HSE code errors
HSE code errors
vikmonti7804
   I am creating a seperate project for the HSE where i am adding the services, frameworks and interface folder from the example code, i am getting some erroe and i am keep including the respective header files to the source code but the errors are still there and i am not able to remove them. these error seems to be related to some settings. kindly look and help  to remove them.
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_get_capabilities.c:82: undefined reference to `gsrvResponse'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_get_version.c:123: undefined reference to `gHseFwVersion'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `write_attr'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `WriteMu1Config'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `ReadMu1Config'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_advance_LC.c:157: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_advance_LC.c:157: undefined reference to `write_attr'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_boot_auth.c:153: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_boot_auth.c:153: undefined reference to `write_attr'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_auth_mode.c:136: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_auth_mode.c:136: undefined reference to `write_attr'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_key.c:299: undefined reference to `write_attr'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_key.c:299: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/fw_attribute/otp/hse_extend_cust_security_policy.o: in function `ExtendCustomerSecurityPolicyService':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `write_attr'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `GetStartAsUserBit'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `GetEnableAdkmBit'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/fw_update/standard/hse_fw_update.o: in function `firmwareUpdateService':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `fwudpate_only'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `ActivatePassiveBlock'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `gHseFwVersion'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:27: undefined reference to `gProgramAttributes'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:27: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/hse_demo_app_config.o: in function `CopyFlashToSRAMHseHost':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:75: undefined reference to `HSE_HOST_FLASH_SRC_START_ADDR'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:75: undefined reference to `HSE_HOST_FLASH_SRC_END_ADDR'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:75: undefined reference to `HSE_HOST_RAM_DST_START_ADDR'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/hse_demo_app_config.o: in function `attributeProgrammingService':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:172: undefined reference to `gEnableIVTAuthBit'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/hse_host_flash.o: in function `HostFlash_Init':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_host_flash.c:156: undefined reference to `FLASH_DRIVER_FLASH_SRC_START_ADDRESS'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_host_flash.c:156: undefined reference to `FLASH_DRIVER_FLASH_SRC_END_ADDRESS'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_host_flash.c:156: undefined reference to `FLASH_DRIVER_RAM_DST_START_ADDRESS'
make: *** [makefile:55: Hse_Ip_AesEncAsyncIrq_S32K312.elf] Error 1
Jason88619
I've encountered the same problem as yours. Could you please tell me how you solved it?
%3CLINGO-SUB%20id%3D%22lingo-sub-1784141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHSE%20code%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1784141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3BI%20am%20creating%20a%20seperate%20project%20for%20the%20HSE%20where%20i%20am%20adding%20the%20services%2C%20frameworks%20and%20interface%20folder%20from%20the%20example%20code%2C%20i%20am%20getting%20some%20erroe%20and%20i%20am%20keep%20including%20the%20respective%20header%20files%20to%20the%20source%20code%20but%20the%20errors%20are%20still%20there%20and%20i%20am%20not%20able%20to%20remove%20them.%20these%20error%20seems%20to%20be%20related%20to%20some%20settings.%20kindly%20look%20and%20help%26nbsp%3B%20to%20remove%20them.%3C%2FP%3E%3CP%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_get_capabilities.c%3A82%3A%20undefined%20reference%20to%20%60gsrvResponse'%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_get_version.c%3A123%3A%20undefined%20reference%20to%20%60gHseFwVersion'%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_mu_config.c%3A129%3A%20undefined%20reference%20to%20%60gsrvResponse'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_mu_config.c%3A129%3A%20undefined%20reference%20to%20%60write_attr'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_mu_config.c%3A129%3A%20undefined%20reference%20to%20%60WriteMu1Config'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_mu_config.c%3A129%3A%20undefined%20reference%20to%20%60ReadMu1Config'%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_advance_LC.c%3A157%3A%20undefined%20reference%20to%20%60gsrvResponse'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_advance_LC.c%3A157%3A%20undefined%20reference%20to%20%60write_attr'%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_boot_auth.c%3A153%3A%20undefined%20reference%20to%20%60gsrvResponse'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_boot_auth.c%3A153%3A%20undefined%20reference%20to%20%60write_attr'%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_debug_auth_mode.c%3A136%3A%20undefined%20reference%20to%20%60gsrvResponse'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_debug_auth_mode.c%3A136%3A%20undefined%20reference%20to%20%60write_attr'%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_debug_key.c%3A299%3A%20undefined%20reference%20to%20%60write_attr'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_debug_key.c%3A299%3A%20undefined%20reference%20to%20%60gsrvResponse'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20.%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_extend_cust_security_policy.o%3A%20in%20function%20%60ExtendCustomerSecurityPolicyService'%3A%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_extend_cust_security_policy.c%3A148%3A%20undefined%20reference%20to%20%60gsrvResponse'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_extend_cust_security_policy.c%3A148%3A%20undefined%20reference%20to%20%60write_attr'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_extend_cust_security_policy.c%3A148%3A%20undefined%20reference%20to%20%60GetStartAsUserBit'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_extend_cust_security_policy.c%3A148%3A%20undefined%20reference%20to%20%60GetEnableAdkmBit'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20.%2Fservices%2Fsrc%2Ffw_update%2Fstandard%2Fhse_fw_update.o%3A%20in%20function%20%60firmwareUpdateService'%3A%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_update%2Fstandard%2Fhse_fw_update.c%3A402%3A%20undefined%20reference%20to%20%60gsrvResponse'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_update%2Fstandard%2Fhse_fw_update.c%3A402%3A%20undefined%20reference%20to%20%60fwudpate_only'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_update%2Fstandard%2Fhse_fw_update.c%3A402%3A%20undefined%20reference%20to%20%60ActivatePassiveBlock'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_update%2Fstandard%2Fhse_fw_update.c%3A402%3A%20undefined%20reference%20to%20%60gHseFwVersion'%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A27%3A%20undefined%20reference%20to%20%60gProgramAttributes'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A27%3A%20undefined%20reference%20to%20%60gsrvResponse'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20.%2Fservices%2Fsrc%2Fhse_demo_app_config.o%3A%20in%20function%20%60CopyFlashToSRAMHseHost'%3A%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A75%3A%20undefined%20reference%20to%20%60HSE_HOST_FLASH_SRC_START_ADDR'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A75%3A%20undefined%20reference%20to%20%60HSE_HOST_FLASH_SRC_END_ADDR'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A75%3A%20undefined%20reference%20to%20%60HSE_HOST_RAM_DST_START_ADDR'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20.%2Fservices%2Fsrc%2Fhse_demo_app_config.o%3A%20in%20function%20%60attributeProgrammingService'%3A%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A172%3A%20undefined%20reference%20to%20%60gEnableIVTAuthBit'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20.%2Fservices%2Fsrc%2Fhse_host_flash.o%3A%20in%20function%20%60HostFlash_Init'%3A%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_host_flash.c%3A156%3A%20undefined%20reference%20to%20%60FLASH_DRIVER_FLASH_SRC_START_ADDRESS'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_host_flash.c%3A156%3A%20undefined%20reference%20to%20%60FLASH_DRIVER_FLASH_SRC_END_ADDRESS'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_host_flash.c%3A156%3A%20undefined%20reference%20to%20%60FLASH_DRIVER_RAM_DST_START_ADDRESS'%3CBR%20%2F%3Emake%3A%20***%20%5Bmakefile%3A55%3A%20Hse_Ip_AesEncAsyncIrq_S32K312.elf%5D%20Error%201%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20code%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EI've%20encountered%20the%20same%20problem%20as%20yours.%20Could%20you%20please%20tell%20me%20how%20you%20solved%20it%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
