FS32K144HAT0 GPIO STATE
1,080 次查看
ramesh3178
Hi Team, I have a doubt that what is the status of the S32K144 when initially it got power
is it High with 3.3V or grounded
标记 (1)
1,068 次查看
Julián_AragónM
Hi @ramesh3178,
The default out-of-reset PORT_PCR configuration of all the pins is specified in the IO_Signal_Description_Input_Multiplexing.xlsx, IO Signal Table, Column U (Reset).
Almost all the pins are in HI-Z state, and they remain in the state until they are reconfigured by the application.
Julián
