Application note about S32K3 eMIOS/TRMUX/ADC
Eli_Wang
Hi,We are helping customer debug ADC/eMIOS of S32K314 and need 32 ADC channels to trigger PWM.  Would you please share application note related with eMIOS/TRMUX/ADC ?
danielmartynek
Hi @Eli_Wang,
Currently, there is only AN13413 ADC Guidelines Spec and Configuration
https://www.nxp.com/docs/en/application-note/AN13413.pdf
which also covers the triggers.
In mid July, there should be motor control demos available with application notes.
danielmartynek
Hi @Eli_Wang,
StabFlo
sadly the link is dead.
Florian
danielmartynek
Hi @StabFlo,
Unfortunately, the AN was temporarily removed from the NXP webpage because of some inconsistencies.
We don't have any target date for the update yet.
MVR
Contributor V
I"m facing "Page Not Found"
Where can I find application note docs about S32K344?
Thanks.
Kazarian
@danielmartynek  the link does not work, can you please share the new link for this.
Ralphty
Eli_Wang
Thanks, there is another question. The customer found that when the bctu module and emios (Opwmt mode) open the interrupt at the same time, the emios interrupt cannot enter. Is there anything to pay attention to when these two modules open the interrupt at the same time?
Eli_Wang
Ok,thanks for reply.
