Error occurred while connecting to the interface hardware or target
2,130件の閲覧回数
Anilpatil_SasvaAuto
Hello Team,
I am using S32K144EVB and tried to run a sample application(hello_world_s32k118) with PE micro debugger (built-in OpenSDA) to check if the EVB is fine. Things were not going well and got errors as below.
Please provide the solution ASAP
2,025件の閲覧回数
Anilpatil_SasvaAuto
It is working now, the issue is with the power supply. need to change J107 for USB supply
Thanks for the support.
7 返答(返信)
2,037件の閲覧回数
Anilpatil_SasvaAuto
Hello World code
2,027件の閲覧回数
Robin_Shen
Have you already referred to that link?
Please tell me which step does not meet expectations.
If you don't tell me in detail, I won't be able to help you solve this problem.
2,026件の閲覧回数
Anilpatil_SasvaAuto
2,105件の閲覧回数
Robin_Shen
Since you are using S32K144EVB, why do you want to run a sample application(hello_world_s32k118)? Please run the S32K144 example in the future.
I happened to be discussing a similar issue with another customer, please refer to: S32K144 EVB Red led 계속 on 상태입니다.
Robin
1,810件の閲覧回数
Anilpatil_SasvaAuto
2,097件の閲覧回数
Anilpatil_SasvaAuto
Sorry, it's a copy mistake. I have run the S32K144 example.
2,091件の閲覧回数
Robin_Shen
Which example codes do you loaded into the device? Any for CSEc?
Did you secure the device?(FSEC SEC=secured )
Doesn't P&E Recovery Utility halt MCU? Please tell me what problem occurred during the operation.
