S32G399A-RDB3 QNX PFE Driver Problems
Seneca
Greetings,
we try to get PFE running on a S32G399A-RDB3 board with QNX. As far as I can tell, this is a valid combination:
BSP 37.0
PFE-FW_S32G_1.7.0
PFE-DRV-S32G_A53_QNX_1.4.0
It ends with a no carrier error on all network interfaces. Plugging the cable into different ethernet ports changes nothing.
It used to work with gmac0.
Any ideas?
io pkt call:
io-pkt-v6-hc -p tcpip -d pfe-2 pfe0_mac=000a0b0c0d66,pfe1_mac=001a1b1c1d66,pfe2_mac=002a2b2c2d66,class_fw=/proc/boot/s32g_pfe_class.fw,no_reset,mode0=sgmii,phy0=0,mode1=sgmii,phy1=1
Uboot parameters:
Uboot is the same as from the Linux sdcard image with modified parmeters for qnx boot.
setenv hwconfig "pcie0:mode=rc,clock=ext;pcie1:mode=sgmii,clock=ext,fmhz=125,xpcs_mode=2G5"
setenv pfeng_mode 'enable,sgmii,sgmii,rgmii'
setenv s32cc_gmac_mode disable
setenv pfeng enable; s32ccgmac disable; s32ccgmac enable;
setenv boot_qnx_atf 'mmc dev 0; fatload mmc 0:1 0x83e00000 s32g399a-rdb3.dtb; pfeng enable; s32ccgmac disable; s32ccgmac enable; fatload mmc 0:1 0x80080000 ifs-s32g399a-rdb.ui; bootm 0x80080000 - 0x83E00000'
setenv bootcmd 'run boot_qnx_atf'
saveenv
Log:
U-Boot 2020.04+g156b168010 (Jun 09 2023 - 10:14:25 +0000)
CPU:   NXP S32G399A rev. 1.1
Model: NXP S32G399A-RDB3
DRAM:  3.5 GiB
MMC:   FSL_SDHC: 0
Loading Environment from MMC... OK
Configuring PCIe0 as RootComplex
PCIe0: Failed to get link up
PCI: Failed autoconfig bar 1c
In:    serial@401c8000
Out:   serial@401c8000
Err:   serial@401c8000
Board revision: RDB3 Revision F
Net:   EQOS phy: rgmii @ 1
Warning: eth_eqos (eth0) using random MAC address - 26:e4:e6:43:15:ad
eth0: eth_eqosFailed to get speed of XPCS for emac1_xpcs PFE: emac0: sgmii emac1: sgmii emac2: rgmii
, eth1: eth_pfeng
Hit any key to stop autoboot:  3  2  1  0
switch to partitions #0, OK
mmc0 is current device
50640 bytes read in 17 ms (2.8 MiB/s)
11948752 bytes read in 540 ms (21.1 MiB/s)
## Booting kernel from Legacy Image at 80080000 ...
   Image Name:
   Image Type:   AArch64 Linux Kernel Image (uncompressed)
   Data Size:    11948688 Bytes = 11.4 MiB
   Load Address: 80080000
   Entry Point:  80080000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 83e00000
   Booting using the fdt blob at 0x83e00000
   Loading Kernel Image
   Using Device Tree in place at 0000000083e00000, end 0000000083e0f5cf
   fixup: pfe0 set to 00:01:be:be:ef:11
   fixup: pfe1 set to 00:01:be:be:ef:22
   fixup: pfe1: update phy addr to 0x8
   fixup: pfe2 set to 00:01:be:be:ef:33
Starting kernel ...
Reserving RAM region for PFE driver on EVB/RDB
Done.
ClockCycles samples:
 0 43600679
 1 43600679
 2 43600678
 3 43600679
 4 43600678
 5 43600678
 6 43600678
 7 43600679
All ClockCycles offsets within tolerance
Welcome to QNX Neutrino 7.1.0 on the NXP S32G399A RDB Board!!
Starting watchdog...
Starting serial driver ...
Starting Networking driver (/dev/socket)...
Process 4107 (ifconfig) exited status=0.
Process 10 (sh) exited status=0.
Process 9 (dhclient) exited status=0.
cp: Can't open source file.  (/proc/boot/libfci_cli)
Process 20489 (cp) exited status=1.
Starting SPI driver (/dev/spi0,1,2,3,4,5)...
Starting I2C 0/1/2/3/4 driver (/dev/i2c0,1,2,3,4)...
Starting USDHC0 memory card driver...
[00]     SIM="SDMMC" HBA="imx"
[00,0,0] type=00 ver=05 resp=00                       SDMMC:
Process 24596 (chkqnx6fs) exited status=0.
Process 28692 (mount) exited status=0.
Starting QSPI Flash driver...
Starting USB host driver (/dev/usb/*)
Detected QSPI Flash: Macronix MX25UW512, JEDEC 0xC2 - 0x813A, Size: 0x4000000
Launching devb-umass for /dev/usb/* ...
Process 36891 (sleep) exited status=0.
sh: /var/cetitec2/startup.sh: No such file or directory
Process 45081 (sh) terminated signo=0 code=0 by process 0 value=0.
slog2info
Jan 01 00:00:00.023                       random.4                  low*     0  qcrypto: loading configuration file '/etc/qcrypto.conf' [qcrypto_common.c(190)]
Jan 01 00:00:00.024                    random.4..0                 slog*   700  Random is using the Fortuna PRNG
Jan 01 00:00:00.031                       random.4                  low      0  qcrypto: 'openssl' plugin loaded [qcrypto_plugins.c(354)]
Jan 01 00:00:00.031                    random.4..0                 slog    700  Selecting timer as an entropy source
Jan 01 00:00:00.032                    random.4..0                 slog    700  Registered path names
Jan 01 00:00:00.032                    random.4..0                 slog    700  random: starting resmgr
Jan 01 00:00:00.032                    random.4..0                 slog    700  random: Daemonizing the process
Jan 01 00:00:00.042             devc_serlinflexd.7                 slog*     0  serlinflexd_interrupt_attach: Attaching to interrupt 114
Jan 01 00:00:00.047                        iopkt.8          main_buffer*     0  tcpip starting
Jan 01 00:00:00.047                        iopkt.8          main_buffer      0  smmu support is disabled
Jan 01 00:00:00.049                        iopkt.8          main_buffer      0  initializing IPsec...
Jan 01 00:00:00.049                        iopkt.8          main_buffer      0   done
Jan 01 00:00:00.049                        iopkt.8          main_buffer      0  IPsec: Initialized Security Association Processing.
Jan 01 00:00:00.051                        iopkt.8          main_buffer      0  devnp-pfe-2.so pfe0_mac=000a0b0c0d66,pfe1_mac=001a1b1c1d66,pfe2_mac=002a2b2c2d66,class_fw=/proc/boot/s32g_pfe_class.fw,pfe0_mode=sgmii,pfe0_phy=0,pfe1_mode=sgmii,pfe1_phy=1
Jan 01 00:00:00.052                 io_pkt_v6_hc.8                 slog*     0  INF[src/pfe_drv.c:1377]: VERSION INFO
Driver version: 1.4.0
Driver commit hash: 2f3265a49ac18f94ba5e48254c8f870fe7bfc511
PFE_CFG_MULTI_INSTANCE_SUPPORT: 0
PFE_CFG_LOCAL_IF: 6
PFE_CFG_MASTER_IF: 6
PFE_CFG_SC_HIF: 1
PFE_CFG_HIF_RING_LENGTH: 256
PFE_CFG_PFE0_PROMISC: 1
PFE_CFG_PFE1_PROMISC: 1
PFE_CFG_PFE2_PROMISC: 1
Jan 01 00:00:00.052                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1384]: --- Safe IRQ enabled. No InterrupAttach() or InterruptAttach_r() allowed.
Jan 01 00:00:00.052                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_fw.c:83]: 42792 bytes read
Jan 01 00:00:00.053                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_fw.c:89]: Loaded firmware file: /proc/boot/s32g_pfe_class.fw
Jan 01 00:00:00.053                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1477]: MII mode configuration for pfe0/EMAC0 not found. Using SGMII.
Jan 01 00:00:00.053                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1477]: MII mode configuration for pfe1/EMAC1 not found. Using SGMII.
Jan 01 00:00:00.053                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1477]: MII mode configuration for pfe2/EMAC2 not found. Using RGMII.
Jan 01 00:00:00.053                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1495]: Issuing PFE peripheral reset...
Jan 01 00:00:00.274                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1496]: PFE reset OK.
Jan 01 00:00:00.274                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:3519]: PFE CBUS p0x46000000 mapped @ v0x38f2e23000
Jan 01 00:00:00.274                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:3524]: HW version 0x101
Jan 01 00:00:00.274                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hw_feature.c:95]: Silicon S32G3
Jan 01 00:00:00.274                 io_pkt_v6_hc.8                 slog      0  WRN[hw/s32g/pfe_platform_master.c:3536]: Fail-Stop mode disabled
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2687]: PFE_ERRORS:Parity instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2702]: PFE_ERRORS:Watchdog instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2718]: PFE_ERRORS:Bus Error instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2731]: PFE_ERRORS:FW Fail Stop instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2744]: PFE_ERRORS:Host Fail Stop instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2757]: PFE_ERRORS:Fail Stop instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2770]: PFE_ERRORS:ECC Err instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:1766]: BMU1 buffer base: p0xc0000000
Jan 01 00:00:00.277                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:1810]: BMU2 buffer base: p0x83000000 (0x200000 bytes)
Jan 01 00:00:00.279                 io_pkt_v6_hc.8                 slog      0  INF[src/oal_irq_qnx.c:117]: PFE BMU IRQ Worker started (IRQ ID: 226)
Jan 01 00:00:00.279                 io_pkt_v6_hc.8                 slog      0  WRN[hw/s32g/pfe_platform_master.c:2194]: The option 'g2_ordered_class_writes' is disabled.
Jan 01 00:00:00.279                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_bmu_csr.c:96]: BMU_EMPTY_INT (BMU @ p0x88000). Pool ready.
Jan 01 00:00:00.279                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_bmu_csr.c:96]: BMU_EMPTY_INT (BMU @ p0x8c000). Pool ready.
Jan 01 00:00:00.281                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2239]: Firmware .elf detected
Jan 01 00:00:00.281                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2248]: Uploading CLASS firmware
Jan 01 00:00:00.281                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_pe.c:609]: Selected FW loading OPs to load 8 PEs in parallel
Jan 01 00:00:00.285                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_pe.c:1945]: pfe_ct.h file version"92367c0e25f21f49217a9b08168ad2c8"
Jan 01 00:00:00.288                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_pe.c:2422]: [FW VERSION] 1.7.0, Build: Jun  2 2023, 13:48:57 (nogitaaa), ID: 0x31454650
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  WRN[hw/s32g/pfe_platform_master.c:2312]: VLAN ID incorrect or not set. Using default VLAN ID = 0x01.
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  WRN[hw/s32g/pfe_platform_master.c:2318]: VLAN stats size incorrect or not set. Using default VLAN stats size = 20.
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_l2br.c:1181]: Software vlan hash table @ p0x20001228
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_l2br.c:1286]: Fall-back bridge domain @ 0x20000a7c (class)
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_l2br.c:1287]: Default bridge domain @ 0x20000a74 (class)
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2412]: Routing table created, Hash Table @ p0x80014000, Pool @ p0x8001c000 (65536 bytes)
Jan 01 00:00:00.407                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_chnl.c:1997]: Initializing RX buffer pool. Depth: 256; Buffer Size: 2048; Cache Line Size: 64
Jan 01 00:00:00.408                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_chnl.c:1997]: Initializing RX buffer pool. Depth: 256; Buffer Size: 2048; Cache Line Size: 64
Jan 01 00:00:00.409                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_chnl.c:1997]: Initializing RX buffer pool. Depth: 256; Buffer Size: 2048; Cache Line Size: 64
Jan 01 00:00:00.508                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:3705]: Feature err051211_workaround: DISABLED
Jan 01 00:00:00.509                        iopkt.8          main_buffer      0  pfe0
Jan 01 00:00:00.509                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2152]: pfe0: Using PHY mode: MDIO=0, ADDR=0, CLAUSE=0, RESET=0
Jan 01 00:00:00.509                 io_pkt_v6_hc.8                 slog      0  INF[src/oal_irq_qnx.c:117]: PFE HIF0 IRQ Worker started (IRQ ID: 222)
Jan 01 00:00:00.509                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1795]: Adding 00:0a:0b:0c:0d:66 to pfe0
Jan 01 00:00:00.511                        iopkt.8          main_buffer      0  pfe1
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2298]: Speed/duplex configuration for pfe0 not found. Using 1 Gbps/full-duplex.
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:336]: Attempt to register HIF client: 0
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:1189]: HIF driver started
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2363]: New PFE device: 0, ID: 0
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2152]: pfe1: Using PHY mode: MDIO=1, ADDR=0, CLAUSE=0, RESET=0
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/oal_irq_qnx.c:117]: PFE HIF1 IRQ Worker started (IRQ ID: 223)
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1795]: Adding 00:1a:1b:1c:1d:66 to pfe1
Jan 01 00:00:00.513                        iopkt.8          main_buffer      0  pfe2
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2298]: Speed/duplex configuration for pfe1 not found. Using 1 Gbps/full-duplex.
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:336]: Attempt to register HIF client: 1
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:1189]: HIF driver started
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2363]: New PFE device: 1, ID: 2
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2145]: pfe2: Using static PHY mode, RESET=0
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/oal_irq_qnx.c:117]: PFE HIF2 IRQ Worker started (IRQ ID: 224)
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1795]: Adding 00:2a:2b:2c:2d:66 to pfe2
Jan 01 00:00:00.515                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2298]: Speed/duplex configuration for pfe2 not found. Using 1 Gbps/full-duplex.
Jan 01 00:00:00.515                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:336]: Attempt to register HIF client: 2
Jan 01 00:00:00.515                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:1189]: HIF driver started
Jan 01 00:00:00.515                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2363]: New PFE device: 2, ID: 4
Jan 01 00:00:00.530                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2702]: Adding 00:0a:0b:0c:0d:66 to pfe0
Jan 01 00:00:00.530                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2707]: Unable to assign MAC address 00:0a:0b:0c:0d:66 to the pfe0
Jan 01 00:00:00.530                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.538                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_mdio.c:427]: pfe0: PHY @ bus 0 addr 0 not found. Switching to static mode.
Jan 01 00:00:00.538                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2829]: EMAC speed change for SGMII is currently not supported.
Jan 01 00:00:00.538                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:ff:0c:0d:66 to emac0
Jan 01 00:00:00.540                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.540                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:ff:0c:0d:66 to emac0
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2450]: unable to add 33:33:ff:0c:0d:66 into emac0: 17
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2450]: unable to add 33:33:00:00:00:01 into emac0: 17
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2829]: EMAC speed change for SGMII is currently not supported.
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 01:00:5e:00:00:01 to emac0
Jan 01 00:00:00.544                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:00:00.544                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2450]: unable to add 33:33:00:00:00:01 into emac0: 17
Jan 01 00:00:00.544                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:ff:0c:0d:66 to emac0
Jan 01 00:00:00.544                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2450]: unable to add 33:33:ff:0c:0d:66 into emac0: 17
Jan 01 00:00:00.544                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.554               spi_master.24585               normal*     0  Starting spi-master resource manager
Jan 01 00:00:00.558               spi_master.24587               normal*     0  Starting spi-master resource manager
Jan 01 00:00:00.561               spi_master.24588               normal*     0  Starting spi-master resource manager
Jan 01 00:00:00.565               spi_master.24589               normal*     0  Starting spi-master resource manager
Jan 01 00:00:00.582          devb_sdmmc_mx8x.24595                 slog*  1800  devb-sdmmc-mx8x 1.00A (Jun 23 2026 09:45:48)
Jan 01 00:00:00.583          devb_sdmmc_mx8x.24595                 slog      0  libcam.so (Jun 22 2020 21:33:15) bver 7010003
Jan 01 00:00:00.594          devb_sdmmc_mx8x.24595                 slog   1800  sdio_cd:  insertion path 0, cd state 0x1
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800  SD CID:
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    MID 0x27, OID 0x5048, PNM SD32G
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    PRV 0x62, PSN 0x6c62d132, MDT 4-2023
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800  SD CSD:
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    CSD_STRUCTURE 1, SPEC_VERS 0, CCC 0x5b5
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    TAAC 14, NSAC 0, TRAN_SPEED 50
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    C_SIZE 59023, C_SIZE_MULT 0
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    READ_BL_LEN 9, WRITE_BL_LEN 9
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    ERASE GRP_SIZE 0, GRP_MULT 0, SIZE 127
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    blksz 512, sectors 60440576, dtr 25000000
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800  SD SW CAPS:
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    bus mode 0x3, cmd sys 0x1
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    drv type 0x1, curr limit 0x1
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    dtr 50000000
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800  CFG:  Timing HS, DTR 50000000, Bus Width 4 bit
Jan 01 00:00:00.645          devb_sdmmc_mx8x.24595                 slog    100  cam-disk.so (Jun 22 2020 21:33:17)
Jan 01 00:00:00.647          devb_sdmmc_mx8x.24595                 slog      0  scsi_interpret_sense (sdmmc ptl-0:0:0):  cam_status=c4, scsi_status=2, flag=00000040, vuflag=0008, cmd=1a, error=70, sense=5, asc=24, ascq=0
Jan 01 00:00:00.647          devb_sdmmc_mx8x.24595                 slog      0  scsi_interpret_sense (sdmmc ptl-0:0:0):  cam_status=c4, scsi_status=2, flag=00000040, vuflag=0008, cmd=5a, error=70, sense=5, asc=24, ascq=0
Jan 01 00:00:01.827          devb_sdmmc_mx8x.24595                 slog   1000  fs-qnx6: Allocation strategy 0
Jan 01 00:00:01.827          devb_sdmmc_mx8x.24595                 slog   1000  fs-qnx6: Use btree directory 0
Jan 01 00:00:01.828          devb_sdmmc_mx8x.24595                 slog   1000  fs-qnx6: fs-qnx6: trim (0,1048576,2) was not requested, and is NOT supported
Jan 01 00:00:01.833               io_usb_otg.36885                 slog*     0  main(453)[tid:1]: io-usb-otg (Jun 13 2020 20:10:17) args: -d hcd-ehci-mx28 ioport=0x44064100,irq=243,ulpi,no_stream,verbose=5
Jan 01 00:00:01.835           devf_qspi_s32g.36884                 slog*     0  (devf  t1::f3s_qspi_ident:73) Page size: 256
Jan 01 00:00:01.835           devf_qspi_s32g.36884                 slog      0  (devf  t1::f3s_qspi_ident:74) Total chip size: 0x4000000, Unit size: 0x10000
Jan 01 00:00:01.839               io_usb_otg.36885                 slog      0  ehci_init: Initialiaing with sever version: 2
Jan 01 00:00:01.839               io_usb_otg.36885                 slog      0  ehci_controller_init(4303): devu-hcd-ehci-mx28.so (Apr 19 2024 13:44:54):  args ulpi,no_stream,verbose=5
Jan 01 00:00:01.840               io_usb_otg.36885                 slog      8  usb_enum_port(94)[tid:1]: busno 0, parent -1, port 0, High speed
Jan 01 00:00:01.840               io_usb_otg.36885                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 1, index 0, length
Jan 01 00:00:01.840               io_usb_otg.36885                 slog     12  usb_device_set_address(245)[tid:1]: b:0 devno 0
Jan 01 00:00:01.840               io_usb_otg.36885                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 1, index 0, length 18)
Jan 01 00:00:01.841               io_usb_otg.36885                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 2, index 0, length 9)
Jan 01 00:00:01.841               io_usb_otg.36885                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 2, index 0, length 25)
Jan 01 00:00:01.841               io_usb_otg.36885                 slog      8  usb_enum_port(141)[tid:1]: vid 0x0000, did 0x0000 enumerated(busno 0, devno 0:0)
Jan 01 00:00:01.841               io_usb_otg.36885                 slog     11  hub_state_inserted(569)[tid:1]: bdentry 0, dentry 0 0
Jan 01 00:00:01.841               io_usb_otg.36885                 slog     13  hub_configuration_enable(263)[tid:1]: 1
Jan 01 00:00:01.943               io_usb_otg.36885                 slog      0  usbh_timeout_init(203)[tid:1]: Complete
Jan 01 00:00:01.954               io_usb_otg.36885                 slog      0  read_vid_pid: ULPI VID 0x0424 PID 0x0009
Jan 01 00:00:01.954               io_usb_otg.36885                 slog      0  s32g_phy_set_vbus: set_vbus off
Jan 01 00:00:01.968               io_usb_otg.36885                 slog      0  s32g_phy_set_vbus: set_vbus on
Jan 01 00:00:01.979               io_usb_otg.36885                 slog      0  ehci_get_port_status(3568 0x44064100): port=0, tpstatus 10100 e_pstatus 8c001000
Jan 01 00:00:01.979               io_usb_otg.36885                 slog      8  usb_enum_port_extract(172)[tid:7]: (busno 0, pdevno 0, portno 1)
Jan 01 00:00:01.979               io_usb_otg.36885                 slog      8  usb_enum_port_extract(192)[tid:7]: status (2)
Jan 01 00:00:01.983               devb_umass.36886                 slog*   900  devb-umass 1.00A (Jun 22 2020 21:33:41)
Jan 01 00:00:01.984               devb_umass.36886                 slog      0  libcam.so (Jun 22 2020 21:33:15) bver 7010003
Jan 01 00:00:01.985               io_usb_otg.36885                 slog      0  usbdi_client_connect(58)[tid:5]: pid 36886 proc=proc/boot/devb-umass usbdi_client 32eebb9a80
Jan 01 00:00:01.986               io_usb_otg.36885                 slog      0  usbdi_resmgr_connect(310)[tid:5]: usbdi_resmgr_connect: pid 36886 usbdi_client 32eebb9a80
Jan 01 00:00:01.986               devb_umass.36886                 slog      0  usbdi debug path /pps/usb/debug/ doesn't exist
Process 49177 (slog2info) exited status=0.
# ifconfig
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 33136
inet 127.0.0.1 netmask 0xff000000
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
pfe0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
capabilities=1f<IP4CSUM,TCP4CSUM,UDP4CSUM,TCP6CSUM,UDP6CSUM>
enabled=0
address: 00:0a:0b:0c:0d:66
media: Ethernet none (1000baseT full-duplex)
status: active
inet 0.0.0.0 netmask 0xff000000 broadcast 255.255.255.255
inet6 fe80::20a:bff:fe0c:d66%pfe0 prefixlen 64 scopeid 0x11
pfe1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
enabled=0
address: 00:1a:1b:1c:1d:66
status: no carrier
pfe2: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
enabled=0
address: 00:2a:2b:2c:2d:66
status: no carrier
Process 57369 (ifconfig) exited status=0.
Seneca
Greetings,
I intend to try the following combination:
BSP 33
PFE Driver 1.2.0
PFE FW 1.3.0
Is this officially supported?
chenyin_h
Hello, @Seneca
Thanks for your post.
By default, the S32G PFE QNX Driver Version 1.4.0 is compatible with S32G PFE Firmware Standard Version 1.6.0, would you mind testing it again with this PFE FW version instead?
Chenyin
Seneca
Ok, so I replaced s32g_pfe_class.fw and s32g_pfe_util.fw with the files from PFE-FW_S32G_1.6.0.zip here:
https://nxp.flexnetoperations.com/control/frse/download?agree=Accept&element=14074877
Uboot parameters:
setenv boot_qnx_atf 'mmc dev 0; fatload mmc 0:1 0x83e00000 s32g399a-rdb3.dtb; run atf_fdt_0to3; run atf_fdt_4to7; fatload mmc 0:1 0x80080000 ifs-s32g399a-rdb.ui; pfeng enable; s32ccgmac disable; s32ccgmac enable; bootm 0x80080000 - 0x83E00000'
setenv atf_fdt_0to3 'fdt addr 0x83e00000; fdt resize; fdt set /cpus/cpu@1 cpu-release-addr <0x0 0xa0000010>; fdt set /cpus/cpu@100 cpu-release-addr <0x0 0xa0000010>; fdt set /cpus/cpu@101 cpu-release-addr <0x0 0xa0000010>;'
setenv atf_fdt_4to7 'fdt set /cpus/cpu@2 cpu-release-addr <0x0 0xa0000010>; fdt set /cpus/cpu@3 cpu-release-addr <0x0 0xa0000010>; fdt set /cpus/cpu@102 cpu-release-addr <0x0 0xa0000010>; fdt set /cpus/cpu@103 cpu-release-addr <0x0 0xa0000010>;'
setenv release_cpus 'run cpu_trap; mp 1 release 0xa0000000; mp 2 release 0xa0000000; mp 3 release 0xa0000000; mp 4 release 0xa0000000; mp 5 release 0xa0000000; mp 6 release 0xa0000000; mp 7 release 0xa0000000;'
setenv cpu_trap 'dcache off; mw.l 0xa0000000 0xd503205f; mw.l 0xa0000004 0x58000060; mw.l 0xa0000008 0xb4ffffc0; mw.l 0xa000000C 0xd61f0000; mw.q 0xa0000010 0x00000000; dcache on;'
saveenv
Note: I removed the release_cpus command from boot_qnx_atf because then I would havef a cpu 1 error.
Doesn't look much better to me:
NOTICE:  BL2: v2.5(release):bsp37.0_rc6-2.5
NOTICE:  BL2: Built : 09:12:21, Jun 13 2023
NOTICE:  BL2: Booting BL31
DRAM:  3.5 GiB
MMC:   FSL_SDHC: 0
In:    serial@401c8000
Warning: eth_eqos (eth0) using random MAC address - 16:ec:a0:4e:1d:7c
, eth1: eth_pfeng
11950600 bytes read in 534 ms (21.3 MiB/s)
   Image Name:
   Data Size:    11950536 Bytes = 11.4 MiB
   Using Device Tree in place at 0000000083e00000, end 0000000083e0ffff
Starting kernel ...
Done.
 0 43642864
 1 43642864
 2 43642864
 3 43642864
 4 43642864
 5 43642864
 6 43642864
 7 43642864
# ifconfig
enabled=0
status: active
enabled=0
status: no carrier
enabled=0
status: no carrier
Process 40985 (ifconfig) exited status=0.
Process 53273 (sh) terminated signo=0 code=0 by process 0 value=0.
# ifconfig
enabled=0
status: active
enabled=0
status: no carrier
enabled=0
status: no carrier
# slog2info | grep pfe
Jan 01 00:00:00.052 io_pkt_v6_hc.8 slog 0 INF[src/pfe_fw.c:83]: 49480 bytes read
Jan 01 00:00:00.052 io_pkt_v6_hc.8 slog 0 INF[src/pfe_fw.c:89]: Loaded firmware file: /proc/boot/s32g_pfe_class.fw
Jan 01 00:00:00.274 io_pkt_v6_hc.8 slog 0 INF[hw/s32g/pfe_platform_master.c:3519]: PFE CBUS p0x46000000 mapped @ v0x1abef95000
Jan 01 00:00:00.288 io_pkt_v6_hc.8 slog 0 INF[src/pfe_pe.c:2422]: [FW VERSION] 1.6.0, Build: Mar 15 2023, 12:37:54 (), ID: 0x31454650
Jan 01 00:00:00.406 io_pkt_v6_hc.8 slog 0 INF[src/pfe_l2br.c:1181]: Software vlan hash table @ p0x20001208
Jan 01 00:00:00.406 io_pkt_v6_hc.8 slog 0 INF[src/pfe_l2br.c:1286]: Fall-back bridge domain @ 0x20000a44 (class)
Jan 01 00:00:00.406 io_pkt_v6_hc.8 slog 0 INF[src/pfe_l2br.c:1287]: Default bridge domain @ 0x20000a3c (class)
Jan 01 00:00:00.509 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2145]: pfe0: Using static PHY mode, RESET=0
Jan 01 00:00:00.510 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:1795]: Adding 00:0a:0b:0c:0d:66 to pfe0
Jan 01 00:00:00.512 iopkt.8 main_buffer 0 pfe1
Jan 01 00:00:00.512 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2298]: Speed/duplex configuration for pfe0 not found. Using 1 Gbps/full-duplex.
Jan 01 00:00:00.512 io_pkt_v6_hc.8 slog 0 INF[src/pfe_hif_drv_sc.c:336]: Attempt to register HIF client: 0
Jan 01 00:00:00.512 io_pkt_v6_hc.8 slog 0 INF[src/pfe_hif_drv_sc.c:1189]: HIF driver started
Jan 01 00:00:00.512 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2363]: New PFE device: 0, ID: 0
Jan 01 00:00:00.512 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2145]: pfe1: Using static PHY mode, RESET=0
Jan 01 00:00:00.512 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:1795]: Adding 00:1a:1b:1c:1d:66 to pfe1
Jan 01 00:00:00.514 iopkt.8 main_buffer 0 pfe2
Jan 01 00:00:00.514 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2298]: Speed/duplex configuration for pfe1 not found. Using 1 Gbps/full-duplex.
Jan 01 00:00:00.514 io_pkt_v6_hc.8 slog 0 INF[src/pfe_hif_drv_sc.c:336]: Attempt to register HIF client: 1
Jan 01 00:00:00.514 io_pkt_v6_hc.8 slog 0 INF[src/pfe_hif_drv_sc.c:1189]: HIF driver started
Jan 01 00:00:00.514 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2363]: New PFE device: 1, ID: 2
Jan 01 00:00:00.514 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2145]: pfe2: Using static PHY mode, RESET=0
Jan 01 00:00:00.514 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:1795]: Adding 00:2a:2b:2c:2d:66 to pfe2
Jan 01 00:00:00.516 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2298]: Speed/duplex configuration for pfe2 not found. Using 1 Gbps/full-duplex.
Jan 01 00:00:00.516 io_pkt_v6_hc.8 slog 0 INF[src/pfe_hif_drv_sc.c:336]: Attempt to register HIF client: 2
Jan 01 00:00:00.516 io_pkt_v6_hc.8 slog 0 INF[src/pfe_hif_drv_sc.c:1189]: HIF driver started
Jan 01 00:00:00.516 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2363]: New PFE device: 2, ID: 4
Jan 01 00:00:00.531 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2702]: Adding 00:0a:0b:0c:0d:66 to pfe0
Jan 01 00:00:00.531 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2707]: Unable to assign MAC address 00:0a:0b:0c:0d:66 to the pfe0
Jan 01 00:00:00.531 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.531 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2829]: EMAC speed change for SGMII is currently not supported.
Jan 01 00:00:00.532 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 33:33:ff:0c:0d:66 to emac0
Jan 01 00:00:00.534 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.534 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:00:00.536 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 33:33:ff:0c:0d:66 to emac0
Jan 01 00:00:00.536 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2450]: unable to add 33:33:ff:0c:0d:66 into emac0: 17
Jan 01 00:00:00.536 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.536 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:00:00.536 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2450]: unable to add 33:33:00:00:00:01 into emac0: 17
Jan 01 00:00:00.536 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2829]: EMAC speed change for SGMII is currently not supported.
Jan 01 00:00:00.536 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 01:00:5e:00:00:01 to emac0
Jan 01 00:00:00.538 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:00:00.538 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2450]: unable to add 33:33:00:00:00:01 into emac0: 17
Jan 01 00:00:00.538 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2450]: unable to add 33:33:ff:0c:0d:66 into emac0: 17
Jan 01 00:00:00.538 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
# slog2info  | grep io_pkt_v6_hc
Jan 01 00:00:00.512 io_pkt_v6_hc.8 slog 0 INF[src/oal_irq_qnx.c:117]: PFE HIF1 IRQ Worker started (IRQ ID: 223)
Jan 01 00:00:00.514 io_pkt_v6_hc.8 slog 0 INF[src/oal_irq_qnx.c:117]: PFE HIF2 IRQ Worker started (IRQ ID: 224)
Process 172057 (slog2info) exited status=0.
Jan 01 00:01:01.630 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:01:01.630 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2450]: unable to add 33:33:00:00:00:01 into emac0: 17
Jan 01 00:01:01.630 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 33:33:ff:0c:0d:66 to emac0
Jan 01 00:01:01.630 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2450]: unable to add 33:33:ff:0c:0d:66 into emac0: 17
Jan 01 00:01:01.630 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2495]: Removing 01:00:5e:00:00:01 from emac0
Jan 01 00:01:01.632 io_pkt_v6_hc.8 slog 0 INF[src/pfe_phy_if.c:2716]: Address 01:00:5e:00:00:01 removed from emac0
Jan 01 00:01:01.632 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
chenyin_h
Hello, @Seneca
Thanks for your reply.
In order for using the PFE drivers for QNX correctly,  you may have to use the versions described below to request integration related support from us.
Would you mind confirming if the QNX SDP 7.1 JBN37 is used or JBN51 is used in your test?(maybe with the name: BSP_nxp-s32g-evb_br-710_be-710_SVN984052_JBN51)
Additionally, from the integration manual within the 1.4 package, the following u-boot tag is used/tested instead of bsp37.0-2020.04
I suggest testing with this combinations firstly for initial analysis.
Chenyin
Seneca
Greetings,
I already use the uboot U-Boot 2020.04+g156b168010 from my 37 bsp setup. Can I reuse that and only switch the IFS file on the sdcard?
Edit: Oh, and the BSP 37 was recommended to my by your support a few months ago when I tried to get gmac0 running. Might 34 break this?
chenyin_h
Hello, @Seneca
From my opinion, I suggest firstly try testing it with QNX SDP 7.1 JBN37 strictly following the PFE_S32G_A53_QNX_IntegrationManual, if no issues with PFE, then checking the GMAC issues if does exist.
Chenyin
Seneca
Is JBN37 the same as BSP37?
BSP37 is what I am using at the moment.BSP_nxp-s32g-rdb3_br-710_be-710_SVN996606_JBN10.zip
I tried to follow the integration manual section 2.6.2 as follows:
Set the uboot variables:
saveenv
boot
When building the ifs image in the .build file, I replaced the networking section with this:
## Networking
display_msg Starting Networking driver (/dev/socket)...
waitfor /dev/socket 10
# Get IP form DHCP for pfe0 device - optional step
dhclient -m -lf /dev/shmem/dhclient.leases -pf /dev/shmem/dhclient.pid -nw pfe0
cp /proc/boot/libfci_cli /tmp # Optional component
And added this in the network driver section:
./../../pfebsp37/PFE-DRV_S32G_A53_QNX_1.4.0/sw/devnp-pfe-2/build/aarch64le-release/devnp-pfe-2.so # PFE driver
# Important - use [+raw] to treat fw as a raw data file
[+raw]./../../pfebsp37/PFE-FE_S32G_1.6.0/s32g_pfe_class.fw
[+raw]./../../pfebsp37/PFE-FE_S32G_1.6.0/s32g_pfe_util.fw
[perms=a+x]libfci_cli # Optional if libfci_cli is needed
In the BSP, I added in src/hardware/startup/boards/s32g/s32g399a-rdb/s32g_init_raminfo.c in s32g_init_raminfo function:
kprintf("Reserving RAM region for PFE driver on EVB/RDB\n");
as_add_containing(0x80000000,0x80000000 + 0x70000000 - 1,AS_ATTR_RAM,
"pfe_ddr","ram");
Did I miss anything?
chenyin_h
Hello, @Seneca
Thanks for your reply..
BSP 37 is the version number for Linux BSP provisioned by NXP(TFA, U-boot, Linux, etc.), while the JBN37 mentioned is part of the name of certain version QNX BSP release(BSP_nxp-s32g-evb_br-710_be-710_SVN950423_JBN37) provisioned by Blackberry, they are different.
According to the release notes, the QNX PFE Driver 1.4 was developed and tested with the following QNX release:  QNX® SDP 7.1 BuildID 472 (BSP_nxp-s32g-evb_br-710_be-710_SVN950423_JBN37), so I suggest firstly checking with your testing setup if the correct QNX version is used.
However, as shared from your previous reply, BSP_nxp-s32g-rdb3_br-710_be-710_SVN996606_JBN10 was used, which does not match the requirement.
Chenyin
Seneca
Greetings,
you recommend a BSP_nxp-s32g-evb* release which looks like for the evb board will this even work with an rdb3 board like mine? Is there a driver compatible with rdb3?
Edit: The only driver version I can find at the moment that lists rdb3 at the moment is 1.9.0 which lists a BSP_nxp-s32g-rdb3_be-800_SVN1011366_JBN153.zip but only for QNX SDP 8.0 not for 7.1.
Are you aware of a package that works with rdb3 and QNX SDP 7.1?
chenyin_h
Hello, @Seneca
If not focused on certain version PFE QNX drivers, I suggest trying PFE QNX driver 1.8 with FW 1.11
1. It is compatible with  QNX® SDP 7.1 BSP for NXP - BuildID 51 (BSP_nxp-s32g-evb_br-710_be-710_SVN984052_JBN51)
2. It was developed and tested with S32G-VNP-RDB3(although named with ...-evb....)
Which fulfill your requirements.
Chenyin
Seneca
Ok, so I downloaded the
package you mentioned, modified the .build file and add the
as_add_containing(0x80000000,0x80000000 + 0x4000000 - 1,AS_ATTR_RAM, "pfe_ddr","ram");
to
src/hardware/startup/boards/s32g/s32g399a-rdb/s32g_init_raminfo.c and replace my ifs file with the resulting ifs-s32g399a-rdb.ui.
Unfortunately, it doesn't seem to execute the pfe_ddr allocation from above.
Is there anything I need to modify for the uboot parameters or else for this new image to work?
chenyin_h
Hello, @Seneca
I suggest referencing the integration manual strictly, refer to the part you mentioned, the following need to be modified before building the QNX BSP.
Chenyin
Seneca
I shall try that, tx.
Can you name me the exact package name in the QNX Software Center? All packages with EVB I see are marked with S32G274A and I don't know if these work with a S32G3 board.
Btw: Some manuals put the *.fw files on the root of the sd card so that uboot can load them with pfeng* commands but it is not part of the integration manuals I have read so far. Is this really necessary or is loading the firmware via io-pkt* enough?
chenyin_h
Hello, @Seneca
Sorry that since QNX is 3rd product, we may not be aware of the BSP details/changes released, my feedback is based on available NXP documents.
1. I have just checked the QNX PFE driver 1.7 and 1.8, and found that the integration manual is actually based on QNX PFE driver 1.7, so this version is also correct for your test.
2. From the corresponding document, for QNX PFE driver 1.7, it is compatible with FW 1.10
While the name of the QNX BSP is:
3. From my previous experience, since there would be some differences across different version QNX PFE drivers, I suggest firstly following the integration manual that is found from certain QNX PFE driver used.
For other details of QNX BSP itself, I suggest directly contacting QNX support portal
Sorry for your inconvenience
Chenyin
Seneca
Hello Chenyin,
can you tell me which NXP BSP Version was used by the person who tested the PFE Driver 1.7.0 with the QNXJBN51?
chenyin_h
Hello, @Seneca
The tested BSP version is BSP39 combine with QNX driver version 1.7.0 and QNX SDP 7.1 BSP JBN51
Chenyin
Seneca
And what was the PFE firmware version used?
JBN51 needs NXP BSP39 which comes with PFE Firmware 1.8.0. But section 2.1.3 of the Pfe Driver 1.7.0 release notes states that only PFW FW 1.10.0 was tested with this release.
Seneca
Greetings,
do you know if NXP provides SDCard images that already have the uboot modifications necessary for PFE as in board_cleanup_before_linux?
I don't know what packages like binaries_auto_linux_bsp37.0_s32g3_pfe do.
chenyin_h
Hello, @Seneca
Sorry that there are not such images for publicly downloaded.
For "binaries_auto_linux_bsp37.0_s32g3_pfe", seems it is the name of the tgz file from:
If so, it includes the pre-built binaries of Linux BSP provisioned by NXP, there are not any QNX related images included.
Chenyin
Seneca
Now I built the uboot myself according to the integration manual. I added the modifications from section 2.10.2 form the PFE Driver 1.7.0 Integration manual. There seem to be some errors during startup:
board_cleanup_before_linux: QNX PFE code.
ethernet@4033c000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
phy_startup() failed: -110FAILED: -110
Found PFE version 0x0101 (S32G3)
pfe2 Waiting for PHY auto negotiation to complete......... TIMEOUT !
pfeng_netif pfe1: Failed to establish XPCS link on PFE1
Is this normal?
%3CLINGO-SUB%20id%3D%22lingo-sub-2385092%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385092%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGreetings%2C%3C%2FP%3E%3CP%3Ewe%20try%20to%20get%20PFE%20running%20on%20a%20S32G399A-RDB3%20board%20with%20QNX.%20As%20far%20as%20I%20can%20tell%2C%20this%20is%20a%20valid%20combination%3A%3C%2FP%3E%3CP%3E%3CSPAN%3EBSP%2037.0%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EPFE-FW_S32G_1.7.0%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EPFE-DRV-S32G_A53_QNX_1.4.0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EIt%20ends%20with%20a%20no%20carrier%20error%20on%20all%20network%20interfaces.%20Plugging%20the%20cable%20into%20different%20ethernet%20ports%20changes%20nothing.%26nbsp%3B%3C%2FP%3E%3CP%3EIt%20used%20to%20work%20with%20gmac0.%3C%2FP%3E%3CP%3EAny%20ideas%3F%3C%2FP%3E%3CP%3Eio%20pkt%20call%3A%3C%2FP%3E%3CP%3Eio-pkt-v6-hc%20-p%20tcpip%20-d%20pfe-2%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cno_reset%2Cmode0%3Dsgmii%2Cphy0%3D0%2Cmode1%3Dsgmii%2Cphy1%3D1%3C%2FP%3E%3CP%3EUboot%20parameters%3A%3C%2FP%3E%3CP%3EUboot%20is%20the%20same%20as%20from%20the%20Linux%20sdcard%20image%20with%20modified%20parmeters%20for%20qnx%20boot.%26nbsp%3B%3C%2FP%3E%3CP%3Esetenv%20hwconfig%20%22pcie0%3Amode%3Drc%2Cclock%3Dext%3Bpcie1%3Amode%3Dsgmii%2Cclock%3Dext%2Cfmhz%3D125%2Cxpcs_mode%3D2G5%22%3CBR%20%2F%3Esetenv%20pfeng_mode%20'enable%2Csgmii%2Csgmii%2Crgmii'%3CBR%20%2F%3Esetenv%20s32cc_gmac_mode%20disable%3CBR%20%2F%3Esetenv%20pfeng%20enable%3B%20s32ccgmac%20disable%3B%20s32ccgmac%20enable%3B%3CBR%20%2F%3Esetenv%20boot_qnx_atf%20'mmc%20dev%200%3B%20fatload%20mmc%200%3A1%200x83e00000%20s32g399a-rdb3.dtb%3B%20pfeng%20enable%3B%20s32ccgmac%20disable%3B%20s32ccgmac%20enable%3B%20fatload%20mmc%200%3A1%200x80080000%20ifs-s32g399a-rdb.ui%3B%20bootm%200x80080000%20-%200x83E00000'%3CBR%20%2F%3Esetenv%20bootcmd%20'run%20boot_qnx_atf'%3CBR%20%2F%3Esaveenv%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ELog%3A%3C%2FP%3E%3CDIV%3EU-Boot%202020.04%2Bg156b168010%20(Jun%2009%202023%20-%2010%3A14%3A25%20%2B0000)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECPU%3A%26nbsp%3B%20%26nbsp%3BNXP%20S32G399A%20rev.%201.1%3C%2FDIV%3E%3CDIV%3EModel%3A%20NXP%20S32G399A-RDB3%3C%2FDIV%3E%3CDIV%3EDRAM%3A%26nbsp%3B%203.5%20GiB%3C%2FDIV%3E%3CDIV%3EMMC%3A%26nbsp%3B%20%26nbsp%3BFSL_SDHC%3A%200%3C%2FDIV%3E%3CDIV%3ELoading%20Environment%20from%20MMC...%20OK%3C%2FDIV%3E%3CDIV%3EConfiguring%20PCIe0%20as%20RootComplex%3C%2FDIV%3E%3CDIV%3EPCIe0%3A%20Failed%20to%20get%20link%20up%3C%2FDIV%3E%3CDIV%3EPCI%3A%20Failed%20autoconfig%20bar%201c%3C%2FDIV%3E%3CDIV%3EIn%3A%26nbsp%3B%20%26nbsp%3B%20serial%40401c8000%3C%2FDIV%3E%3CDIV%3EOut%3A%26nbsp%3B%20%26nbsp%3Bserial%40401c8000%3C%2FDIV%3E%3CDIV%3EErr%3A%26nbsp%3B%20%26nbsp%3Bserial%40401c8000%3C%2FDIV%3E%3CDIV%3EBoard%20revision%3A%20RDB3%20Revision%20F%3C%2FDIV%3E%3CDIV%3ENet%3A%26nbsp%3B%20%26nbsp%3BEQOS%20phy%3A%20rgmii%20%40%201%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EWarning%3A%20eth_eqos%20(eth0)%20using%20random%20MAC%20address%20-%2026%3Ae4%3Ae6%3A43%3A15%3Aad%3C%2FDIV%3E%3CDIV%3Eeth0%3A%20eth_eqosFailed%20to%20get%20speed%20of%20XPCS%20for%20emac1_xpcs%20PFE%3A%20emac0%3A%20sgmii%20emac1%3A%20sgmii%20emac2%3A%20rgmii%3C%2FDIV%3E%3CDIV%3E%2C%20eth1%3A%20eth_pfeng%3C%2FDIV%3E%3CDIV%3EHit%20any%20key%20to%20stop%20autoboot%3A%26nbsp%3B%203%20%26%238%3B%26%238%3B%26%238%3B%202%20%26%238%3B%26%238%3B%26%238%3B%201%20%26%238%3B%26%238%3B%26%238%3B%200%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eswitch%20to%20partitions%20%230%2C%20OK%3C%2FDIV%3E%3CDIV%3Emmc0%20is%20current%20device%3C%2FDIV%3E%3CDIV%3E50640%20bytes%20read%20in%2017%20ms%20(2.8%20MiB%2Fs)%3C%2FDIV%3E%3CDIV%3E11948752%20bytes%20read%20in%20540%20ms%20(21.1%20MiB%2Fs)%3C%2FDIV%3E%3CDIV%3E%23%23%20Booting%20kernel%20from%20Legacy%20Image%20at%2080080000%20...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BImage%20Name%3A%26nbsp%3B%20%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BImage%20Type%3A%26nbsp%3B%20%26nbsp%3BAArch64%20Linux%20Kernel%20Image%20(uncompressed)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BData%20Size%3A%26nbsp%3B%20%26nbsp%3B%2011948688%20Bytes%20%3D%2011.4%20MiB%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BLoad%20Address%3A%2080080000%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BEntry%20Point%3A%26nbsp%3B%2080080000%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BVerifying%20Checksum%20...%20OK%3C%2FDIV%3E%3CDIV%3E%23%23%20Flattened%20Device%20Tree%20blob%20at%2083e00000%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BBooting%20using%20the%20fdt%20blob%20at%200x83e00000%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BLoading%20Kernel%20Image%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BUsing%20Device%20Tree%20in%20place%20at%200000000083e00000%2C%20end%200000000083e0f5cf%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3Bfixup%3A%20pfe0%20set%20to%2000%3A01%3Abe%3Abe%3Aef%3A11%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3Bfixup%3A%20pfe1%20set%20to%2000%3A01%3Abe%3Abe%3Aef%3A22%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3Bfixup%3A%20pfe1%3A%20update%20phy%20addr%20to%200x8%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3Bfixup%3A%20pfe2%20set%20to%2000%3A01%3Abe%3Abe%3Aef%3A33%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EStarting%20kernel%20...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EReserving%20RAM%20region%20for%20PFE%20driver%20on%20EVB%2FRDB%3C%2FDIV%3E%3CDIV%3EDone.%3C%2FDIV%3E%3CDIV%3EClockCycles%20samples%3A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B0%2043600679%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B1%2043600679%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B2%2043600678%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B3%2043600679%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B4%2043600678%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B5%2043600678%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B6%2043600678%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B7%2043600679%3C%2FDIV%3E%3CDIV%3EAll%20ClockCycles%20offsets%20within%20tolerance%3C%2FDIV%3E%3CDIV%3EWelcome%20to%20QNX%20Neutrino%207.1.0%20on%20the%20NXP%20S32G399A%20RDB%20Board!!%3C%2FDIV%3E%3CDIV%3EStarting%20watchdog...%3C%2FDIV%3E%3CDIV%3EStarting%20serial%20driver%20...%3C%2FDIV%3E%3CDIV%3EStarting%20Networking%20driver%20(%2Fdev%2Fsocket)...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%204107%20(ifconfig)%20exited%20status%3D0.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%2010%20(sh)%20exited%20status%3D0.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%209%20(dhclient)%20exited%20status%3D0.%3C%2FDIV%3E%3CDIV%3Ecp%3A%20Can't%20open%20source%20file.%26nbsp%3B%20(%2Fproc%2Fboot%2Flibfci_cli)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%2020489%20(cp)%20exited%20status%3D1.%3C%2FDIV%3E%3CDIV%3EStarting%20SPI%20driver%20(%2Fdev%2Fspi0%2C1%2C2%2C3%2C4%2C5)...%3C%2FDIV%3E%3CDIV%3EStarting%20I2C%200%2F1%2F2%2F3%2F4%20driver%20(%2Fdev%2Fi2c0%2C1%2C2%2C3%2C4)...%3C%2FDIV%3E%3CDIV%3EStarting%20USDHC0%20memory%20card%20driver...%3C%2FDIV%3E%3CDIV%3E%5B00%5D%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BSIM%3D%22SDMMC%22%20HBA%3D%22imx%22%3C%2FDIV%3E%3CDIV%3E%5B00%2C0%2C0%5D%20type%3D00%20ver%3D05%20resp%3D00%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BSDMMC%3A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%2024596%20(chkqnx6fs)%20exited%20status%3D0.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%2028692%20(mount)%20exited%20status%3D0.%3C%2FDIV%3E%3CDIV%3EStarting%20QSPI%20Flash%20driver...%3C%2FDIV%3E%3CDIV%3EStarting%20USB%20host%20driver%20(%2Fdev%2Fusb%2F*)%3C%2FDIV%3E%3CDIV%3EDetected%20QSPI%20Flash%3A%20Macronix%20MX25UW512%2C%20JEDEC%200xC2%20-%200x813A%2C%20Size%3A%200x4000000%3C%2FDIV%3E%3CDIV%3ELaunching%20devb-umass%20for%20%2Fdev%2Fusb%2F*%20...%3C%2FDIV%3E%3CDIV%3E%23%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%2036891%20(sleep)%20exited%20status%3D0.%3C%2FDIV%3E%3CDIV%3Esh%3A%20%2Fvar%2Fcetitec2%2Fstartup.sh%3A%20No%20such%20file%20or%20directory%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%2045081%20(sh)%20terminated%20signo%3D0%20code%3D0%20by%20process%200%20value%3D0.%3C%2FDIV%3E%3CDIV%3Eslog2info%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.023%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Brandom.4%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20low*%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B0%26nbsp%3B%20qcrypto%3A%20loading%20configuration%20file%20'%2Fetc%2Fqcrypto.conf'%20%5Bqcrypto_common.c(190)%5D%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.024%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20random.4..0%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog*%26nbsp%3B%20%26nbsp%3B700%26nbsp%3B%20Random%20is%20using%20the%20Fortuna%20PRNG%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.031%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Brandom.4%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20low%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20qcrypto%3A%20'openssl'%20plugin%20loaded%20%5Bqcrypto_plugins.c(354)%5D%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.031%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20random.4..0%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20700%26nbsp%3B%20Selecting%20timer%20as%20an%20entropy%20source%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.032%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20random.4..0%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20700%26nbsp%3B%20Registered%20path%20names%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.032%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20random.4..0%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20700%26nbsp%3B%20random%3A%20starting%20resmgr%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.032%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20random.4..0%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20700%26nbsp%3B%20random%3A%20Daemonizing%20the%20process%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.042%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bdevc_serlinflexd.7%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog*%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B0%26nbsp%3B%20serlinflexd_interrupt_attach%3A%20Attaching%20to%20interrupt%20114%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.047%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20iopkt.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20main_buffer*%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B0%26nbsp%3B%20tcpip%20starting%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.047%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20iopkt.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20main_buffer%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20smmu%20support%20is%20disabled%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.049%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20iopkt.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20main_buffer%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20initializing%20IPsec...%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.049%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20iopkt.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20main_buffer%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20%26nbsp%3Bdone%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.049%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20iopkt.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20main_buffer%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20IPsec%3A%20Initialized%20Security%20Association%20Processing.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.051%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20iopkt.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20main_buffer%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20devnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cpfe0_mode%3Dsgmii%2Cpfe0_phy%3D0%2Cpfe1_mode%3Dsgmii%2Cpfe1_phy%3D1%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.052%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog*%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B0%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A1377%5D%3A%20VERSION%20INFO%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EDriver%20version%3A%201.4.0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EDriver%20commit%20hash%3A%202f3265a49ac18f94ba5e48254c8f870fe7bfc511%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_MULTI_INSTANCE_SUPPORT%3A%200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_LOCAL_IF%3A%206%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_MASTER_IF%3A%206%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_SC_HIF%3A%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_HIF_RING_LENGTH%3A%20256%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_PFE0_PROMISC%3A%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_PFE1_PROMISC%3A%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_PFE2_PROMISC%3A%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.052%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A1384%5D%3A%20---%20Safe%20IRQ%20enabled.%20No%20InterrupAttach()%20or%20InterruptAttach_r()%20allowed.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.052%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_fw.c%3A83%5D%3A%2042792%20bytes%20read%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.053%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_fw.c%3A89%5D%3A%20Loaded%20firmware%20file%3A%20%2Fproc%2Fboot%2Fs32g_pfe_class.fw%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.053%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%20MII%20mode%20configuration%20for%20pfe0%2FEMAC0%20not%20found.%20Using%20SGMII.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.053%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%20MII%20mode%20configuration%20for%20pfe1%2FEMAC1%20not%20found.%20Using%20SGMII.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.053%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%20MII%20mode%20configuration%20for%20pfe2%2FEMAC2%20not%20found.%20Using%20RGMII.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.053%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A1495%5D%3A%20Issuing%20PFE%20peripheral%20reset...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.274%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A1496%5D%3A%20PFE%20reset%20OK.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.274%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3519%5D%3A%20PFE%20CBUS%20p0x46000000%20mapped%20%40%20v0x38f2e23000%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.274%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3524%5D%3A%20HW%20version%200x101%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.274%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_hw_feature.c%3A95%5D%3A%20Silicon%20S32G3%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.274%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3536%5D%3A%20Fail-Stop%20mode%20disabled%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.275%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2687%5D%3A%20PFE_ERRORS%3AParity%20instance%20created%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.275%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2702%5D%3A%20PFE_ERRORS%3AWatchdog%20instance%20created%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.275%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2718%5D%3A%20PFE_ERRORS%3ABus%20Error%20instance%20created%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.275%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2731%5D%3A%20PFE_ERRORS%3AFW%20Fail%20Stop%20instance%20created%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.275%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2744%5D%3A%20PFE_ERRORS%3AHost%20Fail%20Stop%20instance%20created%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.275%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2757%5D%3A%20PFE_ERRORS%3AFail%20Stop%20instance%20created%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.275%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2770%5D%3A%20PFE_ERRORS%3AECC%20Err%20instance%20created%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.275%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1766%5D%3A%20BMU1%20buffer%20base%3A%20p0xc0000000%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.277%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1810%5D%3A%20BMU2%20buffer%20base%3A%20p0x83000000%20(0x200000%20bytes)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.279%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20BMU%20IRQ%20Worker%20started%20(IRQ%20ID%3A%20226)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.279%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2194%5D%3A%20The%20option%20'g2_ordered_class_writes'%20is%20disabled.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.279%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x88000).%20Pool%20ready.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.279%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x8c000).%20Pool%20ready.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.281%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2239%5D%3A%20Firmware%20.elf%20detected%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.281%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2248%5D%3A%20Uploading%20CLASS%20firmware%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.281%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_pe.c%3A609%5D%3A%20Selected%20FW%20loading%20OPs%20to%20load%208%20PEs%20in%20parallel%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.285%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_pe.c%3A1945%5D%3A%20pfe_ct.h%20file%20version%2292367c0e25f21f49217a9b08168ad2c8%22%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.288%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_pe.c%3A2422%5D%3A%20%5BFW%20VERSION%5D%201.7.0%2C%20Build%3A%20Jun%26nbsp%3B%202%202023%2C%2013%3A48%3A57%20(nogitaaa)%2C%20ID%3A%200x31454650%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.406%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2312%5D%3A%20VLAN%20ID%20incorrect%20or%20not%20set.%20Using%20default%20VLAN%20ID%20%3D%200x01.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.406%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2318%5D%3A%20VLAN%20stats%20size%20incorrect%20or%20not%20set.%20Using%20default%20VLAN%20stats%20size%20%3D%2020.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.406%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_l2br.c%3A1181%5D%3A%20Software%20vlan%20hash%20table%20%40%20p0x20001228%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.406%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_l2br.c%3A1286%5D%3A%20Fall-back%20bridge%20domain%20%40%200x20000a7c%20(class)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.406%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_l2br.c%3A1287%5D%3A%20Default%20bridge%20domain%20%40%200x20000a74%20(class)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.406%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2412%5D%3A%20Routing%20table%20created%2C%20Hash%20Table%20%40%20p0x80014000%2C%20Pool%20%40%20p0x8001c000%20(65536%20bytes)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.407%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20Initializing%20RX%20buffer%20pool.%20Depth%3A%20256%3B%20Buffer%20Size%3A%202048%3B%20Cache%20Line%20Size%3A%2064%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.408%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20Initializing%20RX%20buffer%20pool.%20Depth%3A%20256%3B%20Buffer%20Size%3A%202048%3B%20Cache%20Line%20Size%3A%2064%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.409%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20Initializing%20RX%20buffer%20pool.%20Depth%3A%20256%3B%20Buffer%20Size%3A%202048%3B%20Cache%20Line%20Size%3A%2064%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.508%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3705%5D%3A%20Feature%20err051211_workaround%3A%20DISABLED%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.509%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20iopkt.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20main_buffer%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20pfe0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.509%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2152%5D%3A%20pfe0%3A%20Using%20PHY%20mode%3A%20MDIO%3D0%2C%20ADDR%3D0%2C%20CLAUSE%3D0%2C%20RESET%3D0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.509%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20HIF0%20IRQ%20Worker%20started%20(IRQ%20ID%3A%20222)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.509%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%20Adding%2000%3A0a%3A0b%3A0c%3A0d%3A66%20to%20pfe0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.511%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20iopkt.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20main_buffer%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20pfe1%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.511%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%20Speed%2Fduplex%20configuration%20for%20pfe0%20not%20found.%20Using%201%20Gbps%2Ffull-duplex.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.511%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20Attempt%20to%20register%20HIF%20client%3A%200%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.511%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20driver%20started%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.511%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%20New%20PFE%20device%3A%200%2C%20ID%3A%200%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.511%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2152%5D%3A%20pfe1%3A%20Using%20PHY%20mode%3A%20MDIO%3D1%2C%20ADDR%3D0%2C%20CLAUSE%3D0%2C%20RESET%3D0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.511%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20HIF1%20IRQ%20Worker%20started%20(IRQ%20ID%3A%20223)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.511%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%20Adding%2000%3A1a%3A1b%3A1c%3A1d%3A66%20to%20pfe1%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.513%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20iopkt.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20main_buffer%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20pfe2%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.513%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%20Speed%2Fduplex%20configuration%20for%20pfe1%20not%20found.%20Using%201%20Gbps%2Ffull-duplex.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.513%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20Attempt%20to%20register%20HIF%20client%3A%201%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.513%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20driver%20started%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.513%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%20New%20PFE%20device%3A%201%2C%20ID%3A%202%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.513%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3A%20pfe2%3A%20Using%20static%20PHY%20mode%2C%20RESET%3D0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.513%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20HIF2%20IRQ%20Worker%20started%20(IRQ%20ID%3A%20224)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.513%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%20Adding%2000%3A2a%3A2b%3A2c%3A2d%3A66%20to%20pfe2%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.515%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%20Speed%2Fduplex%20configuration%20for%20pfe2%20not%20found.%20Using%201%20Gbps%2Ffull-duplex.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.515%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20Attempt%20to%20register%20HIF%20client%3A%202%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.515%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20driver%20started%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.515%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%20New%20PFE%20device%3A%202%2C%20ID%3A%204%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.530%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2702%5D%3A%20Adding%2000%3A0a%3A0b%3A0c%3A0d%3A66%20to%20pfe0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.530%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20WRN%5Bsrc%2Fpfe_drv.c%3A2707%5D%3A%20Unable%20to%20assign%20MAC%20address%2000%3A0a%3A0b%3A0c%3A0d%3A66%20to%20the%20pfe0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.530%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.538%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_mdio.c%3A427%5D%3A%20pfe0%3A%20PHY%20%40%20bus%200%20addr%200%20not%20found.%20Switching%20to%20static%20mode.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.538%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3A%20EMAC%20speed%20change%20for%20SGMII%20is%20currently%20not%20supported.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.538%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3Aff%3A0c%3A0d%3A66%20to%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.540%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.540%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3A00%3A00%3A00%3A01%20to%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.542%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3Aff%3A0c%3A0d%3A66%20to%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.542%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3Aff%3A0c%3A0d%3A66%20into%20emac0%3A%2017%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.542%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.542%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3A00%3A00%3A00%3A01%20to%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.542%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3A00%3A00%3A00%3A01%20into%20emac0%3A%2017%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.542%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3Aff%3A0c%3A0d%3A66%20to%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.542%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3Aff%3A0c%3A0d%3A66%20into%20emac0%3A%2017%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.542%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.542%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3A%20EMAC%20speed%20change%20for%20SGMII%20is%20currently%20not%20supported.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.542%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2001%3A00%3A5e%3A00%3A00%3A01%20to%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.544%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3A00%3A00%3A00%3A01%20to%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.544%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3A00%3A00%3A00%3A01%20into%20emac0%3A%2017%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.544%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3Aff%3A0c%3A0d%3A66%20to%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.544%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3Aff%3A0c%3A0d%3A66%20into%20emac0%3A%2017%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.544%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_pkt_v6_hc.8%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.554%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bspi_master.24585%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bnormal*%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B0%26nbsp%3B%20Starting%20spi-master%20resource%20manager%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.558%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bspi_master.24587%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bnormal*%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B0%26nbsp%3B%20Starting%20spi-master%20resource%20manager%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.561%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bspi_master.24588%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bnormal*%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B0%26nbsp%3B%20Starting%20spi-master%20resource%20manager%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.565%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bspi_master.24589%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bnormal*%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B0%26nbsp%3B%20Starting%20spi-master%20resource%20manager%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.582%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog*%26nbsp%3B%201800%26nbsp%3B%20devb-sdmmc-mx8x%201.00A%20(Jun%2023%202026%2009%3A45%3A48)%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.583%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20libcam.so%20(Jun%2022%202020%2021%3A33%3A15)%20bver%207010003%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.594%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20sdio_cd%3A%26nbsp%3B%20insertion%20path%200%2C%20cd%20state%200x1%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.644%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20SD%20CID%3A%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.644%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20%26nbsp%3B%20MID%200x27%2C%20OID%200x5048%2C%20PNM%20SD32G%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.644%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20%26nbsp%3B%20PRV%200x62%2C%20PSN%200x6c62d132%2C%20MDT%204-2023%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.644%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20SD%20CSD%3A%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.644%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20%26nbsp%3B%20CSD_STRUCTURE%201%2C%20SPEC_VERS%200%2C%20CCC%200x5b5%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.644%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20%26nbsp%3B%20TAAC%2014%2C%20NSAC%200%2C%20TRAN_SPEED%2050%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.644%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20%26nbsp%3B%20C_SIZE%2059023%2C%20C_SIZE_MULT%200%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.644%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20%26nbsp%3B%20READ_BL_LEN%209%2C%20WRITE_BL_LEN%209%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.644%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20%26nbsp%3B%20ERASE%20GRP_SIZE%200%2C%20GRP_MULT%200%2C%20SIZE%20127%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.644%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20%26nbsp%3B%20blksz%20512%2C%20sectors%2060440576%2C%20dtr%2025000000%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.644%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20SD%20SW%20CAPS%3A%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.644%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20%26nbsp%3B%20bus%20mode%200x3%2C%20cmd%20sys%200x1%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.644%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20%26nbsp%3B%20drv%20type%200x1%2C%20curr%20limit%200x1%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.644%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20%26nbsp%3B%20dtr%2050000000%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.644%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1800%26nbsp%3B%20CFG%3A%26nbsp%3B%20Timing%20HS%2C%20DTR%2050000000%2C%20Bus%20Width%204%20bit%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.645%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20100%26nbsp%3B%20cam-disk.so%20(Jun%2022%202020%2021%3A33%3A17)%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.647%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%26nbsp%3B%20cam_status%3Dc4%2C%20scsi_status%3D2%2C%20flag%3D00000040%2C%20vuflag%3D0008%2C%20cmd%3D1a%2C%20error%3D70%2C%20sense%3D5%2C%20asc%3D24%2C%20ascq%3D0%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.647%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%26nbsp%3B%20cam_status%3Dc4%2C%20scsi_status%3D2%2C%20flag%3D00000040%2C%20vuflag%3D0008%2C%20cmd%3D5a%2C%20error%3D70%2C%20sense%3D5%2C%20asc%3D24%2C%20ascq%3D0%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A00.647%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%26nbsp%3B%20cam_status%3Dc4%2C%20scsi_status%3D2%2C%20flag%3D00000040%2C%20vuflag%3D0008%2C%20cmd%3D5a%2C%20error%3D70%2C%20sense%3D5%2C%20asc%3D24%2C%20ascq%3D0%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.827%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1000%26nbsp%3B%20fs-qnx6%3A%20Allocation%20strategy%200%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.827%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1000%26nbsp%3B%20fs-qnx6%3A%20Use%20btree%20directory%200%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.828%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20devb_sdmmc_mx8x.24595%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B1000%26nbsp%3B%20fs-qnx6%3A%20fs-qnx6%3A%20trim%20(0%2C1048576%2C2)%20was%20not%20requested%2C%20and%20is%20NOT%20supported%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.833%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog*%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B0%26nbsp%3B%20main(453)%5Btid%3A1%5D%3A%20io-usb-otg%20(Jun%2013%202020%2020%3A10%3A17)%20args%3A%20-d%20hcd-ehci-mx28%20ioport%3D0x44064100%2Cirq%3D243%2Culpi%2Cno_stream%2Cverbose%3D5%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.835%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bdevf_qspi_s32g.36884%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog*%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B0%26nbsp%3B%20(devf%26nbsp%3B%20t1%3A%3Af3s_qspi_ident%3A73)%20Page%20size%3A%20256%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.835%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bdevf_qspi_s32g.36884%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20(devf%26nbsp%3B%20t1%3A%3Af3s_qspi_ident%3A74)%20Total%20chip%20size%3A%200x4000000%2C%20Unit%20size%3A%200x10000%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.839%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20ehci_init%3A%20Initialiaing%20with%20sever%20version%3A%202%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.839%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20ehci_controller_init(4303)%3A%20devu-hcd-ehci-mx28.so%20(Apr%2019%202024%2013%3A44%3A54)%3A%26nbsp%3B%20args%20ulpi%2Cno_stream%2Cverbose%3D5%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.840%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%208%26nbsp%3B%20usb_enum_port(94)%5Btid%3A1%5D%3A%20busno%200%2C%20parent%20-1%2C%20port%200%2C%20High%20speed%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.840%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B11%26nbsp%3B%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(type%201%2C%20index%200%2C%20length%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.840%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B12%26nbsp%3B%20usb_device_set_address(245)%5Btid%3A1%5D%3A%20b%3A0%20devno%200%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.840%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B11%26nbsp%3B%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(type%201%2C%20index%200%2C%20length%2018)%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.841%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B11%26nbsp%3B%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(type%202%2C%20index%200%2C%20length%209)%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.841%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B11%26nbsp%3B%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(type%202%2C%20index%200%2C%20length%2025)%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.841%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%208%26nbsp%3B%20usb_enum_port(141)%5Btid%3A1%5D%3A%20vid%200x0000%2C%20did%200x0000%20enumerated(busno%200%2C%20devno%200%3A0)%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.841%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B11%26nbsp%3B%20hub_state_inserted(569)%5Btid%3A1%5D%3A%20bdentry%200%2C%20dentry%200%200%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.841%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B13%26nbsp%3B%20hub_configuration_enable(263)%5Btid%3A1%5D%3A%201%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.943%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20usbh_timeout_init(203)%5Btid%3A1%5D%3A%20Complete%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.954%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20read_vid_pid%3A%20ULPI%20VID%200x0424%20PID%200x0009%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.954%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20s32g_phy_set_vbus%3A%20set_vbus%20off%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.968%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20s32g_phy_set_vbus%3A%20set_vbus%20on%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.979%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20ehci_get_port_status(3568%200x44064100)%3A%20port%3D0%2C%20tpstatus%2010100%20e_pstatus%208c001000%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.979%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%208%26nbsp%3B%20usb_enum_port_extract(172)%5Btid%3A7%5D%3A%20(busno%200%2C%20pdevno%200%2C%20portno%201)%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.979%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%208%26nbsp%3B%20usb_enum_port_extract(192)%5Btid%3A7%5D%3A%20status%20(2)%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.983%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bdevb_umass.36886%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog*%26nbsp%3B%20%26nbsp%3B900%26nbsp%3B%20devb-umass%201.00A%20(Jun%2022%202020%2021%3A33%3A41)%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.984%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bdevb_umass.36886%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20libcam.so%20(Jun%2022%202020%2021%3A33%3A15)%20bver%207010003%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.985%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20usbdi_client_connect(58)%5Btid%3A5%5D%3A%20pid%2036886%20proc%3Dproc%2Fboot%2Fdevb-umass%20usbdi_client%2032eebb9a80%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.986%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bio_usb_otg.36885%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20usbdi_resmgr_connect(310)%5Btid%3A5%5D%3A%20usbdi_resmgr_connect%3A%20pid%2036886%20usbdi_client%2032eebb9a80%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EJan%2001%2000%3A00%3A01.986%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bdevb_umass.36886%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bslog%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200%26nbsp%3B%20usbdi%20debug%20path%20%2Fpps%2Fusb%2Fdebug%2F%20doesn't%20exist%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%2049177%20(slog2info)%20exited%20status%3D0.%3C%2FDIV%3E%3CDIV%3E%23%20ifconfig%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Elo0%3A%20flags%3D8049%3CUP%3E%20mtu%2033136%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%20127.0.0.1%20netmask%200xff000000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20%3A%3A1%20prefixlen%20128%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A1%25lo0%20prefixlen%2064%20scopeid%200x1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe0%3A%20flags%3D8843%3CUP%3E%20mtu%201500%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eenabled%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eaddress%3A%2000%3A0a%3A0b%3A0c%3A0d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emedia%3A%20Ethernet%20none%20(1000baseT%20full-duplex)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%3A%20active%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%200.0.0.0%20netmask%200xff000000%20broadcast%20255.255.255.255%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A20a%3Abff%3Afe0c%3Ad66%25pfe0%20prefixlen%2064%20scopeid%200x11%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe1%3A%20flags%3D8802%3CBROADCAST%3E%20mtu%201500%3C%2FBROADCAST%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eenabled%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eaddress%3A%2000%3A1a%3A1b%3A1c%3A1d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emedia%3A%20Ethernet%20none%20(1000baseT%20full-duplex)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%3A%20no%20carrier%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe2%3A%20flags%3D8802%3CBROADCAST%3E%20mtu%201500%3C%2FBROADCAST%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eenabled%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eaddress%3A%2000%3A2a%3A2b%3A2c%3A2d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emedia%3A%20Ethernet%20none%20(1000baseT%20full-duplex)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%3A%20no%20carrier%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%2057369%20(ifconfig)%20exited%20status%3D0.%3C%2FDIV%3E%3CDIV%3E%23%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2385521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOk%2C%20so%20I%20replaced%20s32g_pfe_class.fw%20and%20s32g_pfe_util.fw%20with%20the%20files%20from%26nbsp%3B%3CSPAN%3EPFE-FW_S32G_1.6.0.zip%20here%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D14074877%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D14074877%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EUboot%20parameters%3A%3C%2FP%3E%3CP%3Esetenv%20boot_qnx_atf%20'mmc%20dev%200%3B%20fatload%20mmc%200%3A1%200x83e00000%20s32g399a-rdb3.dtb%3B%20run%20atf_fdt_0to3%3B%20run%20atf_fdt_4to7%3B%20fatload%20mmc%200%3A1%200x80080000%20ifs-s32g399a-rdb.ui%3B%20pfeng%20enable%3B%20s32ccgmac%20disable%3B%20s32ccgmac%20enable%3B%20bootm%200x80080000%20-%200x83E00000'%3CBR%20%2F%3Esetenv%20atf_fdt_0to3%20'fdt%20addr%200x83e00000%3B%20fdt%20resize%3B%20fdt%20set%20%2Fcpus%2Fcpu%401%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40100%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40101%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B'%3CBR%20%2F%3Esetenv%20atf_fdt_4to7%20'fdt%20set%20%2Fcpus%2Fcpu%402%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%403%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40102%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40103%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B'%3CBR%20%2F%3Esetenv%20release_cpus%20'run%20cpu_trap%3B%20mp%201%20release%200xa0000000%3B%20mp%202%20release%200xa0000000%3B%20mp%203%20release%200xa0000000%3B%20mp%204%20release%200xa0000000%3B%20mp%205%20release%200xa0000000%3B%20mp%206%20release%200xa0000000%3B%20mp%207%20release%200xa0000000%3B'%3CBR%20%2F%3Esetenv%20cpu_trap%20'dcache%20off%3B%20mw.l%200xa0000000%200xd503205f%3B%20mw.l%200xa0000004%200x58000060%3B%20mw.l%200xa0000008%200xb4ffffc0%3B%20mw.l%200xa000000C%200xd61f0000%3B%20mw.q%200xa0000010%200x00000000%3B%20dcache%20on%3B'%3CBR%20%2F%3Esetenv%20bootcmd%20'run%20boot_qnx_atf'%3CBR%20%2F%3Esetenv%20hwconfig%20%22pcie0%3Amode%3Drc%2Cclock%3Dext%3Bpcie1%3Amode%3Dsgmii%2Cclock%3Dext%2Cfmhz%3D125%2Cxpcs_mode%3D2G5%22%3CBR%20%2F%3Esetenv%20pfeng_mode%20'enable%2Csgmii%2Csgmii%2Crgmii'%3CBR%20%2F%3Esetenv%20s32cc_gmac_mode%20disable%3CBR%20%2F%3Esaveenv%3C%2FP%3E%3CP%3ENote%3A%20I%20removed%20the%20release_cpus%20command%20from%26nbsp%3Bboot_qnx_atf%20because%20then%20I%20would%20havef%20a%20cpu%201%20error.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EDoesn't%20look%20much%20better%20to%20me%3A%3C%2FP%3E%3CDIV%3ENOTICE%3A%26nbsp%3B%20BL2%3A%20v2.5(release)%3Absp37.0_rc6-2.5%3C%2FDIV%3E%3CDIV%3ENOTICE%3A%26nbsp%3B%20BL2%3A%20Built%20%3A%2009%3A12%3A21%2C%20Jun%2013%202023%3C%2FDIV%3E%3CDIV%3ENOTICE%3A%26nbsp%3B%20BL2%3A%20Booting%20BL31%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EU-Boot%202020.04%2Bg156b168010%20(Jun%2009%202023%20-%2010%3A14%3A25%20%2B0000)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECPU%3A%26nbsp%3B%20%26nbsp%3BNXP%20S32G399A%20rev.%201.1%3C%2FDIV%3E%3CDIV%3EModel%3A%20NXP%20S32G399A-RDB3%3C%2FDIV%3E%3CDIV%3EDRAM%3A%26nbsp%3B%203.5%20GiB%3C%2FDIV%3E%3CDIV%3EMMC%3A%26nbsp%3B%20%26nbsp%3BFSL_SDHC%3A%200%3C%2FDIV%3E%3CDIV%3ELoading%20Environment%20from%20MMC...%20OK%3C%2FDIV%3E%3CDIV%3EConfiguring%20PCIe0%20as%20RootComplex%3C%2FDIV%3E%3CDIV%3EPCIe0%3A%20Failed%20to%20get%20link%20up%3C%2FDIV%3E%3CDIV%3EPCI%3A%20Failed%20autoconfig%20bar%201c%3C%2FDIV%3E%3CDIV%3EIn%3A%26nbsp%3B%20%26nbsp%3B%20serial%40401c8000%3C%2FDIV%3E%3CDIV%3EOut%3A%26nbsp%3B%20%26nbsp%3Bserial%40401c8000%3C%2FDIV%3E%3CDIV%3EErr%3A%26nbsp%3B%20%26nbsp%3Bserial%40401c8000%3C%2FDIV%3E%3CDIV%3EBoard%20revision%3A%20RDB3%20Revision%20F%3C%2FDIV%3E%3CDIV%3ENet%3A%26nbsp%3B%20%26nbsp%3BEQOS%20phy%3A%20rgmii%20%40%201%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EWarning%3A%20eth_eqos%20(eth0)%20using%20random%20MAC%20address%20-%2016%3Aec%3Aa0%3A4e%3A1d%3A7c%3C%2FDIV%3E%3CDIV%3Eeth0%3A%20eth_eqosFailed%20to%20get%20speed%20of%20XPCS%20for%20emac1_xpcs%20PFE%3A%20emac0%3A%20sgmii%20emac1%3A%20sgmii%20emac2%3A%20rgmii%3C%2FDIV%3E%3CDIV%3E%2C%20eth1%3A%20eth_pfeng%3C%2FDIV%3E%3CDIV%3EHit%20any%20key%20to%20stop%20autoboot%3A%26nbsp%3B%203%20%26%238%3B%26%238%3B%26%238%3B%202%20%26%238%3B%26%238%3B%26%238%3B%201%20%26%238%3B%26%238%3B%26%238%3B%200%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eswitch%20to%20partitions%20%230%2C%20OK%3C%2FDIV%3E%3CDIV%3Emmc0%20is%20current%20device%3C%2FDIV%3E%3CDIV%3E50640%20bytes%20read%20in%2017%20ms%20(2.8%20MiB%2Fs)%3C%2FDIV%3E%3CDIV%3E11950600%20bytes%20read%20in%20534%20ms%20(21.3%20MiB%2Fs)%3C%2FDIV%3E%3CDIV%3E%23%23%20Booting%20kernel%20from%20Legacy%20Image%20at%2080080000%20...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BImage%20Name%3A%26nbsp%3B%20%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BImage%20Type%3A%26nbsp%3B%20%26nbsp%3BAArch64%20Linux%20Kernel%20Image%20(uncompressed)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BData%20Size%3A%26nbsp%3B%20%26nbsp%3B%2011950536%20Bytes%20%3D%2011.4%20MiB%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BLoad%20Address%3A%2080080000%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BEntry%20Point%3A%26nbsp%3B%2080080000%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BVerifying%20Checksum%20...%20OK%3C%2FDIV%3E%3CDIV%3E%23%23%20Flattened%20Device%20Tree%20blob%20at%2083e00000%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BBooting%20using%20the%20fdt%20blob%20at%200x83e00000%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BLoading%20Kernel%20Image%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3BUsing%20Device%20Tree%20in%20place%20at%200000000083e00000%2C%20end%200000000083e0ffff%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3Bfixup%3A%20pfe0%20set%20to%2000%3A01%3Abe%3Abe%3Aef%3A11%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3Bfixup%3A%20pfe1%20set%20to%2000%3A01%3Abe%3Abe%3Aef%3A22%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3Bfixup%3A%20pfe1%3A%20update%20phy%20addr%20to%200x8%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3Bfixup%3A%20pfe2%20set%20to%2000%3A01%3Abe%3Abe%3Aef%3A33%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EStarting%20kernel%20...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EReserving%20RAM%20region%20for%20PFE%20driver%20on%20EVB%2FRDB%3C%2FDIV%3E%3CDIV%3EDone.%3C%2FDIV%3E%3CDIV%3EClockCycles%20samples%3A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B0%2043642864%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B1%2043642864%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B2%2043642864%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B3%2043642864%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B4%2043642864%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B5%2043642864%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B6%2043642864%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B7%2043642864%3C%2FDIV%3E%3CDIV%3EAll%20ClockCycles%20offsets%20within%20tolerance%3C%2FDIV%3E%3CDIV%3EWelcome%20to%20QNX%20Neutrino%207.1.0%20on%20the%20NXP%20S32G399A%20RDB%20Board!!%3C%2FDIV%3E%3CDIV%3EStarting%20watchdog...%3C%2FDIV%3E%3CDIV%3EStarting%20serial%20driver%20...%3C%2FDIV%3E%3CDIV%3EStarting%20Networking%20driver%20(%2Fdev%2Fsocket)...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%204107%20(ifconfig)%20exited%20status%3D0.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%2010%20(sh)%20exited%20status%3D0.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%209%20(dhclient)%20exited%20status%3D0.%3C%2FDIV%3E%3CDIV%3Ecp%3A%20Can't%20open%20source%20file.%26nbsp%3B%20(%2Fproc%2Fboot%2Flibfci_cli)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%2020489%20(cp)%20exited%20status%3D1.%3C%2FDIV%3E%3CDIV%3EStarting%20SPI%20driver%20(%2Fdev%2Fspi0%2C1%2C2%2C3%2C4%2C5)...%3C%2FDIV%3E%3CDIV%3EStarting%20I2C%200%2F1%2F2%2F3%2F4%20driver%20(%2Fdev%2Fi2c0%2C1%2C2%2C3%2C4)...%3C%2FDIV%3E%3CDIV%3EStarting%20USDHC0%20memory%20card%20driver...%3C%2FDIV%3E%3CDIV%3E%5B00%5D%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BSIM%3D%22SDMMC%22%20HBA%3D%22imx%22%3C%2FDIV%3E%3CDIV%3E%5B00%2C0%2C0%5D%20type%3D00%20ver%3D05%20resp%3D00%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BSDMMC%3A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%2024596%20(chkqnx6fs)%20exited%20status%3D0.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%2028692%20(mount)%20exited%20status%3D0.%3C%2FDIV%3E%3CDIV%3EStarting%20QSPI%20Flash%20driver...%3C%2FDIV%3E%3CDIV%3EStarting%20USB%20host%20driver%20(%2Fdev%2Fusb%2F*)%3C%2FDIV%3E%3CDIV%3EDetected%20QSPI%20Flash%3A%20Macronix%20MX25UW512%2C%20JEDEC%200xC2%20-%200x813A%2C%20Size%3A%200x4000000%3C%2FDIV%3E%3CDIV%3ELaunching%20devb-umass%20for%20%2Fdev%2Fusb%2F*%20...%3C%2FDIV%3E%3CDIV%3E%23%20ifconfig%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Elo0%3A%20flags%3D8049%3CUP%3E%20mtu%2033136%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%20127.0.0.1%20netmask%200xff000000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20%3A%3A1%20prefixlen%20128%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A1%25lo0%20prefixlen%2064%20scopeid%200x1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe0%3A%20flags%3D8843%3CUP%3E%20mtu%201500%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eenabled%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eaddress%3A%2000%3A0a%3A0b%3A0c%3A0d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emedia%3A%20Ethernet%20none%20(1000baseT%20full-duplex)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%3A%20active%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%200.0.0.0%20netmask%200xff000000%20broadcast%20255.255.255.255%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A20a%3Abff%3Afe0c%3Ad66%25pfe0%20prefixlen%2064%20scopeid%200x11%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe1%3A%20flags%3D8802%3CBROADCAST%3E%20mtu%201500%3C%2FBROADCAST%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eenabled%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eaddress%3A%2000%3A1a%3A1b%3A1c%3A1d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emedia%3A%20Ethernet%20none%20(1000baseT%20full-duplex)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%3A%20no%20carrier%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe2%3A%20flags%3D8802%3CBROADCAST%3E%20mtu%201500%3C%2FBROADCAST%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eenabled%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eaddress%3A%2000%3A2a%3A2b%3A2c%3A2d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emedia%3A%20Ethernet%20none%20(1000baseT%20full-duplex)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%3A%20no%20carrier%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%2040985%20(ifconfig)%20exited%20status%3D0.%3C%2FDIV%3E%3CDIV%3E%23%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%2036891%20(sleep)%20exited%20status%3D0.%3C%2FDIV%3E%3CDIV%3Esh%3A%20%2Fvar%2Fcetitec2%2Fstartup.sh%3A%20No%20such%20file%20or%20directory%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EProcess%2053273%20(sh)%20terminated%20signo%3D0%20code%3D0%20by%20process%200%20value%3D0.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%23%20ifconfig%20%26%238%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Elo0%3A%20flags%3D8049%3CUP%3E%20mtu%2033136%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%20127.0.0.1%20netmask%200xff000000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20%3A%3A1%20prefixlen%20128%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A1%25lo0%20prefixlen%2064%20scopeid%200x1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe0%3A%20flags%3D8843%3CUP%3E%20mtu%201500%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eenabled%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eaddress%3A%2000%3A0a%3A0b%3A0c%3A0d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emedia%3A%20Ethernet%20none%20(1000baseT%20full-duplex)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%3A%20active%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%200.0.0.0%20netmask%200xff000000%20broadcast%20255.255.255.255%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A20a%3Abff%3Afe0c%3Ad66%25pfe0%20prefixlen%2064%20scopeid%200x11%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe1%3A%20flags%3D8802%3CBROADCAST%3E%20mtu%201500%3C%2FBROADCAST%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eenabled%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eaddress%3A%2000%3A1a%3A1b%3A1c%3A1d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emedia%3A%20Ethernet%20none%20(1000baseT%20full-duplex)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%3A%20no%20carrier%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe2%3A%20flags%3D8802%3CBROADCAST%3E%20mtu%201500%3C%2FBROADCAST%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eenabled%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eaddress%3A%2000%3A2a%3A2b%3A2c%3A2d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emedia%3A%20Ethernet%20none%20(1000baseT%20full-duplex)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%3A%20no%20carrier%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CP%3E%23%20slog2info%20%7C%20grep%20pfe%3C%2FP%3E%3CP%3EJan%2001%2000%3A00%3A00.051%20iopkt.8%20main_buffer%200%20devnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8%20slog*%200%20INF%5Bsrc%2Fpfe_drv.c%3A1377%5D%3A%20VERSION%20INFO%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1384%5D%3A%20---%20Safe%20IRQ%20enabled.%20No%20InterrupAttach()%20or%20InterruptAttach_r()%20allowed.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A83%5D%3A%2049480%20bytes%20read%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A89%5D%3A%20Loaded%20firmware%20file%3A%20%2Fproc%2Fboot%2Fs32g_pfe_class.fw%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%20MII%20mode%20configuration%20for%20pfe0%2FEMAC0%20not%20found.%20Using%20SGMII.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%20MII%20mode%20configuration%20for%20pfe1%2FEMAC1%20not%20found.%20Using%20SGMII.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%20MII%20mode%20configuration%20for%20pfe2%2FEMAC2%20not%20found.%20Using%20RGMII.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1495%5D%3A%20Issuing%20PFE%20peripheral%20reset...%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1496%5D%3A%20PFE%20reset%20OK.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3519%5D%3A%20PFE%20CBUS%20p0x46000000%20mapped%20%40%20v0x1abef95000%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3524%5D%3A%20HW%20version%200x101%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hw_feature.c%3A95%5D%3A%20Silicon%20S32G3%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3536%5D%3A%20Fail-Stop%20mode%20disabled%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2687%5D%3A%20PFE_ERRORS%3AParity%20instance%20created%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2702%5D%3A%20PFE_ERRORS%3AWatchdog%20instance%20created%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2718%5D%3A%20PFE_ERRORS%3ABus%20Error%20instance%20created%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2731%5D%3A%20PFE_ERRORS%3AFW%20Fail%20Stop%20instance%20created%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2744%5D%3A%20PFE_ERRORS%3AHost%20Fail%20Stop%20instance%20created%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2757%5D%3A%20PFE_ERRORS%3AFail%20Stop%20instance%20created%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2770%5D%3A%20PFE_ERRORS%3AECC%20Err%20instance%20created%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1766%5D%3A%20BMU1%20buffer%20base%3A%20p0xc0000000%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.277%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1810%5D%3A%20BMU2%20buffer%20base%3A%20p0x83000000%20(0x200000%20bytes)%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.279%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2194%5D%3A%20The%20option%20'g2_ordered_class_writes'%20is%20disabled.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.279%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x88000).%20Pool%20ready.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.279%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x8c000).%20Pool%20ready.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.281%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2239%5D%3A%20Firmware%20.elf%20detected%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.281%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2248%5D%3A%20Uploading%20CLASS%20firmware%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.281%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A609%5D%3A%20Selected%20FW%20loading%20OPs%20to%20load%208%20PEs%20in%20parallel%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.285%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A1945%5D%3A%20pfe_ct.h%20file%20version%2292367c0e25f21f49217a9b08168ad2c8%22%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.288%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A2422%5D%3A%20%5BFW%20VERSION%5D%201.6.0%2C%20Build%3A%20Mar%2015%202023%2C%2012%3A37%3A54%20()%2C%20ID%3A%200x31454650%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.406%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2312%5D%3A%20VLAN%20ID%20incorrect%20or%20not%20set.%20Using%20default%20VLAN%20ID%20%3D%200x01.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.406%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2318%5D%3A%20VLAN%20stats%20size%20incorrect%20or%20not%20set.%20Using%20default%20VLAN%20stats%20size%20%3D%2020.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.406%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1181%5D%3A%20Software%20vlan%20hash%20table%20%40%20p0x20001208%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.406%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1286%5D%3A%20Fall-back%20bridge%20domain%20%40%200x20000a44%20(class)%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.406%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1287%5D%3A%20Default%20bridge%20domain%20%40%200x20000a3c%20(class)%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.406%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2412%5D%3A%20Routing%20table%20created%2C%20Hash%20Table%20%40%20p0x80014000%2C%20Pool%20%40%20p0x8001c000%20(65536%20bytes)%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.407%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20Initializing%20RX%20buffer%20pool.%20Depth%3A%20256%3B%20Buffer%20Size%3A%202048%3B%20Cache%20Line%20Size%3A%2064%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.408%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20Initializing%20RX%20buffer%20pool.%20Depth%3A%20256%3B%20Buffer%20Size%3A%202048%3B%20Cache%20Line%20Size%3A%2064%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.409%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20Initializing%20RX%20buffer%20pool.%20Depth%3A%20256%3B%20Buffer%20Size%3A%202048%3B%20Cache%20Line%20Size%3A%2064%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.508%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3705%5D%3A%20Feature%20err051211_workaround%3A%20DISABLED%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.509%20iopkt.8%20main_buffer%200%20pfe0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.509%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3A%20pfe0%3A%20Using%20static%20PHY%20mode%2C%20RESET%3D0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.510%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%20Adding%2000%3A0a%3A0b%3A0c%3A0d%3A66%20to%20pfe0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.512%20iopkt.8%20main_buffer%200%20pfe1%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%20Speed%2Fduplex%20configuration%20for%20pfe0%20not%20found.%20Using%201%20Gbps%2Ffull-duplex.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20Attempt%20to%20register%20HIF%20client%3A%200%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20driver%20started%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%20New%20PFE%20device%3A%200%2C%20ID%3A%200%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3A%20pfe1%3A%20Using%20static%20PHY%20mode%2C%20RESET%3D0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%20Adding%2000%3A1a%3A1b%3A1c%3A1d%3A66%20to%20pfe1%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.514%20iopkt.8%20main_buffer%200%20pfe2%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%20Speed%2Fduplex%20configuration%20for%20pfe1%20not%20found.%20Using%201%20Gbps%2Ffull-duplex.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20Attempt%20to%20register%20HIF%20client%3A%201%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20driver%20started%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%20New%20PFE%20device%3A%201%2C%20ID%3A%202%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3A%20pfe2%3A%20Using%20static%20PHY%20mode%2C%20RESET%3D0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%20Adding%2000%3A2a%3A2b%3A2c%3A2d%3A66%20to%20pfe2%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.516%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%20Speed%2Fduplex%20configuration%20for%20pfe2%20not%20found.%20Using%201%20Gbps%2Ffull-duplex.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.516%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20Attempt%20to%20register%20HIF%20client%3A%202%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.516%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20driver%20started%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.516%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%20New%20PFE%20device%3A%202%2C%20ID%3A%204%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2702%5D%3A%20Adding%2000%3A0a%3A0b%3A0c%3A0d%3A66%20to%20pfe0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2707%5D%3A%20Unable%20to%20assign%20MAC%20address%2000%3A0a%3A0b%3A0c%3A0d%3A66%20to%20the%20pfe0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3A%20EMAC%20speed%20change%20for%20SGMII%20is%20currently%20not%20supported.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.532%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3Aff%3A0c%3A0d%3A66%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.534%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.534%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3A00%3A00%3A00%3A01%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3Aff%3A0c%3A0d%3A66%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3Aff%3A0c%3A0d%3A66%20into%20emac0%3A%2017%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3A00%3A00%3A00%3A01%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3A00%3A00%3A00%3A01%20into%20emac0%3A%2017%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3Aff%3A0c%3A0d%3A66%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3Aff%3A0c%3A0d%3A66%20into%20emac0%3A%2017%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3A%20EMAC%20speed%20change%20for%20SGMII%20is%20currently%20not%20supported.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2001%3A00%3A5e%3A00%3A00%3A01%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3A00%3A00%3A00%3A01%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3A00%3A00%3A00%3A01%20into%20emac0%3A%2017%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3Aff%3A0c%3A0d%3A66%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3Aff%3A0c%3A0d%3A66%20into%20emac0%3A%2017%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%23%20slog2info%20%26%238%3B%20%7C%20grep%20io_pkt_v6_hc%3C%2FP%3E%3CP%3EJan%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8%20slog*%200%20INF%5Bsrc%2Fpfe_drv.c%3A1377%5D%3A%20VERSION%20INFO%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1384%5D%3A%20---%20Safe%20IRQ%20enabled.%20No%20InterrupAttach()%20or%20InterruptAttach_r()%20allowed.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A83%5D%3A%2049480%20bytes%20read%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A89%5D%3A%20Loaded%20firmware%20file%3A%20%2Fproc%2Fboot%2Fs32g_pfe_class.fw%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%20MII%20mode%20configuration%20for%20pfe0%2FEMAC0%20not%20found.%20Using%20SGMII.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%20MII%20mode%20configuration%20for%20pfe1%2FEMAC1%20not%20found.%20Using%20SGMII.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%20MII%20mode%20configuration%20for%20pfe2%2FEMAC2%20not%20found.%20Using%20RGMII.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1495%5D%3A%20Issuing%20PFE%20peripheral%20reset...%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1496%5D%3A%20PFE%20reset%20OK.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3519%5D%3A%20PFE%20CBUS%20p0x46000000%20mapped%20%40%20v0x1abef95000%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3524%5D%3A%20HW%20version%200x101%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hw_feature.c%3A95%5D%3A%20Silicon%20S32G3%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3536%5D%3A%20Fail-Stop%20mode%20disabled%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2687%5D%3A%20PFE_ERRORS%3AParity%20instance%20created%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2702%5D%3A%20PFE_ERRORS%3AWatchdog%20instance%20created%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2718%5D%3A%20PFE_ERRORS%3ABus%20Error%20instance%20created%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2731%5D%3A%20PFE_ERRORS%3AFW%20Fail%20Stop%20instance%20created%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2744%5D%3A%20PFE_ERRORS%3AHost%20Fail%20Stop%20instance%20created%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2757%5D%3A%20PFE_ERRORS%3AFail%20Stop%20instance%20created%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2770%5D%3A%20PFE_ERRORS%3AECC%20Err%20instance%20created%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1766%5D%3A%20BMU1%20buffer%20base%3A%20p0xc0000000%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.277%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1810%5D%3A%20BMU2%20buffer%20base%3A%20p0x83000000%20(0x200000%20bytes)%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.279%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2194%5D%3A%20The%20option%20'g2_ordered_class_writes'%20is%20disabled.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.279%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20BMU%20IRQ%20Worker%20started%20(IRQ%20ID%3A%20226)%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.279%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x88000).%20Pool%20ready.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.279%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x8c000).%20Pool%20ready.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.281%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2239%5D%3A%20Firmware%20.elf%20detected%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.281%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2248%5D%3A%20Uploading%20CLASS%20firmware%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.281%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A609%5D%3A%20Selected%20FW%20loading%20OPs%20to%20load%208%20PEs%20in%20parallel%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.285%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A1945%5D%3A%20pfe_ct.h%20file%20version%2292367c0e25f21f49217a9b08168ad2c8%22%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.288%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A2422%5D%3A%20%5BFW%20VERSION%5D%201.6.0%2C%20Build%3A%20Mar%2015%202023%2C%2012%3A37%3A54%20()%2C%20ID%3A%200x31454650%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.406%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2312%5D%3A%20VLAN%20ID%20incorrect%20or%20not%20set.%20Using%20default%20VLAN%20ID%20%3D%200x01.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.406%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2318%5D%3A%20VLAN%20stats%20size%20incorrect%20or%20not%20set.%20Using%20default%20VLAN%20stats%20size%20%3D%2020.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.406%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1181%5D%3A%20Software%20vlan%20hash%20table%20%40%20p0x20001208%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.406%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1286%5D%3A%20Fall-back%20bridge%20domain%20%40%200x20000a44%20(class)%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.406%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1287%5D%3A%20Default%20bridge%20domain%20%40%200x20000a3c%20(class)%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.406%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2412%5D%3A%20Routing%20table%20created%2C%20Hash%20Table%20%40%20p0x80014000%2C%20Pool%20%40%20p0x8001c000%20(65536%20bytes)%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.407%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20Initializing%20RX%20buffer%20pool.%20Depth%3A%20256%3B%20Buffer%20Size%3A%202048%3B%20Cache%20Line%20Size%3A%2064%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.408%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20Initializing%20RX%20buffer%20pool.%20Depth%3A%20256%3B%20Buffer%20Size%3A%202048%3B%20Cache%20Line%20Size%3A%2064%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.409%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20Initializing%20RX%20buffer%20pool.%20Depth%3A%20256%3B%20Buffer%20Size%3A%202048%3B%20Cache%20Line%20Size%3A%2064%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.508%20io_pkt_v6_hc.8%20slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3705%5D%3A%20Feature%20err051211_workaround%3A%20DISABLED%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.509%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3A%20pfe0%3A%20Using%20static%20PHY%20mode%2C%20RESET%3D0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.509%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20HIF0%20IRQ%20Worker%20started%20(IRQ%20ID%3A%20222)%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.510%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%20Adding%2000%3A0a%3A0b%3A0c%3A0d%3A66%20to%20pfe0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%20Speed%2Fduplex%20configuration%20for%20pfe0%20not%20found.%20Using%201%20Gbps%2Ffull-duplex.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20Attempt%20to%20register%20HIF%20client%3A%200%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20driver%20started%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%20New%20PFE%20device%3A%200%2C%20ID%3A%200%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3A%20pfe1%3A%20Using%20static%20PHY%20mode%2C%20RESET%3D0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20HIF1%20IRQ%20Worker%20started%20(IRQ%20ID%3A%20223)%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%20Adding%2000%3A1a%3A1b%3A1c%3A1d%3A66%20to%20pfe1%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%20Speed%2Fduplex%20configuration%20for%20pfe1%20not%20found.%20Using%201%20Gbps%2Ffull-duplex.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20Attempt%20to%20register%20HIF%20client%3A%201%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20driver%20started%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%20New%20PFE%20device%3A%201%2C%20ID%3A%202%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3A%20pfe2%3A%20Using%20static%20PHY%20mode%2C%20RESET%3D0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20HIF2%20IRQ%20Worker%20started%20(IRQ%20ID%3A%20224)%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%20Adding%2000%3A2a%3A2b%3A2c%3A2d%3A66%20to%20pfe2%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.516%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%20Speed%2Fduplex%20configuration%20for%20pfe2%20not%20found.%20Using%201%20Gbps%2Ffull-duplex.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.516%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20Attempt%20to%20register%20HIF%20client%3A%202%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.516%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20driver%20started%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.516%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%20New%20PFE%20device%3A%202%2C%20ID%3A%204%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2702%5D%3A%20Adding%2000%3A0a%3A0b%3A0c%3A0d%3A66%20to%20pfe0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2707%5D%3A%20Unable%20to%20assign%20MAC%20address%2000%3A0a%3A0b%3A0c%3A0d%3A66%20to%20the%20pfe0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3A%20EMAC%20speed%20change%20for%20SGMII%20is%20currently%20not%20supported.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.532%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3Aff%3A0c%3A0d%3A66%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.534%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.534%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3A00%3A00%3A00%3A01%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3Aff%3A0c%3A0d%3A66%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3Aff%3A0c%3A0d%3A66%20into%20emac0%3A%2017%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3A00%3A00%3A00%3A01%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3A00%3A00%3A00%3A01%20into%20emac0%3A%2017%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3Aff%3A0c%3A0d%3A66%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3Aff%3A0c%3A0d%3A66%20into%20emac0%3A%2017%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3A%20EMAC%20speed%20change%20for%20SGMII%20is%20currently%20not%20supported.%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2001%3A00%3A5e%3A00%3A00%3A01%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3A00%3A00%3A00%3A01%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3A00%3A00%3A00%3A01%20into%20emac0%3A%2017%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3Aff%3A0c%3A0d%3A66%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3Aff%3A0c%3A0d%3A66%20into%20emac0%3A%2017%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3C%2FP%3E%3CP%3EProcess%20172057%20(slog2info)%20exited%20status%3D0.%3CBR%20%2F%3EJan%2001%2000%3A01%3A01.630%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3A00%3A00%3A00%3A01%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A01%3A01.630%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3A00%3A00%3A00%3A01%20into%20emac0%3A%2017%3CBR%20%2F%3EJan%2001%2000%3A01%3A01.630%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%20Adding%2033%3A33%3Aff%3A0c%3A0d%3A66%20to%20emac0%3CBR%20%2F%3EJan%2001%2000%3A01%3A01.630%20io_pkt_v6_hc.8%20slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%20unable%20to%20add%2033%3A33%3Aff%3A0c%3A0d%3A66%20into%20emac0%3A%2017%3CBR%20%2F%3EJan%2001%2000%3A01%3A01.630%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2495%5D%3A%20Removing%2001%3A00%3A5e%3A00%3A00%3A01%20from%20emac0%3CBR%20%2F%3EJan%2001%2000%3A01%3A01.632%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_phy_if.c%3A2716%5D%3A%20Address%2001%3A00%3A5e%3A00%3A00%3A01%20removed%20from%20emac0%3CBR%20%2F%3EJan%2001%2000%3A01%3A01.632%20io_pkt_v6_hc.8%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2385407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post.%3C%2FP%3E%0A%3CP%3EBy%20default%2C%26nbsp%3Bthe%26nbsp%3B%3CSPAN%3ES32G%20PFE%20QNX%20Driver%20Version%201.4.0%20is%20compatible%20with%20S32G%20PFE%20Firmware%20Standard%20Version%201.6.0%2C%20would%20you%20mind%20testing%20it%20again%20with%20this%20PFE%20FW%20version%20instead%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EChenyin%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2386380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2386380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOk%2C%20so%20I%20downloaded%20the%26nbsp%3B%3C%2FP%3E%3CP%3EBSP_nxp-s32g-evb_br-710_be-710_SVN984052_JBN51%3C%2FP%3E%3CP%3Epackage%20you%20mentioned%2C%20modified%20the%20.build%20file%20and%20add%20the%26nbsp%3B%3C%2FP%3E%3CP%3Ekprintf(%22Reserving%20RAM%20region%20for%20PFE%20driver%20on%20EVB%2FRDB%5Cn%22)%3B%3CBR%20%2F%3Eas_add_containing(0x80000000%2C0x80000000%20%2B%200x4000000%20-%201%2CAS_ATTR_RAM%2C%20%22pfe_ddr%22%2C%22ram%22)%3B%3C%2FP%3E%3CP%3Eto%3C%2FP%3E%3CP%3Esrc%2Fhardware%2Fstartup%2Fboards%2Fs32g%2Fs32g399a-rdb%2Fs32g_init_raminfo.c%20and%20replace%20my%20ifs%20file%20with%20the%20resulting%20ifs-s32g399a-rdb.ui.%3C%2FP%3E%3CP%3EUnfortunately%2C%20it%20doesn't%20seem%20to%20execute%20the%20pfe_ddr%20allocation%20from%20above.%26nbsp%3B%3C%2FP%3E%3CP%3EIs%20there%20anything%20I%20need%20to%20modify%20for%20the%20uboot%20parameters%20or%20else%20for%20this%20new%20image%20to%20work%3F%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2386663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2386663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EI%20suggest%20referencing%20the%20integration%20manual%20strictly%2C%20refer%20to%20the%20part%20you%20mentioned%2C%20the%20following%20need%20to%20be%20modified%20before%20building%20the%20QNX%20BSP.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F390231i1339D06D28BE6C6B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1782443542271.png%22%20alt%3D%22chenyin_h_0-1782443542271.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Echenyin_h_0-1782443542271.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGreetings%2C%3C%2FP%3E%3CP%3Edo%20you%20know%20if%20NXP%20provides%20SDCard%20images%20that%20already%20have%20the%20uboot%20modifications%20necessary%20for%20PFE%20as%20in%20board_cleanup_before_linux%3F%3C%2FP%3E%3CP%3EI%20don't%20know%20what%20packages%20like%26nbsp%3Bbinaries_auto_linux_bsp37.0_s32g3_pfe%20do.%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAnd%20what%20was%20the%20PFE%20firmware%20version%20used%3F%3C%2FP%3E%3CP%3EJBN51%20needs%20NXP%20BSP39%20which%20comes%20with%20PFE%20Firmware%201.8.0.%20But%20section%202.1.3%20of%20the%20Pfe%20Driver%201.7.0%20release%20notes%20states%20that%20only%20PFW%20FW%201.10.0%20was%20tested%20with%20this%20release.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F390945iAC23A6EE62F0B101%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Seneca_0-1782903766239.png%22%20alt%3D%22Seneca_0-1782903766239.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESeneca_0-1782903766239.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EThe%20tested%20BSP%20version%20is%20BSP39%20combine%20with%26nbsp%3BQNX%20driver%20version%201.7.0%20and%20QNX%20SDP%207.1%20BSP%20JBN51%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGreetings%2C%3C%2FP%3E%3CP%3EI%20intend%20to%20try%20the%20following%20combination%3A%3C%2FP%3E%3CP%3EBSP%2033%3C%2FP%3E%3CP%3EPFE%20Driver%201.2.0%3C%2FP%3E%3CP%3EPFE%20FW%201.3.0%3C%2FP%3E%3CP%3EIs%20this%20officially%20supported%3F%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGreetings%2C%3C%2FP%3E%3CP%3EI%20intend%20to%20try%20the%20following%20combination%3A%3C%2FP%3E%3CP%3EBSP%2033%3C%2FP%3E%3CP%3EPFE%20Driver%201.2.0%3C%2FP%3E%3CP%3EPFE%20FW%201.3.0%3C%2FP%3E%3CP%3EIs%20this%20officially%20supported%3F%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello.%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3E1.%20For%20the%20combination%2C%20I%20suggest%20referencing%20the%20documents%20included%20in%20the%20QNX%20PFE%20drivers%20directly%2C%20which%20included%20the%20recommended%2Ftested%20combination.%3C%2FP%3E%0A%3CP%3EOther%20combination%20may%20or%20may%20not%20work%2C%20you%20may%20test%20it%20accordingly%20if%20indeed%20needed.%3C%2FP%3E%0A%3CP%3E2.%20From%20the%20available%20information%2C%20for%20QNX%20PFE%20drive%201.2%2C%20the%20supported%20PFE%20FW%20is%201.2%20with%20BSP30%20used%20for%20test%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Chenyin%2C%3C%2FP%3E%3CP%3Ecan%20you%20tell%20me%20which%20NXP%20BSP%20Version%20was%20used%20by%20the%20person%20who%20tested%20the%20PFE%20Driver%201.7.0%20with%20the%20QNXJBN51%3F%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ESorry%20that%20there%20are%20not%20such%20images%20for%20publicly%20downloaded.%3C%2FP%3E%0A%3CP%3EFor%20%22%3CSPAN%3Ebinaries_auto_linux_bsp37.0_s32g3_pfe%3C%2FSPAN%3E%22%2C%20seems%20it%20is%20the%20name%20of%20the%20tgz%20file%20from%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F390855iCCB52D1818442408%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1782879234963.png%22%20alt%3D%22chenyin_h_0-1782879234963.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Echenyin_h_0-1782879234963.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EIf%20so%2C%20it%20includes%20the%20pre-built%20binaries%20of%20Linux%20BSP%20provisioned%20by%20NXP%2C%20there%20are%20not%20any%20QNX%20related%20images%20included.%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EWould%20you%20mind%20providing%20the%20full%20booting%20log%20including%20all%20u-boot%20env%20information%20for%20further%20checking%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENote%3A%20io%20pkt%20is%20not%20started%20at%20the%20moment.%20Starting%20it%20will%20not%20remove%20the%20no%20carrier%20problem%20though.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EU-Boot%202022.04%20(Jul%2001%202026%20-%2016%3A53%3A39%20%2B0200)%3C%2FP%3E%3CP%3ESoC%3A%20NXP%20S32G399A%20rev.%201.1%3CBR%20%2F%3ECPU%3A%20ARM%20Cortex-A53%20r0p4%20%40%20max%201300%20MHz%3CBR%20%2F%3EModel%3A%20NXP%20S32G399A-RDB3%3CBR%20%2F%3EDRAM%3A%203.5%20GiB%3CBR%20%2F%3ECore%3A%20306%20devices%2C%2025%20uclasses%2C%20devicetree%3A%20board%3CBR%20%2F%3EMMC%3A%20FSL_SDHC%3A%200%3CBR%20%2F%3ELoading%20Environment%20from%20MMC...%20OK%3CBR%20%2F%3EIn%3A%20serial%40401c8000%3CBR%20%2F%3EOut%3A%20serial%40401c8000%3CBR%20%2F%3EErr%3A%20serial%40401c8000%3CBR%20%2F%3EBoard%20revision%3A%20RDB3%20Revision%20F%3CBR%20%2F%3EPCIe%3A%20BusDevFun%20VendorId%20DeviceId%20Device%20Class%20Sub-Class%3CBR%20%2F%3E__________________________________________________________________________%3CBR%20%2F%3Epcie%4040400000%20RootComplex%3CBR%20%2F%3E%7C%20%60--%2001%3A00.00%200x1957%200x4300%20Bridge%20device%200x04%3CBR%20%2F%3ENet%3A%20eth0%3A%20ethernet%404033c000%3CBR%20%2F%3EFound%20PFE%20version%200x0101%20(S32G3)%3CBR%20%2F%3E%2C%20eth1%3A%20pfe0%2C%20eth2%3A%20pfe1%2C%20eth3%3A%20pfe2%3CBR%20%2F%3EHit%20any%20key%20to%20stop%20autoboot%3A%202%20%26%238%3B%26%238%3B%26%238%3B%201%20%26%238%3B%26%238%3B%26%238%3B%200%3CBR%20%2F%3E%3D%26gt%3B%20printenv%3CBR%20%2F%3Eatf_fdt_0to3%3Dfdt%20addr%200x83e00000%3B%20fdt%20resize%3B%20fdt%20set%20%2Fcpus%2Fcpu%401%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40100%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40101%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%3CBR%20%2F%3Eatf_fdt_4to7%3Dfdt%20set%20%2Fcpus%2Fcpu%402%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%403%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40102%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40103%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%3CBR%20%2F%3Ebaudrate%3D115200%3CBR%20%2F%3Eboard_rev%3DF%3CBR%20%2F%3Eboot_mtd%3Dbooti%3CBR%20%2F%3Eboot_qnx_atf%3Dmmc%20dev%200%3B%20fatload%20mmc%200%3A1%200x83e00000%20s32g399a-rdb3.dtb%3B%20run%20atf_fdt_0to3%3B%20run%20atf_fdt_4to7%3B%20fatload%20mmc%200%3A1%200x80080000%20ifs-s32g399a-rdb.ui%3B%20bootm%200x80080000%20-%200x83E00000%3CBR%20%2F%3Ebootargs%3Droot%3D%2Fdev%2Fram%20rw%20earlycon%20loglevel%3D7%3CBR%20%2F%3Ebootcmd%3Drun%20boot_qnx_atf%3CBR%20%2F%3Ebootdelay%3D2%3CBR%20%2F%3Econsole%3DttyLF0%3CBR%20%2F%3Ecpu_trap%3Ddcache%20off%3B%20mw.l%200xa0000000%200xd503205f%3B%20mw.l%200xa0000004%200x58000060%3B%20mw.l%200xa0000008%200xb4ffffc0%3B%20mw.l%200xa000000C%200xd61f0000%3B%20mw.q%200xa0000010%200x00000000%3B%20dcache%20on%3B%3CBR%20%2F%3Eeth1addr%3D00%3A04%3A9f%3Abe%3Aef%3A00%3CBR%20%2F%3Eeth2addr%3D00%3A04%3A9f%3Abe%3Aef%3A01%3CBR%20%2F%3Eeth3addr%3D00%3A04%3A9f%3Abe%3Aef%3A02%3CBR%20%2F%3Eethaddr%3D0e%3A46%3A58%3A92%3A0b%3A68%3CBR%20%2F%3Efdt_addr%3D0x83000000%3CBR%20%2F%3Efdt_enable_hs400es%3Dfdt%20addr%20%24%7Bfdt_addr%7D%3B%20fdt%20rm%20%2Fsoc%2Fmmc%20no-1-8-v%3B%20fdt%20resize%3B%3CBR%20%2F%3Efdt_file%3Ds32g399a-rdb3.dtb%3CBR%20%2F%3Efdt_high%3D0xffffffffffffffff%3CBR%20%2F%3Efdt_override%3D%3B%3CBR%20%2F%3Efdtcontroladdr%3Dffa96000%3CBR%20%2F%3Eflashboot%3Decho%20Booting%20from%20flash...%3B%20run%20flashbootargs%3Bmtd%20read%20Kernel%20%24%7Bloadaddr%7D%3Bmtd%20read%20DTB%20%24%7Bfdt_addr%7D%3Bmtd%20read%20Rootfs%20%24%7Bramdisk_addr%7D%3B%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20%24%7Bramdisk_addr%7D%20%24%7Bfdt_addr%7D%3B%3CBR%20%2F%3Eflashbootargs%3Dsetenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fram%20rw%20earlycon%20%3Bsetenv%20flashsize%200x04000000%3B%3CBR%20%2F%3Ehwconfig%3Dserdes0%3Amode%3Dpcie%2Cclock%3Dext%3Bpcie0%3Amode%3Drc%3Bserdes1%3Amode%3Dxpcs0%26amp%3Bxpcs1%2Cclock%3Dext%2Cfmhz%3D125%3Bxpcs1_0%3Aspeed%3D2G5%3Bxpcs1_1%3Aspeed%3D1G%3CBR%20%2F%3Eimage%3DImage%3CBR%20%2F%3Einitrd_high%3D0xffffffffffffffff%3CBR%20%2F%3Eipaddr%3D10.0.0.100%3CBR%20%2F%3Eloadaddr%3D0x80000000%3CBR%20%2F%3Eloadfdt%3Dfatload%20mmc%20%24%7Bmmcdev%7D%3A%24%7Bmmcpart%7D%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%3B%20run%20fdt_override%3B%3CBR%20%2F%3Eloadimage%3Dfatload%20mmc%20%24%7Bmmcdev%7D%3A%24%7Bmmcpart%7D%20%24%7Bloadaddr%7D%20%24%7Bimage%7D%3CBR%20%2F%3Eloadtftpfdt%3Dtftp%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%3B%3CBR%20%2F%3Eloadtftpimage%3Dtftp%20%24%7Bloadaddr%7D%20%24%7Bimage%7D%3B%3CBR%20%2F%3Emmcargs%3Dsetenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%24%7Bmmcroot%7D%20earlycon%3CBR%20%2F%3Emmcboot%3Decho%20Booting%20from%20mmc%20...%3B%20run%20mmcargs%3B%20if%20run%20loadfdt%3B%20then%20run%20fdt_fixups%3B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%3B%20else%20echo%20WARN%3A%20Cannot%20load%20the%20DT%3B%20fi%3B%3CBR%20%2F%3Emmcdev%3D0%3CBR%20%2F%3Emmcpart%3D1%3CBR%20%2F%3Emmcroot%3D%2Fdev%2Fmmcblk0p2%20rootwait%20rw%3CBR%20%2F%3Enetargs%3Dsetenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fnfs%20ip%3Ddhcp%20nfsroot%3D%24%7Bserverip%7D%3A%24%7Bnfsroot%7D%2Cv3%2Ctcp%20earlycon%3CBR%20%2F%3Enetboot%3Decho%20Booting%20from%20net%20...%3B%20run%20netargs%3B%20if%20test%20%24%7Bip_dyn%7D%20%3D%20yes%3B%20then%20setenv%20get_cmd%20dhcp%3B%20else%20setenv%20get_cmd%20tftp%3B%20fi%3B%20%24%7Bget_cmd%7D%20%24%7Bimage%7D%3B%20if%20test%20%24%7Bboot_fdt%7D%20%3D%20yes%20%7C%7C%20test%20%24%7Bboot_fdt%7D%20%3D%20try%3B%20then%20if%20%24%7Bget_cmd%7D%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%3B%20then%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%3B%20else%20if%20test%20%24%7Bboot_fdt%7D%20%3D%20try%3B%20then%20%24%7Bboot_mtd%7D%3B%20else%20echo%20WARN%3A%20Cannot%20load%20the%20DT%3B%20fi%3B%20fi%3B%20else%20%24%7Bboot_mtd%7D%3B%20fi%3B%3CBR%20%2F%3Enetmask%3D255.255.255.0%3CBR%20%2F%3Enfsboot%3Decho%20Booting%20from%20net%20using%20tftp%20and%20nfs...%3B%20run%20nfsbootargs%3Brun%20loadtftpimage%3B%20run%20loadtftpfdt%3B%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%3B%3CBR%20%2F%3Enfsbootargs%3Dsetenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fnfs%20rw%20ip%3D%24%7Bipaddr%7D%3A%24%7Bserverip%7D%3A%3A%24%7Bnetmask%7D%3A%3Aeth0%3Aoff%20nfsroot%3D%24%7Bserverip%7D%3A%2Ftftpboot%2Frfs%2Cnolock%2Cv3%2Ctcp%20earlycon%3CBR%20%2F%3Epfe1_phy_addr%3D8%3CBR%20%2F%3Epfeng_mode%3Denable%2Csgmii%2Csgmii%2Crgmii%3CBR%20%2F%3Eramdisk_addr%3D0x90000000%3CBR%20%2F%3Erelease_cpus%3Drun%20cpu_trap%3B%20mp%201%20release%200xa0000000%3B%20mp%202%20release%200xa0000000%3B%20mp%203%20release%200xa0000000%3B%20mp%204%20release%200xa0000000%3B%20mp%205%20release%200xa0000000%3B%20mp%206%20release%200xa0000000%3B%20mp%207%20release%200xa0000000%3B%3CBR%20%2F%3Escript%3Dboot.scr%3CBR%20%2F%3Eserverip%3D10.0.0.1%3CBR%20%2F%3Eskip_scmi_reset_agent%3D1%3CBR%20%2F%3Estderr%3Dserial%40401c8000%3CBR%20%2F%3Estdin%3Dserial%40401c8000%3CBR%20%2F%3Estdout%3Dserial%40401c8000%3C%2FP%3E%3CP%3EEnvironment%20size%3A%203581%2F8188%20bytes%3CBR%20%2F%3E%3D%26gt%3B%20boot%3CBR%20%2F%3Eswitch%20to%20partitions%20%230%2C%20OK%3CBR%20%2F%3Emmc0%20is%20current%20device%3CBR%20%2F%3E59970%20bytes%20read%20in%207%20ms%20(8.2%20MiB%2Fs)%3CBR%20%2F%3E9362112%20bytes%20read%20in%20394%20ms%20(22.7%20MiB%2Fs)%3CBR%20%2F%3E%23%23%20Booting%20kernel%20from%20Legacy%20Image%20at%2080080000%20...%3CBR%20%2F%3EImage%20Name%3A%3CBR%20%2F%3EImage%20Type%3A%20AArch64%20Linux%20Kernel%20Image%20(uncompressed)%3CBR%20%2F%3EData%20Size%3A%209362048%20Bytes%20%3D%208.9%20MiB%3CBR%20%2F%3ELoad%20Address%3A%2080080000%3CBR%20%2F%3EEntry%20Point%3A%2080080000%3CBR%20%2F%3EVerifying%20Checksum%20...%20OK%3CBR%20%2F%3E%23%23%20Flattened%20Device%20Tree%20blob%20at%2083e00000%3CBR%20%2F%3EBooting%20using%20the%20fdt%20blob%20at%200x83e00000%3CBR%20%2F%3ELoading%20Kernel%20Image%3CBR%20%2F%3EUsing%20Device%20Tree%20in%20place%20at%200000000083e00000%2C%20end%200000000083e11fff%3CBR%20%2F%3Efixup%3A%20pfe1%3A%20update%20phy%20addr%20to%200x8%3C%2FP%3E%3CP%3EStarting%20kernel%20...%3C%2FP%3E%3CP%3Eboard_cleanup_before_linux%3A%20QNX%20PFE%20code.%3CBR%20%2F%3Eethernet%404033c000%20Waiting%20for%20PHY%20auto%20negotiation%20to%20complete.........%20TIMEOUT%20!%3CBR%20%2F%3Ephy_startup()%20failed%3A%20-110FAILED%3A%20-110%3CBR%20%2F%3EFound%20PFE%20version%200x0101%20(S32G3)%3C%2FP%3E%3CP%3EFound%20PFE%20version%200x0101%20(S32G3)%3CBR%20%2F%3Epfe2%20Waiting%20for%20PHY%20auto%20negotiation%20to%20complete.........%20TIMEOUT%20!%3CBR%20%2F%3Epfeng_netif%20pfe1%3A%20Failed%20to%20establish%20XPCS%20link%20on%20PFE1%3CBR%20%2F%3E%23%23%20Setting%20pfe_ts%20clock%20...%3CBR%20%2F%3E%23%23%20Setting%20ftm0_sys%20clock%20...%3CBR%20%2F%3E%23%23%20Setting%20ftm0_ext%20clock%20...%3CBR%20%2F%3E%23%23%20Setting%20ftm1_sys%20clock%20...%3CBR%20%2F%3E%23%23%20Setting%20ftm1_ext%20clock%20...%3CBR%20%2F%3EReserving%20RAM%20region%20for%20PFE%20driver%20on%20EVB%2FRDB%3CBR%20%2F%3EClockCycles%20samples%3A%3CBR%20%2F%3E0%20166386615%3CBR%20%2F%3E1%20166386614%3CBR%20%2F%3E2%20166386615%3CBR%20%2F%3E3%20166386615%3CBR%20%2F%3E4%20166386615%3CBR%20%2F%3E5%20166386615%3CBR%20%2F%3E6%20166386616%3CBR%20%2F%3E7%20166386615%3CBR%20%2F%3EAll%20ClockCycles%20offsets%20within%20tolerance%3CBR%20%2F%3EWelcome%20to%20QNX%20Neutrino%207.1.0%20on%20the%20NXP%20S32G399A%20RDB%20Board!!%3CBR%20%2F%3EStarting%20watchdog...%3CBR%20%2F%3EStarting%20serial%20driver%20...%3CBR%20%2F%3EStarting%20Networking%20driver%20(%2Fdev%2Fsocket)...%3CBR%20%2F%3EUtarting%20SPI%20driver%20(%2Fdev%2Fspi0%2C1%2C2%2C3%2C4%2C5)...%3CBR%20%2F%3EStarting%20I2C%200%2F1%2F2%2F3%2F4%20driver%20(%2Fdev%2Fi2c0%2C1%2C2%2C3%2C4)...%3CBR%20%2F%3EStarting%20USDHC0%20memory%20card%20driver...%3CBR%20%2F%3E%5B00%5D%20Starting%20QSPI%20Flash%20driver...%3CBR%20%2F%3ESIM%3D%22SDMMC%22%20HBA%3D%22imx%22%3CBR%20%2F%3E%5B00%2C0%2C0%5D%20type%3D00%20ver%3D05%20resp%3D00%20SDMMC%3A%3CBR%20%2F%3EStarting%20USB%20host%20driver%20(%2Fdev%2Fusb%2F*)%3CBR%20%2F%3EDetected%20QSPI%20Flash%3A%20Macronix%20MX25UW512%2C%20JEDEC%200xC2%20-%200x813A%2C%20Size%3A%200x4000000%3CBR%20%2F%3ELaunching%20devb-umass%20for%20%2Fdev%2Fusb%2F*%20...%3CBR%20%2F%3EU%23%20slogi%26%238%3B%20%26%238%3B2info%3C%2FP%3E%3CP%3EJan%2001%2000%3A00%3A00.022%20random.4%20low*%200%20qcrypto%3A%20loading%20configuration%20file%20'%2Fetc%2Fqcrypto.conf'%20%5Bqcrypto_common.c(190)%5D%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.023%20random.4..0%20slog*%20700%20Random%20is%20using%20the%20Fortuna%20PRNG%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.031%20random.4%20low%200%20qcrypto%3A%20'openssl'%20plugin%20loaded%20%5Bqcrypto_plugins.c(354)%5D%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.031%20random.4..0%20slog%20700%20Selecting%20timer%20as%20an%20entropy%20source%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.031%20random.4..0%20slog%20700%20Registered%20path%20names%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.031%20random.4..0%20slog%20700%20random%3A%20starting%20resmgr%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.031%20random.4..0%20slog%20700%20random%3A%20Daemonizing%20the%20process%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.041%20devc_serlinflexd.7%20slog*%200%20serlinflexd_interrupt_attach%3A%20Attaching%20to%20interrupt%20114%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.146%20spi_master.8%20normal*%200%20Starting%20spi-master%20resource%20manager%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.149%20spi_master.9%20normal*%200%20Starting%20spi-master%20resource%20manager%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.152%20spi_master.10%20normal*%200%20Starting%20spi-master%20resource%20manager%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.155%20spi_master.11%20normal*%200%20Starting%20spi-master%20resource%20manager%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.158%20spi_master.12%20normal*%200%20Starting%20spi-master%20resource%20manager%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.161%20spi_master.13%20normal*%200%20Starting%20spi-master%20resource%20manager%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.177%20devb_sdmmc_mx8x.19%20slog*%201800%20devb-sdmmc-mx8x%201.00A%20(Jul%201%202026%2014%3A10%3A37)%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.178%20devb_sdmmc_mx8x.19%20slog%200%20libcam.so%20(Jun%2022%202020%2021%3A33%3A15)%20bver%207010003%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.189%20devb_sdmmc_mx8x.19%20slog%201800%20sdio_cd%3A%20insertion%20path%200%2C%20cd%20state%200x1%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20SD%20CID%3A%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20MID%200x27%2C%20OID%200x5048%2C%20PNM%20SD32G%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20PRV%200x62%2C%20PSN%200x6c62d196%2C%20MDT%204-2023%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20SD%20CSD%3A%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20CSD_STRUCTURE%201%2C%20SPEC_VERS%200%2C%20CCC%200x5b5%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20TAAC%2014%2C%20NSAC%200%2C%20TRAN_SPEED%2050%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20C_SIZE%2059023%2C%20C_SIZE_MULT%200%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20READ_BL_LEN%209%2C%20WRITE_BL_LEN%209%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20ERASE%20GRP_SIZE%200%2C%20GRP_MULT%200%2C%20SIZE%20127%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20blksz%20512%2C%20sectors%2060440576%2C%20dtr%2025000000%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20SD%20SW%20CAPS%3A%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20bus%20mode%200x3%2C%20cmd%20sys%200x1%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20drv%20type%200x1%2C%20curr%20limit%200x1%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20dtr%2050000000%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20CFG%3A%20Timing%20HS%2C%20DTR%2050000000%2C%20Bus%20Width%204%20bit%3C%2FP%3E%3CP%3EJan%2001%2000%3A00%3A10.240%20devb_sdmmc_mx8x.19%20slog%20100%20cam-disk.so%20(Jun%2022%202020%2021%3A33%3A17)%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.242%20devb_sdmmc_mx8x.19%20slog%200%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%20cam_status%3Dc4%2C%20scsi_status%3D2%2C%20flag%3D00000040%2C%20vuflag%3D0008%2C%20cmd%3D1a%2C%20error%3D70%2C%20sense%3D5%2C%20asc%3D24%2C%20ascq%3D0%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.242%20devb_sdmmc_mx8x.19%20slog%200%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%20cam_status%3Dc4%2C%20scsi_status%3D2%2C%20flag%3D00000040%2C%20vuflag%3D0008%2C%20cmd%3D5a%2C%20error%3D70%2C%20sense%3D5%2C%20asc%3D24%2C%20ascq%3D0%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.242%20devb_sdmmc_mx8x.19%20slog%200%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%20cam_status%3Dc4%2C%20scsi_status%3D2%2C%20flag%3D00000040%2C%20vuflag%3D0008%2C%20cmd%3D5a%2C%20error%3D70%2C%20sense%3D5%2C%20asc%3D24%2C%20ascq%3D0%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.248%20io_usb_otg.21%20slog*%200%20main(453)%5Btid%3A1%5D%3A%20io-usb-otg%20(Jun%2013%202020%2020%3A10%3A17)%20args%3A%20-d%20hcd-ehci-mx28%20ioport%3D0x44064100%2Cirq%3D243%2Culpi%2Cno_stream%2Cverbose%3D5%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.250%20devf_qspi_s32g.20%20slog*%200%20(devf%20t1%3A%3Af3s_qspi_ident%3A73)%20Page%20size%3A%20256%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.250%20devf_qspi_s32g.20%20slog%200%20(devf%20t1%3A%3Af3s_qspi_ident%3A74)%20Total%20chip%20size%3A%200x4000000%2C%20Unit%20size%3A%200x10000%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.254%20io_usb_otg.21%20slog%200%20ehci_init%3A%20Initialiaing%20with%20sever%20version%3A%202%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.254%20io_usb_otg.21%20slog%200%20ehci_controller_init(4292)%3A%20devu-hcd-ehci-mx28.so%20(Aug%2015%202023%2016%3A44%3A48)%3A%20args%20ulpi%2Cno_stream%2Cverbose%3D5%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.254%20io_usb_otg.21%20slog%208%20usb_enum_port(94)%5Btid%3A1%5D%3A%20busno%200%2C%20parent%20-1%2C%20port%200%2C%20High%20speed%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.255%20io_usb_otg.21%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(type%201%2C%20index%200%2C%20length%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.255%20io_usb_otg.21%20slog%2012%20usb_device_set_address(245)%5Btid%3A1%5D%3A%20b%3A0%20devno%200%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.255%20io_usb_otg.21%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(type%201%2C%20index%200%2C%20length%2018)%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.255%20io_usb_otg.21%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(type%202%2C%20index%200%2C%20length%209)%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.255%20io_usb_otg.21%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(type%202%2C%20index%200%2C%20length%2025)%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.256%20io_usb_otg.21%20slog%208%20usb_enum_port(141)%5Btid%3A1%5D%3A%20vid%200x0000%2C%20did%200x0000%20enumerated(busno%200%2C%20devno%200%3A0)%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.256%20io_usb_otg.21%20slog%2011%20hub_state_inserted(569)%5Btid%3A1%5D%3A%20bdentry%200%2C%20dentry%200%200%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.256%20io_usb_otg.21%20slog%2013%20hub_configuration_enable(263)%5Btid%3A1%5D%3A%201%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.358%20io_usb_otg.21%20slog%200%20usbh_timeout_init(203)%5Btid%3A1%5D%3A%20Complete%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.369%20io_usb_otg.21%20slog%200%20read_vid_pid%3A%20ULPI%20VID%200x0424%20PID%200x0009%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.369%20io_usb_otg.21%20slog%200%20s32g_phy_set_vbus%3A%20set_vbus%20off%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.383%20io_usb_otg.21%20slog%200%20s32g_phy_set_vbus%3A%20set_vbus%20on%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.394%20io_usb_otg.21%20slog%200%20ehci_get_port_status(3557%200x44064100)%3A%20port%3D0%2C%20tpstatus%2010100%20e_pstatus%208c001000%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.394%20io_usb_otg.21%20slog%208%20usb_enum_port_extract(172)%5Btid%3A7%5D%3A%20(busno%200%2C%20pdevno%200%2C%20portno%201)%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.394%20io_usb_otg.21%20slog%208%20usb_enum_port_extract(192)%5Btid%3A7%5D%3A%20status%20(2)%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.398%20devb_umass.22%20slog*%20900%20devb-umass%201.00A%20(Jun%2022%202020%2021%3A33%3A41)%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.399%20devb_umass.22%20slog%200%20libcam.so%20(Jun%2022%202020%2021%3A33%3A15)%20bver%207010003%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.400%20io_usb_otg.21%20slog%200%20usbdi_client_connect(58)%5Btid%3A5%5D%3A%20pid%2022%20proc%3Dproc%2Fboot%2Fdevb-umass%20usbdi_client%2051ba29fa80%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.400%20io_usb_otg.21%20slog%200%20usbdi_resmgr_connect(310)%5Btid%3A5%5D%3A%20usbdi_resmgr_connect%3A%20pid%2022%20usbdi_client%2051ba29fa80%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.400%20devb_umass.22%20slog%200%20usbdi%20debug%20path%20%2Fpps%2Fusb%2Fdebug%2F%20doesn't%20exist%3CBR%20%2F%3EJan%2001%2000%3A00%3A14.507%20qconn.24%20slog*%200%20Couldn't%20initialize%20listen%20service%3A%20tcp%20(Address%20family%20not%20supported%20by%20protocol%20family)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20sharing%20the%20log.%3C%2FP%3E%0A%3CP%3EThere%20seems%20serdes%20issues%20existed%20during%20the%20booting%20phase%2C%20may%20I%20know%20if%20you%20had%20done%20the%20following%20modification%3F%20(to%20comment%20out%20the%20init_serdes()%20function)%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391062i0603F69D828AD2F3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1782977121730.png%22%20alt%3D%22chenyin_h_0-1782977121730.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Echenyin_h_0-1782977121730.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENote%3A%20I%20not%20both%20pfe0%20and%20pfe2%20work%20at%20the%20same%20time.%20And%20when%20I%20ping%20them%20from%20an%20external%20machine%20it%20assigns%20pfe0%20a%20funny%20mac%20address%3A%3C%2FP%3E%3CP%3Earp%20-a%20%7C%20grep%20192%3CBR%20%2F%3E%3F%20(192.168.0.200)%20at%2022%3A33%3A44%3A55%3A66%3A77%20%5Bether%5D%20on%20enx00e04c680383%3CBR%20%2F%3E%3F%20(192.168.0.202)%20at%20%3CINCOMPLETE%3E%20on%20enx00e04c680383%3C%2FINCOMPLETE%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThis%20is%20from%20qnx%20slog2info%3A%3C%2FP%3E%3CP%3EJan%2001%2000%3A00%3A58.251%20iopkt.4121%20main_buffer%200%20duplicate%20IP%20address%20192.168.0.200%20sent%20from%20link%20address%2022%3A33%3A44%3A55%3A66%3A77%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOk%20some%20more%20news%3A%3C%2FP%3E%3CP%3EWhen%20I%20start%20the%20network%20client%20manually%3C%2FP%3E%3CP%3Eio-pkt-v6-hc%20-p%20tcpip%20pkt_typed_mem%3Dpfe_ddr%20-d%20%2Fproc%2Fboot%2Fdevnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cutil_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_util.fw%3C%2FP%3E%3CP%3Eand%20set%20a%20static%20ip%20for%20pfe0%3C%2FP%3E%3CP%3Eifconfig%20pfe0%20192.168.0.200%20netmask%20255.255.255.0%3C%2FP%3E%3CP%3Eifconfig%20pfe0%20down%3C%2FP%3E%3CP%3Eifconfig%20pfe0%20up%3C%2FP%3E%3CP%3EI%20actually%20get%20a%20ping%20to%20an%20external%20address.%3C%2FP%3E%3CP%3ENevertheless%2C%20in%20ifconfig%20pfe0%20still%20shows%20ethernet%20none.%20It%20seems%20to%20me%20there%20are%20problems%20negotiating%20interface%20speed%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%23%20slog2info%20%7C%20grep%20pfe0%3C%2FP%3E%3CP%3EJan%2001%2000%3A00%3A25.515%20iopkt.4121%20main_buffer%200%20%2Fproc%2Fboot%2Fdevnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cutil_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_util.fw%3CBR%20%2F%3EJan%2001%2000%3A00%3A25.517%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1460%5D%3A%20MII%20mode%20configuration%20for%20pfe0%2FEMAC0%20not%20found.%20Using%20SGMII.%3CBR%20%2F%3EJan%2001%2000%3A00%3A25.647%20iopkt.4121%20main_buffer%200%20pfe0%3C%2FP%3E%3CP%3EProcess%2098332%20(slog2info)%20exited%20status%3D0.%3CBR%20%2F%3EJan%2001%2000%3A00%3A25.647%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2124%5D%3A%20pfe0%3A%20Using%20static%20PHY%20mode%2C%20RESET%3D0%3CBR%20%2F%3EJan%2001%2000%3A00%3A25.647%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2286%5D%3A%20Speed%2Fduplex%20configuration%20for%20pfe0%20not%20found.%20Using%201%20Gbps%2Ffull-duplex.%3CBR%20%2F%3EJan%2001%2000%3A00%3A58.251%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2606%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3CBR%20%2F%3EJan%2001%2000%3A00%3A58.251%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2606%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3CBR%20%2F%3EJan%2001%2000%3A00%3A58.251%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2606%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3CBR%20%2F%3EJan%2001%2000%3A00%3A58.251%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2606%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3CBR%20%2F%3EJan%2001%2000%3A01%3A05.966%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2606%5D%3A%20pfe0%3A%20Disabling%20promiscuous%20mode%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EFor%20Pfe2%20it%20might%20already%20fail%20in%20uboot%20in%20the%26nbsp%3Bboard_cleanup_before_linux%3C%2FP%3E%3CP%3Epfe2%20Waiting%20for%20PHY%20auto%20negotiation%20to%20complete.........%20TIMEOUT%20!%3C%2FP%3E%3CP%3EEdit%3A%20I%20can%20also%20obtain%20a%20ping%20from%20pfe2%20but%20it%20also%20seems%20to%20have%20problems%20negotiating%20the%20correct%20speed.%20I%20wonder%20if%20the%20above%20timeout%20is%20correct.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOk%20then%20hopefully%20these%20questions%20will%20bring%20me%20close%20to%20the%20finish%20line%3A%3C%2FP%3E%3CP%3E-%20How%20should%20I%20set%20the%20MAC%20addresses%20of%20pfe0%20and%20pfe2%3F%20I%20understand%20an%20attempt%20is%20made%20to%20set%20it%20via%20io%20pkt%3C%2FP%3E%3CP%3Eio-pkt-v6-hc%20-p%20tcpip%20pkt_typed_mem%3Dpfe_ddr%20-d%20%2Fproc%2Fboot%2Fdevnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cutil_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_util.fw%3C%2FP%3E%3CP%3EBut%20when%20I%20ping%20pfe0%20from%20an%20external%20machine%20that%20machines%20arp%20table%20presents%20a%20bogus%20address%3C%2FP%3E%3CP%3E%3F%20(192.168.0.200)%20at%2022%3A33%3A44%3A55%3A66%3A77%20%5Bether%5D%20on%20enx00e04c680383%3C%2FP%3E%3CP%3EOn%20the%20external%20machine%2C%20tcpdump%20reveals%20there%20doesn't%20seem%20to%20be%20an%20arp%20response%20from%20pfe0%20which%20has%20192.168.0.200%3A%3C%2FP%3E%3CP%3E08%3A53%3A11.208021%20IP6%20user-Precision-7510%20%26gt%3B%20ff02%3A%3A16%3A%20HBH%20ICMP6%2C%20multicast%20listener%20report%20v2%2C%202%20group%20record(s)%2C%20length%2048%3CBR%20%2F%3E08%3A53%3A11.394038%20IP6%20user-Precision-7510%20%26gt%3B%20ff02%3A%3A16%3A%20HBH%20ICMP6%2C%20multicast%20listener%20report%20v2%2C%202%20group%20record(s)%2C%20length%2048%3CBR%20%2F%3E08%3A53%3A25.750284%20ARP%2C%20Request%20who-has%20192.168.0.200%20tell%20192.168.0.200%2C%20length%2046%3CBR%20%2F%3E08%3A53%3A26.641915%20IP6%20%3A%3A%20%26gt%3B%20ff02%3A%3A1%3Aff0c%3Ad66%3A%20HBH%20ICMP6%2C%20multicast%20listener%20reportmax%20resp%20delay%3A%200%20addr%3A%20ff02%3A%3A1%3Aff0c%3Ad66%2C%20length%2024%3CBR%20%2F%3E08%3A53%3A26.692011%20IP6%20%3A%3A%20%26gt%3B%20ff02%3A%3A1%3Aff0c%3Ad66%3A%20ICMP6%2C%20neighbor%20solicitation%2C%20who%20has%20fe80%3A%3A20a%3Abff%3Afe0c%3Ad66%2C%20length%2024%3CBR%20%2F%3E08%3A53%3A32.742005%20IP6%20fe80%3A%3A20a%3Abff%3Afe0c%3Ad66%20%26gt%3B%20ff02%3A%3A1%3Aff0c%3Ad66%3A%20HBH%20ICMP6%2C%20multicast%20listener%20reportmax%20resp%20delay%3A%200%20addr%3A%20ff02%3A%3A1%3Aff0c%3Ad66%2C%20length%2024%3C%2FP%3E%3CP%3EWhen%20I%20cast%20another%20ping%20from%20the%20external%20machine%20I%20finally%20get%20a%20response%3A%3C%2FP%3E%3CP%3E08%3A59%3A22.118282%20ARP%2C%20Request%20who-has%20192.168.0.200%20tell%20user-Precision-7510%2C%20length%2028%3CBR%20%2F%3E08%3A59%3A22.118553%20ARP%2C%20Reply%20192.168.0.200%20is-at%2022%3A33%3A44%3A55%3A66%3A77%20(oui%20Unknown)%2C%20length%2046%3CBR%20%2F%3E08%3A59%3A22.118569%20IP%20user-Precision-7510%20%26gt%3B%20192.168.0.200%3A%20ICMP%20echo%20request%2C%20id%201%2C%20seq%201%2C%20length%2064%3CBR%20%2F%3E08%3A59%3A22.118554%20ARP%2C%20Reply%20192.168.0.200%20is-at%2000%3A0a%3A0b%3A0c%3A0d%3A66%20(oui%20Unknown)%2C%20length%2046%3C%2FP%3E%3CP%3E00%3A0a%3A0b%3A0c%3A0d%3A66%20is%20what%20should%20be%20the%20correct%20mac%20address.%3C%2FP%3E%3CP%3ENevertheless%20the%20arp%20table%20of%20the%20external%20machine%20still%20shows%20the%20bogus%20address%3C%2FP%3E%3CP%3Earp%20-a%3C%2FP%3E%3CP%3E%3F%20(192.168.0.200)%20at%2022%3A33%3A44%3A55%3A66%3A77%20%5Bether%5D%20on%20enx00e04c680383%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMy%20first%20guess%20would%20be%20to%20set%20them%20manually%20in%20uboot%20but%20I%20see%20no%20section%20in%20the%20integration%20manual%20that%20recommends%20that.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E-%20What%20are%20the%20commands%20to%20use%20%22fixed%20link%22%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20see.%3C%2FP%3E%3CP%3EThe%20ethaddr%2C%20eth1addr%2C%20eth2addr%2C%20eth3addr%20are%20set%20in%20my%20uboot%20but%20they%20are%20not%20enough%20to%20prevent%20the%20funny%20MAC%20for%20pfe0.%3C%2FP%3E%3CP%3EAre%20there%20other%20parameters%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20updates.%3C%2FP%3E%0A%3CP%3EGlad%20that%20the%20PFE%20would%20ping%20correctly%20with%20the%20external%20machine.%3C%2FP%3E%0A%3CP%3EThere%20are%20limitation%20for%20the%20PFE%20driver%20in%20QNX%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391145i0C1C82024E1B820A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1783044213433.png%22%20alt%3D%22chenyin_h_0-1783044213433.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Echenyin_h_0-1783044213433.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESo%20that%20it%20is%20suggested%20using%20the%20fixed%20link%2C%20while%20speed%20changes%20triggered%20by%20AN%20are%20not%20supported.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOk%2C%20just%20for%20understanding%20this%20right%3A%3C%2FP%3E%3CP%3EThere%20is%20another%20component%20that%20just%20happens%20to%20use%20192.168.0.200%3F%3C%2FP%3E%3CP%3EAnd%20if%20I%20use%20192.168.1.200%20for%20pfe0%20I%20will%20be%20fine%3F%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20the%20reply.%3C%2FP%3E%0A%3CP%3E1.%20Yes%2C%20it%20is%20usually%20by%20default%20used%20by%20the%20switch%20connected.%3C%2FP%3E%0A%3CP%3E2.%20I%20think%20the%20new%20IP%20addr%20you%20mentioned%20is%20fine%20for%20the%20test.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3E1.%20For%20setting%20the%20MAC%20address%2C%20you%20may%20try%20using%20the%26nbsp%3B%26nbsp%3B%22%3CSPAN%20class%3D%22fontstyle0%22%3Eio-pkt-v6-hc%20-p%20tcpip%20-d%20%3CDRIVER%3E%20%5C%20pfe1_mac%3D000a0b0c0d0e%2Cpfe2_mac%3D001a1b1c1d1e%22%20for%20example.%3C%2FDRIVER%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2.%20Since%20you%20are%20using%20RDB3%2C%20while%20with%20default%20settings%20you%20tried%2C%20the%20PFE0%20connected%20to%20the%20sja1110%20switch%2C%20usually%20the%20192.168.0.200%20is%20set%20internally%20within%20the%20SJA1110%20SDK%2C%20so%20I%20suggest%20not%20using%20this%20IP%20for%20testing%20with%20PFE0%2C%20you%20may%20try%20setting%20other%20IP%20address%20like%20192.168.1.X%20for%20PFE0%3C%2FP%3E%0A%3CP%3E3.%20In%20u-boot%2C%20you%20may%20try%20setting%20the%20mac%20address%20with%20the%20%22setenv%20ethaddr%2Feth1addr%2Feth2addr%20xxxx%22%20for%20each%20MAC.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGreetings%20chenyin%2C%3C%2FP%3E%3CP%3EI%20intend%20to%20create%20a%20bridge%20interface%20using%20the%20ethernet%20ports%20gmac0%2C%20pfe0%2C%20pfe2.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.qnx.com%2Fdevelopers%2Fdocs%2F7.0.0%2Findex.html%23com.qnx.doc.neutrino.utilities%2Ftopic%2Fb%2Fbrconfig.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.qnx.com%2Fdevelopers%2Fdocs%2F7.0.0%2Findex.html%23com.qnx.doc.neutrino.utilities%2Ftopic%2Fb%2Fbrconfig.html%3C%2FA%3E%3C%2FP%3E%3CP%3EThe%20connected%20clients%20are%20intended%20to%20be%20in%20the%20subnet%20192.168.0.X%20netmask%20255.255.255.0%26nbsp%3B%3C%2FP%3E%3CP%3EWill%20this%20conflict%20with%20192.168.0.200%20or%20anything%20else%3F%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EIf%20you%20do%20want%20to%20use%20the%20192.168%2C.0.x%20subnet%2C%20when%20not%20assigning%20192.168.0.200%20to%20both%20PFE0%20and%20the%20external%20devices%20that%20are%20connected%20to%20the%20switch%2C%20It%20would%20be%20correct%20for%20the%20network%20connection%20when%20you%20try%20pinging%20from%20outside%20to%20PFE0%20or%20vice%20versa.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EFrom%20my%20understanding%2C%20there%20would%20not%20be%20confliction%20while%20not%20using%20192.168.0.200.%3C%2FP%3E%0A%3CP%3EHowever%2C%20if%20possible%2C%20you%20may%20use%20other%20subnet%20instead%20to%20avoid%20possible%20issues.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2391085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2391085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGreetings%2C%3C%2FP%3E%3CP%3Ecan%20you%20tell%20me%20if%20192.168.0.200%20listens%20to%20broadcast%20calls%20or%20something%20like%20that%3F%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWould%20you%20mind%20making%20sure%20internally%3F%20Is%20there%20anything%20192.168.0.200%20does%20that%20requires%20it%20to%20have%20sole%20control%20of%20the%20subnet%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2391371%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2391371%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EThis%20IP%20could%20receive%20the%20broadcast%20packets%20from%20linked%20devices.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2392451%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2392451%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGreetings%20chenyin%2C%3C%2FP%3E%3CP%3Ea%20new%20problem%20has%20arisen%3A%3C%2FP%3E%3CP%3EThe%20arp%20handshake%20fails%20when%20I%20connect%20a%20TC387%20%2F%20FreeRTOS%20target%20to%20pfe_mac2.%20It%20works%20with%20a%20regular%20Linux%20machine.%3C%2FP%3E%3CP%3EAny%20ideas%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2392719%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2392719%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3ESince%20the%20same%20setup%20works%20with%20a%20Linux%20machine%2C%20the%20problem%20is%20more%20likely%20to%20be%20on%20the%20TC387%20side%20(Ethernet%20driver%2C%20TCP%2FIP%20stack%20configuration%2C%20or%20related%20implementation)%20rather%20than%20on%20the%20MAC%20side.%20Further%20packet-level%20analysis%20would%20be%20needed%20to%20confirm%20the%20exact%20cause%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2392810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2392810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3ESince%20the%20PFE2%20could%20work%20correctly%20with%20a%20Linux%20machine%2C%20there%20may%20not%20much%20issue%20existed%20on%20the%20S32G%20side%2C%20in%20order%20for%20solving%20your%20issue%2C%20you%20may%20try%20checking%20the%20link%20status%2C%20every%20frames%20sent%20between%20the%20two%20sides%20and%20then%20analyze%20on%20them%2C%20sorry%20that%20I%20do%20not%20know%20much%20about%20the%20software%20stack%20on%20your%20Infineon%20board.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGreetings%2C%3C%2FP%3E%3CP%3Ewhen%20I%20connect%20the%20TC387%20to%20my%20Linux%20desktop%20there%20are%20lots%20of%20arp%2Ficmp%20messages%20produced%20immediately.%20The%20same%20when%20I%20connect%20my%20S32G%20pfe2%20port%20to%20the%20Linux%20desktop.%20But%20when%20I%20connect%20the%20TC387%20to%20the%20S32G%20pfe2%20port%20I%20get%20not%20arp%20or%20icmp%20messages%20at%20all.%3C%2FP%3E%3CP%3EFor%20which%20error%20messages%20should%20I%20look%3F%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGreetings%20chenyin%2C%3C%2FP%3E%3CP%3Ecould%20you%20please%20tell%20me%20again%20which%20ports%20on%20the%20target%20was%20exactly%20pfe0%20and%20pfe2%20on%20s32g399Ardb3%3F%3C%2FP%3E%3CP%3EI%20assumed%20pfe0%20is%20the%20left%20one%20of%20the%20three%20stacked%20ports%20and%20pfe2%20top-center%2C%20is%20this%20correct%3F%3C%2FP%3E%3CP%3EAre%20there%20any%20known%20problems%20mixing%20pfe%20and%20gmac%3F%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%20I%20suggest%20referencing%20the%20following%20picture.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392313iB58AFA9F989B7423%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1784081687384.png%22%20alt%3D%22chenyin_h_0-1784081687384.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Echenyin_h_0-1784081687384.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPFE0%20is%20connected%20with%20the%20SJA1110%2C%20cables%20connected%20to%20P1%2F2%2F3%20could%20be%20linked%20with%20PFE0%3C%2FP%3E%0A%3CP%3EGMAC%20could%20be%20used%20with%20PFE%20together.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395256%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395256%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAnother%20thing.%20Will%20this%20uboot%20line%20recommended%20in%20the%20integration%20manual%3A%3C%2FP%3E%3CP%3Ehwconfig%20%22serdes0%3Amode%3Dpcie%2Cclock%3Dext%3Bpcie0%3Amode%3Drc%3Bserdes1%3Amode%3Dxpcs0%26amp%3Bxpcs1%2Cclock%3Dext%2Cfmhz%3D125%3Bxpcs1_0%3Aspeed%3D2G5%3Bxpcs1_1%3Aspeed%3D1G%22%3C%2FP%3E%3CP%3EReally%20enable%20gmac0%2C%20pfe0%20and%20pfe2%20as%20individual%20interfaces%20or%20only%20two%20of%20them%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3E1.%20For%20the%20hwconfig%20you%20mentioned%2C%20when%20using%20them%20on%20RDB3%2C%20the%203%20MACs%20could%20all%20be%20used.%3C%2FP%3E%0A%3CP%3E2.%20For%20the%20error%20log%20you%20shared%2C%20sorry%20that%20we%20do%20not%20commonly%20support%20QNX%20commands%20directly%2C%20form%20my%20personal%20experience%2C%20it%20may%20caused%20by%20the%20command%20used%20itself%2C%20I%20suggest%20%26nbsp%3Bre-checking%26nbsp%3Bsyntax%20of%20commands%26nbsp%3Bbased%20on%20the%20QNX%20document.%3C%2FP%3E%0A%3CP%3E3.%20Under%20QNX%2C%20there%20are%20some%20limitation%20for%20the%20PFE%20driver%2C%20auto-negotiation%20is%20not%20supported%2C%20so%20you%20may%20make%20sure%20that%20the%20two%20sides%20are%20running%20with%20the%20same%20speed.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1784104171784.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784104171784.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784104171784.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784104171784.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784104171784.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784104171784.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392340i9DFDF7D21F4AC640%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1784104171784.png%22%20alt%3D%22chenyin_h_0-1784104171784.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Echenyin_h_0-1784104171784.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395272%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395272%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGreetings%2C%3C%2FP%3E%3CP%3EI%20tried%20setting%20the%20correct%20speed%20on%20QNX%20with%20something%20like%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Eifconfig%20pfe2%20media%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E100%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3EbaseTX%20mediaopt%20full-duplex%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Ebut%20it%20wasn't%20enough.%20Do%20I%20have%20to%20do%20something%20else%2C%20maybe%20even%20in%20uboot%20parameters%3F%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGreetings%2C%3C%2FP%3E%3CP%3Eafter%20more%20research%20it%20seem%20that%20pfe_mac2%20in%20particular%20has%20problems%20with%20our%20100T1%20ethernet%20adapters.%20Connecting%20a%20Linux%20Laptop%20with%20USB%20ethernet%20works%20fine%20though.%3C%2FP%3E%3CP%3EDo%20you%20know%20if%20pfe_mac2%20can%20connect%20to%20this%20adapter%20type%20correctly%20and%20if%20I%20have%20to%20do%20something%20special%20to%20make%20it%20work%3F%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOk%2C%20so%20I%20should%20be%20able%20to%20use%2C%20from%20the%20three%20stacked%20ports%2C%20left%20port%20as%20pfe0%20and%20top%20center%20as%20pfe2%20I%20presume.%20Bottom%20center%20for%20gmac0.%3C%2FP%3E%3CP%3ENow%2C%20I%20try%20to%20start%20the%20interfaces%20in%20bridge%20mode%20using%20the%20following%20io%20pkt%20syntax%20(note%20the%20bridge%20parameter%20behind%20tcp%20ip)%3A%3C%2FP%3E%3CP%3Eio-pkt-v6-hc%20-p%20tcpip%20bridge%20pkt_typed_mem%3Dpfe_ddr%20-d%20dwceqos-s32g%20mac%3D%60genmac-random%20-m%60%2Cptp_off%2Cverbose%3D5%20-d%20%2Fproc%2Fboot%2Fdevnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cutil_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_util.fw%3CBR%20%2F%3Eifconfig%20dwc0%20192.168.10.100%20up%3CBR%20%2F%3Eifconfig%20pfe0%200.0.0.0%20up%3CBR%20%2F%3Eifconfig%20pfe2%200.0.0.0%20up%3CBR%20%2F%3Eifconfig%20bridge0%20create%3CBR%20%2F%3Eifconfig%20bridge0%20add%20dwc0%20add%20pfe0%20add%20pfe2%20up%3C%2FP%3E%3CP%3EThis%20will%20result%20in%20lots%20of%20memory%20errors%20in%20slog2info%3C%2FP%3E%3CP%3EJan%2001%2000%3A04%3A37.485%20io_pkt_v6_hc.159753%20slog%200%20ERR%5Bsrc%2Fpfe_drv.c%3A2996%5D%3A%20(DRIVER)%20event%201%20-%20Driver%20runtime%20error%3A%20Mbuf%20addr%20out%20of%2032bit.%20Start%20%40%20p0x8df239b58%20end%20%40%20p0x8df239b82%3C%2FP%3E%3CP%3EJan%2001%2000%3A04%3A38.485%20io_pkt_v6_hc.159753%20slog%200%20ERR%5Bsrc%2Fpfe_drv.c%3A2996%5D%3A%20(DRIVER)%20event%201%20-%20Driver%20runtime%20error%3A%20Mbuf%20addr%20out%20of%2032bit.%20Start%20%40%20p0x8df239558%20end%20%40%20p0x8df239582%3C%2FP%3E%3CP%3EJan%2001%2000%3A04%3A38.485%20io_pkt_v6_hc.159753%20slog%200%20ERR%5Bsrc%2Fpfe_drv.c%3A2996%5D%3A%20(DRIVER)%20event%201%20-%20Driver%20runtime%20error%3A%20Mbuf%20addr%20out%20of%2032bit.%20Start%20%40%20p0x8df239558%20end%20%40%20p0x8df239582%3C%2FP%3E%3CP%3EJan%2001%2000%3A04%3A39.451%20io_pkt_v6_hc.159753%20slog%200%20ERR%5Bsrc%2Fpfe_drv.c%3A2996%5D%3A%20(DRIVER)%20event%201%20-%20Driver%20runtime%20error%3A%20Mbuf%20addr%20out%20of%2032bit.%20Start%20%40%20p0x8df239b58%20end%20%40%20p0x8df239b82%3C%2FP%3E%3CP%3EJan%2001%2000%3A04%3A39.451%20io_pkt_v6_hc.159753%20slog%200%20ERR%5Bsrc%2Fpfe_drv.c%3A2996%5D%3A%20(DRIVER)%20event%201%20-%20Driver%20runtime%20error%3A%20Mbuf%20addr%20out%20of%2032bit.%20Start%20%40%20p0x8df239b58%20end%20%40%20p0x8df239b82%3C%2FP%3E%3CP%3EIs%20bridge%20parameter%20correct%20in%20io-pkt-v6-hc%20call%3F%26nbsp%3B%3C%2FP%3E%3CP%3EAlso%2C%20I%20use%20this%20allocation%20from%20the%20driver%20integration%20manual%20for%20both%20gmac0%20and%20pfe%20as%20can%20be%20seen%20in%20the%20io-pkt-v6-hc%20call.%20Is%20that%20a%20problem%3F%3C%2FP%3E%3CP%3Ekprintf(%22Reserving%20RAM%20region%20for%20PFE%20driver%20on%20EVB%2FRDB%5Cn%22)%3B%3CBR%20%2F%3Eas_add_containing(0x80000000%2C0x80000000%20%2B%200x4000000%20-%201%2CAS_ATTR_RAM%2C%20%22pfe_ddr%22%2C%22ram%22)%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post.%3C%2FP%3E%0A%3CP%3E1.%20I%20can%20confirm%20that%20the%20PFE2%20port%20on%20RDB3%20could%20work%20correctly%20with%20connection%20to%20100T1%20network%20via%20a%20100base-TX%26lt%3B-%26gt%3B100base-T1%20converter%20under%20Linux%20BSP%20provisioned%20by%20NXP.%3C%2FP%3E%0A%3CP%3E2.%20You%20may%20try%20the%20following%20command%20for%20a%20test%3A%26nbsp%3B%3CSPAN%20class%3D%22fontstyle0%22%3Eio-pkt-v6-hc%20-p%20tcpip%20-d%20pfe2_link%3D100-1-2%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBut%20I%20am%20not%20very%20sure%20for%20these%20settings%20on%20QNX%20since%20it%20is%20beyond%20our%20S32G%20community%20supporting%20scope%2C%26nbsp%3B%20sorry%20for%20your%20inconvenience.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
