bitbake stuck
bitbake stuck
2,029件の閲覧回数
Abhiram_m_s
I am trying to build ros-image-core, but when i bitbake it, the server is stuck at 55%. i am using ubuntu 20.04 and trying to build bsp version 40.0.
Please let me know how to resolve the issue.
Thank you.
Regards.
Abhiram M S
3 返答(返信)
1,982件の閲覧回数
chenyin_h
Hello, @Abhiram_m_s
Thanks for the feedback.
1. source ./nxp-setup-alb.sh -m s32g399ardb3ubuntu
2. bitbake fsl-image-ubuntu-ros
Best Regards
Chenyin
1,994件の閲覧回数
chenyin_h
Hello, @Abhiram_m_s
Thanks for the questions
From the BSP40.0 UM, the only images that related with ROS is fsl-image-ubuntu-ros,  have you ever tried it before?
Best Regards
Chenyin
1,991件の閲覧回数
Abhiram_m_s
when i try to run fsl-image-ubuntu-ros, i am getting "Machine not supported error". I am using S32G399ARDB3 board. How do i proceed?
