Device selection not showing up
st_edison_stab
I'm trying to install IAR plug-in in NXP S32 DS. I'm following process from below link.
https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-Install-IAR-Eclipse-plug-in-into...
My target is to run example from IAR for NXP Eval board  S32K148EVB.
Device selection is not showing up in my case. Can you please let me know why this might happen?
Robin_Shen
The basic installation of S32 Design Studio 3.4 does not contain all SW packages. It is necessary to install required packages in the S32DS. Please refer: S32DS Extensions & Updates: Explanation and How To Use
You may need to select latest packages:
S32K1xx development package
S32SDK S32K1XX RTM 4.0.2
Robin
