Error While using S32K14 AutoSAR OS in TresOS
sandipta_mohan1
I installed tresos Studio 23.0 , Autosar OS(SW32K14-OS401-RTM-1.0.0 b4.0.98)  and Autosar MCAL(SW32K14-MCAL401-RTMC-1.0.4).
But when I try to generate OS configuration file(.c,.h), it gives the following 3 error:
1.The external generator for module Os_TS_T40D2M4I0R98 terminated with exit code 7
Used generator commandline: C:\EB\tresos\plugins\Os_TS_T40D2M4I0R98\ssc\bin\generator\sg.exe
2.Failed to run generator "Os_TS_T40D2M4I0R98GeneratorId" (mode: "verify") for module "Os_TS_T40D2M4I0R98"
3. Error in external generator: C:\EB\tresos\workspace\oooooll\output\generated\epc\project.epc(1816) AUTOSAR/AR-PACKAGES/AR-PACKAGE[SHORT-NAME='Os']/ELEMENTS/ECUC-MODULE-CONFIGURATION-VALUES[SHORT-NAME='Os']/CONTAINERS/ECUC-CONTAINER-VALUE[SHORT-NAME='Task_Environ']/REFERENCE-VALUES/ECUC-REFERENCE-VALUE[DEFINITION-REF='/TS_T40D2M4I0R98/Os/OsTask/OsTaskEventRef']: 3254: Multiplicity check error for 'VALUE-REF'
I want to what's the problem reason? and how to resolve it?
Thanks.
Tags (2)
TianciCao
My AUTOSAR OS is 4.0.98 ,EB is 21.0.0,try above these answers,not to solve it , but I try to uninstall 21.0.0 then install EB 24.0.1 is not show the two errors.
TianciCao
Oh,Sorry,above answer can't to solve this problem .With the help of my master, we have tried multiple times and found that the JRE environment has not been installed
mohamedD
I have the same problem. Can you please help me resolve it?
hungnguyenphi
Hello Sandipta Mohanty ,
It seem that you haven't added the value for the OsTaskEvenRef in the configuration. Could you please try to add it.
Note that user also need to add atleast one element in the OsEvent to make the list show in the OsTaskEvenRef
Hung.
MySterio_1
@sandipta_mohan1  did you solved this problem?
%3CLINGO-SUB%20id%3D%22lingo-sub-1079360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EError%20While%20using%20S32K14%20AutoSAR%20OS%20in%20TresOS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1079360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EI%20installed%26nbsp%3Btresos%20Studio%2023.0%20%2C%20Autosar%20OS(SW32K14-OS401-RTM-1.0.0%20b4.0.98)%26nbsp%3B%20and%26nbsp%3BAutosar%20MCAL(SW32K14-MCAL401-RTMC-1.0.4).%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3EBut%20when%20I%20try%20to%20generate%20OS%20configuration%20file(.c%2C.h)%2C%20it%20gives%20the%20following%203%20error%3A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E1.The%20external%20generator%20for%20module%20Os_TS_T40D2M4I0R98%20terminated%20with%20exit%20code%207%3CBR%20%2F%3EUsed%20generator%20commandline%3A%20C%3A%5CEB%5Ctresos%5Cplugins%5COs_TS_T40D2M4I0R98%5Cssc%5Cbin%5Cgenerator%5Csg.exe%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E2.Failed%20to%20run%20generator%20%22Os_TS_T40D2M4I0R98GeneratorId%22%20(mode%3A%20%22verify%22)%20for%20module%20%22Os_TS_T40D2M4I0R98%22%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E3.%26nbsp%3BError%20in%20external%20generator%3A%20C%3A%5CEB%5Ctresos%5Cworkspace%5Coooooll%5Coutput%5Cgenerated%5Cepc%5Cproject.epc(1816)%20AUTOSAR%2FAR-PACKAGES%2FAR-PACKAGE%5BSHORT-NAME%3D'Os'%5D%2FELEMENTS%2FECUC-MODULE-CONFIGURATION-VALUES%5BSHORT-NAME%3D'Os'%5D%2FCONTAINERS%2FECUC-CONTAINER-VALUE%5BSHORT-NAME%3D'Task_Environ'%5D%2FREFERENCE-VALUES%2FECUC-REFERENCE-VALUE%5BDEFINITION-REF%3D'%2FTS_T40D2M4I0R98%2FOs%2FOsTask%2FOsTaskEventRef'%5D%3A%203254%3A%20Multiplicity%20check%20error%20for%20'VALUE-REF'%3CBR%20%2F%3EUsed%20generator%20commandline%3A%20C%3A%5CEB%5Ctresos%5Cplugins%5COs_TS_T40D2M4I0R98%5Cssc%5Cbin%5Cgenerator%5Csg.exe%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EI%20want%20to%20what's%20the%20problem%20reason%3F%20and%20how%20to%20resolve%20it%3F%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2352324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Error%20While%20using%20S32K14%20AutoSAR%20OS%20in%20TresOS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2352324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F149532%22%20target%3D%22_blank%22%3E%40sandipta_mohan1%3C%2FA%3E%26nbsp%3B%20did%20you%20solved%20this%20problem%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1899386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Error%20While%20using%20S32K14%20AutoSAR%20OS%20in%20TresOS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1899386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOh%EF%BC%8CSorry%EF%BC%8Cabove%20answer%20can't%20to%20solve%20this%20problem%20.With%20the%20help%20of%20my%20master%2C%20we%20have%20tried%20multiple%20times%20and%20found%20that%20the%20JRE%20environment%20has%20not%20been%20installed%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1898287%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Error%20While%20using%20S32K14%20AutoSAR%20OS%20in%20TresOS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1898287%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMy%20AUTOSAR%20OS%20is%204.0.98%20%EF%BC%8CEB%20is%2021.0.0%EF%BC%8Ctry%20above%20these%20answers%2Cnot%20to%20solve%20it%20%2C%20but%20I%20try%20to%20uninstall%2021.0.0%20then%20install%20EB%2024.0.1%20is%20not%20show%20the%20two%20errors.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842439%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Error%20While%20using%20S32K14%20AutoSAR%20OS%20in%20TresOS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842439%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EI%20have%20the%20same%20problem.%20Can%20you%20please%20help%20me%20resolve%20it%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mohamedD_0-1712581145660.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mohamedD_0-1712581145660.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272517i01FD0F980277F6EB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mohamedD_0-1712581145660.png%22%20alt%3D%22mohamedD_0-1712581145660.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1079361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Error%20While%20using%20S32K14%20AutoSAR%20OS%20in%20TresOS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1079361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22361621%22%20data-username%3D%22sandipta.mohanty212%40gmail.com%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fsandipta.mohanty212%40gmail.com%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.9994px%3B%22%20target%3D%22_blank%22%3ESandipta%20Mohanty%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIt%20seem%20that%20you%20haven't%20added%20the%20value%20for%20the%20OsTaskEvenRef%20in%20the%20configuration.%20Could%20you%20please%20try%20to%20add%20it.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F115085i75F2082A1AA5F3FC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ENote%20that%20user%20also%20need%20to%20add%20atleast%20one%20element%20in%20the%20OsEvent%20to%20make%20the%20list%20show%20in%20the%26nbsp%3B%3CSPAN%3EOsTaskEvenRef%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20891px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F115086i9583B39D42CDE24F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3EHung.%3C%2FP%3E%3C%2FLINGO-BODY%3E
