S32K142 controller EEPROM Read and Write source code
sureshm
Iam using S32K142 controller. Is there any source code available for EEPROM Read and Write operations.
Thank You,
danielmartynek
The flash_partitioning_s32k142 SDK example shows how to write the EEPROM.
The read/write operation is described in
AN11983 Using the S32K1xx EEPROM Functionality
3.6.1 EEE writes
3.6.2 EEE reads
https://www.nxp.com/docs/en/application-note/AN11983.pdf
