 danielmartynek
			danielmartynek
		Hi @lingyunzhi,
There is only one instance of FlexIO on the MCU.
You should be able to use one FlexIO driver and generate two configurations in it.
 danielmartynek
			danielmartynek
		Hi @lingyunzhi,
Hi danielmartynek,
Yes, one FlexIO driver and generate two configurations, the problem has already been solved.
Thank you for reply.
