Assistance Required for Flash Programming S32K344 Using USB Multilink Universal FX in S32 Design Stu
387件の閲覧回数
Aravind_Togaralli
Dear NXP Technical Support Team,
I hope you are doing well.
I am currently working with the FRDM-A-S32K344 evaluation board and using S32 Design Studio (S32DS) for application development. I would like to program and debug the S32K344 MCU using a PEmicro USB Multilink Universal FX debugger through the JTAG/SWD interface.
I would appreciate your guidance on the correct configuration and setup for this hardware combination. Specifically, I would like assistance with the following:
  1. Software and Driver Requirements
    • Required PEmicro drivers and firmware versions.
    • Any additional S32DS packages or device support that must be installed.
    • Recommended version compatibility between S32DS and the USB Multilink Universal FX.
  2. S32 Design Studio Debug Configuration
    • Step-by-step instructions for creating a PEmicro GDB Server debug configuration.
    • Recommended settings for the Main, Debugger, Startup, and Common tabs.
    • Any target-specific configuration required for the S32K344.
  3. Hardware Connection
    • Confirmation of the correct JTAG/SWD pin connections between the FRDM-A-S32K344 J9 header and the USB Multilink Universal FX (Port B).
    • Whether any special wiring or signal connections are recommended.
  4. Board Configuration
    • Required jumper or switch settings on the FRDM-A-S32K344 board.
    • Any configuration related to the FS26 System Basis Chip (SBC) or watchdog that should be considered to prevent resets during programming and debugging.
  5. Reference Documentation
    • Any application notes, user guides, or example projects demonstrating the use of the USB Multilink Universal FX with the S32K344 would be greatly appreciated.
For your reference, I have also attached a diagram illustrating the JTAG pin connections between the FRDM-A-S32K344 board and the USB Multilink Universal FX.
Thank you for your time and support. I look forward to your guidance.
Kind regards,
Aravind Togaralli
356件の閲覧回数
Julián_AragónM
Hi @Aravind_Togaralli,
1. NXP always recommends using the latest SW release available. Right now, the latest release for S32K3 include:
S32DS 3.6.10 includes PEmicro interface debugging support version 6.2.1.
2. When importing an example, or creating a new S32DS application project, the respective debug configuration is generated. You can refer to the examples for the recommended settings, however, most important ones are 'C/C++ Application' path, device & port selected, and GDB Client executable path:
3. Yes, if you wish to debug the FRDM-A-S32K344 with an external debugger, you must use the J9 20-pin Cortex Debug + ETM header.
4. As detailed inside the FRDM-A-S32K344 development board user manual (UM12406), to enable this interface, jumper JP11 (OpenSDA voltage) must be removed.
5. You can refer to HOWTO Build a Project and Setup Debugging with GDB PEMicro Debugging Interface. Or you can refer directly to PEmicro: PEmicro NXP_Automotive S32K3xx Device Support.
For any specific function/configuration, you can try contacting PEmicro instead.
Julián
%3CLINGO-SUB%20id%3D%22lingo-sub-2402539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32%20Design%20Stu%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BUSB%E3%83%9E%E3%83%AB%E3%83%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%ABFX%20S32K344%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E6%94%AF%E6%8F%B4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2402539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3ENXP%E6%8A%80%E8%A1%93%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%81%E3%83%BC%E3%83%A0%E3%81%B8%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%8A%E5%85%83%E6%B0%97%E3%81%A7%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%20%3CSTRONG%3EFRDM-A-S32K344%3C%2FSTRONG%3E%20%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E9%96%8B%E7%99%BA%E3%81%AB%E3%81%AF%20%3CSTRONG%3ES32%20Design%20Studio(S32DS)%3C%2FSTRONG%3E%20%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%80%81%20%3CSTRONG%3EPEmicro%20USB%20Multilink%20Universal%20FX%3C%2FSTRONG%3E%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%82%92%20%3CSTRONG%3EJTAG%2FSWD%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FSTRONG%3E%E7%B5%8C%E7%94%B1%E3%81%A7S32K344%20MCU%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A8%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%92%E8%A1%8C%E3%81%84%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%A7%8B%E6%88%90%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E9%81%A9%E5%88%87%E3%81%AA%E8%A8%AD%E5%AE%9A%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%94%E6%95%99%E7%A4%BA%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%94%AF%E6%8F%B4%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%3CSTRONG%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8A%E3%82%88%E3%81%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E8%A6%81%E4%BB%B6%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%E5%BF%85%E8%A6%81%E3%81%AAPEmicro%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A8%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%80%82%3C%2FLI%3E%3CLI%3E%E8%BF%BD%E5%8A%A0%E3%81%AES32DS%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3ES32DS%E3%81%A8USB%20Multilink%20Universal%20FX%E9%96%93%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E4%BA%92%E6%8F%9B%E6%80%A7%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3ES32%20Design%20Studio%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%3CSTRONG%3EPEmicro%20GDB%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%3C%2FSTRONG%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%A7%8B%E6%88%90%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E6%AE%B5%E9%9A%8E%E7%9A%84%E3%81%AB%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E3%83%A1%E3%82%A4%E3%83%B3%3C%2FSTRONG%3E%E3%80%81%3CSTRONG%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%3C%2FSTRONG%3E%E3%80%81%3CSTRONG%3E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FSTRONG%3E%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%3CSTRONG%3E%E5%85%B1%E9%80%9A%3C%2FSTRONG%3E%E3%82%BF%E3%83%96%E3%81%AE%E6%8E%A8%E5%A5%A8%E8%A8%AD%E5%AE%9A%E3%80%82%3C%2FLI%3E%3CLI%3ES32K344%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E5%9B%BA%E6%9C%89%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%8E%A5%E7%B6%9A%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%3CSTRONG%3EFRDM-A-S32K344%20J9%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%3C%2FSTRONG%3E%E3%81%A8%3CSTRONG%3EUSB%E3%83%9E%E3%83%AB%E3%83%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%ABFX%EF%BC%88%E3%83%9D%E3%83%BC%E3%83%88B%EF%BC%89%3C%2FSTRONG%3E%E9%96%93%E3%81%AEJTAG%2FSWD%E3%83%94%E3%83%B3%E6%8E%A5%E7%B6%9A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%E7%89%B9%E5%88%A5%E3%81%AA%E9%85%8D%E7%B7%9A%E3%82%84%E4%BF%A1%E5%8F%B7%E6%8E%A5%E7%B6%9A%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E6%A7%8B%E6%88%90%3C%2FSTRONG%3E%3CUL%3E%3CLI%3EFRDM-A-S32K344%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%BF%85%E9%A0%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EFS26%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%99%E3%83%BC%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%81%E3%83%83%E3%83%97(SBC)%3C%2FSTRONG%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%84%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E4%B8%AD%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E9%98%B2%E3%81%90%E3%81%9F%E3%82%81%E3%81%AB%E8%80%83%E6%85%AE%E3%81%99%E3%81%B9%E3%81%8D%E6%A7%8B%E6%88%90%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%3C%2FSTRONG%3E%3CUL%3E%3CLI%3EUSB%20%3CSTRONG%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%ABFX%3C%2FSTRONG%3E%20%E3%82%92%20%3CSTRONG%3ES32K344%3C%2FSTRONG%3E%20%E3%81%A7%E4%BD%BF%E3%81%86%E4%BE%8B%E3%82%92%E7%A4%BA%E3%81%99%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E4%BE%8B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%81%9C%E3%81%B2%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E3%81%94%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%20%3CSTRONG%3EFRDM-A-S32K344%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%E3%81%A8%3CSTRONG%3EUSB%E3%83%9E%E3%83%AB%E3%83%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%ABFX%3C%2FSTRONG%3E%E9%96%93%E3%81%AEJTAG%E3%83%94%E3%83%B3%E6%8E%A5%E7%B6%9A%E3%82%92%E7%A4%BA%E3%81%99%E5%9B%B3%E3%82%82%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%8A%E6%99%82%E9%96%93%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E6%8C%87%E5%B0%8E%E3%82%92%E5%BF%83%E3%82%88%E3%82%8A%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%82%A2%E3%83%A9%E3%83%B4%E3%82%A3%E3%83%B3%E3%83%89%E3%83%BB%E3%83%88%E3%82%AC%E3%83%A9%E3%83%AA%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2402623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Assistance%20Required%20for%20Flash%20Programming%20S32K344%20Using%20USB%20Multilink%20Universal%20FX%20in%20S32%20Design%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2402623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262505%22%20target%3D%22_blank%22%3E%40Aravind_Togaralli%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%20NXP%E3%81%AF%E5%B8%B8%E3%81%AB%E6%9C%80%E6%96%B0%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%8E%A8%E5%A5%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81S32K3%E3%81%AE%E6%9C%80%E6%96%B0%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Felement%3D8103061%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32%20Design%20Studio%20IDE%203.6.10%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Felement%3D7873971%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20S32K3_S32M27x%20%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20ASR%20R23-11%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%207.0.1%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3ES32DS%203.6.10PEmicro%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B36.2.1%E3%82%92%E5%90%AB%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20%E4%BE%8B%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%9F%E3%82%8A%E3%80%81%E6%96%B0%E3%81%97%E3%81%84S32DS%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%A7%8B%E6%88%90%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E6%8E%A8%E5%A5%A8%E8%A8%AD%E5%AE%9A%E3%81%AE%E4%BE%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%9C%80%E3%82%82%E9%87%8D%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%AF%E3%80%8CC%2FC%2B%2B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8D%E3%83%91%E3%82%B9%E3%80%81%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%26amp%3B%E3%83%9D%E3%83%BC%E3%83%88%E3%80%81GDB%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%91%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Julin_AragnM_1-1786048764074.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_1-1786048764074.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393902iE70214F2399D9366%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Julin_AragnM_1-1786048764074.png%22%20alt%3D%22Julin_AragnM_1-1786048764074.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Julin_AragnM_0-1786048752996.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1786048752996.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393901i20704FC1FA6DA1DC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Julin_AragnM_0-1786048752996.png%22%20alt%3D%22Julin_AragnM_0-1786048752996.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E3.%20%E3%81%AF%E3%81%84%E3%80%81%E5%A4%96%E9%83%A8%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%A7FRDM-A-S32K344%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%3CSTRONG%3EJ9%3CSPAN%3E%2020%E3%83%94%E3%83%B3Cortex%20Debug%20%2B%20ETM%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%3C%2FSPAN%3E%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E4.%20FRDM-A-S32K344%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB(%3CSTRONG%3EUM12406%3C%2FSTRONG%3E)%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E9%80%9A%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%82%B8%E3%83%A3%E3%83%B3%20%3CSTRONG%3E%E3%83%91%E3%83%BCJP11(OpenSDA%E9%9B%BB%E5%9C%A7%3C%2FSTRONG%3E%20)%E3%82%92%E9%99%A4%E5%8E%BB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E5.%E3%80%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FHOWTO-Build-a-Project-and-Setup-Debugging-with-GDB-PEMicro%2Fta-p%2F1941848%22%20target%3D%22_blank%22%3EHOWTO%20Build%20a%20Project%20and%20Setup%20Debugging%20with%20GDB%20PEMicro%20Debugging%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FA%3E%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81PEmicro%E3%81%AB%E7%9B%B4%E6%8E%A5%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3A%3CA%20href%3D%22https%3A%2F%2Fwww.pemicro.com%2Farm%2Fdevice_support%2FNXP_Automotive%2FS32K3xx%2Findex.cfm%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EPEmicro%20NXP_Automotive%20S32K3xx%20Device%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FA%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E7%89%B9%E5%AE%9A%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%84%E6%A7%8B%E6%88%90%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%ABPEmicro%E3%81%AB%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%B8%E3%83%A5%E3%83%AA%E3%82%A2%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
