makefile error in PFE example
4,630 次查看
Youngsoo_do
I'm using the makefile in the PFE example to compile.
However, I keep getting an error saying the path is not found.
I wonder if this error is caused by my not entering the path correctly in the makefile or if it's a problem with the Tresos_cmd.bat file.
This is the version of the file I'm using. Version compatibility seems to be fine.
PFE-FW_S32G_1.7.1
PFE-DRV_S32G_M7_MCAL_1.2.0
SW32G_RTD_4.4_4.0.2
C:\EB\tresos\bin\workspace>make generate
process_begin: CreateProcess(NULL, cygpath -m C:/EB/tresos/bin/workspace/MasterProject_RDB3, ...) failed.
make: Makefile:647: pipe: No such file or directory
C:/EB/tresos/bin/tresos_cmd.bat -data C:/EB/tresos/bin/workspace importProject 2>&1
C:/EB/tresos/bin/tresos_cmd.bat: line 1: @echo: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 2: REM: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 4: IF: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 5: IF: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 6: IF: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 7: IF: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 8: IF: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 9: IF: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 10: IF: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 11: IF: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 13: goto: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 15: :NOJAVA: command not found
ERROR: java not found: %JAVA%
C:/EB/tresos/bin/tresos_cmd.bat: line 17: EXIT: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 19: :NOWINDOWS: command not found
ERROR: tresos only runs on Windows2000 and Windows/XP
C:/EB/tresos/bin/tresos_cmd.bat: line 21: EXIT: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 23: :START: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 24: REM: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 25: SET: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 26: SET: command not found
C:/EB/tresos/bin/tresos_cmd.bat: line 48: unexpected EOF while looking for matching `"'
C:/EB/tresos/bin/tresos_cmd.bat: line 54: syntax error: unexpected end of file
Makefile:647: recipe for target 'generate' failed
make: [generate] Error 2 (ignored)
C:/EB/tresos/bin/tresos_cmd.bat -data C:/EB/tresos/bin/workspace autoconfigure MasterProject_RDB3 GenerateAllVariants 2>&1
make: *** [generate] Error 2
Upload the relevant files, just in case.
标记 (1)
4,565 次查看
Youngsoo_do
For this issue, I went to that page, downloaded the Arm GNU Toolchain, and changed the path to GCC_DIR in the makefile, which solved the problem.
https://developer.arm.com/downloads/-/arm-gnu-toolchain-downloads
(I want it to be helpful to someone who has a similar problem to mine)
But I have another problem—it's never-ending. I'll have to create a new case to ask the question.
Thank you for your help on this issue.
5 回复数
4,476 次查看
chenyin_h
Hello, @ Youngsoo_do
Thanks for the valuable information.
Best Regards
Chenyin
4,595 次查看
chenyin_h
Thanks for the question.
Let me summarize the building steps for your reference:
  1. Install the following packages SW32G_RTD_4.4_4.0.2, PFE-DRV_S32G_M7_MCAL_1.2.0, PFE-FW_S32G_1.7.1 to your host.
  2. Create link file under $EB_PATH/links with the content:
path=$SW32G_RTD_4.4_4.0.2_PATH
  1. Copy the plugin from PFE DIR: Eth_43…. to the $SW32G_RTD_4.4_4.0.2_PATH/eclipse/plugins
  2. Import the project: MasterProject_RDB3 to the EB
  3. Generate project code by EB, by default, the code path is shown below:
After successfully generation,
Copy generate_RDB3/* to $PFE-DRV_S32G_M7_MCAL_1.2.0\example_application
  1. Open the project_parameters.mk, At least modify the following part: change the path depending on your installation.
GCC_DIR ?= c:/NXP/S32DS.3.5/S32DS/build_tools/gcc_v9.2/gcc-9.2-arm32-eabi #depend on your path
TRESOS_DIR ?= C:/EB/tresos    # EB installation path
PLUGINS_DIR ?= $RTD_4.0.2_installation_path/eclipse/plugins
TRESOS_WORKSPACE_DIR ?= $(TRESOS_DIR)/workspace
FW_DIR ?= $pfe_FW_installation_path
  1. Build the project by typing “make HW=RDB3”
Hope it helps
Best Regards
Chenyin
4,583 次查看
Youngsoo_do
Thank you very much for your response.
I tried doing it the way you suggested.
However, I got the following error in the "make build" command.
The end of the build says that the file "nosys.specs" was not found.
Does anyone know of a solution to this problem?
$ make buil
CC generate_RDB3/src/isa.c
CC generate_RDB3/src/Eth_PFE_LLD.c
CC generate_RDB3/src/fci.c
CC generate_RDB3/src/fci_core_autosar.c
CC generate_RDB3/src/Serdes_Ipw_PBCfg.c
CC generate_RDB3/src/pfe_bus_err_csr.c
CC generate_RDB3/src/Eth_43_PFE_VS_0_PBcfg.c
CC generate_RDB3/src/fifo.c
CC generate_RDB3/src/pfe_ecc_err_csr.c
CC generate_RDB3/src/elf.c
CC generate_RDB3/src/Rtc_Ip_VS_0_PBcfg.c
CC generate_RDB3/src/pfe_rtable.c
CC generate_RDB3/src/Platform_Ipw_Cfg.c
CC generate_RDB3/src/fci_rt_db.c
CC generate_RDB3/src/pfe_tmu.c
CC generate_RDB3/src/pfe_emac_slave.c
CC generate_RDB3/src/fci_fp.c
CC generate_RDB3/src/fci_mirror.c
CC generate_RDB3/src/Platform_Cfg.c
CC generate_RDB3/src/pfe_emac_csr.c
CC generate_RDB3/src/pfe_phy_if.c
CC generate_RDB3/src/pfe_bus_err.c
CC generate_RDB3/src/Dma_Ip_VS_0_PBcfg.c
CC generate_RDB3/src/libfci_autosar.c
CC generate_RDB3/src/fci_qos.c
CC generate_RDB3/src/pfe_host_fail_stop_csr.c
CC generate_RDB3/src/fci_l2br_domains.c
CC generate_RDB3/src/pfe_wdt_csr.c
CC generate_RDB3/src/pfe_fw_feature.c
CC generate_RDB3/src/OsIf_Cfg.c
CC generate_RDB3/src/pfe_hm.c
CC generate_RDB3/src/Serdes_Ip_PBCfg.c
CC generate_RDB3/src/oal_irq_autosar.c
CC generate_RDB3/src/Clock_Ip_Cfg.c
CC generate_RDB3/src/Power_Ip_VS_0_PBcfg.c
CC generate_RDB3/src/pfe_hif_ring.c
CC generate_RDB3/src/oal_time_autosar.c
CC generate_RDB3/src/pfe_fw_fail_stop_csr.c
CC generate_RDB3/src/pfe_log_if.c
CC generate_RDB3/src/IntCtrl_Ip_Cfg.c
CC generate_RDB3/src/pfe_emac.c
CC generate_RDB3/src/pfe_gpi_csr.c
CC generate_RDB3/src/fci_routes.c
CC generate_RDB3/src/Gpt_VS_0_PBcfg.c
CC generate_RDB3/src/pfe_class.c
CC generate_RDB3/src/pfe_bmu.c
CC generate_RDB3/src/pfe_minihif_drv.c
CC generate_RDB3/src/pfe_hif_nocpy_csr.c
CC generate_RDB3/src/pfe_log_if_slave.c
CC generate_RDB3/src/Siul2_Port_Ip_VS_0_PBcfg.c
CC generate_RDB3/src/pfe_platform_slave.c
CC generate_RDB3/src/Port_Cfg.c
CC generate_RDB3/src/pfe_l2br_table.c
CC generate_RDB3/src/Mcu_VS_0_PBcfg.c
CC generate_RDB3/src/pfe_phy_if_slave.c
CC generate_RDB3/src/nxp_snprintf.c
CC generate_RDB3/src/fci_l2br.c
CC generate_RDB3/src/pfe_fw_fail_stop.c
CC generate_RDB3/src/Ram_Ip_Cfg.c
CC generate_RDB3/src/Mcu_Cfg.c
CC generate_RDB3/src/pfe_gpi.c
CC generate_RDB3/src/pfe_host_fail_stop.c
CC generate_RDB3/src/oal_job_autosar.c
CC generate_RDB3/src/pfe_util.c
CC generate_RDB3/src/Ftm_Gpt_Ip_VS_0_PBcfg.c
CC generate_RDB3/src/fci_connections.c
CC generate_RDB3/src/pfe_if_db.c
CC generate_RDB3/src/Eth_43_PFE_Cfg.c
CC generate_RDB3/src/pfe_bmu_csr.c
CC generate_RDB3/src/pfe_fail_stop_csr.c
CC generate_RDB3/src/pfe_l2br.c
CC generate_RDB3/src/CDD_Mcl_Cfg.c
CC generate_RDB3/src/Stm_Ip_VS_0_PBcfg.c
CC generate_RDB3/src/pfe_feature_mgr.c
CC generate_RDB3/src/pfe_util_csr.c
CC generate_RDB3/src/Gpt_Ipw_VS_0_PBcfg.c
CC generate_RDB3/src/pfe_hw_feature.c
CC generate_RDB3/src/pfe_idex.c
CC generate_RDB3/src/pfe_hif_ptp.c
CC generate_RDB3/src/fci_fp_db.c
CC generate_RDB3/src/Dma_Ip_Cfg.c
CC generate_RDB3/src/pfe_hif_csr.c
CC generate_RDB3/src/pfe_fail_stop.c
CC generate_RDB3/src/pfe_fp.c
CC generate_RDB3/src/pfe_mirror.c
CC generate_RDB3/src/pfe_platform_master.c
CC generate_RDB3/src/oal_mm_autosar.c
CC generate_RDB3/src/pfe_parity_csr.c
CC generate_RDB3/src/pfe_wdt.c
CC generate_RDB3/src/Power_Ip_Cfg.c
CC generate_RDB3/src/oal_util_net_autosar.c
CC generate_RDB3/src/pfe_hif_chnl.c
CC generate_RDB3/src/Serdes_Cfg.c
CC generate_RDB3/src/Clock_Ip_VS_0_PBcfg.c
CC generate_RDB3/src/fci_interfaces.c
CC generate_RDB3/src/pfe_hif.c
CC generate_RDB3/src/fci_owner.c
CC generate_RDB3/src/fci_fw_features.c
CC generate_RDB3/src/Eth_43_PFE_Irq.c
CC generate_RDB3/src/pfe_hif_drv.c
CC generate_RDB3/src/pfe_class_csr.c
CC generate_RDB3/src/Eth_43_PFE.c
CC generate_RDB3/src/EthIf_Cbk.c
CC generate_RDB3/src/pfe_parity.c
CC generate_RDB3/src/CDD_Mcl_VS_0_PBcfg.c
CC generate_RDB3/src/Pit_Ip_VS_0_PBcfg.c
CC generate_RDB3/src/pfe_hif_nocpy.c
CC generate_RDB3/src/fci_hm.c
CC generate_RDB3/src/Port_VS_0_PBcfg.c
CC generate_RDB3/src/pfe_ecc_err.c
CC generate_RDB3/src/oal_util_autosar.c
CC generate_RDB3/src/pfe_pe.c
CC generate_RDB3/src/pfe_mac_db.c
CC generate_RDB3/src/blalloc.c
CC generate_RDB3/src/autolibc.c
CC generate_RDB3/src/Gpt_Cfg.c
CC generate_RDB3/src/fci_timer_owner.c
CC generate_RDB3/src/Ram_Ip_VS_0_PBcfg.c
CC generate_RDB3/src/pfe_tmu_csr.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Platform_TS_T40D11M40I2R0/startup/src/nvic.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Platform_TS_T40D11M40I2R0/startup/src/sys_init.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Platform_TS_T40D11M40I2R0/startup/src/system.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Platform_TS_T40D11M40I2R0/startup/src/m7/startup.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Platform_TS_T40D11M40I2R0/startup/src/m7/exceptions.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/BaseNXP_TS_T40D11M40I2R0/src/OsIf_Interrupts.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/BaseNXP_TS_T40D11M40I2R0/src/OsIf_Timer_System.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/BaseNXP_TS_T40D11M40I2R0/src/OsIf_Timer_System_Internal_Systick.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/BaseNXP_TS_T40D11M40I2R0/src/OsIf_Timer.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/BaseNXP_TS_T40D11M40I2R0/src/OsIf_Timer_System_Internal_GenericTimer.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Det_TS_T40D11M40I2R0/src/Det_stub.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Det_TS_T40D11M40I2R0/src/Det.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Dem_TS_T40D11M40I2R0/src/Dem_stub.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Dem_TS_T40D11M40I2R0/src/Dem.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Gpt_TS_T40D11M40I2R0/src/Gpt.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Gpt_TS_T40D11M40I2R0/src/Pit_Ip.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Gpt_TS_T40D11M40I2R0/src/Ftm_Gpt_Ip.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Gpt_TS_T40D11M40I2R0/src/Stm_Ip.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Gpt_TS_T40D11M40I2R0/src/Rtc_Ip.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Gpt_TS_T40D11M40I2R0/src/Gpt_Ipw.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_Selector.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_Data.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_Data2.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_Frequency2.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_Specific.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Power_Ip.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_ExtOsc.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_Frequency1.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_Specific2.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_Irq.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_Frequency.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Power_Ip_CortexM7.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Mcu_Dem_Wrapper.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_Gate.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Ram_Ip.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_Data1.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_FracDiv.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_DividerTrigger.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_IntOsc.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Power_Ip_CortexA.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_Specific1.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Power_Ip_PMC.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Power_Ip_MSCM.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_Monitor.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Mcu_Ipw.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_Divider.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Power_Ip_Private.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Power_Ip_MC_ME.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_ProgFreqSwitch.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Clock_Ip_Pll.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Power_Ip_MC_RGM.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Mcu.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Mcu_TS_T40D11M40I2R0/src/Power_Ip_MC_RGM_Irq.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Icu.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Fee.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Ocu.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Pmic.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Fr_43_LLCE.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Pwm.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Uart.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Fls.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Eth.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_I2c.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Port.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_EthTrcv_43_PHY.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Gpt.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Mcu.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Spi.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Can_43_LLCE.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Fr.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Ocotp.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Thermal.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Eth_43_PFE.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_EthSwt_43_SJA11XX.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Eep.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Mcl.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Adc.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Wdg.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Dio.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Qdec.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Serdes.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Rm.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Crypto.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Can.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Lin.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_CanTrcv_tja115x.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Ipcf.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Wdg_43_VR5510.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Rte_TS_T40D11M40I2R0/src/SchM_Crc.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Port_TS_T40D11M40I2R0/src/Siul2_Port_Ip.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Port_TS_T40D11M40I2R0/src/Port.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Port_TS_T40D11M40I2R0/src/Port_Ipw.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Platform_TS_T40D11M40I2R0/src/System_Ip.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Platform_TS_T40D11M40I2R0/src/IntCtrl_Ip.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Platform_TS_T40D11M40I2R0/src/Platform_Ipw.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Platform_TS_T40D11M40I2R0/src/Platform.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/EthSwt_TS_T40D11M40I2R0/src/EthSwt.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/EthTrcv_TS_T40D11M40I2R0/src/EthTrcv.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Serdes_TS_T40D11M40I2R0/src/Serdes_Ip_HwAccess.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Serdes_TS_T40D11M40I2R0/src/Serdes.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Serdes_TS_T40D11M40I2R0/src/Serdes_Ipw.c
CC C:/NXP/SW32G_RTD_4.4_4.0.2/eclipse/plugins/Serdes_TS_T40D11M40I2R0/src/Serdes_Ip.c
LD output_RDB3/main_RDB3.elf
C:/NXP/S32DS.3.5/S32DS/build_tools/gcc_v9.2/gcc-9.2-arm32-eabi/bin/arm-none-eabi-gcc.exe --entry=Reset_Handler -Tlinker/linker_maste
r_app/autosar_intram.gld --sysroot="C:/NXP/S32DS.3.5/S32DS/build_tools/gcc_v9.2/gcc-9.2-arm32-eabi/arm-none-eabi/newlib" -specs=nano
.specs -specs=nosys.specs -nostartfiles -mcpu=cortex-m7 -mthumb -mfpu=fpv5-sp-d16 -mfloat-abi=hard -ggdb3 -Wl,-Map,output_RDB3/main_
RDB3.map -lc -lm -lgcc -mlittle-endian output_RDB3/isa.o output_RDB3/Eth_PFE_LLD.o output_RDB3/fci.o output_RDB3/fci_core_autosar.o
output_RDB3/Serdes_Ipw_PBCfg.o output_RDB3/pfe_bus_err_csr.o output_RDB3/Eth_43_PFE_VS_0_PBcfg.o output_RDB3/fifo.o output_RDB3/pfe_
ecc_err_csr.o output_RDB3/elf.o output_RDB3/Rtc_Ip_VS_0_PBcfg.o output_RDB3/pfe_rtable.o output_RDB3/Platform_Ipw_Cfg.o output_RDB3/
fci_rt_db.o output_RDB3/pfe_tmu.o output_RDB3/pfe_emac_slave.o output_RDB3/fci_fp.o output_RDB3/fci_mirror.o output_RDB3/Platform_Cf
g.o output_RDB3/pfe_emac_csr.o output_RDB3/pfe_phy_if.o output_RDB3/pfe_bus_err.o output_RDB3/Dma_Ip_VS_0_PBcfg.o output_RDB3/libfci
_autosar.o output_RDB3/fci_qos.o output_RDB3/pfe_host_fail_stop_csr.o output_RDB3/fci_l2br_domains.o output_RDB3/pfe_wdt_csr.o outpu
t_RDB3/pfe_fw_feature.o output_RDB3/OsIf_Cfg.o output_RDB3/pfe_hm.o output_RDB3/Serdes_Ip_PBCfg.o output_RDB3/oal_irq_autosar.o outp
ut_RDB3/Clock_Ip_Cfg.o output_RDB3/Power_Ip_VS_0_PBcfg.o output_RDB3/pfe_hif_ring.o output_RDB3/oal_time_autosar.o output_RDB3/pfe_f
w_fail_stop_csr.o output_RDB3/pfe_log_if.o output_RDB3/IntCtrl_Ip_Cfg.o output_RDB3/pfe_emac.o output_RDB3/pfe_gpi_csr.o output_RDB3
/fci_routes.o output_RDB3/Gpt_VS_0_PBcfg.o output_RDB3/pfe_class.o output_RDB3/pfe_bmu.o output_RDB3/pfe_minihif_drv.o output_RDB3/p
fe_hif_nocpy_csr.o output_RDB3/pfe_log_if_slave.o output_RDB3/Siul2_Port_Ip_VS_0_PBcfg.o output_RDB3/pfe_platform_slave.o output_RDB
3/Port_Cfg.o output_RDB3/pfe_l2br_table.o output_RDB3/Mcu_VS_0_PBcfg.o output_RDB3/pfe_phy_if_slave.o output_RDB3/nxp_snprintf.o out
put_RDB3/fci_l2br.o output_RDB3/pfe_fw_fail_stop.o output_RDB3/Ram_Ip_Cfg.o output_RDB3/Mcu_Cfg.o output_RDB3/pfe_gpi.o output_RDB3/
pfe_host_fail_stop.o output_RDB3/oal_job_autosar.o output_RDB3/pfe_util.o output_RDB3/Ftm_Gpt_Ip_VS_0_PBcfg.o output_RDB3/fci_connec
tions.o output_RDB3/pfe_if_db.o output_RDB3/Eth_43_PFE_Cfg.o output_RDB3/pfe_bmu_csr.o output_RDB3/pfe_fail_stop_csr.o output_RDB3/p
fe_l2br.o output_RDB3/CDD_Mcl_Cfg.o output_RDB3/Stm_Ip_VS_0_PBcfg.o output_RDB3/pfe_feature_mgr.o output_RDB3/pfe_util_csr.o output_
RDB3/Gpt_Ipw_VS_0_PBcfg.o output_RDB3/pfe_hw_feature.o output_RDB3/pfe_idex.o output_RDB3/pfe_hif_ptp.o output_RDB3/fci_fp_db.o outp
ut_RDB3/Dma_Ip_Cfg.o output_RDB3/pfe_hif_csr.o output_RDB3/pfe_fail_stop.o output_RDB3/pfe_fp.o output_RDB3/pfe_mirror.o output_RDB3
/pfe_platform_master.o output_RDB3/oal_mm_autosar.o output_RDB3/pfe_parity_csr.o output_RDB3/pfe_wdt.o output_RDB3/Power_Ip_Cfg.o ou
tput_RDB3/oal_util_net_autosar.o output_RDB3/pfe_hif_chnl.o output_RDB3/Serdes_Cfg.o output_RDB3/Clock_Ip_VS_0_PBcfg.o output_RDB3/f
ci_interfaces.o output_RDB3/pfe_hif.o output_RDB3/fci_owner.o output_RDB3/fci_fw_features.o output_RDB3/Eth_43_PFE_Irq.o output_RDB3
/pfe_hif_drv.o output_RDB3/pfe_class_csr.o output_RDB3/Eth_43_PFE.o output_RDB3/EthIf_Cbk.o output_RDB3/pfe_parity.o output_RDB3/CDD
_Mcl_VS_0_PBcfg.o output_RDB3/Pit_Ip_VS_0_PBcfg.o output_RDB3/pfe_hif_nocpy.o output_RDB3/fci_hm.o output_RDB3/Port_VS_0_PBcfg.o out
put_RDB3/pfe_ecc_err.o output_RDB3/oal_util_autosar.o output_RDB3/pfe_pe.o output_RDB3/pfe_mac_db.o output_RDB3/blalloc.o output_RDB
3/autolibc.o output_RDB3/Gpt_Cfg.o output_RDB3/fci_timer_owner.o output_RDB3/Ram_Ip_VS_0_PBcfg.o output_RDB3/pfe_tmu_csr.o output_RD
B3/nvic.o output_RDB3/sys_init.o output_RDB3/system.o output_RDB3/startup.o output_RDB3/exceptions.o output_RDB3/OsIf_Interrupts.o o
utput_RDB3/OsIf_Timer_System.o output_RDB3/OsIf_Timer_System_Internal_Systick.o output_RDB3/OsIf_Timer.o output_RDB3/OsIf_Timer_Syst
em_Internal_GenericTimer.o output_RDB3/Det_stub.o output_RDB3/Det.o output_RDB3/Dem_stub.o output_RDB3/Dem.o output_RDB3/Gpt.o outpu
t_RDB3/Pit_Ip.o output_RDB3/Ftm_Gpt_Ip.o output_RDB3/Stm_Ip.o output_RDB3/Rtc_Ip.o output_RDB3/Gpt_Ipw.o output_RDB3/Clock_Ip_Select
or.o output_RDB3/Clock_Ip_Data.o output_RDB3/Clock_Ip_Data2.o output_RDB3/Clock_Ip_Frequency2.o output_RDB3/Clock_Ip_Specific.o outp
ut_RDB3/Power_Ip.o output_RDB3/Clock_Ip_ExtOsc.o output_RDB3/Clock_Ip.o output_RDB3/Clock_Ip_Frequency1.o output_RDB3/Clock_Ip_Speci
fic2.o output_RDB3/Clock_Ip_Irq.o output_RDB3/Clock_Ip_Frequency.o output_RDB3/Power_Ip_CortexM7.o output_RDB3/Mcu_Dem_Wrapper.o out
put_RDB3/Clock_Ip_Gate.o output_RDB3/Ram_Ip.o output_RDB3/Clock_Ip_Data1.o output_RDB3/Clock_Ip_FracDiv.o output_RDB3/Clock_Ip_Divid
erTrigger.o output_RDB3/Clock_Ip_IntOsc.o output_RDB3/Power_Ip_CortexA.o output_RDB3/Clock_Ip_Specific1.o output_RDB3/Power_Ip_PMC.o
output_RDB3/Power_Ip_MSCM.o output_RDB3/Clock_Ip_Monitor.o output_RDB3/Mcu_Ipw.o output_RDB3/Clock_Ip_Divider.o output_RDB3/Power_I
p_Private.o output_RDB3/Power_Ip_MC_ME.o output_RDB3/Clock_Ip_ProgFreqSwitch.o output_RDB3/Clock_Ip_Pll.o output_RDB3/Power_Ip_MC_RG
M.o output_RDB3/Mcu.o output_RDB3/Power_Ip_MC_RGM_Irq.o output_RDB3/SchM_Icu.o output_RDB3/SchM_Fee.o output_RDB3/SchM_Ocu.o output_
RDB3/SchM_Pmic.o output_RDB3/SchM_Fr_43_LLCE.o output_RDB3/SchM_Pwm.o output_RDB3/SchM_Uart.o output_RDB3/SchM_Fls.o output_RDB3/Sch
M_Eth.o output_RDB3/SchM_I2c.o output_RDB3/SchM_Port.o output_RDB3/SchM_EthTrcv_43_PHY.o output_RDB3/SchM_Gpt.o output_RDB3/SchM_Mcu
.o output_RDB3/SchM_Spi.o output_RDB3/SchM_Can_43_LLCE.o output_RDB3/SchM_Fr.o output_RDB3/SchM_Ocotp.o output_RDB3/SchM_Thermal.o o
utput_RDB3/SchM_Eth_43_PFE.o output_RDB3/SchM_EthSwt_43_SJA11XX.o output_RDB3/SchM_Eep.o output_RDB3/SchM_Mcl.o output_RDB3/SchM_Adc
.o output_RDB3/SchM_Wdg.o output_RDB3/SchM_Dio.o output_RDB3/SchM_Qdec.o output_RDB3/SchM_Serdes.o output_RDB3/SchM_Rm.o output_RDB3
/SchM_Crypto.o output_RDB3/SchM_Can.o output_RDB3/SchM_Lin.o output_RDB3/SchM_CanTrcv_tja115x.o output_RDB3/SchM_Ipcf.o output_RDB3/
SchM_Wdg_43_VR5510.o output_RDB3/SchM_Crc.o output_RDB3/Siul2_Port_Ip.o output_RDB3/Port.o output_RDB3/Port_Ipw.o output_RDB3/System
_Ip.o output_RDB3/IntCtrl_Ip.o output_RDB3/Platform_Ipw.o output_RDB3/Platform.o output_RDB3/EthSwt.o output_RDB3/EthTrcv.o output_R
DB3/Serdes_Ip_HwAccess.o output_RDB3/Serdes.o output_RDB3/Serdes_Ipw.o output_RDB3/Serdes_Ip.o output_RDB3/startup_cm7.o output_RDB3
/Vector_Table.o -o output_RDB3/main_RDB3.elf
arm-none-eabi-gcc.exe: fatal error: cannot read spec file 'nosys.specs': No such file or directory
compilation terminated.
Makefile:627: recipe for target 'output_RDB3/main_RDB3.elf' failed
make: *** [output_RDB3/main_RDB3.elf] Error 1
For this issue, I installed the Cygwin program from https://www.cygwin.com/install.html, then generated it using Cygdrive.
4,565 次查看
Youngsoo_do
4,497 次查看
Youngsoo_do
This answer is not a fundamental solution to the problem.
The answer to this problem is
C:\NXP\S32DS.3.5\S32DS\build_tools\gcc_v9.2\gcc-9.2-arm32-eabi\arm-none-eabi\newlib
If you go there, you'll find a folder called newlib. you change this newlib to lib.
I spent a few days struggling with this.
%3CLINGO-SUB%20id%3D%22lingo-sub-1876417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPFE%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%E7%9A%84%20makefile%20%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1876417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20PFE%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%E7%9A%84%20makefile%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E8%AF%91%E3%80%82%3CBR%20%2F%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E4%B8%8D%E6%96%AD%E6%94%B6%E5%88%B0%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%EF%BC%8C%E6%8F%90%E7%A4%BA%E6%9C%AA%E6%89%BE%E5%88%B0%E8%B7%AF%E5%BE%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%E6%98%AF%E7%94%B1%E4%BA%8E%E6%88%91%E6%B2%A1%E6%9C%89%E5%9C%A8%3CSTRONG%3Emakefile%3C%2FSTRONG%3E%E4%B8%AD%E6%AD%A3%E7%A1%AE%E8%BE%93%E5%85%A5%E8%B7%AF%E5%BE%84%E5%BC%95%E8%B5%B7%E7%9A%84%EF%BC%8C%E8%BF%98%E6%98%AF%E5%9B%A0%E4%B8%BA%3CSTRONG%3ETresos_cmd.bat%3C%2FSTRONG%3E%E6%96%87%E4%BB%B6%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%96%87%E4%BB%B6%E7%9A%84%E7%89%88%E6%9C%AC%E3%80%82%E7%89%88%E6%9C%AC%E5%85%BC%E5%AE%B9%E6%80%A7%E4%BC%BC%E4%B9%8E%E5%BE%88%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3EPFE-FW_S32G_1.7.1%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EPFE-DRV_S32G_M7_MCAL_1.2.0%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ESW32G_RTD_4.4_4.0.2%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EC%3A%5CEB%5Ctresos%5Cbin%5Cworkspace%26gt%3B%E7%94%9F%E6%88%90%3CBR%20%2F%3Eprocess_begin%EF%BC%9ACreateProcess%EF%BC%88NULL%EF%BC%8Ccygpath%20-m%20C%EF%BC%9A%2FEB%2Ftresos%2Fbin%2Fworkspace%2FMasterProject_RDB3%EF%BC%8C...%EF%BC%89%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3Emake%EF%BC%9AMakefile%EF%BC%9A647%EF%BC%9A%E7%AE%A1%E9%81%93%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%20-data%20C%3A%2FEB%2Ftresos%2Fbin%2Fworkspace%20importProject%202%26gt%3B%26amp%3B1%3CBR%20%2F%3E%20C%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%201%20%E8%A1%8C%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F3933%22%20target%3D%22_blank%22%3E%40echo%3C%2FA%3E%20%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%202%20%E8%A1%8C%EF%BC%9AREM%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%204%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%205%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%206%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%207%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%208%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%209%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2010%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2011%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2013%20%E8%A1%8C%EF%BC%9Agoto%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2015%20%E8%A1%8C%3A%20%3ANOJAVA%3A%20%E6%89%BE%E4%B8%8D%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%20java%EF%BC%9A%20%25JAVA%25%3CBR%20%2F%3E%20C%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2017%20%E8%A1%8C%EF%BC%9AEXIT%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2019%20%E8%A1%8C%3A%3ANOWINDOWS%3A%20%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Atresos%20%E4%BB%85%E5%9C%A8%20Windows2000%20%E5%92%8C%20Windows%2FXP%20%E4%B8%8A%E8%BF%90%E8%A1%8C%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2021%20%E8%A1%8C%EF%BC%9AEXIT%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2023%20%E8%A1%8C%3A%3ASTART%3A%20%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2024%20%E8%A1%8C%EF%BC%9AREM%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2025%20%E8%A1%8C%EF%BC%9ASET%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2026%20%E8%A1%8C%EF%BC%9ASET%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%EF%BC%9A%E7%AC%AC%2048%20%E8%A1%8C%EF%BC%9A%E6%9F%A5%E6%89%BE%E5%8C%B9%E9%85%8D%E7%9A%84%E2%80%9C%E2%80%9D%E6%97%B6%E5%87%BA%E7%8E%B0%E6%84%8F%E5%A4%96%E7%9A%84%20EOF%3CBR%20%2F%3E%20C%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%EF%BC%9A%E7%AC%AC%2054%20%E8%A1%8C%EF%BC%9A%E8%AF%AD%E6%B3%95%E9%94%99%E8%AF%AF%EF%BC%9A%E6%96%87%E4%BB%B6%E6%84%8F%E5%A4%96%E7%BB%93%E6%9D%9F%3CBR%20%2F%3EMakefile%EF%BC%9A647%EF%BC%9A%E7%9B%AE%E6%A0%87%E2%80%9C%E7%94%9F%E6%88%90%E2%80%9D%E7%9A%84%E9%85%8D%E6%96%B9%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3Emake%EF%BC%9A%5B%E7%94%9F%E6%88%90%5D%20%E9%94%99%E8%AF%AF%202%EF%BC%88%E5%B7%B2%E5%BF%BD%E7%95%A5%EF%BC%89%3CBR%20%2F%3E%20C%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%20-data%20C%3A%2FEB%2Ftresos%2Fbin%2Fworkspace%20%E8%87%AA%E5%8A%A8%E9%85%8D%E7%BD%AE%20MasterProject_RDB3GenerateAllVariants%202%26gt%3B%26amp%3B1%3CBR%20%2F%3E%20C%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%201%20%E8%A1%8C%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F3933%22%20target%3D%22_blank%22%3E%40echo%3C%2FA%3E%20%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%202%20%E8%A1%8C%EF%BC%9AREM%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%204%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%205%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%206%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%207%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%208%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%209%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2010%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2011%20%E8%A1%8C%EF%BC%9A%E5%A6%82%E6%9E%9C%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2013%20%E8%A1%8C%EF%BC%9Agoto%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2015%20%E8%A1%8C%3A%20%3ANOJAVA%3A%20%E6%89%BE%E4%B8%8D%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%20java%EF%BC%9A%20%25JAVA%25%3CBR%20%2F%3E%20C%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2017%20%E8%A1%8C%EF%BC%9AEXIT%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2019%20%E8%A1%8C%3A%3ANOWINDOWS%3A%20%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Atresos%20%E4%BB%85%E5%9C%A8%20Windows2000%20%E5%92%8C%20Windows%2FXP%20%E4%B8%8A%E8%BF%90%E8%A1%8C%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2021%20%E8%A1%8C%EF%BC%9AEXIT%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2023%20%E8%A1%8C%3A%3ASTART%3A%20%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2024%20%E8%A1%8C%EF%BC%9AREM%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2025%20%E8%A1%8C%EF%BC%9ASET%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%3A%20%E7%AC%AC%2026%20%E8%A1%8C%EF%BC%9ASET%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3EC%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%EF%BC%9A%E7%AC%AC%2048%20%E8%A1%8C%EF%BC%9A%E6%9F%A5%E6%89%BE%E5%8C%B9%E9%85%8D%E7%9A%84%E2%80%9C%E2%80%9D%E6%97%B6%E5%87%BA%E7%8E%B0%E6%84%8F%E5%A4%96%E7%9A%84%20EOF%3CBR%20%2F%3E%20C%3A%2FEB%2Ftresos%2Fbin%2Ftresos_cmd.bat%EF%BC%9A%E7%AC%AC%2054%20%E8%A1%8C%EF%BC%9A%E8%AF%AD%E6%B3%95%E9%94%99%E8%AF%AF%EF%BC%9A%E6%96%87%E4%BB%B6%E6%84%8F%E5%A4%96%E7%BB%93%E6%9D%9F%3CBR%20%2F%3EMakefile%EF%BC%9A647%EF%BC%9A%E7%9B%AE%E6%A0%87%E2%80%9C%E7%94%9F%E6%88%90%E2%80%9D%E7%9A%84%E9%85%8D%E6%96%B9%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3Emake%EF%BC%9A***%20%5B%E7%94%9F%E6%88%90%5D%20%E9%94%99%E8%AF%AF%202%3C%2FP%3E%3CP%3EC%3A%5CEB%5Ctresos%5Cbin%5Cworkspace%26gt%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%8A%E4%BC%A0%E7%9B%B8%E5%85%B3%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BB%A5%E9%98%B2%E4%B8%87%E4%B8%80%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1880216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APFE%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%E7%9A%84%20makefile%20%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1880216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%40%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210937%22%20target%3D%22_blank%22%3EYoungsoo_do%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E5%AE%9D%E8%B4%B5%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1879757%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APFE%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%E7%9A%84%20makefile%20%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1879757%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E4%B8%AA%E7%AD%94%E6%A1%88%E5%B9%B6%E4%B8%8D%E6%98%AF%E9%97%AE%E9%A2%98%E7%9A%84%E6%A0%B9%E6%9C%AC%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%E7%AD%94%E6%A1%88%E6%98%AF%3C%2FP%3E%3CP%3EC%3A%5CNXP%5CS32DS.3.5%5CS32DS%5Cbuild_tools%5Cgcc_v9.2%5Cgcc-9.2-arm32-eabi%5Carm-none-eabi%5Cnewlib%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E5%8E%BB%E9%82%A3%E9%87%8C%EF%BC%8C%E4%BD%A0%E4%BC%9A%E5%8F%91%E7%8E%B0%E4%B8%80%E4%B8%AA%E5%90%8D%E4%B8%BA%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E6%96%B0%E5%BA%93%3C%2FSTRONG%3E%E3%80%82%E4%BD%A0%E6%94%B9%E5%8F%98%E8%BF%99%E4%B8%AA%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E6%96%B0%E5%9B%BE%E4%B9%A6%E9%A6%86%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%88%B0%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E5%BA%93%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%8A%B1%E4%BA%86%E5%87%A0%E5%A4%A9%E7%9A%84%E6%97%B6%E9%97%B4%E6%9D%A5%E8%A7%A3%E5%86%B3%E6%AD%A4%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1878505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APFE%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%E7%9A%84%20makefile%20%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1878505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%AF%B9%E4%BA%8E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E8%BF%9B%E5%85%A5%E8%AF%A5%E9%A1%B5%E9%9D%A2%EF%BC%8C%E4%B8%8B%E8%BD%BD%E4%BA%86%3CSTRONG%3EArm%20GNU%20Toolchain%3C%2FSTRONG%3E%20%EF%BC%8C%E5%B9%B6%E5%9C%A8%3CSTRONG%3Emakefile%3C%2FSTRONG%3E%E4%B8%AD%E5%B0%86%E8%B7%AF%E5%BE%84%E6%9B%B4%E6%94%B9%E4%B8%BA%3CSTRONG%3EGCC_DIR%3C%2FSTRONG%3E%20%EF%BC%8C%E4%BB%8E%E8%80%8C%E8%A7%A3%E5%86%B3%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fdeveloper.arm.com%2Fdownloads%2F-%2Farm-gnu-toolchain-downloads%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdeveloper.arm.com%2Fdownloads%2F-%2Farm-gnu-toolchain-downloads%3C%2FA%3E%3C%2FP%3E%3CP%3E%EF%BC%88%E6%88%91%E5%B8%8C%E6%9C%9B%E5%AE%83%E8%83%BD%E5%AF%B9%E6%9C%89%E5%92%8C%E6%88%91%E7%B1%BB%E4%BC%BC%E9%97%AE%E9%A2%98%E7%9A%84%E4%BA%BA%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%EF%BC%89%3C%2FP%3E%3CP%3E%E4%BD%86%E6%88%91%E8%BF%98%E6%9C%89%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E2%80%94%E2%80%94%E5%AE%83%E6%B0%B8%E6%97%A0%E6%AD%A2%E5%A2%83%E3%80%82%E6%88%91%E5%BF%85%E9%A1%BB%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E6%A1%88%E4%BE%8B%E6%9D%A5%E6%8F%90%E5%87%BA%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%AF%B9%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1877890%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APFE%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%E7%9A%84%20makefile%20%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1877890%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%88%91%E5%B0%9D%E8%AF%95%E6%8C%89%E7%85%A7%E6%82%A8%E5%BB%BA%E8%AE%AE%E7%9A%84%E6%96%B9%E5%BC%8F%E5%8E%BB%E5%81%9A%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E5%9C%A8%3CSTRONG%3E%E2%80%9Cmake%20build%E2%80%9D%3C%2FSTRONG%3E%E5%91%BD%E4%BB%A4%E4%B8%AD%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%9E%84%E5%BB%BA%E7%BB%93%E6%9D%9F%E6%97%B6%E6%98%BE%E7%A4%BA%E6%96%87%E4%BB%B6%3CSTRONG%3E%E2%80%9Cnosys.specs%E2%80%9D%3C%2FSTRONG%3E%E6%9C%AA%E6%89%BE%E5%88%B0%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%9C%89%E8%B0%81%E7%9F%A5%E9%81%93%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%E6%96%B9%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%24%20make%20buil%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fisa.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FEth_PFE_LLD.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci_core_autosar.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FSerdes_Ipw_PBCfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_bus_err_csr.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FEth_43_PFE_VS_0_PBcfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffifo.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_ecc_err_csr.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Felf.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FRtc_Ip_VS_0_PBcfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_rtable.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FPlatform_Ipw_Cfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci_rt_db.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_tmu.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_emac_slave.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci_fp.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci_mirror.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FPlatform_Cfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_emac_csr.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_phy_if.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_bus_err.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FDma_Ip_VS_0_PBcfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Flibfci_autosar.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci_qos.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_host_fail_stop_csr.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci_l2br_domains.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_wdt_csr.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_fw_feature.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FOsIf_Cfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_hm.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FSerdes_Ip_PBCfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Foal_irq_autosar.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FClock_Ip_Cfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FPower_Ip_VS_0_PBcfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_hif_ring.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Foal_time_autosar.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_fw_fail_stop_csr.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_log_if.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FIntCtrl_Ip_Cfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_emac.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_gpi_csr.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci_routes.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FGpt_VS_0_PBcfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_class.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_bmu.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_minihif_drv.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_hif_nocpy_csr.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_log_if_slave.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FSiul2_Port_Ip_VS_0_PBcfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_platform_slave.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FPort_Cfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_l2br_table.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FMcu_VS_0_PBcfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_phy_if_slave.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fnxp_snprintf.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci_l2br.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_fw_fail_stop.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FRam_Ip_Cfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FMcu_Cfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_gpi.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_host_fail_stop.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Foal_job_autosar.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_util.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FFtm_Gpt_Ip_VS_0_PBcfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci_connections.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_if_db.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FEth_43_PFE_Cfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_bmu_csr.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_fail_stop_csr.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_l2br.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FCDD_Mcl_Cfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FStm_Ip_VS_0_PBcfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_feature_mgr.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_util_csr.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FGpt_Ipw_VS_0_PBcfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_hw_feature.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_idex.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_hif_ptp.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci_fp_db.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FDma_Ip_Cfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_hif_csr.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_fail_stop.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_fp.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_mirror.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_platform_master.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Foal_mm_autosar.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_parity_csr.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_wdt.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FPower_Ip_Cfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Foal_util_net_autosar.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_hif_chnl.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FSerdes_Cfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FClock_Ip_VS_0_PBcfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci_interfaces.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_hif.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci_owner.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci_fw_features.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FEth_43_PFE_Irq.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_hif_drv.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_class_csr.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FEth_43_PFE.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FEthIf_Cbk.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_parity.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FCDD_Mcl_VS_0_PBcfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FPit_Ip_VS_0_PBcfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_hif_nocpy.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci_hm.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FPort_VS_0_PBcfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_ecc_err.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Foal_util_autosar.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_pe.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_mac_db.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fblalloc.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fautolibc.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FGpt_Cfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Ffci_timer_owner.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2FRam_Ip_VS_0_PBcfg.c%3CBR%20%2F%3ECC%20generate_RDB3%2Fsrc%2Fpfe_tmu_csr.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FPlatform_TS_T40D11M40I2R0%2Fstartup%2Fsrc%2Fnvic.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FPlatform_TS_T40D11M40I2R0%2Fstartup%2Fsrc%2Fsys_init.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FPlatform_TS_T40D11M40I2R0%2Fstartup%2Fsrc%2Fsystem.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FPlatform_TS_T40D11M40I2R0%2Fstartup%2Fsrc%2Fm7%2Fstartup.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FPlatform_TS_T40D11M40I2R0%2Fstartup%2Fsrc%2Fm7%2Fexceptions.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FBaseNXP_TS_T40D11M40I2R0%2Fsrc%2FOsIf_Interrupts.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FBaseNXP_TS_T40D11M40I2R0%2Fsrc%2FOsIf_Timer_System.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FBaseNXP_TS_T40D11M40I2R0%2Fsrc%2FOsIf_Timer_System_Internal_Systick.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FBaseNXP_TS_T40D11M40I2R0%2Fsrc%2FOsIf_Timer.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FBaseNXP_TS_T40D11M40I2R0%2Fsrc%2FOsIf_Timer_System_Internal_GenericTimer.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FDet_TS_T40D11M40I2R0%2Fsrc%2FDet_stub.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FDet_TS_T40D11M40I2R0%2Fsrc%2FDet.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FDem_TS_T40D11M40I2R0%2Fsrc%2FDem_stub.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FDem_TS_T40D11M40I2R0%2Fsrc%2FDem.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FGpt_TS_T40D11M40I2R0%2Fsrc%2FGpt.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FGpt_TS_T40D11M40I2R0%2Fsrc%2FPit_Ip.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FGpt_TS_T40D11M40I2R0%2Fsrc%2FFtm_Gpt_Ip.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FGpt_TS_T40D11M40I2R0%2Fsrc%2FStm_Ip.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FGpt_TS_T40D11M40I2R0%2Fsrc%2FRtc_Ip.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FGpt_TS_T40D11M40I2R0%2Fsrc%2FGpt_Ipw.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_Selector.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_Data.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_Data2.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_Frequency2.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_Specific.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FPower_Ip.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_ExtOsc.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_Frequency1.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_Specific2.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_Irq.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_Frequency.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FPower_Ip_CortexM7.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FMcu_Dem_Wrapper.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_Gate.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FRam_Ip.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_Data1.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_FracDiv.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_DividerTrigger.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_IntOsc.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FPower_Ip_CortexA.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_Specific1.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FPower_Ip_PMC.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FPower_Ip_MSCM.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_Monitor.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FMcu_Ipw.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_Divider.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FPower_Ip_Private.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FPower_Ip_MC_ME.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_ProgFreqSwitch.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FClock_Ip_Pll.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FPower_Ip_MC_RGM.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FMcu.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FMcu_TS_T40D11M40I2R0%2Fsrc%2FPower_Ip_MC_RGM_Irq.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Icu.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Fee.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Ocu.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Pmic.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Fr_43_LLCE.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Pwm.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Uart.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Fls.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Eth.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_I2c.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Port.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_EthTrcv_43_PHY.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Gpt.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Mcu.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Spi.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Can_43_LLCE.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Fr.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Ocotp.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Thermal.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Eth_43_PFE.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_EthSwt_43_SJA11XX.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Eep.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Mcl.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Adc.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Wdg.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Dio.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Qdec.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Serdes.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Rm.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Crypto.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Can.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Lin.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_CanTrcv_tja115x.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Ipcf.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Wdg_43_VR5510.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FRte_TS_T40D11M40I2R0%2Fsrc%2FSchM_Crc.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FPort_TS_T40D11M40I2R0%2Fsrc%2FSiul2_Port_Ip.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FPort_TS_T40D11M40I2R0%2Fsrc%2FPort.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FPort_TS_T40D11M40I2R0%2Fsrc%2FPort_Ipw.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FPlatform_TS_T40D11M40I2R0%2Fsrc%2FSystem_Ip.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FPlatform_TS_T40D11M40I2R0%2Fsrc%2FIntCtrl_Ip.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FPlatform_TS_T40D11M40I2R0%2Fsrc%2FPlatform_Ipw.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FPlatform_TS_T40D11M40I2R0%2Fsrc%2FPlatform.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FEthSwt_TS_T40D11M40I2R0%2Fsrc%2FEthSwt.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FEthTrcv_TS_T40D11M40I2R0%2Fsrc%2FEthTrcv.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FSerdes_TS_T40D11M40I2R0%2Fsrc%2FSerdes_Ip_HwAccess.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FSerdes_TS_T40D11M40I2R0%2Fsrc%2FSerdes.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FSerdes_TS_T40D11M40I2R0%2Fsrc%2FSerdes_Ipw.c%3CBR%20%2F%3ECC%20C%3A%2FNXP%2FSW32G_RTD_4.4_4.0.2%2Feclipse%2Fplugins%2FSerdes_TS_T40D11M40I2R0%2Fsrc%2FSerdes_Ip.c%3CBR%20%2F%3ELD%20output_RDB3%2Fmain_RDB3.elf%3CBR%20%2F%3EC%3A%2FNXP%2FS32DS.3.5%2FS32DS%2Fbuild_tools%2Fgcc_v9.2%2Fgcc-9.2-arm32-eabi%2Fbin%2Farm-none-eabi-gcc.exe%20--entry%3DReset_Handler%20-Tlinker%2Flinker_maste%3CBR%20%2F%3Er_app%2Fautosar_intram.gld%20--sysroot%3D%22C%3A%2FNXP%2FS32DS.3.5%2FS32DS%2Fbuild_tools%2Fgcc_v9.2%2Fgcc-9.2-arm32-eabi%2Farm-none-eabi%2Fnewlib%22%20-specs%3Dnano%3CBR%20%2F%3E.specs%20-specs%3Dnosys.specs%20-nostartfiles%20-mcpu%3Dcortex-m7%20-mthumb%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-ggdb3%20-Wl%2C-Map%2Coutput_RDB3%2Fmain_%3CBR%20%2F%3ERDB3.map%20-lc%20-lm%20-lgcc%20-mlittle-endian%20output_RDB3%2Fisa.o%20output_RDB3%2FEth_PFE_LLD.o%20output_RDB3%2Ffci.o%20output_RDB3%2Ffci_core_autosar.o%3CBR%20%2F%3Eoutput_RDB3%2FSerdes_Ipw_PBCfg.o%20output_RDB3%2Fpfe_bus_err_csr.o%20output_RDB3%2FEth_43_PFE_VS_0_PBcfg.o%20output_RDB3%2Ffifo.o%20output_RDB3%2Fpfe_%3CBR%20%2F%3Eecc_err_csr.o%20output_RDB3%2Felf.o%20output_RDB3%2FRtc_Ip_VS_0_PBcfg.o%20output_RDB3%2Fpfe_rtable.o%20output_RDB3%2FPlatform_Ipw_Cfg.o%20output_RDB3%2F%3CBR%20%2F%3Efci_rt_db.o%20output_RDB3%2Fpfe_tmu.o%20output_RDB3%2Fpfe_emac_slave.o%20output_RDB3%2Ffci_fp.o%20output_RDB3%2Ffci_mirror.o%20output_RDB3%2FPlatform_Cf%3CBR%20%2F%3Eg.o%20output_RDB3%2Fpfe_emac_csr.o%20output_RDB3%2Fpfe_phy_if.o%20output_RDB3%2Fpfe_bus_err.o%20output_RDB3%2FDma_Ip_VS_0_PBcfg.o%20output_RDB3%2Flibfci%3CBR%20%2F%3E_autosar.o%20output_RDB3%2Ffci_qos.o%20output_RDB3%2Fpfe_host_fail_stop_csr.o%20output_RDB3%2Ffci_l2br_domains.o%20output_RDB3%2Fpfe_wdt_csr.o%20outpu%3CBR%20%2F%3Et_RDB3%2Fpfe_fw_feature.o%20output_RDB3%2FOsIf_Cfg.o%20output_RDB3%2Fpfe_hm.o%20output_RDB3%2FSerdes_Ip_PBCfg.o%20output_RDB3%2Foal_irq_autosar.o%20outp%3CBR%20%2F%3Eut_RDB3%2FClock_Ip_Cfg.o%20output_RDB3%2FPower_Ip_VS_0_PBcfg.o%20output_RDB3%2Fpfe_hif_ring.o%20output_RDB3%2Foal_time_autosar.o%20output_RDB3%2Fpfe_f%3CBR%20%2F%3Ew_fail_stop_csr.o%20output_RDB3%2Fpfe_log_if.o%20output_RDB3%2FIntCtrl_Ip_Cfg.o%20output_RDB3%2Fpfe_emac.o%20output_RDB3%2Fpfe_gpi_csr.o%20output_RDB3%3CBR%20%2F%3E%2Ffci_routes.o%20output_RDB3%2FGpt_VS_0_PBcfg.o%20output_RDB3%2Fpfe_class.o%20output_RDB3%2Fpfe_bmu.o%20output_RDB3%2Fpfe_minihif_drv.o%20output_RDB3%2Fp%3CBR%20%2F%3Efe_hif_nocpy_csr.o%20output_RDB3%2Fpfe_log_if_slave.o%20output_RDB3%2FSiul2_Port_Ip_VS_0_PBcfg.o%20output_RDB3%2Fpfe_platform_slave.o%20output_RDB%3CBR%20%2F%3E3%2FPort_Cfg.o%20output_RDB3%2Fpfe_l2br_table.o%20output_RDB3%2FMcu_VS_0_PBcfg.o%20output_RDB3%2Fpfe_phy_if_slave.o%20output_RDB3%2Fnxp_snprintf.o%20out%3CBR%20%2F%3Eput_RDB3%2Ffci_l2br.o%20output_RDB3%2Fpfe_fw_fail_stop.o%20output_RDB3%2FRam_Ip_Cfg.o%20output_RDB3%2FMcu_Cfg.o%20output_RDB3%2Fpfe_gpi.o%20output_RDB3%2F%3CBR%20%2F%3Epfe_host_fail_stop.o%20output_RDB3%2Foal_job_autosar.o%20output_RDB3%2Fpfe_util.o%20output_RDB3%2FFtm_Gpt_Ip_VS_0_PBcfg.o%20output_RDB3%2Ffci_connec%3CBR%20%2F%3Etions.o%20output_RDB3%2Fpfe_if_db.o%20output_RDB3%2FEth_43_PFE_Cfg.o%20output_RDB3%2Fpfe_bmu_csr.o%20output_RDB3%2Fpfe_fail_stop_csr.o%20output_RDB3%2Fp%3CBR%20%2F%3Efe_l2br.o%20output_RDB3%2FCDD_Mcl_Cfg.o%20output_RDB3%2FStm_Ip_VS_0_PBcfg.o%20output_RDB3%2Fpfe_feature_mgr.o%20output_RDB3%2Fpfe_util_csr.o%20output_%3CBR%20%2F%3ERDB3%2FGpt_Ipw_VS_0_PBcfg.o%20output_RDB3%2Fpfe_hw_feature.o%20output_RDB3%2Fpfe_idex.o%20output_RDB3%2Fpfe_hif_ptp.o%20output_RDB3%2Ffci_fp_db.o%20outp%3CBR%20%2F%3Eut_RDB3%2FDma_Ip_Cfg.o%20output_RDB3%2Fpfe_hif_csr.o%20output_RDB3%2Fpfe_fail_stop.o%20output_RDB3%2Fpfe_fp.o%20output_RDB3%2Fpfe_mirror.o%20output_RDB3%3CBR%20%2F%3E%2Fpfe_platform_master.o%20output_RDB3%2Foal_mm_autosar.o%20output_RDB3%2Fpfe_parity_csr.o%20output_RDB3%2Fpfe_wdt.o%20output_RDB3%2FPower_Ip_Cfg.o%20ou%3CBR%20%2F%3Etput_RDB3%2Foal_util_net_autosar.o%20output_RDB3%2Fpfe_hif_chnl.o%20output_RDB3%2FSerdes_Cfg.o%20output_RDB3%2FClock_Ip_VS_0_PBcfg.o%20output_RDB3%2Ff%3CBR%20%2F%3Eci_interfaces.o%20output_RDB3%2Fpfe_hif.o%20output_RDB3%2Ffci_owner.o%20output_RDB3%2Ffci_fw_features.o%20output_RDB3%2FEth_43_PFE_Irq.o%20output_RDB3%3CBR%20%2F%3E%2Fpfe_hif_drv.o%20output_RDB3%2Fpfe_class_csr.o%20output_RDB3%2FEth_43_PFE.o%20output_RDB3%2FEthIf_Cbk.o%20output_RDB3%2Fpfe_parity.o%20output_RDB3%2FCDD%3CBR%20%2F%3E_Mcl_VS_0_PBcfg.o%20output_RDB3%2FPit_Ip_VS_0_PBcfg.o%20output_RDB3%2Fpfe_hif_nocpy.o%20output_RDB3%2Ffci_hm.o%20output_RDB3%2FPort_VS_0_PBcfg.o%20out%3CBR%20%2F%3Eput_RDB3%2Fpfe_ecc_err.o%20output_RDB3%2Foal_util_autosar.o%20output_RDB3%2Fpfe_pe.o%20output_RDB3%2Fpfe_mac_db.o%20output_RDB3%2Fblalloc.o%20output_RDB%3CBR%20%2F%3E3%2Fautolibc.o%20output_RDB3%2FGpt_Cfg.o%20output_RDB3%2Ffci_timer_owner.o%20output_RDB3%2FRam_Ip_VS_0_PBcfg.o%20output_RDB3%2Fpfe_tmu_csr.o%20output_RD%3CBR%20%2F%3EB3%2Fnvic.o%20output_RDB3%2Fsys_init.o%20output_RDB3%2Fsystem.o%20output_RDB3%2Fstartup.o%20output_RDB3%2Fexceptions.o%20output_RDB3%2FOsIf_Interrupts.o%20o%3CBR%20%2F%3Eutput_RDB3%2FOsIf_Timer_System.o%20output_RDB3%2FOsIf_Timer_System_Internal_Systick.o%20output_RDB3%2FOsIf_Timer.o%20output_RDB3%2FOsIf_Timer_Syst%3CBR%20%2F%3Eem_Internal_GenericTimer.o%20output_RDB3%2FDet_stub.o%20output_RDB3%2FDet.o%20output_RDB3%2FDem_stub.o%20output_RDB3%2FDem.o%20output_RDB3%2FGpt.o%20outpu%3CBR%20%2F%3Et_RDB3%2FPit_Ip.o%20output_RDB3%2FFtm_Gpt_Ip.o%20output_RDB3%2FStm_Ip.o%20output_RDB3%2FRtc_Ip.o%20output_RDB3%2FGpt_Ipw.o%20output_RDB3%2FClock_Ip_Select%3CBR%20%2F%3Eor.o%20output_RDB3%2FClock_Ip_Data.o%20output_RDB3%2FClock_Ip_Data2.o%20output_RDB3%2FClock_Ip_Frequency2.o%20output_RDB3%2FClock_Ip_Specific.o%20outp%3CBR%20%2F%3Eut_RDB3%2FPower_Ip.o%20output_RDB3%2FClock_Ip_ExtOsc.o%20output_RDB3%2FClock_Ip.o%20output_RDB3%2FClock_Ip_Frequency1.o%20output_RDB3%2FClock_Ip_Speci%3CBR%20%2F%3Efic2.o%20output_RDB3%2FClock_Ip_Irq.o%20output_RDB3%2FClock_Ip_Frequency.o%20output_RDB3%2FPower_Ip_CortexM7.o%20output_RDB3%2FMcu_Dem_Wrapper.o%20out%3CBR%20%2F%3Eput_RDB3%2FClock_Ip_Gate.o%20output_RDB3%2FRam_Ip.o%20output_RDB3%2FClock_Ip_Data1.o%20output_RDB3%2FClock_Ip_FracDiv.o%20output_RDB3%2FClock_Ip_Divid%3CBR%20%2F%3EerTrigger.o%20output_RDB3%2FClock_Ip_IntOsc.o%20output_RDB3%2FPower_Ip_CortexA.o%20output_RDB3%2FClock_Ip_Specific1.o%20output_RDB3%2FPower_Ip_PMC.o%3CBR%20%2F%3Eoutput_RDB3%2FPower_Ip_MSCM.o%20output_RDB3%2FClock_Ip_Monitor.o%20output_RDB3%2FMcu_Ipw.o%20output_RDB3%2FClock_Ip_Divider.o%20output_RDB3%2FPower_I%3CBR%20%2F%3Ep_Private.o%20output_RDB3%2FPower_Ip_MC_ME.o%20output_RDB3%2FClock_Ip_ProgFreqSwitch.o%20output_RDB3%2FClock_Ip_Pll.o%20output_RDB3%2FPower_Ip_MC_RG%3CBR%20%2F%3EM.o%20output_RDB3%2FMcu.o%20output_RDB3%2FPower_Ip_MC_RGM_Irq.o%20output_RDB3%2FSchM_Icu.o%20output_RDB3%2FSchM_Fee.o%20output_RDB3%2FSchM_Ocu.o%20output_%3CBR%20%2F%3ERDB3%2FSchM_Pmic.o%20output_RDB3%2FSchM_Fr_43_LLCE.o%20output_RDB3%2FSchM_Pwm.o%20output_RDB3%2FSchM_Uart.o%20output_RDB3%2FSchM_Fls.o%20output_RDB3%2FSch%3CBR%20%2F%3EM_Eth.o%20output_RDB3%2FSchM_I2c.o%20output_RDB3%2FSchM_Port.o%20output_RDB3%2FSchM_EthTrcv_43_PHY.o%20output_RDB3%2FSchM_Gpt.o%20output_RDB3%2FSchM_Mcu%3CBR%20%2F%3E.o%20output_RDB3%2FSchM_Spi.o%20output_RDB3%2FSchM_Can_43_LLCE.o%20output_RDB3%2FSchM_Fr.o%20output_RDB3%2FSchM_Ocotp.o%20output_RDB3%2FSchM_Thermal.o%20o%3CBR%20%2F%3Eutput_RDB3%2FSchM_Eth_43_PFE.o%20output_RDB3%2FSchM_EthSwt_43_SJA11XX.o%20output_RDB3%2FSchM_Eep.o%20output_RDB3%2FSchM_Mcl.o%20output_RDB3%2FSchM_Adc%3CBR%20%2F%3E.o%20output_RDB3%2FSchM_Wdg.o%20output_RDB3%2FSchM_Dio.o%20output_RDB3%2FSchM_Qdec.o%20output_RDB3%2FSchM_Serdes.o%20output_RDB3%2FSchM_Rm.o%20output_RDB3%3CBR%20%2F%3E%2FSchM_Crypto.o%20output_RDB3%2FSchM_Can.o%20output_RDB3%2FSchM_Lin.o%20output_RDB3%2FSchM_CanTrcv_tja115x.o%20output_RDB3%2FSchM_Ipcf.o%20output_RDB3%2F%3CBR%20%2F%3ESchM_Wdg_43_VR5510.o%20output_RDB3%2FSchM_Crc.o%20output_RDB3%2FSiul2_Port_Ip.o%20output_RDB3%2FPort.o%20output_RDB3%2FPort_Ipw.o%20output_RDB3%2FSystem%3CBR%20%2F%3E_Ip.o%20output_RDB3%2FIntCtrl_Ip.o%20output_RDB3%2FPlatform_Ipw.o%20output_RDB3%2FPlatform.o%20output_RDB3%2FEthSwt.o%20output_RDB3%2FEthTrcv.o%20output_R%3CBR%20%2F%3EDB3%2FSerdes_Ip_HwAccess.o%20output_RDB3%2FSerdes.o%20output_RDB3%2FSerdes_Ipw.o%20output_RDB3%2FSerdes_Ip.o%20output_RDB3%2Fstartup_cm7.o%20output_RDB3%3CBR%20%2F%3E%2FVector_Table.o%20-o%20output_RDB3%2Fmain_RDB3.elf%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%3CSTRONG%3Earm-none-eabi-gcc.exe%3A%20fatal%20error%3A%20cannot%20read%20spec%20file%20'nosys.specs'%3A%20No%20such%20file%20or%20directory%3C%2FSTRONG%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%3CSTRONG%3Ecompilation%20terminated.%3C%2FSTRONG%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%3CSTRONG%3EMakefile%3A627%3A%20recipe%20for%20target%20'output_RDB3%2Fmain_RDB3.elf'%20failed%3C%2FSTRONG%3E%3C%2FFONT%3E%3CBR%20%2F%3Emake%3A%20***%20%5Boutput_RDB3%2Fmain_RDB3.elf%5D%20Error%201%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220240529_185149.png%22%20style%3D%22width%3A%20935px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220240529_185149.png%22%20style%3D%22width%3A%20935px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F281451i0429BA68D22C99EC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2220240529_185149.png%22%20alt%3D%2220240529_185149.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E5%AF%B9%E4%BA%8E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%3C%2FSPAN%3E%3CSPAN%3E%20%E4%BB%8E%3C%2FSPAN%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fwww.cygwin.com%2Finstall.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%20https%3A%2F%2Fwww.cygwin.com%2Finstall.html%3C%2FA%3E%3C%2FSTRONG%3E%3CSTRONG%3E%20%E5%AE%89%E8%A3%85%E4%BA%86%20Cygwin%3C%2FSTRONG%3E%3CSTRONG%3E%20%E7%A8%8B%E5%BA%8F%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BD%BF%E7%94%A8%20Cygdrive%3C%2FSTRONG%3E%3CSPAN%3E%20%E7%94%9F%E6%88%90%E5%AE%83%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1877455%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APFE%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%E7%9A%84%20makefile%20%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1877455%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%40%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210937%22%20target%3D%22_blank%22%3EYoungsoo_do%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%8F%90%E9%97%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%9D%A5%E6%80%BB%E7%BB%93%E4%B8%80%E4%B8%8B%E6%90%AD%E5%BB%BA%E6%AD%A5%E9%AA%A4%EF%BC%8C%E4%BE%9B%E5%A4%A7%E5%AE%B6%E5%8F%82%E8%80%83%EF%BC%9A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%E5%B0%86%E4%BB%A5%E4%B8%8B%E8%BD%AF%E4%BB%B6%E5%8C%85%20SW32G_RTD_4.4_4.0.2%E3%80%81PFE-DRV_S32G_M7_MCAL_1.2.0%E3%80%81PFE-FW_S32G_1.7.1%20%E5%AE%89%E8%A3%85%E5%88%B0%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9C%BA%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E5%9C%A8%20%24EB_PATH%2Flinks%20%E4%B8%8B%E5%88%9B%E5%BB%BA%E9%93%BE%E6%8E%A5%E6%96%87%E4%BB%B6%EF%BC%8C%E5%86%85%E5%AE%B9%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E8%B7%AF%E5%BE%84%3D%24SW32G_RTD_4.4_4.0.2_PATH%3C%2FP%3E%0A%3COL%20start%3D%223%22%3E%0A%3CLI%3E%E5%B0%86%E6%8F%92%E4%BB%B6%E4%BB%8E%20PFE%20DIR%3A%20Eth_43%E2%80%A6.%20%E5%A4%8D%E5%88%B6%E5%88%B0%20%24SW32G_RTD_4.4_4.0.2_PATH%2Feclipse%2Fplugins%3C%2FLI%3E%0A%3CLI%3E%E5%B0%86%E9%A1%B9%E7%9B%AE%EF%BC%9AMasterProject_RDB3%20%E5%AF%BC%E5%85%A5%E5%88%B0%20EB%3C%2FLI%3E%0A%3CLI%3E%E9%80%9A%E8%BF%87EB%E7%94%9F%E6%88%90%E5%B7%A5%E7%A8%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E9%BB%98%E8%AE%A4%E4%BB%A3%E7%A0%81%E8%B7%AF%E5%BE%84%E5%A6%82%E4%B8%8B%E5%9B%BE%EF%BC%9A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1716999603822.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1716999603822.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F281542i5E12D791A27C4B97%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1716999603822.png%22%20alt%3D%22chenyin_h_0-1716999603822.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%90%E5%8A%9F%E7%94%9F%E6%88%90%E5%90%8E%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E5%B0%86%20generate_RDB3%2F*%20%E5%A4%8D%E5%88%B6%E5%88%B0%20%24PFE-DRV_S32G_M7_MCAL_1.2.0%5Cexample_application%3C%2FP%3E%0A%3COL%20start%3D%226%22%3E%0A%3CLI%3E%E6%89%93%E5%BC%80%20project_parameters.mk%EF%BC%8C%E8%87%B3%E5%B0%91%E4%BF%AE%E6%94%B9%E4%BB%A5%E4%B8%8B%E9%83%A8%E5%88%86%EF%BC%9A%E6%A0%B9%E6%8D%AE%E6%82%A8%E7%9A%84%E5%AE%89%E8%A3%85%E6%9B%B4%E6%94%B9%E8%B7%AF%E5%BE%84%E3%80%82%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3EGCC_DIR%EF%BC%9F%3Dc%3A%2FNXP%2FS32DS.3.5%2FS32DS%2Fbuild_tools%2Fgcc_v9.2%2Fgcc-9.2-arm32-eabi%23%E5%8F%96%E5%86%B3%E4%BA%8E%E4%BD%A0%E7%9A%84%E8%B7%AF%E5%BE%84%3C%2FP%3E%0A%3CP%3ETRESOS_DIR%20%3F%3DC%3A%2FEB%2Ftresos%20%23EB%E5%AE%89%E8%A3%85%E8%B7%AF%E5%BE%84%3C%2FP%3E%0A%3CP%3EPLUGINS_DIR%20%3F%3D%20%24RTD_4.0.2_installation_path%2Feclipse%2Fplugins%3C%2FP%3E%0A%3CP%3ETRESOS_WORKSPACE_DIR%20%3F%3D%20%24(TRESOS_DIR)%2F%E5%B7%A5%E4%BD%9C%E5%8C%BA%3C%2FP%3E%0A%3CP%3EFW_DIR%20%3F%3D%20%24pfe_FW_%E5%AE%89%E8%A3%85%E8%B7%AF%E5%BE%84%3C%2FP%3E%0A%3COL%20start%3D%227%22%3E%0A%3CLI%3E%E9%80%9A%E8%BF%87%E8%BE%93%E5%85%A5%E2%80%9Cmake%20HW%3DRDB3%E2%80%9D%E6%9D%A5%E6%9E%84%E5%BB%BA%E9%A1%B9%E7%9B%AE%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E6%9C%89%E5%B8%AE%E5%8A%A9%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E
