Flash_Error with Open SDA
810 次查看
Ajay_R1
I am using S32 Design Studio IDE for ARM architecture.
At time of debugging i have get an following error
"PEmicro GDB Launch Failure : Unable to auto-detect debug hardware. Please specify on the command-line. If running from Eclipse, check the launch Debug Configuration settings"
how to resolve this error ?
I have use OpenSDA debugger But in debug configuration for the PEMicro Interface Settings, i am not able to select any device in the "Port" field. its blank for me
In device manager opensda port is also detectable
I have install all required driver but still i am not able to detect what will be the problem.
could u please give me solution to resolve that problem ?
777 次查看
VaneB
Hi @Ajay_R1
Take a look at Issues with NXP S32K148EVB board. Here are some solutions that you could try.
If the information mentioned in the community post is not useful for you, let me know.
B.R
VaneB
