Format SREC
Format SREC
3,459件の閲覧回数
abderrahimjamao
In the bootloader application, why we choose the SREC format to send data.
タグ(2)
2 返答(返信)
3,389件の閲覧回数
dianabatrlova
It is up to you if you use SREC or other file formats. A bin or hex file can also be used.
Diana
3,389件の閲覧回数
dianabatrlova
I would like to add a note.
If you are building your own bootloader you can choose the file which you want.
However, our example such as AN12218 is programmed to process SREC. So, if you want to use another format you should change the code.
Diana
