Error in services launch sequence The GDB Server was not able to establish a connection to the targe
1,094 次查看
冯雷
I use S32K118EVB create a example project,had a error
The GDB Server was not able to establish a connection to the target processor. Please check your connections and power. Verify that the launch settings in the Debug Configuration are accurate. To run simultaneous debug sessions, please specify a unique Server Port and GDBMI Port in the Debug Configuration for each project.
1,086 次查看
danielmartynek
Hi @冯雷,
Can you show screenshots of the configuration?
What debugger do you use?
Have you checked the connection and power supply (VDD_MCU)?
BR, Daniel
