DS 3.6.0 MU Error
DS 3.6.0 MU Error
darknite2023
Hi.
I am running DS3.6.0 with all RTD 5.0.0 + 5.0.0 P08 SDKs installed and running into an issue when trying to build with support for HSE. I have copied over the necessary HSE files from C:\NXP\HSE_FW_S32K344_0_2_55_0\hse_ab_swap\interface and when I try to build, I get the following error:
I have searched the SDK and it is not clear where to find this file. Any suggestions on how to resolve this would be greatly appreciated. Thanks in advance.
Tags (3)
Robin_Shen
Sorry for the inconvenience we bring you!
The 3 Known Issues for 5.0.0 P08 section of SW32K3_S32M27x_RTD_R21-11_5.0.0_D2410_ReleaseNotes.pdf mentioned:
ARTD-177531 Bug [SECRDR_S32K3][BLN_PB_S32K3XX_R202503] Missing Mu_Ip_Mask.h when using only Hse component S32DS
I noticed that in addition to adding the Hse component to Drivers, the Hse_Ip_AesEncAsyncIrq example also adds the MCAL component Crypto_43_HSE.
I have asked the software team about this issue and will let you know once I get a response.
Robin
darknite2023
Peripheral configuration is as follows:
Tags (3)
darknite2023
Hi.
After some searching, I found the missing file in SEC_CRYPTO/Crypto_43_HSE_TS_T40D34M50I0R0/include directory. So, in addition to copying the HSE FW version dependent include files, do I also need to copy the include files from SEC_CRYPTO/Crypto_43_HSE_TS_T4XXX/include directory into my project for Non AutoSAR versions?
Tags (3)
Robin_Shen
A colleague from the SW team told me: It's a known bug and the workaround will be to add Crypto_43_HSE in your configuration.
Robin_Shen
Robin
darknite2023
Thanks.
%3CLINGO-SUB%20id%3D%22lingo-sub-2082087%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDS%203.6.0%20MU%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2082087%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi.%3C%2FP%3E%3CP%3EI%20am%20running%20DS3.6.0%20with%20all%20RTD%205.0.0%20%2B%205.0.0%20P08%20SDKs%20installed%20and%20running%20into%20an%20issue%20when%20trying%20to%20build%20with%20support%20for%20HSE.%20I%20have%20copied%20over%20the%20necessary%20HSE%20files%20from%20C%3A%5CNXP%5CHSE_FW_S32K344_0_2_55_0%5Chse_ab_swap%5Cinterface%20and%20when%20I%20try%20to%20build%2C%20I%20get%20the%20following%20error%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22darknite2023_0-1744853716892.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22darknite2023_0-1744853716892.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F333545i57FF259C969681A5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22darknite2023_0-1744853716892.png%22%20alt%3D%22darknite2023_0-1744853716892.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EI%20have%20searched%20the%20SDK%20and%20it%20is%20not%20clear%20where%20to%20find%20this%20file.%20Any%20suggestions%20on%20how%20to%20resolve%20this%20would%20be%20greatly%20appreciated.%20Thanks%20in%20advance.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2087519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20DS%203.6.0%20MU%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2087519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThanks.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2085194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20DS%203.6.0%20MU%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2085194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EA%20colleague%20from%20the%20SW%20team%20told%20me%3A%20It's%20a%20known%20bug%20and%20the%20workaround%20will%20be%20to%20add%20%3CSTRONG%3ECrypto_43_HSE%3C%2FSTRONG%3E%20in%20your%20configuration.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2083221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20DS%203.6.0%20MU%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2083221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%0A%3CP%3ESorry%20for%20the%20inconvenience%20we%20bring%20you!%3CBR%20%2F%3EThe%26nbsp%3B3%20Known%20Issues%20for%205.0.0%20P08%26nbsp%3Bsection%20of%26nbsp%3BSW32K3_S32M27x_RTD_R21-11_5.0.0_D2410_ReleaseNotes.pdf%20mentioned%EF%BC%9A%3CBR%20%2F%3EARTD-177531%20Bug%20%5BSECRDR_S32K3%5D%5BBLN_PB_S32K3XX_R202503%5D%20Missing%20Mu_Ip_Mask.h%20when%20using%20only%20Hse%20component%20S32DS%3C%2FP%3E%0A%3CP%3EI%20noticed%20that%20in%20addition%20to%20adding%20the%20%3CSTRONG%3EHse%3C%2FSTRONG%3E%20component%20to%20Drivers%2C%20the%20%3CSTRONG%3EHse_Ip_AesEncAsyncIrq%3C%2FSTRONG%3E%20example%20also%20adds%20the%20MCAL%20component%20%3CSTRONG%3ECrypto_43_HSE%3C%2FSTRONG%3E.%3C%2FP%3E%0A%3CP%3EI%20have%20asked%20the%20software%20team%20about%20this%20issue%20and%20will%20let%20you%20know%20once%20I%20get%20a%20response.%3C%2FP%3E%0A%3CP%3EBest%20Regards%2C%3CBR%20%2F%3ERobin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2082352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20DS%203.6.0%20MU%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2082352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi.%3C%2FP%3E%3CP%3EAfter%20some%20searching%2C%20I%20found%20the%20missing%20file%20in%20SEC_CRYPTO%2FCrypto_43_HSE_TS_T40D34M50I0R0%2Finclude%20directory.%20So%2C%20in%20addition%20to%20copying%20the%20HSE%20FW%20version%20dependent%20include%20files%2C%20do%20I%20also%20need%20to%20copy%20the%20include%20files%20from%20SEC_CRYPTO%2FCrypto_43_HSE_TS_T4XXX%2Finclude%20directory%20into%20my%20project%20for%20Non%20AutoSAR%20versions%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2082106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20DS%203.6.0%20MU%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2082106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPeripheral%20configuration%20is%20as%20follows%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22darknite2023_0-1744855548599.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22darknite2023_0-1744855548599.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F333550i66291BFB2DADAC18%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22darknite2023_0-1744855548599.png%22%20alt%3D%22darknite2023_0-1744855548599.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
