DMA For ADC
3,031件の閲覧回数
Ayaz
I am using DMA to transfer data from FIFO1 and FIFO2 into a buffer. I am utilizing fixed DMA configurations for this data transfer. when completion of the transfer, the following functions will be called:
  • Bctu_Ip_Bctu0Fifo1DmaComplete
  • Bctu_Ip_Bctu0Fifo2DmaComplete
The system functions correctly when I use an interrupt from RTD (IntCtrl_Ip_Init).
However, for my project, I am using a different file to configure the interrupt handler, set priority, and enable the handler.
For DMA0_CH1 &DMA0_CH16,i am using IRQ :
DMATCD1_IRQn / Dma0_Ch1_IRQHandler / Priority
DMATCD16_IRQn / Dma0_Ch16_IRQHandler / Priority
It works for BCTU_IRQn and PIT0_IRQn. It also works with DMA when it is triggered by PIT using the following configurations:
However, it does not show any indication if the transfer has begun or not, and it is not raising an interrupt when the transfer is completed for DMA while reading data from FIFO using the fixed RTD configuration setup for DMA transfer (Bctu_FifoSetupDma).
What additional configurations are needed to get the system working?
タグ(1)
2,928件の閲覧回数
PetrS
I do not expect issue with clock gating. You can check DMA TCD dest address if is has desired value.
1-2) No, it is always enabled
3) if Dcache is enabled and buffer not placed in non cacheable area, then you should use it flush/invalidate cache if needed
4) depend on application, if peripheral is used/accessed must not be clock gated.
BR, Petr
5 返答(返信)
3,010件の閲覧回数
PetrS
not sure of the code you execute, probably just IntCtrl_Ip_InstallHandler and IntCtrl_Ip_EnableIrq. But the same is done in IntCtrl_Ip_Init as well.
Try to check/compare in debugger NVIC content and assigned handler in vector table for both ways.
BR, Petr
3,005件の閲覧回数
Ayaz
Hi@PetrS
I have tested the system and identified Destination Bus Errors on channels 1 and 16.”
Do you have any idea about the cause of this ?
2,987件の閲覧回数
PetrS
error may happen in case destination address points to memory range that is inaccessible - it means either access to reserved memory space or to disabled or un-clocked peripheral or protected by any kind of protection leading in bus error (MPU, XRDC).
BR, Petr
2,977件の閲覧回数
Ayaz
Hi@PetrS
Thanks for the information. Here is the list of clocks enabled in my project:
  • TRGMUX
  • BCTU 0
  • eMIOS 0
  • eMIOS 1
  • eMIOS 2
  • ADC 0
  • ADC 1
  • ADC 2
  • PIT 0
  • PUPD
  • MC_ME_CTL_KEY_KEY(0x5AF0)
  • MC_ME_CTL_KEY_KEY(0xA50F)
  • eDMA - Control & Status
  • eDMA - Transfer Control Descriptor 0 to 31
  • DMA Channel Multiplexer 0
  • DMA Channel Multiplexer 1
  • MSCM
  • STM0
  • SIUL2
  • CMU 0-6
  • PLL
  • FlexCAN 0 to 3
  • LPI2C 0 to 1
  • LPSPI 0 to 3
  • CRC
  • PCUD
1 )Does XRDC need clock enabling? If yes, can you provide the information on how to enable it?
2) Does Crossbar need clock enabling? If yes, can you provide the information on how to enable it?
3)Do i need to Adde Cache_Ip driver into the project ?
4)Are there any other clocks that need to be enabled?
2,929件の閲覧回数
PetrS
BR, Petr
%3CLINGO-SUB%20id%3D%22lingo-sub-2035769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EADC%E3%81%AEDMA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2035769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDMA%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81FIFO1%20%E3%81%A8%20FIFO2%20%E3%81%8B%E3%82%89%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%BC%E3%81%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%BB%A2%E9%80%81%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E3%81%AB%E3%81%AF%E5%9B%BA%E5%AE%9A%20DMA%20%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%BB%A2%E9%80%81%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%8C%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3EBctu_Ip_Bctu0Fifo1DmaComplete%3C%2FLI%3E%3CLI%3EBctu_Ip_Bctu0Fifo2DmaComplete%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171541.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171541.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F321834iFE413577E0099933%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sk%C3%A6rmbillede%202025-01-29%20171541.png%22%20alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171541.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESk%C3%A6rmbillede%202025-01-29%20171541.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171455.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171455.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F321835i83D8C650D14A239E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sk%C3%A6rmbillede%202025-01-29%20171455.png%22%20alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171455.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESk%C3%A6rmbillede%202025-01-29%20171455.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171501.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171501.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F321836iD84BD08DF692F767%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sk%C3%A6rmbillede%202025-01-29%20171501.png%22%20alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171501.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESk%C3%A6rmbillede%202025-01-29%20171501.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E2%80%83%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171150.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171150.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F321837i8D900007918E3333%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sk%C3%A6rmbillede%202025-01-29%20171150.png%22%20alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171150.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESk%C3%A6rmbillede%202025-01-29%20171150.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171416.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171416.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F321838iA5DE27A8979180AF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sk%C3%A6rmbillede%202025-01-29%20171416.png%22%20alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171416.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESk%C3%A6rmbillede%202025-01-29%20171416.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171443.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171443.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F321839iE340C6BA93BD70C9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sk%C3%A6rmbillede%202025-01-29%20171443.png%22%20alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171443.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESk%C3%A6rmbillede%202025-01-29%20171443.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ERTD(IntCtrl_Ip_Init)%E3%81%8B%E3%82%89%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20170758.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20170758.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F321830i1836EC65726909AA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sk%C3%A6rmbillede%202025-01-29%20170758.png%22%20alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20170758.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESk%C3%A6rmbillede%202025-01-29%20170758.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%AE%E6%A7%8B%E6%88%90%E3%80%81%E5%84%AA%E5%85%88%E5%BA%A6%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%AB%E5%88%A5%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CP%3EDMA0_CH1%26amp%3BDMA0_CH16%E3%80%81%E7%A7%81%E3%81%AFIRQ%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CDIV%3E%3CSPAN%3EDMATCD1_IRQn%20%2F%20Dma0_Ch1_IRQHandler%20%2F%26nbsp%3BPriority%3CBR%20%2F%3EDMATCD16_IRQn%20%2F%20Dma0_Ch16_IRQHandler%20%2F%26nbsp%3BPriority%3C%2FSPAN%3E%3C%2FDIV%3E%3CSPAN%3E%3CSPAN%3EBCTU_IRQn%E3%81%A8PIT0_IRQn%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E6%AC%A1%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20PIT%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%82%82%E3%80%81DMA%20%E3%81%A8%E9%80%A3%E6%90%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20172845.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20172845.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F321841iC6785B9BC87DD9A0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sk%C3%A6rmbillede%202025-01-29%20172845.png%22%20alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20172845.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESk%C3%A6rmbillede%202025-01-29%20172845.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CP%3E%E2%80%83%3CBR%20%2F%3E%3CSPAN%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E8%BB%A2%E9%80%81%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81DMA%20%E8%BB%A2%E9%80%81%E3%81%AE%E5%9B%BA%E5%AE%9A%20RTD%20%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%20(Bctu_FifoSetupDma)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20FIFO%20%E3%81%8B%E3%82%89%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%87%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81DMA%20%E3%81%AE%E8%BB%A2%E9%80%81%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171150.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171150.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F321844iC11700C3A54B5D60%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sk%C3%A6rmbillede%202025-01-29%20171150.png%22%20alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171150.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESk%C3%A6rmbillede%202025-01-29%20171150.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171416.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171416.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F321845iE69891410A9EA643%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sk%C3%A6rmbillede%202025-01-29%20171416.png%22%20alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171416.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESk%C3%A6rmbillede%202025-01-29%20171416.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171443.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171443.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F321846i1CA2AAA70E65CAD8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sk%C3%A6rmbillede%202025-01-29%20171443.png%22%20alt%3D%22Sk%C3%A6rmbillede%202025-01-29%20171443.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESk%C3%A6rmbillede%202025-01-29%20171443.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E2%80%83%3CSPAN%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E8%BF%BD%E5%8A%A0%E6%A7%8B%E6%88%90%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2036607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AADC%E3%81%AEDMA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E4%BA%88%E6%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82DMA%20TCD%20%E5%AE%9B%E5%85%88%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E7%9B%AE%E7%9A%84%E3%81%AE%E5%80%A4%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E1-2)%20%E3%81%84%E3%81%84%E3%81%88%E3%80%81%E5%B8%B8%E3%81%AB%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E3)Dcache%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%A7%E3%80%81%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%8C%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%AA%E9%A0%98%E5%9F%9F%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%2F%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E4)%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%82%E3%82%88%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%2F%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B2%E3%83%BC%E3%83%88%E3%81%A7%E3%81%82%E3%81%A3%E3%81%A6%E3%81%AF%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2036190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AADC%E3%81%AEDMA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52961%22%20target%3D%22_self%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%9A%E3%83%88%E3%83%ABS%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3ETRGMUX%E3%81%AE%3C%2FLI%3E%3CLI%3EBCTU%200%3C%2FLI%3E%3CLI%3EeMIOS%200%3C%2FLI%3E%3CLI%3EeMIOS%201%3C%2FLI%3E%3CLI%3EeMIOS%202%3C%2FLI%3E%3CLI%3EADC%200%3C%2FLI%3E%3CLI%3EADC%201%3C%2FLI%3E%3CLI%3EADC%202%3C%2FLI%3E%3CLI%3E%E3%83%94%E3%83%83%E3%83%880%3C%2FLI%3E%3CLI%3E%E3%83%91%E3%83%97%E3%83%89%3C%2FLI%3E%3CLI%3EMC_ME_CTL_KEY_KEY(0x5AF0)%3C%2FLI%3E%3CLI%3EMC_ME_CTL_KEY_KEY(0xA50F)%3C%2FLI%3E%3CLI%3EeDMA%20-%20%E5%88%B6%E5%BE%A1%E3%81%A8%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FLI%3E%3CLI%3EeDMA%20-%20Transfer%20Control%20Descriptor%200%20to%2031%20(%E8%BB%A2%E9%80%81%E5%88%B6%E5%BE%A1%E8%A8%98%E8%BF%B0%E5%AD%90%200%20%E3%81%8B%E3%82%89%2031)%3C%2FLI%3E%3CLI%3EDMA%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B50%3C%2FLI%3E%3CLI%3EDMA%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B51%3C%2FLI%3E%3CLI%3EMSCM%3C%2FLI%3E%3CLI%3ESTM0%E3%81%AE%3C%2FLI%3E%3CLI%3ESIUL2%3C%2FLI%3E%3CLI%3ECMU%200-6%3C%2FLI%3E%3CLI%3EPLL%3C%2FLI%3E%3CLI%3EFlexCAN%200%20%E3%81%8B%E3%82%89%203%3C%2FLI%3E%3CLI%3ELPI2C%200%20%E5%AF%BE%201%3C%2FLI%3E%3CLI%3ELPSPI%200%20%E3%81%8B%E3%82%89%203%3C%2FLI%3E%3CLI%3ECRC%3C%2FLI%3E%3CLI%3EPCUD%3C%2FLI%3E%3C%2FUL%3E%3CP%3E1)XRDC%E3%81%AF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E5%8C%96%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%80%8C%E3%81%AF%E3%81%84%E3%80%8D%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E2)%20%E3%82%AF%E3%83%AD%E3%82%B9%E3%83%90%E3%83%BC%E3%81%AB%E3%81%AF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%80%8C%E3%81%AF%E3%81%84%E3%80%8D%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E3)%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E8%BF%BD%E5%8A%A0%3CSPAN%3ECache_Ip%3C%2FSPAN%3E%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CSPAN%3E%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E4)%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E4%BB%96%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2036132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AADC%E3%81%AEDMA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%AE%9B%E5%85%88%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%83%A1%E3%83%A2%E3%83%AA%E7%AF%84%E5%9B%B2%E3%82%92%E6%8C%87%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20-%20%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%80%81%E7%84%A1%E5%8A%B9%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%90%E3%82%B9%20%E3%82%A8%E3%83%A9%E3%83%BC%20(MPU%E3%80%81XRDC)%20%E3%81%AB%E3%81%A4%E3%81%AA%E3%81%8C%E3%82%8B%E3%81%82%E3%82%89%E3%82%86%E3%82%8B%E7%A8%AE%E9%A1%9E%E3%81%AE%E4%BF%9D%E8%AD%B7%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%2C%20Petr%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2036068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AADC%E3%81%AEDMA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52961%22%20target%3D%22_self%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%9A%E3%83%88%E3%83%ABS%3C%2FSPAN%3E%3C%2FA%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%80%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB1%E3%81%A816%E3%81%A7%20%3CSTRONG%3E%E3%83%87%E3%82%B9%E3%83%86%E3%82%A3%E3%83%8D%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%90%E3%82%B9%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSTRONG%3E%20%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-30%20102630.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sk%C3%A6rmbillede%202025-01-30%20102630.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F321891i94C505B47EFF07FC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sk%C3%A6rmbillede%202025-01-30%20102630.png%22%20alt%3D%22Sk%C3%A6rmbillede%202025-01-30%20102630.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESk%C3%A6rmbillede%202025-01-30%20102630.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%BD%95%E3%81%8B%E8%80%83%E3%81%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2036050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AADC%E3%81%AEDMA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%80%81%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8FIntCtrl_Ip_InstallHandler%E3%81%A8IntCtrl_Ip_EnableIrq%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%81%8C%3CSPAN%3EIntCtrl_Ip_Init%E3%82%82%E5%90%8C%E6%A7%98%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%A7NVIC%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%81%A8%E3%83%99%E3%82%AF%E3%82%BF%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E7%A2%BA%E8%AA%8D%2F%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%2C%20Petr%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
