Application note about S32K3 eMIOS/TRMUX/ADC
9,122件の閲覧回数
Eli_Wang
Hi,We are helping customer debug ADC/eMIOS of S32K314 and need 32 ADC channels to trigger PWM.  Would you please share application note related with eMIOS/TRMUX/ADC ?
9,107件の閲覧回数
danielmartynek
Hi @Eli_Wang,
Currently, there is only AN13413 ADC Guidelines Spec and Configuration
https://www.nxp.com/docs/en/application-note/AN13413.pdf
which also covers the triggers.
In mid July, there should be motor control demos available with application notes.
8 返答(返信)
9,108件の閲覧回数
danielmartynek
Hi @Eli_Wang,
4,787件の閲覧回数
StabFlo
sadly the link is dead.
Florian
4,773件の閲覧回数
danielmartynek
Hi @StabFlo,
Unfortunately, the AN was temporarily removed from the NXP webpage because of some inconsistencies.
We don't have any target date for the update yet.
4,917件の閲覧回数
MVR
Contributor V
I"m facing "Page Not Found"
Where can I find application note docs about S32K344?
Thanks.
6,206件の閲覧回数
Kazarian
@danielmartynek  the link does not work, can you please share the new link for this.
7,025件の閲覧回数
Ralphty
9,077件の閲覧回数
Eli_Wang
Thanks, there is another question. The customer found that when the bctu module and emios (Opwmt mode) open the interrupt at the same time, the emios interrupt cannot enter. Is there anything to pay attention to when these two modules open the interrupt at the same time?
9,079件の閲覧回数
Eli_Wang
Ok,thanks for reply.
