SPI full duplex communication with flash
1,467件の閲覧回数
sai-bodhanapu
Hello @VaneB , I am using S32k312 EVB, i tried to communicate with flash using SPI in full duplex mode, when i use the functions Spi_SyncTransmit ()or Spi_AsyncTransmit(), i always get dummy data before actual data in rx_buffer, the dummy data is always the size of tx_buffer.
these are my configurations from S32DS. please let me know if anything wrong with my configuration.
1,440件の閲覧回数
VaneB
Hi @sai-bodhanapu
Can you share the RTD version you are using so I can try to replicate your issue? Or your project, if it is possible?
Also, have you already tested the SPI examples? Specifically for S32K312 devices, the last RTD version with examples is the v2.0.3.
B.R.
VaneB
