E5%B0%8F%E9%97%AE%E9%A2%98%E2%80%94%E2%80%94%E6%88%91%E5%8F%91%E7%8E%B0%E6%88%91%E7%9A%84%E4%B8%A4%E4%B8%AA%E6%9D%BF%E4%B8%8A%E9%83%BD%E5%B7%B2%E7%BB%8F%E5%AE%89%E8%A3%85%E4%BA%86%202.6.0%20%E5%9B%BA%E4%BB%B6%EF%BC%8C%E8%80%8C%E4%B8%94%E6%97%A0%E6%B3%95%E5%88%A0%E9%99%A4%EF%BC%88%E8%BF%99%E4%B8%AA%E5%8A%9F%E8%83%BD%E6%98%AF%E5%9C%A8%202.40.0%20%E7%89%88%E6%9C%AC%E4%B8%AD%E6%B7%BB%E5%8A%A0%E7%9A%84%EF%BC%89%E3%80%82%E6%88%91%E5%B0%86%E5%9C%A8%E6%98%9F%E6%9C%9F%E4%B8%80%E8%8E%B7%E5%BE%97%E5%85%A8%E6%96%B0%E7%9A%84%E6%9D%BF%EF%BC%8C%E6%88%91%E4%BC%9A%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%BF%98%E6%98%AF%E6%A3%80%E6%9F%A5%E4%BA%86%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%8F%91%E7%8E%B0%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E5%8F%AA%E6%98%AF%E4%B8%8D%E4%BC%9A%E5%9C%A8%E6%AF%8F%E6%AC%A1%20RESET%20%E5%90%8E%E6%97%A0%E6%9D%A1%E4%BB%B6%E5%9C%B0%E5%AF%B9%20HSE%20%E5%8A%9F%E8%83%BD%E6%A0%87%E5%BF%97%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BC%9A%E5%9C%A8%E5%91%A8%E4%B8%80%E5%91%8A%E8%AF%89%E4%BD%A0%E4%BB%AC%E6%88%91%E7%9A%84%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1813764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1813764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E8%B0%83%E8%AF%95%E5%B9%B6%E6%A3%80%E6%9F%A5%E4%B8%BA%E4%BB%80%E4%B9%88%20hse%20gpr%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%BD%8D%E6%B2%A1%E6%9C%89%E8%A2%AB%E8%AE%BE%E7%BD%AE%EF%BC%8C%E8%80%8C%E4%B8%94%20sbaf%20%E6%B2%A1%E6%9C%89%E5%AE%8C%E6%88%90%E5%AE%89%E8%A3%85%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1813763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1813763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E6%9F%A5%E6%89%BE%E8%AF%A5%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1813755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1813755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224860%22%20target%3D%22_blank%22%3E%40vikmonti7804%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E8%AF%A5%E9%A1%B9%E7%9B%AE%EF%BC%9F%E6%88%91%E4%BC%9A%E5%9C%A8%E6%88%91%E8%BF%99%E8%BE%B9%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1813711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1813711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%E9%9A%8F%E9%99%84%E7%9A%84%E5%9B%BE%E7%89%87%EF%BC%8CAB_Swap%20%E7%9A%84%E6%A0%87%E5%A4%B4%E4%B9%9F%E5%9C%A8%E5%86%85%E5%AD%98%E4%B8%AD%E6%89%80%E4%BB%A5%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E5%9B%BA%E4%BB%B6%E5%B7%B2%E5%9C%A8%E5%86%85%E5%AD%98%E4%B8%AD%E9%97%AA%E5%AD%98%EF%BC%8Cutest%20%E5%8C%BA%E5%9F%9F%E7%9A%84%E5%80%BC%E4%B8%BA%20AABBCCDDDDCBBAA%20%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%20utest%20%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8CHSE%20GPR%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%BD%8D%200%20%E6%9C%AA%E8%AE%BE%E7%BD%AE%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%EF%BC%9F%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%20RESET%20%E5%90%8E%20SBAF%20%E6%B2%A1%E6%9C%89%E5%B0%86%20hse%20%E5%9B%BA%E4%BB%B6%E5%AE%89%E8%A3%85%E5%9C%A8%E5%AE%89%E5%85%A8%E5%86%85%E5%AD%98%E5%8C%BA%E5%9F%9F%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E7%B4%A7%E6%80%A5%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264536i89A663620CCD852C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_0-1708596640252.png%22%20alt%3D%22vikmonti7804_0-1708596640252.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1812942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1812942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AA%E6%98%AF%E5%9C%A8%E9%81%B5%E5%BE%AA%20s32k344%20%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E4%B8%BA%20s32k312%20%E5%88%9B%E5%BB%BA%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%B9%B6%E4%BB%8E%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E4%B8%AD%E5%AF%BC%E5%85%A5%E4%BA%86%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%8C%E6%88%91%E5%9C%A8%E5%86%85%E5%AD%98%E7%AA%97%E5%8F%A3%E7%9A%84%200x1b000000%20%E4%BD%8D%E7%BD%AE%E7%9C%8B%E5%88%B0%200xaabbccdd%EF%BC%8C%E9%97%AE%E9%A2%98%E5%8F%AF%E8%83%BD%E5%87%BA%E5%9C%A8%E5%93%AA%E9%87%8C%E3%80%82%E4%B8%80%E5%88%87%E9%83%BD%E4%B8%8E%20s32k344%20%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E7%9B%B8%E5%90%8C%EF%BC%8C%E5%8F%AA%E6%98%AF%E6%88%91%E6%9B%B4%E6%94%B9%E4%BA%86%E9%93%BE%E6%8E%A5%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%E5%86%85%E5%AD%98%E4%BD%8D%E7%BD%AE%E3%80%82%E8%AF%B7%E6%82%A8%E6%8F%90%E4%BE%9B%E7%B4%A7%E6%80%A5%E5%B8%AE%E5%8A%A9%EF%BC%8C%E6%88%96%E8%80%85%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E5%B0%8F%E5%9E%8B%E7%94%B5%E8%AF%9D%E8%BF%9B%E8%A1%8C%E5%9C%A8%E7%BA%BF%E8%B0%83%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E5%92%8C%E7%A8%8B%E5%BA%8F%E7%9A%84%E7%89%87%E6%AE%B5%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264315iE0EDA2AD10EFECE3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_0-1708531086237.png%22%20alt%3D%22vikmonti7804_0-1708531086237.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264316iFEF84EEEF1A434E6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_1-1708531115954.png%22%20alt%3D%22vikmonti7804_1-1708531115954.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264317iF134C0887931C929%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_2-1708531147534.png%22%20alt%3D%22vikmonti7804_2-1708531147534.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1812914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1812914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E5%A4%96%E8%AE%BE%E7%BB%93%E6%9E%84%E4%B8%AD%E6%B2%A1%E6%9C%89%E5%AE%9A%E4%B9%89%20HSE%20GPR%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%9C%89%E5%BF%85%E8%A6%81%E7%9B%B4%E6%8E%A5%E6%A3%80%E6%9F%A5%E5%86%85%E5%AD%98%E3%80%82%E5%A6%82%E6%9E%9C%E5%9C%A8%200x4039C028%20%E5%A4%84%E7%9C%8B%E5%88%B0%200xC1010000%EF%BC%8C%E5%88%99%E6%98%BE%E7%84%B6%E6%B2%A1%E6%9C%89%E5%AE%89%E8%A3%85%20HSE%20FW%E3%80%82%3C%2FP%3E%0A%3CP%3E0x1B000000%20%E7%9A%84%20HSE%20%E5%8A%9F%E8%83%BD%E9%97%AA%E5%AD%98%E6%98%AF%E5%90%A6%E5%B7%B2%E7%BC%96%E7%A8%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%BF%98%E6%9C%89%E4%B8%80%E4%BB%B6%E4%BA%8B--%E6%88%91%E8%AE%B0%E5%BE%97%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%22without%20IVT%22%20%E6%96%B9%E6%B3%95%E5%AE%89%E8%A3%85%E5%9B%BA%E4%BB%B6%EF%BC%8C%E9%97%AA%E5%AD%98%E4%B8%AD%E4%B8%8D%E5%8F%AF%E8%83%BD%E6%9C%89%E6%9C%89%E6%95%88%E7%9A%84%20IVT%E3%80%82%E5%90%A6%E5%88%99%EF%BC%8C%E5%AE%83%E5%B0%B1%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E5%A6%82%E6%9E%9C%E7%B2%89%E8%89%B2%2Fbin%20%E6%96%87%E4%BB%B6%E4%B8%8E%E6%9F%90%E4%BA%9B%E9%A1%B9%E7%9B%AE%E4%B8%80%E8%B5%B7%E5%8A%A0%E8%BD%BD%EF%BC%8C%E5%88%99%E6%9C%89%E5%BF%85%E8%A6%81%E5%88%A0%E9%99%A4%20IVT%E3%80%82%E6%88%96%22%EF%BC%8C%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20IVT%22%20%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1812756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1812756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%20%E3%80%81%20%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%20S32DS%20%E7%9A%84%E4%BB%BB%E4%BD%95%E5%A4%96%E8%AE%BE%E7%AA%97%E5%8F%A3%E4%B8%AD%E7%9C%8B%E5%88%B0%E8%BF%99%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%3CSPAN%3E0x4039C028%20%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%E7%9C%8B%E5%88%B0%200xC1010000%20%E7%9A%84%E5%80%BC%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1812517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1812517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%20%20%20%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E4%B8%BA%20s32k312%20%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BD%86%E5%9C%A8%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E4%B8%8B%E8%BF%90%E8%A1%8C%E6%97%B6%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E5%AE%83%E7%9B%B4%E6%8E%A5%E8%B7%B3%E8%BD%AC%E5%88%B0%E9%BB%98%E8%AE%A4%E6%89%8B%E6%9F%84%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E8%BF%9B%E5%85%A5%E4%B8%BB%E7%95%8C%E9%9D%A2%EF%BC%8C%E8%AF%B7%E4%BD%A0%E4%BB%AC%E5%B8%AE%E5%8A%A9%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9C%8B%E5%88%B0%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%B7%B2%E6%94%BE%E5%85%A5%E9%97%AA%E5%AD%98%E4%B8%AD%EF%BC%8C%E4%BD%86%E6%98%AF%20utest%20%E7%94%B1%E4%BA%8E%E6%B2%A1%E6%9C%89%E8%BF%9B%E5%85%A5%E4%B8%BB%E7%95%8C%E9%9D%A2%E8%80%8C%E6%9C%AA%E5%90%AF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%B8%AE%E6%88%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1812005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1812005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%9F%A5%20HSE%20GPR%20%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8%200x4039C028%20%E4%B8%AD%E7%9A%84%E7%AC%AC%200%20%E4%BD%8D%E3%80%82%E5%A6%82%E6%9E%9C%E4%B8%BA%20%221%22%EF%BC%8C%E5%88%99%E8%A1%A8%E7%A4%BA%22HSE%20FW%20%E5%AD%98%E5%9C%A8%EF%BC%8CSBAF%20%E5%BC%95%E5%AF%BC%E7%9A%84%20HSE%20%E5%9B%BA%E4%BB%B6%22%20%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%9C%A8%20HSE_B%20%E5%9B%BA%E4%BB%B6%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E7%89%88%E6%9C%AC%202.2%20%E4%B8%AD%E6%89%BE%E5%88%B0%E8%BF%99%E4%B8%AA%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1811847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1811847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%20%20%E5%A6%82%E6%9E%9C%E6%88%91%E8%83%BD%E5%A4%9F%E6%88%90%E5%8A%9F%E5%AE%89%E8%A3%85%20HSE%20%E5%9B%BA%E4%BB%B6%EF%BC%8C%E5%A6%82%E4%BD%95%E9%AA%8C%E8%AF%81%E8%AF%A5%E5%9B%BA%E4%BB%B6%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E5%AE%89%E8%A3%85%E5%9C%A8%E5%AE%89%E5%85%A8%E5%AD%98%E5%82%A8%E5%99%A8%E4%B8%AD%E6%88%96%E6%88%90%E5%8A%9F%E5%AE%89%E8%A3%85%E5%9C%A8%E5%AD%98%E5%82%A8%E5%99%A8%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E6%A3%80%E6%9F%A5%E5%86%85%E5%AD%98%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1809755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1809755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9B%BA%E4%BB%B6%E4%BB%A5%E5%8A%A0%E5%AF%86%E5%BD%A2%E5%BC%8F%E4%BD%9C%E4%B8%BA%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E6%8F%90%E4%BE%9B%E3%80%82%E6%98%AF%E7%9A%84%EF%BC%8CHSE%20FW%20%E4%BB%A3%E7%A0%81%E5%8C%85%E4%BB%85%E5%8C%85%E5%90%AB%E4%BA%8C%E8%BF%9B%E5%88%B6%EF%BC%88%E7%B2%89%E8%89%B2%EF%BC%89%E6%96%87%E4%BB%B6%E5%92%8C%E7%9B%B8%E5%BA%94%E7%9A%84%20API%20%E6%A0%87%E5%A4%B4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8A%B3%E7%89%B9%E5%B7%B4%E8%B5%AB%E7%94%A8%E6%88%B7%E8%BF%98%E5%8F%AF%E4%BD%BF%E7%94%A8%20HSE%20DEMOAPP%20%E5%AE%89%E8%A3%85%E5%9B%BA%E4%BB%B6%E5%B9%B6%E6%A3%80%E6%9F%A5%20HSE%20%E5%8A%9F%E8%83%BD%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F263436i6D824F1E7A23ED65%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1708065109693.png%22%20alt%3D%22lukaszadrapa_0-1708065109693.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%BD%86%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E8%AF%A5%E6%BC%94%E7%A4%BA%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%E5%8A%B3%E7%89%B9%E5%B7%B4%E8%B5%AB%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%E5%AE%83%E4%B8%8D%E8%83%BD%E4%B8%8E%20Pemicro%20%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A3%E5%A6%82%E6%82%A8%E5%9C%A8%E4%B8%8A%E8%BF%B0%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%E6%88%96%20HSE%20FW%20RM%20%E4%B8%AD%E7%9C%8B%E5%88%B0%E7%9A%84%E9%82%A3%E6%A0%B7%EF%BC%8C%E5%9B%BA%E4%BB%B6%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%AE%89%E8%A3%85%E6%88%96%E4%B8%8D%E4%BD%BF%E7%94%A8%20IVT%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%AE%89%E8%A3%85%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%B2%A1%E6%9C%89IVT%E7%9A%84%E5%AE%89%E8%A3%85%E6%AF%94%E8%BE%83%E5%AE%B9%E6%98%93%EF%BC%8C%E4%BD%86%E6%98%AF%E4%BD%A0%E9%9C%80%E8%A6%81%E4%B8%80%E4%B8%AA%E8%83%BD%E5%A4%9F%E5%B0%86%E5%8E%9F%E5%A7%8B%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%8A%A0%E8%BD%BD%E5%88%B0%E9%97%AA%E5%AD%98%E7%9A%84%E5%B7%A5%E5%85%B7%EF%BC%8C%E8%80%8CPemicro%E8%B0%83%E8%AF%95%E5%99%A8%E5%88%99%E4%B8%8D%E6%98%AF%E8%BF%99%E6%A0%B7%E3%80%82%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%22%E4%B8%8E%20IVT%22%20%E6%96%B9%E6%B3%95%E6%9B%B4%E4%B8%BA%E6%96%B9%E4%BE%BF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E4%B8%BA%E6%AF%8F%E4%B8%AA%E8%A1%8D%E7%94%9F%E7%A8%8B%E5%BA%8F%E6%8F%90%E4%BE%9B%20S32K344_HSE_FW_INSTALL%E3%80%82%E8%BF%99%E5%8F%AA%E6%98%AF%E4%B8%80%E4%B8%AA%E7%A4%BA%E4%BE%8B%EF%BC%8C%E7%94%A8%E6%88%B7%E5%8F%AF%E8%87%AA%E8%A1%8C%E5%88%9B%E5%BB%BA%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%88%E6%AF%8F%E4%B8%AA%E5%AE%A2%E6%88%B7%E7%9A%84%E8%A6%81%E6%B1%82%E5%92%8C%E7%94%9F%E4%BA%A7%E5%B7%A5%E5%85%B7%2F%E8%83%BD%E5%8A%9B%E5%90%84%E4%B8%8D%E7%9B%B8%E5%90%8C%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%80%8E%E4%B9%88%E5%8A%9E%EF%BC%9A%3CBR%20%2F%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%20S32%20Design%20Studio%20%E4%B8%AD%E7%9B%B4%E6%8E%A5%E4%B8%BA%20S32K312%20%E5%88%9B%E5%BB%BA%E6%96%B0%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%A1%B9%E7%9B%AE%E3%80%82%E7%84%B6%E5%90%8E%E5%A4%8D%E5%88%B6%20S32K344_HSE_FW_INSTALL%20%E4%B8%AD%E7%9A%84%E6%BA%90%E6%96%87%E4%BB%B6%EF%BC%8C%E6%9B%B4%E6%96%B0%20boot_header.c%20%E4%B8%AD%E7%9A%84%20HseFwHeader_StartAddress%E3%80%82%E7%84%B6%E5%90%8E%E4%BF%AE%E6%94%B9%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%20-%20%E4%BD%BF%E7%94%A8%20S32K344_HSE_FW_INSTALL%20%E4%B8%AD%E7%9A%84%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E4%BD%9C%E4%B8%BA%E6%A8%A1%E6%9D%BF%E3%80%82%E5%A6%82%E6%9E%9C%E6%8C%89%E7%85%A7%E6%88%91%E4%B9%8B%E5%89%8D%E7%9A%84%E5%BB%BA%E8%AE%AE%E9%98%85%E8%AF%BB%20readme.md%20%E6%96%87%E4%BB%B6%EF%BC%8C%E5%85%B6%E4%B8%AD%E4%B8%80%E5%AE%9A%E6%9C%89%E6%8C%87%E5%90%91%20bin%2Fpink%20%E6%96%87%E4%BB%B6%E7%9A%84%E9%93%BE%E6%8E%A5%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%AE%83%E5%B7%B2%E9%93%BE%E6%8E%A5%E5%88%B0%E9%A1%B9%E7%9B%AE%E4%B8%AD%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%9C%A8%E5%9C%B0%E5%9D%80%200x1B000000%20%E5%A4%84%E8%BE%93%E5%85%A5%E4%B8%8E%200xFFFFFFFFFFFFFFFF%20%E4%B8%8D%E5%90%8C%E7%9A%84%E4%BB%BB%E4%BD%95%E5%80%BC%EF%BC%8C%E4%BB%A3%E7%A0%81%E6%89%8D%E8%83%BD%E5%90%AF%E7%94%A8%20HSE%20%E5%8A%9F%E8%83%BD%E6%A0%87%E5%BF%97%E3%80%82%E7%84%B6%E5%90%8E%E6%BB%A1%E8%B6%B3%E6%89%80%E6%9C%89%E5%AE%89%E8%A3%85%E6%9D%A1%E4%BB%B6%E2%80%94%E2%80%94HSE%E5%8A%9F%E8%83%BD%E6%A0%87%E5%BF%97%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8CIVT%E6%8C%87%E5%90%91%E9%97%AA%E5%AD%98%E4%B8%AD%E7%9A%84%E6%9C%89%E6%95%88%E7%B2%89%E8%89%B2%E5%9B%BE%E5%83%8F%EF%BC%8C%E5%9B%A0%E6%AD%A4SBAF%E5%B0%86%E5%9C%A8%E4%B8%8B%E6%AC%A1RESET%E5%90%8E%E5%AE%89%E8%A3%85%E5%9B%BA%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1809037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1809037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3Es32k312%20%E7%9A%84%E5%9B%BA%E4%BB%B6%E5%8F%AA%E6%98%AF%E6%8E%A5%E5%8F%A3%E5%92%8C%E4%B8%BB%E6%9C%BA%E4%B9%8B%E7%B1%BB%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%8C%E5%AE%83%E4%B8%8D%E6%98%AF%E5%AE%8C%E6%95%B4%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%83%8F%20s32k344%20hse%20%E6%BC%94%E7%A4%BA%E7%A4%BA%E4%BE%8B%E4%B8%80%E6%A0%B7%E5%B0%86%20HSE%20%E5%9B%BA%E4%BB%B6%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E9%97%AA%E5%AD%98%E5%88%B0%E6%8E%A7%E5%88%B6%E5%99%A8%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%B0%86%20HSE%20%E5%9B%BA%E4%BB%B6%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E9%97%AA%E5%AD%98%E5%88%B0%20cntroller%20%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8F%AA%E6%8F%90%E4%BE%9B%E4%BA%86%20.bin%20%E6%96%87%E4%BB%B6%E3%80%82%E6%96%87%E4%BB%B6%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E5%86%85%E7%BD%AE%E8%B0%83%E8%AF%95%E5%99%A8%E7%9A%84%20PE%20%E5%BE%AE%E5%9E%8B%E5%92%8C%E8%AF%84%E4%BC%B0%E6%9D%BF%E4%BD%86%E6%97%A0%E6%B3%95%E5%81%9A%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E5%AE%83%E5%8F%AA%E8%83%BD%E6%94%AF%E6%8C%81%20.elf%20%E5%92%8C%20.hex%E9%94%89%E5%88%80%E8%AF%B7%E5%B8%AE%E6%88%91%E5%B0%86%20.bin%20%E9%97%AA%E5%AD%98%E5%88%B0%E6%8E%A7%E5%88%B6%E5%99%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1809034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1809034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3ES32K312%20%E7%9A%84%20HSE%20%E5%9B%BA%E4%BB%B6%E4%BB%A3%E7%A0%81%E5%8C%85%E4%BB%85%E5%8C%85%E5%90%AB%20bin%20%E6%96%87%E4%BB%B6%E4%BB%A5%E5%8F%8A%E4%B8%80%E4%BA%9B%E7%94%A8%E4%BA%8E%E5%88%9B%E5%BB%BA%E9%A1%B9%E7%9B%AE%E7%9A%84%E6%8E%A5%E5%8F%A3%E5%92%8C%E4%B8%BB%E6%9C%BA%E6%96%87%E4%BB%B6%E3%80%82%E5%AE%83%E4%B8%8D%E5%83%8F%20s32k344%20%E7%9A%84%20HSE%20%E6%BC%94%E7%A4%BA%E7%A4%BA%E4%BE%8B%E9%82%A3%E6%A0%B7%E6%98%AF%E4%B8%80%E4%B8%AA%E5%AE%8C%E6%95%B4%E7%9A%84%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E9%9D%A2%E4%B8%B4%E7%9D%80%E4%BD%BF%E7%94%A8%E8%AF%84%E4%BC%B0%E6%9D%BF%E8%B0%83%E8%AF%95%E5%99%A8%E5%92%8C%20PE%20%E5%BE%AE%E5%9E%8B%E8%B0%83%E8%AF%95%E5%99%A8%E5%88%B7%E6%96%B0%20HSE%20%E5%9B%BA%E4%BB%B6%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%BB%85%E6%94%AF%E6%8C%81%20.elf%20%E5%92%8C%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%E8%AF%B7%E5%B8%AE%E6%88%91%E5%B0%86%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%88%B7%E6%96%B0%E5%88%B0%E8%AF%84%E4%BC%B0%E6%9D%BF%E4%B8%8A%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1808928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1808928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224860%22%20target%3D%22_blank%22%3E%40vikmonti7804%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EHSE%20%E5%9B%BA%E4%BB%B6%E5%8F%AF%E4%BB%A5%E5%9C%A8%20S32K3%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DSW32K3-STDSW-D%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20%E6%A0%87%E5%87%86%E8%BD%AF%E4%BB%B6%E5%8C%85%E4%B8%AD%E6%89%BE%E5%88%B0%EF%BC%9Ahttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DSW32K3-STDSW-D%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%89%93%E5%BC%80%22Automotive%20SW%20-%20S32K3%20-%20HSE%20Firmware%22%20%EF%BC%8C%E6%82%A8%E5%B0%86%E7%9C%8B%E5%88%B0%E6%89%80%E6%9C%89%E5%8F%AF%E7%94%A8%E7%89%88%E6%9C%AC%EF%BC%8C%E5%8C%85%E6%8B%AC%20S32K312%20%E7%9A%84%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A4%BA%E4%BE%8B%20S32K344_HSE_FW_INSTALL%20%E6%98%BE%E7%A4%BA%E4%BA%86%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85%E5%9B%BA%E4%BB%B6%E7%9A%84%E9%80%89%E9%A1%B9%E3%80%82%E6%88%91%E5%BB%BA%E8%AE%AE%E9%98%85%E8%AF%BB%E8%AF%B4%E6%98%8E%EF%BC%9A%3CBR%20%2F%3Ec%3A%5CNXP%5CS32K3_HSE_DemoExamples_1_0_0%5CS32K3_HSE_DemoExamples%5CDevice_Configuration%5CS32K344_HSE_FW_INSTALL%5CReadme.md%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E8%BF%98%E6%8F%90%E4%BE%9B%E4%BA%86%20AN744810%20%E5%8F%B7%E6%96%87%E4%BB%B6%20%22HSE%20FW%20install%20for%20S32K3xx%22%EF%BC%8C%E5%85%B6%E4%B8%AD%E4%BB%8B%E7%BB%8D%E4%BA%86%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85%E5%9B%BA%E4%BB%B6%E3%80%82%E5%8F%AF%E5%9C%A8%E5%AE%89%E5%85%A8%E6%96%87%E4%BB%B6%E9%83%A8%E5%88%86%E7%9A%84%E6%96%87%E6%A1%A3%E4%B8%AD%E6%89%BE%E5%88%B0%EF%BC%9A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Fs32-automotive-platform%2Fs32k-auto-general-purpose-mcus%2Fs32k3-microcontrollers-for-automotive-general-purpose%3AS32K3%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Fs32-automotive-platform%2Fs32k-auto-general-purpose-mcus%2Fs32k3-microcontrollers-for-automotive-general-purpose%3AS32K3%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224860%22%20target%3D%22_blank%22%3E%23hello%40vikmonti7804%3C%2FA%3E%E4%BD%A0%E5%BE%97%E5%88%B0%E4%B8%8A%E8%BF%B0%E9%97%AE%E9%A2%98%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E4%BA%86%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sanjana_k_0-1764857943379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764857943379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764857943379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764857943379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764857943379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368644i592958693E4B6065%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sanjana_k_0-1764857943379.png%22%20alt%3D%22Sanjana_k_0-1764857943379.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E8%AF%B7%E5%B8%AE%E5%B8%AE%E6%88%91%E4%BB%AC%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E5%81%9A%E4%BA%86%E5%BE%88%E5%A4%9A%E5%8A%AA%E5%8A%9B%EF%BC%8C%E4%BD%86%E8%BF%98%E6%98%AF%E4%B8%8D%E7%9F%A5%E9%81%93%E8%AF%A5%E6%80%8E%E4%B9%88%E5%8A%9E%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%EF%BC%8C%E6%88%91%E4%BB%AC%E7%9A%84%E5%9B%BA%E4%BB%B6%E4%BB%A3%E7%A0%81%E6%9C%AC%E8%BA%AB%E5%8D%A1%E4%BD%8F%E4%BA%86%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E8%BF%99%E6%A0%B7%EF%BC%8C%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E3%80%82%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sanjana_k_0-1764856626000.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764856626000.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764856626000.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764856626000.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368640iC3DE810D0B7AFC41%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sanjana_k_0-1764856626000.png%22%20alt%3D%22Sanjana_k_0-1764856626000.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%9B%BA%E4%BB%B6%E5%8D%87%E7%BA%A7%E5%B9%B6%E9%80%9A%E8%BF%87%E4%BA%86%E9%AA%8C%E8%AF%81%EF%BC%8C%E4%BD%86%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E6%88%91%E7%9A%84%E5%9B%BA%E4%BB%B6%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E3%80%82%20%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%23Hello%40lukaszadrapa%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%EF%BC%8C%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E6%88%91%E4%BB%AC%E7%9A%84%20HSE%20%E5%9B%BA%E4%BB%B6%E5%B7%B2%E6%88%90%E5%8A%9F%E9%97%AA%E5%AD%98%EF%BC%8C%E4%BD%86%E9%97%AA%E5%AD%98%E5%90%8E%E5%9B%BA%E4%BB%B6%3CSTRONG%3E%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%3C%2FSTRONG%3E%E3%80%82%3CBR%20%2F%3E%E7%B3%BB%E7%BB%9F%E6%AF%8F%E6%AC%A1%E9%83%BD%E4%BC%9A%E5%8D%A1%E5%9C%A8%E5%90%8C%E4%B8%80%E4%B8%AA%E7%82%B9%E4%B8%8A%EF%BC%8C%E6%97%A0%E6%B3%95%E7%BB%A7%E7%BB%AD%E6%89%A7%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sanjana_k_1-1764857212653.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_1-1764857212653.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_1-1764857212653.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368643iAB002B507DAF0A5F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sanjana_k_1-1764857212653.png%22%20alt%3D%22Sanjana_k_1-1764857212653.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E5%87%A0%E4%B8%AA%E7%96%91%E9%97%AE%EF%BC%9A%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E5%9C%A8%E9%97%AA%E5%AD%98%E5%9B%BA%E4%BB%B6%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E8%BF%90%E8%A1%8C%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%A6%82%E5%AF%86%E9%92%A5%E7%9B%AE%E5%BD%95%E7%A4%BA%E4%BE%8B%E6%88%96%E4%BB%BB%E4%BD%95%E5%85%88%E5%86%B3%E9%85%8D%E7%BD%AE%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%97%A9%E4%BA%9B%E6%97%B6%E5%80%99%EF%BC%8C%E6%88%91%E4%BB%AC%E5%88%B7%E6%96%B0%E4%BA%86%3CSTRONG%3E2.1%20%E7%89%88%20HSE%20%E5%9B%BA%E4%BB%B6%3C%2FSTRONG%3E%EF%BC%8C%E4%BD%86%E7%8E%B0%E5%9C%A8%E6%88%91%E4%BB%AC%E5%B0%86%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%94%B9%E4%B8%BA%3CSTRONG%3E2.55%20%E7%89%88%3C%2FSTRONG%3E%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%E5%8F%98%E5%8C%96%E4%BC%9A%E5%AF%BC%E8%87%B4%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E6%88%91%E4%BB%AC%E8%AF%BB%E5%8F%96%E7%9A%84%20SBUF%20%E7%89%88%E6%9C%AC%E6%98%AF%200x00500000%3C%2FSTRONG%3E%E3%80%82%3CBR%20%2F%3E2.55%20%E7%89%88%E5%9B%BA%E4%BB%B6%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%9C%A8%E6%9B%B4%E6%96%B0%E5%88%B0%E6%96%B0%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%AF%B9%3CSTRONG%3EHSE_FW_INSTALL%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BB%A3%E7%A0%81%3C%2FSTRONG%3E%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%E7%89%B9%E5%AE%9A%E6%9B%B4%E6%94%B9%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%E6%88%91%E4%BB%AC%E5%9C%A8%E6%8F%90%E4%BE%9B%E5%9B%BA%E4%BB%B6%E7%9A%84%E5%90%8C%E6%97%B6%E8%BF%98%E6%8F%90%E4%BE%9B%E4%BA%86%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%EF%BC%8C%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E5%9C%A8%E5%93%AA%E9%87%8C%E4%BD%BF%E7%94%A8%E5%AE%83%E4%BB%AC%EF%BC%9F%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E4%BB%AC%E6%98%AF%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E5%AF%BC%E8%87%B4%E5%9B%BA%E4%BB%B6%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2256206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2256206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%23%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243050%22%20target%3D%22_blank%22%3E%20Hello%40sandor_b%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%94%B6%E5%88%B0%E6%9C%89%E5%85%B3%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E6%9C%80%E6%96%B0%E6%B6%88%E6%81%AF%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98--%E6%88%91%E4%BB%AC%E7%9A%84%E7%A8%8B%E5%BA%8F%E5%8D%A1%E5%9C%A8%E4%BA%86%E8%BF%99%E6%9D%A1%E7%BA%BF%E4%B8%8A%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%89%BE%E5%88%B0%E4%BA%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E8%AF%B7%E4%B8%8E%E6%88%91%E4%BB%AC%E5%88%86%E4%BA%AB%E3%80%82%E5%AE%83%E7%9C%9F%E7%9A%84%E4%BC%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E
