HSE code errors
HSE code errors
1,209件の閲覧回数
vikmonti7804
   I am creating a seperate project for the HSE where i am adding the services, frameworks and interface folder from the example code, i am getting some erroe and i am keep including the respective header files to the source code but the errors are still there and i am not able to remove them. these error seems to be related to some settings. kindly look and help  to remove them.
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_get_capabilities.c:82: undefined reference to `gsrvResponse'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_get_version.c:123: undefined reference to `gHseFwVersion'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `write_attr'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `WriteMu1Config'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `ReadMu1Config'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_advance_LC.c:157: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_advance_LC.c:157: undefined reference to `write_attr'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_boot_auth.c:153: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_boot_auth.c:153: undefined reference to `write_attr'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_auth_mode.c:136: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_auth_mode.c:136: undefined reference to `write_attr'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_key.c:299: undefined reference to `write_attr'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_key.c:299: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/fw_attribute/otp/hse_extend_cust_security_policy.o: in function `ExtendCustomerSecurityPolicyService':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `write_attr'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `GetStartAsUserBit'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `GetEnableAdkmBit'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/fw_update/standard/hse_fw_update.o: in function `firmwareUpdateService':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `fwudpate_only'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `ActivatePassiveBlock'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `gHseFwVersion'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:27: undefined reference to `gProgramAttributes'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:27: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/hse_demo_app_config.o: in function `CopyFlashToSRAMHseHost':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:75: undefined reference to `HSE_HOST_FLASH_SRC_START_ADDR'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:75: undefined reference to `HSE_HOST_FLASH_SRC_END_ADDR'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:75: undefined reference to `HSE_HOST_RAM_DST_START_ADDR'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/hse_demo_app_config.o: in function `attributeProgrammingService':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:172: undefined reference to `gEnableIVTAuthBit'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/hse_host_flash.o: in function `HostFlash_Init':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_host_flash.c:156: undefined reference to `FLASH_DRIVER_FLASH_SRC_START_ADDRESS'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_host_flash.c:156: undefined reference to `FLASH_DRIVER_FLASH_SRC_END_ADDRESS'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_host_flash.c:156: undefined reference to `FLASH_DRIVER_RAM_DST_START_ADDRESS'
make: *** [makefile:55: Hse_Ip_AesEncAsyncIrq_S32K312.elf] Error 1
700件の閲覧回数
Jason88619
I've encountered the same problem as yours. Could you please tell me how you solved it?
%3CLINGO-SUB%20id%3D%22lingo-sub-1784141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHSE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1784141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20HSE%20%E7%94%A8%E3%81%AE%E5%88%A5%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%9D%E3%81%93%E3%81%A7%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E5%90%AB%E3%82%81%E7%B6%9A%E3%81%91%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A0%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E5%89%8A%E9%99%A4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E8%A6%AA%E5%88%87%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E5%89%8A%E9%99%A4%E3%81%AB%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_get_capabilities.c%3A82%3A%20%60gsrvResponse'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_get_version.c%3A123%3A%20%60gHseFwVersion'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_mu_config.c%3A129%3A%20%60gsrvResponse'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_mu_config.c%3A129%3A%20%60write_attr'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_mu_config.c%3A129%3A%20%60WriteMu1Config'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_mu_config.c%3A129%3A%20%60ReadMu1Config'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_advance_LC.c%3A157%3A%20%60gsrvResponse'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_advance_LC.c%3A157%3A%20%60write_attr'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_boot_auth.c%3A153%3A%20%60gsrvResponse'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_boot_auth.c%3A153%3A%20%60write_attr'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_debug_auth_mode.c%3A136%3A%20%60gsrvResponse'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_debug_auth_mode.c%3A136%3A%20%60write_attr'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_debug_key.c%3A299%3A%20%60write_attr'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_debug_key.c%3A299%3A%20%60gsrvResponse'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A.%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_extend_cust_security_policy.o%3A%20%E9%96%A2%E6%95%B0%20%60ExtendCustomerSecurityPolicyService'%20%E5%86%85%3A%3CBR%20%2F%3E%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_extend_cust_security_policy.c%3A148%3A%20%60gsrvResponse'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_extend_cust_security_policy.c%3A148%3A%20%60write_attr'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_extend_cust_security_policy.c%3A148%3A%20%60GetStartAsUserBit'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_extend_cust_security_policy.c%3A148%3A%20%60GetEnableAdkmBit'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A.%2Fservices%2Fsrc%2Ffw_update%2Fstandard%2Fhse_fw_update.o%3A%20%E9%96%A2%E6%95%B0%20%60firmwareUpdateService'%20%E5%86%85%3A%3CBR%20%2F%3E%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_update%2Fstandard%2Fhse_fw_update.c%3A402%3A%20%60gsrvResponse'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_update%2Fstandard%2Fhse_fw_update.c%3A402%3A%20%60fwudpate_only'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_update%2Fstandard%2Fhse_fw_update.c%3A402%3A%20%60ActivatePassiveBlock'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_update%2Fstandard%2Fhse_fw_update.c%3A402%3A%20%60gHseFwVersion'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A27%3A%20%60gProgramAttributes'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A27%3A%20%60gsrvResponse'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A.%2Fservices%2Fsrc%2Fhse_demo_app_config.o%3A%20%E9%96%A2%E6%95%B0%20%60CopyFlashToSRAMHseHost'%20%E5%86%85%3A%3CBR%20%2F%3E%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A75%3A%20%60HSE_HOST_FLASH_SRC_START_ADDR'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A75%3A%20%60HSE_HOST_FLASH_SRC_END_ADDR'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A75%3A%20%60HSE_HOST_RAM_DST_START_ADDR'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A.%2Fservices%2Fsrc%2Fhse_demo_app_config.o%3A%20%E9%96%A2%E6%95%B0%20%60attributeProgrammingService'%20%E5%86%85%3A%3CBR%20%2F%3E%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A172%3A%20%60gEnableIVTAuthBit'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A.%2Fservices%2Fsrc%2Fhse_host_flash.o%3A%20%E9%96%A2%E6%95%B0%20%60HostFlash_Init'%20%E5%86%85%3A%3CBR%20%2F%3E%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_host_flash.c%3A156%3A%20%60FLASH_DRIVER_FLASH_SRC_START_ADDRESS'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_host_flash.c%3A156%3A%20%60FLASH_DRIVER_FLASH_SRC_END_ADDRESS'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_host_flash.c%3A156%3A%20%60FLASH_DRIVER_RAM_DST_START_ADDRESS'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3E%E3%83%A1%E3%82%A4%E3%82%AF%3A%20***%20%5B%E3%83%A1%E3%82%A4%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A55%3A%20Hse_Ip_AesEncAsyncIrq_S32K312.elf%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20code%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E7%A7%81%E3%82%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%A8%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%9F%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
