CAN Transmission
11,008件の閲覧回数
sarwath
Hello Community,
I am trying to send data through can0 bus.
My motto is to verify whether the can module is working or not.
I sent data and verifying through PCAN View. In PCAN View I got PASSIVE error during receiving the data.
I have attached my project and SS, Please have a look and help me to solve the issue.
BR,
Sarwath
10,969件の閲覧回数
PetrS
I tried your code on EVB and it was working, message was received on CAN tool.
some example is e.g. in https://community.nxp.com/t5/S32K-Knowledge-Base/Example-S32K144-FlexCAN-TX-RX-Error-ISR-test-S32DS2...
BR, Petr
4 返答(返信)
10,992件の閲覧回数
PetrS
most probably you have wrong CAN bit timing. Check if CAN tool use the same setting as your device.
BR, Petr
10,988件の閲覧回数
sarwath
Hello @PetrS,
I am attaching my settings for your reference.
Any issues in my code to transmit the data. If you have any example for send and receive please share it with me.
BR,
Sarwath
10,970件の閲覧回数
PetrS
BR, Petr
10,999件の閲覧回数
sarwath
I want to send and receive the data through CAN bus.
