Cannot flash S32K344
Rexyz
I am using S32DS IDE and PEMicro interface to program S32K344. I had flashed the Wdg_fs26_example_HLD_S32K344 example code on S32K344evb BMU board.
After programming i can no longer flash the MCU again. I am getting Runtime error. I have attached the screenshot. Please check. Is there a way to erase or flash the MCU ??.
Revathi
VaneB
Hi @Rexyz
I am not familiar with this error. Could you send the full output from the debug console and a .log file from the workspace?
Also, do you have an updated PE micro plugin?
B.R.
VaneB
Rexyz
Hello Vane,
Please find the debug console output below. I dont have a .log file from the workspace.
Yes, i have the updated plugin.
Revathi
VaneB
Hi @Rexyz
It looks like this topic has already been discussed in the PEmicro forum, check the following link it might be useful for you.
Error 216 problem
If you are still not able to debug, maybe you can submit a question to PEmicro Customer Support.
