CAN Transmission
CAN Transmission
sarwath
Hello Community,
I am trying to send data through can0 bus.
My motto is to verify whether the can module is working or not.
I sent data and verifying through PCAN View. In PCAN View I got PASSIVE error during receiving the data.
I have attached my project and SS, Please have a look and help me to solve the issue.
BR,
Sarwath
PetrS
I tried your code on EVB and it was working, message was received on CAN tool.
some example is e.g. in https://community.nxp.com/t5/S32K-Knowledge-Base/Example-S32K144-FlexCAN-TX-RX-Error-ISR-test-S32DS2...
BR, Petr
PetrS
most probably you have wrong CAN bit timing. Check if CAN tool use the same setting as your device.
BR, Petr
sarwath
Hello @PetrS,
I am attaching my settings for your reference.
Any issues in my code to transmit the data. If you have any example for send and receive please share it with me.
BR,
Sarwath
PetrS
BR, Petr
sarwath
I want to send and receive the data through CAN bus.
