HSE Response Error
HSE Response Error
3,628件の閲覧回数
Vamsi421
Currently i am working on NXPs32k344 board for Encryption and decryption. For that I am using Cypto_driver and example application (Crypto_Symmetric_S32K344)given in s32 design studio but that example is not working it struck in the while loop that i shared in the document.
2 返答(返信)
3,609件の閲覧回数
VaneB
Hi @Vamsi421
This application requires HSE FW to run, have you already installed the FW? If so, did you select the nxp_s32k344_1x32x980k_hse_enabled algorithm in the Flash Algorithm Selection of the Debug Configurations?
BR, VaneB
3,517件の閲覧回数
Vamsi421
Hi @VaneB ,
I am trying A/b swap ota feature in nxps32k344. In this process i am using hse feature ,i collect the .bin file of the new firmware and placed it in the memory address of 0x005000000h and run the program . After completion of my program run i reset my board but i didn't get any update firmware and i tried to flash another program my board got disconnected and provided the error logs as shared in below attachments.
