Can not new a s32k144 project with sdk s32k1 RTD AUTOSAR 4.4 Version 1.0.1
1,397 次查看
laofu
Hi@nxp
i have installed s32k1 RTD AUTOSAR 4.4 Version 1.0.1 as follow,
why i can not import this sdk when new a project.
标记 (1)
1,311 次查看
jiri_kral
please make sure that you choose correct build toolchain. RTD supports GNU gcc v9.2:
4 回复数
1,312 次查看
jiri_kral
1,232 次查看
laofu
I have solved with the help of you ,thanks very much @jiri_kral ,in addition ,do this version  RTD carrying FreeRTOS submodule
1,358 次查看
petervlna
This could be cause by version of S32 design studio.
Which version of S32DS are you using?
Peter
1,351 次查看
laofu
it is s32ds 3.4,but i can import example project that use this RTD
thinks
