How to generate the boot loader in cli
ソリューションへジャンプ
2,280件の閲覧回数
MaximeGPwrx
This is my command :
ubuntu@maxime-NucBox-K10:/usr/local/NXP/S32DS/eclipse$ ./s32ds \
-noSplash \
-configuration /home/ubuntu/hts/output/nxp/bsp/s32ds/configuration \
-data /home/ubuntu/hts/output/nxp/bsp/s32ds/workspace \
-application com.nxp.swtools.framework.application \
--launcher.ini /usr/local/NXP/S32DS/eclipse/s32ds.ini \
-HeadlessTool IVT \
-raw_binary /home/ubuntu/hts/output/generated/app_qspi.bin \
-start_pointer_addr 0x34000000 \
-entry_pointer_addr 0x34500400 \
-ExportAB /home/ubuntu/hts/output/generated/bootloader_qspi.bin \
-SDKVersion PlatformSDK_S32XX_4_0_0 \
-MCU S32G274A_Rev2
I know that the blob command come after. Yet, I just want to create the boot loader app
I don't understand what is wrong in my command.
Every folder/file exist.
This is my last log :
Mar 12, 2026 10:43:25 AM com.nxp.swtools.utils.scripting.internal.ScriptApi logInfo
INFO: [CODEGEN] Duration for "I2c_Ip_CfgDefines.h": 21.871747ms
INFO: [CODEGEN] Generating file "Siul2_Dio_Ip_Cfg.h"
INFO: [CODEGEN] Duration for "Siul2_Dio_Ip_Cfg.h": 7.381366ms
Mar 12, 2026 10:43:25 AM com.nxp.swtools.utils.ConfigurationUtils getEclipseProject
SEVERE: Cannot get container for IPath /home/ubuntu/hts/bsp-hts.mex
SEVERE: ERROR - Export AB file: The imported image is not complete. [IVTCmdApplication.exportApplicationBootloaderImage]
SEVERE: [TOOL] Application Bootloader Image Export failed. [IVTCmdApplication.logResult]
WARNING: [DATA] Dependency source (from javascript) contains . as separator instead of : Pins.BOARD_InitPins [ScriptDependencyHelper.addDependency]
It never create my file.
2,131件の閲覧回数
MaximeGPwrx
The problem was coming from the order of the option. It should be that way :
-MCU S32G274A_Rev2
4 返答(返信)
2,132件の閲覧回数
MaximeGPwrx
-MCU S32G274A_Rev2
2,109件の閲覧回数
alejandro_e
Hello @MaximeGPwrx,
Thanks for letting me know you were  able to solve your issue.
If you have any other problem in the future please create a new post an me or one of my colleagues will support you.
Thanks.
2,246件の閲覧回数
alejandro_e
Hello @MaximeGPwrx,
Thanks for reaching out to us. I will try to copy your setup to test on my side, for that, please share the following:
  • RTD version
  • Ubuntu version
  • General file structure of your project and workspace
  • Any other relevant information of your generation/build process.
Thanks in advance.
2,270件の閲覧回数
MaximeGPwrx
I just add that I use the S32DS 3.6.5 RFP.
%3CLINGO-SUB%20id%3D%22lingo-sub-2331377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECLI%E3%81%A7%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2331377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E5%91%BD%E4%BB%A4%E3%81%A7%E3%81%99%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%20ubuntu%40maxime-NucBox-K10%3A%2Fusr%2Flocal%2FNXP%2FS32DS%2Feclipse%24%20.%2Fs32ds%5C%3C%2FP%3E%3CP%3E-noSplash%20%5C%3C%2FP%3E%3CP%3E-configuration%20%2Fhome%2Fubuntu%2Fhts%2Foutput%2Fnxp%2Fbsp%2Fs32ds%2Fconfiguration%20%5C%3C%2FP%3E%3CP%3E-data%20%2Fhome%2Fubuntu%2Fhts%2Foutput%2Fnxp%2Fbsp%2Fs32ds%2Fworkspace%20%5C%3C%2FP%3E%3CP%3E-%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20com.nxp.swtools.framework.application%20%5C%3C%2FP%3E%3CP%3E--launcher.ini%20%2Fusr%2Flocal%2FNXP%2FS32DS%2Feclipse%2Fs32ds.ini%20%5C%3C%2FP%3E%3CP%3E-HeadlessTool%20IVT%20%5C%3C%2FP%3E%3CP%3E-raw_binary%20%2Fhome%2Fubuntu%2Fhts%2Foutput%2Fgenerated%2Fapp_qspi.bin%20%5C%3C%2FP%3E%3CP%3E-start_pointer_addr%200x34000000%20%5C%3C%2FP%3E%3CP%3E-entry_pointer_addr%200x34500400%20%5C%3C%2FP%3E%3CP%3E-ExportAB%20%2Fhome%2Fubuntu%2Fhts%2Foutput%2Fgenerated%2Fbootloader_qspi.bin%20%5C%3C%2FP%3E%3CP%3E-SDKVersion%20PlatformSDK_S32XX_4_0_0%20%5C%3C%2FP%3E%3CP%3E-MCU%20S32G274A_Rev2%3CBR%20%2F%3E%3CBR%20%2F%3E%20blob%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AB%E6%9D%A5%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%88%86%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%81%84%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%AA%E5%88%86%E3%81%AE%E5%91%BD%E4%BB%A4%E3%81%AE%E3%81%A9%E3%81%93%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%2F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%202026%E5%B9%B43%E6%9C%8812%E6%97%A5%20%E5%8D%88%E5%89%8D10%E6%99%8243%E5%88%8625%E7%A7%92%20com.nxp.swtools.utils.scripting.internal.ScriptApi%20logInfo%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BCODEGEN%5D%20%22I2c_Ip_CfgDefines.h%22%20%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%99%82%E9%96%93%3A%2021.871747ms%3CBR%20%2F%3E%202026%E5%B9%B43%E6%9C%8812%E6%97%A5%20%E5%8D%88%E5%89%8D10%E6%99%8243%E5%88%8625%E7%A7%92%20com.nxp.swtools.utils.scripting.internal.ScriptApi%20logInfo%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BCODEGEN%5D%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22Siul2_Dio_Ip_Cfg.h%22%20%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E2026%E5%B9%B43%E6%9C%8812%E6%97%A5%20%E5%8D%88%E5%89%8D10%E6%99%8243%E5%88%8625%E7%A7%92%20com.nxp.swtools.utils.scripting.internal.ScriptApi%20logInfo%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%5BCODEGEN%5D%20%22Siul2_Dio_Ip_Cfg.h%22%20%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%99%82%E9%96%93%3A%207.381366ms%3CBR%20%2F%3E%202026%E5%B9%B43%E6%9C%8812%E6%97%A5%20%E5%8D%88%E5%89%8D10%E6%99%8243%E5%88%8625%E7%A7%92%20com.nxp.swtools.utils.ConfigurationUtils%20getEclipseProject%3CBR%20%2F%3E%E9%87%8D%E5%A4%A7%3A%20IPath%20%2Fhome%2Fubuntu%2Fhts%2Fbsp-hts.mex%20%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E9%87%8D%E5%A4%A7%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%20-%20AB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%3A%20%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E7%94%BB%E5%83%8F%E3%81%8C%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%A7%E3%81%99%E3%80%82%5BIVTCmdApplication.exportApplicationBootloaderImage%5D%3CBR%20%2F%3E%E9%87%8D%E5%A4%A7%3A%20%5B%E3%83%84%E3%83%BC%E3%83%AB%5D%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%5BIVTCmdApplication.logResult%5D%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%5BDATA%5D%20%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%BD%E3%83%BC%E3%82%B9%20(javascript%20%E3%81%8B%E3%82%89)%20%E3%81%AB%E3%81%AF%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%8C%BA%E5%88%87%E3%82%8A%E6%96%87%E5%AD%97%E3%81%A8%E3%81%97%E3%81%A6%20%3A%20Pins.BOARD_InitPins%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20%5BScriptDependencyHelper.addDependency%5D%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%5BDATA%5D%20%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%BD%E3%83%BC%E3%82%B9%20(javascript%20%E3%81%8B%E3%82%89)%20%E3%81%AB%E3%81%AF%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%8C%BA%E5%88%87%E3%82%8A%E6%96%87%E5%AD%97%E3%81%A8%E3%81%97%E3%81%A6%20%3A%20Pins.BOARD_InitPins%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20%5BScriptDependencyHelper.addDependency%5D%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%5BDATA%5D%20%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%BD%E3%83%BC%E3%82%B9%20(javascript%20%E3%81%8B%E3%82%89)%20%E3%81%AB%E3%81%AF%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%8C%BA%E5%88%87%E3%82%8A%E6%96%87%E5%AD%97%E3%81%A8%E3%81%97%E3%81%A6%20%3A%20Pins.BOARD_InitPins%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20%5BScriptDependencyHelper.addDependency%5D%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%5BDATA%5D%20%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%BD%E3%83%BC%E3%82%B9%20(javascript%20%E3%81%8B%E3%82%89)%20%E3%81%AB%E3%81%AF%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%8C%BA%E5%88%87%E3%82%8A%E6%96%87%E5%AD%97%E3%81%A8%E3%81%97%E3%81%A6%20%3A%20Pins.BOARD_InitPins%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20%5BScriptDependencyHelper.addDependency%5D%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%5BDATA%5D%20%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%BD%E3%83%BC%E3%82%B9%20(javascript%20%E3%81%8B%E3%82%89)%20%E3%81%AB%E3%81%AF%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%8C%BA%E5%88%87%E3%82%8A%E6%96%87%E5%AD%97%E3%81%A8%E3%81%97%E3%81%A6%20%3A%20Pins.BOARD_InitPins%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20%5BScriptDependencyHelper.addDependency%5D%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%5BDATA%5D%20%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%BD%E3%83%BC%E3%82%B9%20(javascript%20%E3%81%8B%E3%82%89)%20%E3%81%AB%E3%81%AF%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%8C%BA%E5%88%87%E3%82%8A%E6%96%87%E5%AD%97%E3%81%A8%E3%81%97%E3%81%A6%20%3A%20Pins.BOARD_InitPins%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20%5BScriptDependencyHelper.addDependency%5D%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%5BDATA%5D%20%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%BD%E3%83%BC%E3%82%B9%20(javascript%20%E3%81%8B%E3%82%89)%20%E3%81%AB%E3%81%AF%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%8C%BA%E5%88%87%E3%82%8A%E6%96%87%E5%AD%97%E3%81%A8%E3%81%97%E3%81%A6%20%3A%20Pins.BOARD_InitPins%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20%5BScriptDependencyHelper.addDependency%5D%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2331872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20generate%20the%20boot%20loader%20in%20cli%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2331872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260641%22%20target%3D%22_blank%22%3E%40MaximeGPwrx%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E7%A7%81%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3ERTD%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FLI%3E%0A%3CLI%3EUbuntu%E7%89%88%3C%2FLI%3E%0A%3CLI%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A8%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AE%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E6%A7%8B%E9%80%A0%3C%2FLI%3E%0A%3CLI%3E%E7%94%9F%E6%88%90%EF%BC%8F%E6%A7%8B%E7%AF%89%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E9%96%A2%E9%80%A3%E6%83%85%E5%A0%B1%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2331389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20generate%20the%20boot%20loader%20in%20cli%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2331389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AFS32DS%203.6.5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82RFP%EF%BC%88%E6%8F%90%E6%A1%88%E4%BE%9D%E9%A0%BC%E6%9B%B8%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2334206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20generate%20the%20boot%20loader%20in%20cli%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2334206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260641%22%20target%3D%22_blank%22%3E%40MaximeGPwrx%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EFUTURE%E4%BD%95%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E6%8A%95%E7%A8%BF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E7%A7%81%E3%81%8B%E5%90%8C%E5%83%9A%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2333706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20generate%20the%20boot%20loader%20in%20cli%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2333706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E9%A0%86%E5%BA%8F%E3%81%AB%E3%81%82%E3%81%A3%E3%81%9F%E3%80%82%E3%81%9D%E3%81%86%E3%81%82%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A0%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E-SDKVersion%20PlatformSDK_S32XX_4_0_0%20%5C%3C%2FP%3E%3CP%3E-MCU%20S32G274A_Rev2%3C%2FP%3E%3CP%3E-ExportAB%20%2Fhome%2Fubuntu%2Fhts%2Foutput%2Fgenerated%2Fbootloader_qspi.bin%20%5C%3C%2FP%3E%3CP%3E-raw_binary%20%2Fhome%2Fubuntu%2Fhts%2Foutput%2Fgenerated%2Fapp_qspi.bin%20%5C%3C%2FP%3E%3CP%3E-start_pointer_addr%200x34000000%20%5C%3C%2FP%3E%3CP%3E-entry_pointer_addr%200x34500400%3C%2FP%3E%3C%2FLINGO-BODY%3E
