AMMCLIB S32K3 with S32DS Help
2,323件の閲覧回数
shivchopra5
I am using the S32DS and wanted to use the AMMCLIB library for the new S32K3 series. I see that the S32K3 version of the library is available online here -> https://www.nxp.com/design/automotive-software-and-tools/automotive-math-and-motor-control-library-a...
But the option to get this library does not exist in the S32DS. I only see the option for the other devices such as S32K14x. I was able to download and install the binary, but I wanted to know what the procedure is to use this library with S32DS.
Is there some guide to how I can use the AMMCLIB library for S32K3 with the S32DS. Can I include the paths or something?
Any guidance would be of great help.
Thank You!
タグ(2)
2,306件の閲覧回数
Senlent
Hi@shivchopra5
I don't know if you have seen this document, maybe this document can help you,
BR!
2,307件の閲覧回数
Senlent
Hi@shivchopra5
BR!
