debug error error code is 1303
JunSeoHan
The following error appears every time I proceed with debugging.
what should I do?
The error message says "GTA: Target Access Error." I cannot figure out what the problem is.
I am using an MCU called s32g274a and the S32 Debug Probe, a debugger provided by NXP.
Joey_z
Hi,JunSeoHan
Could you share your Debugger configuration information as the following picture?
Joey
JunSeoHan
 The debugger configuration information is as shown in the attached picture.
Joey_z
Thank you for your reply.
1.Could you test the connection state between S32G with the S32DS debugger as the following picture?
2.Do you use the customer board or the development board?
3.what is your boot configuration when you debug process?
Joey
Joey_z
Hi,JunSeoHan
Thank you for contacting us.
I will help you to check it.
Joey
