Disable Multi-Bit ECC Error Exception
1,004件の閲覧回数
paul_jack
Hello everyone, when I used UDSboot to test the update program, a Multi-Bit ECC Error occurred, which caused the program to get stuck in the hardware fault handler and could not update the program again through UDSboot. Then I configured PFCR[DMEEE] to 1, which could solve the problem of getting stuck. I wonder if the official advice is to Disable Multi-Bit ECC Error Exception?
タグ(2)
0 返答(返信)
