Hmm, that is not possible.
After writing data to the flash, did you verify that data are present in flash? Not just in the debugger GUI, but physically loaded in flash?
Once the data are loaded into flash, only way to remove them is to perform erase procedure.
I would guess, that your data was not programmed into uC and you see them only in debugger GUI.
Peter
