S32G399A-RDB3 QNX PFE Driver Problems
6,165 次查看
Seneca
Greetings,
we try to get PFE running on a S32G399A-RDB3 board with QNX. As far as I can tell, this is a valid combination:
BSP 37.0
PFE-FW_S32G_1.7.0
PFE-DRV-S32G_A53_QNX_1.4.0
It ends with a no carrier error on all network interfaces. Plugging the cable into different ethernet ports changes nothing.
It used to work with gmac0.
Any ideas?
io pkt call:
io-pkt-v6-hc -p tcpip -d pfe-2 pfe0_mac=000a0b0c0d66,pfe1_mac=001a1b1c1d66,pfe2_mac=002a2b2c2d66,class_fw=/proc/boot/s32g_pfe_class.fw,no_reset,mode0=sgmii,phy0=0,mode1=sgmii,phy1=1
Uboot parameters:
Uboot is the same as from the Linux sdcard image with modified parmeters for qnx boot.
setenv hwconfig "pcie0:mode=rc,clock=ext;pcie1:mode=sgmii,clock=ext,fmhz=125,xpcs_mode=2G5"
setenv pfeng_mode 'enable,sgmii,sgmii,rgmii'
setenv s32cc_gmac_mode disable
setenv pfeng enable; s32ccgmac disable; s32ccgmac enable;
setenv boot_qnx_atf 'mmc dev 0; fatload mmc 0:1 0x83e00000 s32g399a-rdb3.dtb; pfeng enable; s32ccgmac disable; s32ccgmac enable; fatload mmc 0:1 0x80080000 ifs-s32g399a-rdb.ui; bootm 0x80080000 - 0x83E00000'
setenv bootcmd 'run boot_qnx_atf'
saveenv
Log:
U-Boot 2020.04+g156b168010 (Jun 09 2023 - 10:14:25 +0000)
CPU:   NXP S32G399A rev. 1.1
Model: NXP S32G399A-RDB3
DRAM:  3.5 GiB
MMC:   FSL_SDHC: 0
Loading Environment from MMC... OK
Configuring PCIe0 as RootComplex
PCIe0: Failed to get link up
PCI: Failed autoconfig bar 1c
In:    serial@401c8000
Out:   serial@401c8000
Err:   serial@401c8000
Board revision: RDB3 Revision F
Net:   EQOS phy: rgmii @ 1
Warning: eth_eqos (eth0) using random MAC address - 26:e4:e6:43:15:ad
eth0: eth_eqosFailed to get speed of XPCS for emac1_xpcs PFE: emac0: sgmii emac1: sgmii emac2: rgmii
, eth1: eth_pfeng
Hit any key to stop autoboot:  3  2  1  0
switch to partitions #0, OK
mmc0 is current device
50640 bytes read in 17 ms (2.8 MiB/s)
11948752 bytes read in 540 ms (21.1 MiB/s)
## Booting kernel from Legacy Image at 80080000 ...
   Image Name:
   Image Type:   AArch64 Linux Kernel Image (uncompressed)
   Data Size:    11948688 Bytes = 11.4 MiB
   Load Address: 80080000
   Entry Point:  80080000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 83e00000
   Booting using the fdt blob at 0x83e00000
   Loading Kernel Image
   Using Device Tree in place at 0000000083e00000, end 0000000083e0f5cf
   fixup: pfe0 set to 00:01:be:be:ef:11
   fixup: pfe1 set to 00:01:be:be:ef:22
   fixup: pfe1: update phy addr to 0x8
   fixup: pfe2 set to 00:01:be:be:ef:33
Starting kernel ...
Reserving RAM region for PFE driver on EVB/RDB
Done.
ClockCycles samples:
 0 43600679
 1 43600679
 2 43600678
 3 43600679
 4 43600678
 5 43600678
 6 43600678
 7 43600679
All ClockCycles offsets within tolerance
Welcome to QNX Neutrino 7.1.0 on the NXP S32G399A RDB Board!!
Starting watchdog...
Starting serial driver ...
Starting Networking driver (/dev/socket)...
Process 4107 (ifconfig) exited status=0.
Process 10 (sh) exited status=0.
Process 9 (dhclient) exited status=0.
cp: Can't open source file.  (/proc/boot/libfci_cli)
Process 20489 (cp) exited status=1.
Starting SPI driver (/dev/spi0,1,2,3,4,5)...
Starting I2C 0/1/2/3/4 driver (/dev/i2c0,1,2,3,4)...
Starting USDHC0 memory card driver...
[00]     SIM="SDMMC" HBA="imx"
[00,0,0] type=00 ver=05 resp=00                       SDMMC:
Process 24596 (chkqnx6fs) exited status=0.
Process 28692 (mount) exited status=0.
Starting QSPI Flash driver...
Starting USB host driver (/dev/usb/*)
Detected QSPI Flash: Macronix MX25UW512, JEDEC 0xC2 - 0x813A, Size: 0x4000000
Launching devb-umass for /dev/usb/* ...
Process 36891 (sleep) exited status=0.
sh: /var/cetitec2/startup.sh: No such file or directory
Process 45081 (sh) terminated signo=0 code=0 by process 0 value=0.
slog2info
Jan 01 00:00:00.023                       random.4                  low*     0  qcrypto: loading configuration file '/etc/qcrypto.conf' [qcrypto_common.c(190)]
Jan 01 00:00:00.024                    random.4..0                 slog*   700  Random is using the Fortuna PRNG
Jan 01 00:00:00.031                       random.4                  low      0  qcrypto: 'openssl' plugin loaded [qcrypto_plugins.c(354)]
Jan 01 00:00:00.031                    random.4..0                 slog    700  Selecting timer as an entropy source
Jan 01 00:00:00.032                    random.4..0                 slog    700  Registered path names
Jan 01 00:00:00.032                    random.4..0                 slog    700  random: starting resmgr
Jan 01 00:00:00.032                    random.4..0                 slog    700  random: Daemonizing the process
Jan 01 00:00:00.042             devc_serlinflexd.7                 slog*     0  serlinflexd_interrupt_attach: Attaching to interrupt 114
Jan 01 00:00:00.047                        iopkt.8          main_buffer*     0  tcpip starting
Jan 01 00:00:00.047                        iopkt.8          main_buffer      0  smmu support is disabled
Jan 01 00:00:00.049                        iopkt.8          main_buffer      0  initializing IPsec...
Jan 01 00:00:00.049                        iopkt.8          main_buffer      0   done
Jan 01 00:00:00.049                        iopkt.8          main_buffer      0  IPsec: Initialized Security Association Processing.
Jan 01 00:00:00.051                        iopkt.8          main_buffer      0  devnp-pfe-2.so pfe0_mac=000a0b0c0d66,pfe1_mac=001a1b1c1d66,pfe2_mac=002a2b2c2d66,class_fw=/proc/boot/s32g_pfe_class.fw,pfe0_mode=sgmii,pfe0_phy=0,pfe1_mode=sgmii,pfe1_phy=1
Jan 01 00:00:00.052                 io_pkt_v6_hc.8                 slog*     0  INF[src/pfe_drv.c:1377]: VERSION INFO
Driver version: 1.4.0
Driver commit hash: 2f3265a49ac18f94ba5e48254c8f870fe7bfc511
PFE_CFG_MULTI_INSTANCE_SUPPORT: 0
PFE_CFG_LOCAL_IF: 6
PFE_CFG_MASTER_IF: 6
PFE_CFG_SC_HIF: 1
PFE_CFG_HIF_RING_LENGTH: 256
PFE_CFG_PFE0_PROMISC: 1
PFE_CFG_PFE1_PROMISC: 1
PFE_CFG_PFE2_PROMISC: 1
Jan 01 00:00:00.052                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1384]: --- Safe IRQ enabled. No InterrupAttach() or InterruptAttach_r() allowed.
Jan 01 00:00:00.052                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_fw.c:83]: 42792 bytes read
Jan 01 00:00:00.053                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_fw.c:89]: Loaded firmware file: /proc/boot/s32g_pfe_class.fw
Jan 01 00:00:00.053                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1477]: MII mode configuration for pfe0/EMAC0 not found. Using SGMII.
Jan 01 00:00:00.053                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1477]: MII mode configuration for pfe1/EMAC1 not found. Using SGMII.
Jan 01 00:00:00.053                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1477]: MII mode configuration for pfe2/EMAC2 not found. Using RGMII.
Jan 01 00:00:00.053                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1495]: Issuing PFE peripheral reset...
Jan 01 00:00:00.274                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1496]: PFE reset OK.
Jan 01 00:00:00.274                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:3519]: PFE CBUS p0x46000000 mapped @ v0x38f2e23000
Jan 01 00:00:00.274                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:3524]: HW version 0x101
Jan 01 00:00:00.274                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hw_feature.c:95]: Silicon S32G3
Jan 01 00:00:00.274                 io_pkt_v6_hc.8                 slog      0  WRN[hw/s32g/pfe_platform_master.c:3536]: Fail-Stop mode disabled
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2687]: PFE_ERRORS:Parity instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2702]: PFE_ERRORS:Watchdog instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2718]: PFE_ERRORS:Bus Error instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2731]: PFE_ERRORS:FW Fail Stop instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2744]: PFE_ERRORS:Host Fail Stop instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2757]: PFE_ERRORS:Fail Stop instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2770]: PFE_ERRORS:ECC Err instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:1766]: BMU1 buffer base: p0xc0000000
Jan 01 00:00:00.277                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:1810]: BMU2 buffer base: p0x83000000 (0x200000 bytes)
Jan 01 00:00:00.279                 io_pkt_v6_hc.8                 slog      0  INF[src/oal_irq_qnx.c:117]: PFE BMU IRQ Worker started (IRQ ID: 226)
Jan 01 00:00:00.279                 io_pkt_v6_hc.8                 slog      0  WRN[hw/s32g/pfe_platform_master.c:2194]: The option 'g2_ordered_class_writes' is disabled.
Jan 01 00:00:00.279                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_bmu_csr.c:96]: BMU_EMPTY_INT (BMU @ p0x88000). Pool ready.
Jan 01 00:00:00.279                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_bmu_csr.c:96]: BMU_EMPTY_INT (BMU @ p0x8c000). Pool ready.
Jan 01 00:00:00.281                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2239]: Firmware .elf detected
Jan 01 00:00:00.281                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2248]: Uploading CLASS firmware
Jan 01 00:00:00.281                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_pe.c:609]: Selected FW loading OPs to load 8 PEs in parallel
Jan 01 00:00:00.285                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_pe.c:1945]: pfe_ct.h file version"92367c0e25f21f49217a9b08168ad2c8"
Jan 01 00:00:00.288                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_pe.c:2422]: [FW VERSION] 1.7.0, Build: Jun  2 2023, 13:48:57 (nogitaaa), ID: 0x31454650
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  WRN[hw/s32g/pfe_platform_master.c:2312]: VLAN ID incorrect or not set. Using default VLAN ID = 0x01.
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  WRN[hw/s32g/pfe_platform_master.c:2318]: VLAN stats size incorrect or not set. Using default VLAN stats size = 20.
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_l2br.c:1181]: Software vlan hash table @ p0x20001228
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_l2br.c:1286]: Fall-back bridge domain @ 0x20000a7c (class)
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_l2br.c:1287]: Default bridge domain @ 0x20000a74 (class)
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2412]: Routing table created, Hash Table @ p0x80014000, Pool @ p0x8001c000 (65536 bytes)
Jan 01 00:00:00.407                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_chnl.c:1997]: Initializing RX buffer pool. Depth: 256; Buffer Size: 2048; Cache Line Size: 64
Jan 01 00:00:00.408                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_chnl.c:1997]: Initializing RX buffer pool. Depth: 256; Buffer Size: 2048; Cache Line Size: 64
Jan 01 00:00:00.409                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_chnl.c:1997]: Initializing RX buffer pool. Depth: 256; Buffer Size: 2048; Cache Line Size: 64
Jan 01 00:00:00.508                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:3705]: Feature err051211_workaround: DISABLED
Jan 01 00:00:00.509                        iopkt.8          main_buffer      0  pfe0
Jan 01 00:00:00.509                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2152]: pfe0: Using PHY mode: MDIO=0, ADDR=0, CLAUSE=0, RESET=0
Jan 01 00:00:00.509                 io_pkt_v6_hc.8                 slog      0  INF[src/oal_irq_qnx.c:117]: PFE HIF0 IRQ Worker started (IRQ ID: 222)
Jan 01 00:00:00.509                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1795]: Adding 00:0a:0b:0c:0d:66 to pfe0
Jan 01 00:00:00.511                        iopkt.8          main_buffer      0  pfe1
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2298]: Speed/duplex configuration for pfe0 not found. Using 1 Gbps/full-duplex.
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:336]: Attempt to register HIF client: 0
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:1189]: HIF driver started
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2363]: New PFE device: 0, ID: 0
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2152]: pfe1: Using PHY mode: MDIO=1, ADDR=0, CLAUSE=0, RESET=0
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/oal_irq_qnx.c:117]: PFE HIF1 IRQ Worker started (IRQ ID: 223)
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1795]: Adding 00:1a:1b:1c:1d:66 to pfe1
Jan 01 00:00:00.513                        iopkt.8          main_buffer      0  pfe2
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2298]: Speed/duplex configuration for pfe1 not found. Using 1 Gbps/full-duplex.
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:336]: Attempt to register HIF client: 1
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:1189]: HIF driver started
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2363]: New PFE device: 1, ID: 2
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2145]: pfe2: Using static PHY mode, RESET=0
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/oal_irq_qnx.c:117]: PFE HIF2 IRQ Worker started (IRQ ID: 224)
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1795]: Adding 00:2a:2b:2c:2d:66 to pfe2
Jan 01 00:00:00.515                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2298]: Speed/duplex configuration for pfe2 not found. Using 1 Gbps/full-duplex.
Jan 01 00:00:00.515                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:336]: Attempt to register HIF client: 2
Jan 01 00:00:00.515                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:1189]: HIF driver started
Jan 01 00:00:00.515                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2363]: New PFE device: 2, ID: 4
Jan 01 00:00:00.530                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2702]: Adding 00:0a:0b:0c:0d:66 to pfe0
Jan 01 00:00:00.530                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2707]: Unable to assign MAC address 00:0a:0b:0c:0d:66 to the pfe0
Jan 01 00:00:00.530                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.538                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_mdio.c:427]: pfe0: PHY @ bus 0 addr 0 not found. Switching to static mode.
Jan 01 00:00:00.538                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2829]: EMAC speed change for SGMII is currently not supported.
Jan 01 00:00:00.538                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:ff:0c:0d:66 to emac0
Jan 01 00:00:00.540                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.540                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:ff:0c:0d:66 to emac0
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2450]: unable to add 33:33:ff:0c:0d:66 into emac0: 17
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2450]: unable to add 33:33:00:00:00:01 into emac0: 17
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2829]: EMAC speed change for SGMII is currently not supported.
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 01:00:5e:00:00:01 to emac0
Jan 01 00:00:00.544                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:00:00.544                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2450]: unable to add 33:33:00:00:00:01 into emac0: 17
Jan 01 00:00:00.544                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:ff:0c:0d:66 to emac0
Jan 01 00:00:00.544                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2450]: unable to add 33:33:ff:0c:0d:66 into emac0: 17
Jan 01 00:00:00.544                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.554               spi_master.24585               normal*     0  Starting spi-master resource manager
Jan 01 00:00:00.558               spi_master.24587               normal*     0  Starting spi-master resource manager
Jan 01 00:00:00.561               spi_master.24588               normal*     0  Starting spi-master resource manager
Jan 01 00:00:00.565               spi_master.24589               normal*     0  Starting spi-master resource manager
Jan 01 00:00:00.582          devb_sdmmc_mx8x.24595                 slog*  1800  devb-sdmmc-mx8x 1.00A (Jun 23 2026 09:45:48)
Jan 01 00:00:00.583          devb_sdmmc_mx8x.24595                 slog      0  libcam.so (Jun 22 2020 21:33:15) bver 7010003
Jan 01 00:00:00.594          devb_sdmmc_mx8x.24595                 slog   1800  sdio_cd:  insertion path 0, cd state 0x1
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800  SD CID:
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    MID 0x27, OID 0x5048, PNM SD32G
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    PRV 0x62, PSN 0x6c62d132, MDT 4-2023
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800  SD CSD:
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    CSD_STRUCTURE 1, SPEC_VERS 0, CCC 0x5b5
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    TAAC 14, NSAC 0, TRAN_SPEED 50
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    C_SIZE 59023, C_SIZE_MULT 0
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    READ_BL_LEN 9, WRITE_BL_LEN 9
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    ERASE GRP_SIZE 0, GRP_MULT 0, SIZE 127
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    blksz 512, sectors 60440576, dtr 25000000
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800  SD SW CAPS:
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    bus mode 0x3, cmd sys 0x1
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    drv type 0x1, curr limit 0x1
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    dtr 50000000
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800  CFG:  Timing HS, DTR 50000000, Bus Width 4 bit
Jan 01 00:00:00.645          devb_sdmmc_mx8x.24595                 slog    100  cam-disk.so (Jun 22 2020 21:33:17)
Jan 01 00:00:00.647          devb_sdmmc_mx8x.24595                 slog      0  scsi_interpret_sense (sdmmc ptl-0:0:0):  cam_status=c4, scsi_status=2, flag=00000040, vuflag=0008, cmd=1a, error=70, sense=5, asc=24, ascq=0
Jan 01 00:00:00.647          devb_sdmmc_mx8x.24595                 slog      0  scsi_interpret_sense (sdmmc ptl-0:0:0):  cam_status=c4, scsi_status=2, flag=00000040, vuflag=0008, cmd=5a, error=70, sense=5, asc=24, ascq=0
Jan 01 00:00:01.827          devb_sdmmc_mx8x.24595                 slog   1000  fs-qnx6: Allocation strategy 0
Jan 01 00:00:01.827          devb_sdmmc_mx8x.24595                 slog   1000  fs-qnx6: Use btree directory 0
Jan 01 00:00:01.828          devb_sdmmc_mx8x.24595                 slog   1000  fs-qnx6: fs-qnx6: trim (0,1048576,2) was not requested, and is NOT supported
Jan 01 00:00:01.833               io_usb_otg.36885                 slog*     0  main(453)[tid:1]: io-usb-otg (Jun 13 2020 20:10:17) args: -d hcd-ehci-mx28 ioport=0x44064100,irq=243,ulpi,no_stream,verbose=5
Jan 01 00:00:01.835           devf_qspi_s32g.36884                 slog*     0  (devf  t1::f3s_qspi_ident:73) Page size: 256
Jan 01 00:00:01.835           devf_qspi_s32g.36884                 slog      0  (devf  t1::f3s_qspi_ident:74) Total chip size: 0x4000000, Unit size: 0x10000
Jan 01 00:00:01.839               io_usb_otg.36885                 slog      0  ehci_init: Initialiaing with sever version: 2
Jan 01 00:00:01.839               io_usb_otg.36885                 slog      0  ehci_controller_init(4303): devu-hcd-ehci-mx28.so (Apr 19 2024 13:44:54):  args ulpi,no_stream,verbose=5
Jan 01 00:00:01.840               io_usb_otg.36885                 slog      8  usb_enum_port(94)[tid:1]: busno 0, parent -1, port 0, High speed
Jan 01 00:00:01.840               io_usb_otg.36885                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 1, index 0, length
Jan 01 00:00:01.840               io_usb_otg.36885                 slog     12  usb_device_set_address(245)[tid:1]: b:0 devno 0
Jan 01 00:00:01.840               io_usb_otg.36885                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 1, index 0, length 18)
Jan 01 00:00:01.841               io_usb_otg.36885                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 2, index 0, length 9)
Jan 01 00:00:01.841               io_usb_otg.36885                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 2, index 0, length 25)
Jan 01 00:00:01.841               io_usb_otg.36885                 slog      8  usb_enum_port(141)[tid:1]: vid 0x0000, did 0x0000 enumerated(busno 0, devno 0:0)
Jan 01 00:00:01.841               io_usb_otg.36885                 slog     11  hub_state_inserted(569)[tid:1]: bdentry 0, dentry 0 0
Jan 01 00:00:01.841               io_usb_otg.36885                 slog     13  hub_configuration_enable(263)[tid:1]: 1
Jan 01 00:00:01.943               io_usb_otg.36885                 slog      0  usbh_timeout_init(203)[tid:1]: Complete
Jan 01 00:00:01.954               io_usb_otg.36885                 slog      0  read_vid_pid: ULPI VID 0x0424 PID 0x0009
Jan 01 00:00:01.954               io_usb_otg.36885                 slog      0  s32g_phy_set_vbus: set_vbus off
Jan 01 00:00:01.968               io_usb_otg.36885                 slog      0  s32g_phy_set_vbus: set_vbus on
Jan 01 00:00:01.979               io_usb_otg.36885                 slog      0  ehci_get_port_status(3568 0x44064100): port=0, tpstatus 10100 e_pstatus 8c001000
Jan 01 00:00:01.979               io_usb_otg.36885                 slog      8  usb_enum_port_extract(172)[tid:7]: (busno 0, pdevno 0, portno 1)
Jan 01 00:00:01.979               io_usb_otg.36885                 slog      8  usb_enum_port_extract(192)[tid:7]: status (2)
Jan 01 00:00:01.983               devb_umass.36886                 slog*   900  devb-umass 1.00A (Jun 22 2020 21:33:41)
Jan 01 00:00:01.984               devb_umass.36886                 slog      0  libcam.so (Jun 22 2020 21:33:15) bver 7010003
Jan 01 00:00:01.985               io_usb_otg.36885                 slog      0  usbdi_client_connect(58)[tid:5]: pid 36886 proc=proc/boot/devb-umass usbdi_client 32eebb9a80
Jan 01 00:00:01.986               io_usb_otg.36885                 slog      0  usbdi_resmgr_connect(310)[tid:5]: usbdi_resmgr_connect: pid 36886 usbdi_client 32eebb9a80
Jan 01 00:00:01.986               devb_umass.36886                 slog      0  usbdi debug path /pps/usb/debug/ doesn't exist
Process 49177 (slog2info) exited status=0.
# ifconfig
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 33136
inet 127.0.0.1 netmask 0xff000000
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
pfe0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
capabilities=1f<IP4CSUM,TCP4CSUM,UDP4CSUM,TCP6CSUM,UDP6CSUM>
enabled=0
address: 00:0a:0b:0c:0d:66
media: Ethernet none (1000baseT full-duplex)
status: active
inet 0.0.0.0 netmask 0xff000000 broadcast 255.255.255.255
inet6 fe80::20a:bff:fe0c:d66%pfe0 prefixlen 64 scopeid 0x11
pfe1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
enabled=0
address: 00:1a:1b:1c:1d:66
status: no carrier
pfe2: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
enabled=0
address: 00:2a:2b:2c:2d:66
status: no carrier
Process 57369 (ifconfig) exited status=0.
54 回复数
2,409 次查看
Seneca
Greetings,
I intend to try the following combination:
BSP 33
PFE Driver 1.2.0
PFE FW 1.3.0
Is this officially supported?
3,629 次查看
chenyin_h
Hello, @Seneca
Thanks for your post.
By default, the S32G PFE QNX Driver Version 1.4.0 is compatible with S32G PFE Firmware Standard Version 1.6.0, would you mind testing it again with this PFE FW version instead?
Chenyin
3,619 次查看
Seneca
Ok, so I replaced s32g_pfe_class.fw and s32g_pfe_util.fw with the files from PFE-FW_S32G_1.6.0.zip here:
https://nxp.flexnetoperations.com/control/frse/download?agree=Accept&element=14074877
Uboot parameters:
setenv boot_qnx_atf 'mmc dev 0; fatload mmc 0:1 0x83e00000 s32g399a-rdb3.dtb; run atf_fdt_0to3; run atf_fdt_4to7; fatload mmc 0:1 0x80080000 ifs-s32g399a-rdb.ui; pfeng enable; s32ccgmac disable; s32ccgmac enable; bootm 0x80080000 - 0x83E00000'
setenv atf_fdt_0to3 'fdt addr 0x83e00000; fdt resize; fdt set /cpus/cpu@1 cpu-release-addr <0x0 0xa0000010>; fdt set /cpus/cpu@100 cpu-release-addr <0x0 0xa0000010>; fdt set /cpus/cpu@101 cpu-release-addr <0x0 0xa0000010>;'
setenv atf_fdt_4to7 'fdt set /cpus/cpu@2 cpu-release-addr <0x0 0xa0000010>; fdt set /cpus/cpu@3 cpu-release-addr <0x0 0xa0000010>; fdt set /cpus/cpu@102 cpu-release-addr <0x0 0xa0000010>; fdt set /cpus/cpu@103 cpu-release-addr <0x0 0xa0000010>;'
setenv release_cpus 'run cpu_trap; mp 1 release 0xa0000000; mp 2 release 0xa0000000; mp 3 release 0xa0000000; mp 4 release 0xa0000000; mp 5 release 0xa0000000; mp 6 release 0xa0000000; mp 7 release 0xa0000000;'
setenv cpu_trap 'dcache off; mw.l 0xa0000000 0xd503205f; mw.l 0xa0000004 0x58000060; mw.l 0xa0000008 0xb4ffffc0; mw.l 0xa000000C 0xd61f0000; mw.q 0xa0000010 0x00000000; dcache on;'
saveenv
Note: I removed the release_cpus command from boot_qnx_atf because then I would havef a cpu 1 error.
Doesn't look much better to me:
NOTICE:  BL2: v2.5(release):bsp37.0_rc6-2.5
NOTICE:  BL2: Built : 09:12:21, Jun 13 2023
NOTICE:  BL2: Booting BL31
DRAM:  3.5 GiB
MMC:   FSL_SDHC: 0
In:    serial@401c8000
Warning: eth_eqos (eth0) using random MAC address - 16:ec:a0:4e:1d:7c
, eth1: eth_pfeng
11950600 bytes read in 534 ms (21.3 MiB/s)
   Image Name:
   Data Size:    11950536 Bytes = 11.4 MiB
   Using Device Tree in place at 0000000083e00000, end 0000000083e0ffff
Starting kernel ...
Done.
 0 43642864
 1 43642864
 2 43642864
 3 43642864
 4 43642864
 5 43642864
 6 43642864
 7 43642864
# ifconfig
enabled=0
status: active
enabled=0
status: no carrier
enabled=0
status: no carrier
Process 40985 (ifconfig) exited status=0.
Process 53273 (sh) terminated signo=0 code=0 by process 0 value=0.
# ifconfig
enabled=0
status: active
enabled=0
status: no carrier
enabled=0
status: no carrier
# slog2info | grep pfe
Jan 01 00:00:00.052 io_pkt_v6_hc.8 slog 0 INF[src/pfe_fw.c:83]: 49480 bytes read
Jan 01 00:00:00.052 io_pkt_v6_hc.8 slog 0 INF[src/pfe_fw.c:89]: Loaded firmware file: /proc/boot/s32g_pfe_class.fw
Jan 01 00:00:00.274 io_pkt_v6_hc.8 slog 0 INF[hw/s32g/pfe_platform_master.c:3519]: PFE CBUS p0x46000000 mapped @ v0x1abef95000
Jan 01 00:00:00.288 io_pkt_v6_hc.8 slog 0 INF[src/pfe_pe.c:2422]: [FW VERSION] 1.6.0, Build: Mar 15 2023, 12:37:54 (), ID: 0x31454650
Jan 01 00:00:00.406 io_pkt_v6_hc.8 slog 0 INF[src/pfe_l2br.c:1181]: Software vlan hash table @ p0x20001208
Jan 01 00:00:00.406 io_pkt_v6_hc.8 slog 0 INF[src/pfe_l2br.c:1286]: Fall-back bridge domain @ 0x20000a44 (class)
Jan 01 00:00:00.406 io_pkt_v6_hc.8 slog 0 INF[src/pfe_l2br.c:1287]: Default bridge domain @ 0x20000a3c (class)
Jan 01 00:00:00.509 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2145]: pfe0: Using static PHY mode, RESET=0
Jan 01 00:00:00.510 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:1795]: Adding 00:0a:0b:0c:0d:66 to pfe0
Jan 01 00:00:00.512 iopkt.8 main_buffer 0 pfe1
Jan 01 00:00:00.512 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2298]: Speed/duplex configuration for pfe0 not found. Using 1 Gbps/full-duplex.
Jan 01 00:00:00.512 io_pkt_v6_hc.8 slog 0 INF[src/pfe_hif_drv_sc.c:336]: Attempt to register HIF client: 0
Jan 01 00:00:00.512 io_pkt_v6_hc.8 slog 0 INF[src/pfe_hif_drv_sc.c:1189]: HIF driver started
Jan 01 00:00:00.512 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2363]: New PFE device: 0, ID: 0
Jan 01 00:00:00.512 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2145]: pfe1: Using static PHY mode, RESET=0
Jan 01 00:00:00.512 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:1795]: Adding 00:1a:1b:1c:1d:66 to pfe1
Jan 01 00:00:00.514 iopkt.8 main_buffer 0 pfe2
Jan 01 00:00:00.514 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2298]: Speed/duplex configuration for pfe1 not found. Using 1 Gbps/full-duplex.
Jan 01 00:00:00.514 io_pkt_v6_hc.8 slog 0 INF[src/pfe_hif_drv_sc.c:336]: Attempt to register HIF client: 1
Jan 01 00:00:00.514 io_pkt_v6_hc.8 slog 0 INF[src/pfe_hif_drv_sc.c:1189]: HIF driver started
Jan 01 00:00:00.514 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2363]: New PFE device: 1, ID: 2
Jan 01 00:00:00.514 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2145]: pfe2: Using static PHY mode, RESET=0
Jan 01 00:00:00.514 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:1795]: Adding 00:2a:2b:2c:2d:66 to pfe2
Jan 01 00:00:00.516 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2298]: Speed/duplex configuration for pfe2 not found. Using 1 Gbps/full-duplex.
Jan 01 00:00:00.516 io_pkt_v6_hc.8 slog 0 INF[src/pfe_hif_drv_sc.c:336]: Attempt to register HIF client: 2
Jan 01 00:00:00.516 io_pkt_v6_hc.8 slog 0 INF[src/pfe_hif_drv_sc.c:1189]: HIF driver started
Jan 01 00:00:00.516 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2363]: New PFE device: 2, ID: 4
Jan 01 00:00:00.531 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2702]: Adding 00:0a:0b:0c:0d:66 to pfe0
Jan 01 00:00:00.531 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2707]: Unable to assign MAC address 00:0a:0b:0c:0d:66 to the pfe0
Jan 01 00:00:00.531 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.531 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2829]: EMAC speed change for SGMII is currently not supported.
Jan 01 00:00:00.532 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 33:33:ff:0c:0d:66 to emac0
Jan 01 00:00:00.534 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.534 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:00:00.536 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 33:33:ff:0c:0d:66 to emac0
Jan 01 00:00:00.536 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2450]: unable to add 33:33:ff:0c:0d:66 into emac0: 17
Jan 01 00:00:00.536 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.536 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:00:00.536 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2450]: unable to add 33:33:00:00:00:01 into emac0: 17
Jan 01 00:00:00.536 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2829]: EMAC speed change for SGMII is currently not supported.
Jan 01 00:00:00.536 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 01:00:5e:00:00:01 to emac0
Jan 01 00:00:00.538 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:00:00.538 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2450]: unable to add 33:33:00:00:00:01 into emac0: 17
Jan 01 00:00:00.538 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2450]: unable to add 33:33:ff:0c:0d:66 into emac0: 17
Jan 01 00:00:00.538 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
# slog2info  | grep io_pkt_v6_hc
Jan 01 00:00:00.512 io_pkt_v6_hc.8 slog 0 INF[src/oal_irq_qnx.c:117]: PFE HIF1 IRQ Worker started (IRQ ID: 223)
Jan 01 00:00:00.514 io_pkt_v6_hc.8 slog 0 INF[src/oal_irq_qnx.c:117]: PFE HIF2 IRQ Worker started (IRQ ID: 224)
Process 172057 (slog2info) exited status=0.
Jan 01 00:01:01.630 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:01:01.630 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2450]: unable to add 33:33:00:00:00:01 into emac0: 17
Jan 01 00:01:01.630 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2443]: Adding 33:33:ff:0c:0d:66 to emac0
Jan 01 00:01:01.630 io_pkt_v6_hc.8 slog 0 WRN[src/pfe_drv.c:2450]: unable to add 33:33:ff:0c:0d:66 into emac0: 17
Jan 01 00:01:01.630 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2495]: Removing 01:00:5e:00:00:01 from emac0
Jan 01 00:01:01.632 io_pkt_v6_hc.8 slog 0 INF[src/pfe_phy_if.c:2716]: Address 01:00:5e:00:00:01 removed from emac0
Jan 01 00:01:01.632 io_pkt_v6_hc.8 slog 0 INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
3,605 次查看
chenyin_h
Hello, @Seneca
Thanks for your reply.
In order for using the PFE drivers for QNX correctly,  you may have to use the versions described below to request integration related support from us.
Would you mind confirming if the QNX SDP 7.1 JBN37 is used or JBN51 is used in your test?(maybe with the name: BSP_nxp-s32g-evb_br-710_be-710_SVN984052_JBN51)
Additionally, from the integration manual within the 1.4 package, the following u-boot tag is used/tested instead of bsp37.0-2020.04
I suggest testing with this combinations firstly for initial analysis.
Chenyin
3,602 次查看
Seneca
Greetings,
I already use the uboot U-Boot 2020.04+g156b168010 from my 37 bsp setup. Can I reuse that and only switch the IFS file on the sdcard?
Edit: Oh, and the BSP 37 was recommended to my by your support a few months ago when I tried to get gmac0 running. Might 34 break this?
3,599 次查看
chenyin_h
Hello, @Seneca
From my opinion, I suggest firstly try testing it with QNX SDP 7.1 JBN37 strictly following the PFE_S32G_A53_QNX_IntegrationManual, if no issues with PFE, then checking the GMAC issues if does exist.
Chenyin
3,596 次查看
Seneca
Is JBN37 the same as BSP37?
BSP37 is what I am using at the moment.BSP_nxp-s32g-rdb3_br-710_be-710_SVN996606_JBN10.zip
I tried to follow the integration manual section 2.6.2 as follows:
Set the uboot variables:
saveenv
boot
When building the ifs image in the .build file, I replaced the networking section with this:
## Networking
display_msg Starting Networking driver (/dev/socket)...
waitfor /dev/socket 10
# Get IP form DHCP for pfe0 device - optional step
dhclient -m -lf /dev/shmem/dhclient.leases -pf /dev/shmem/dhclient.pid -nw pfe0
cp /proc/boot/libfci_cli /tmp # Optional component
And added this in the network driver section:
./../../pfebsp37/PFE-DRV_S32G_A53_QNX_1.4.0/sw/devnp-pfe-2/build/aarch64le-release/devnp-pfe-2.so # PFE driver
# Important - use [+raw] to treat fw as a raw data file
[+raw]./../../pfebsp37/PFE-FE_S32G_1.6.0/s32g_pfe_class.fw
[+raw]./../../pfebsp37/PFE-FE_S32G_1.6.0/s32g_pfe_util.fw
[perms=a+x]libfci_cli # Optional if libfci_cli is needed
In the BSP, I added in src/hardware/startup/boards/s32g/s32g399a-rdb/s32g_init_raminfo.c in s32g_init_raminfo function:
kprintf("Reserving RAM region for PFE driver on EVB/RDB\n");
as_add_containing(0x80000000,0x80000000 + 0x70000000 - 1,AS_ATTR_RAM,
"pfe_ddr","ram");
Did I miss anything?
3,538 次查看
chenyin_h
Hello, @Seneca
Thanks for your reply..
BSP 37 is the version number for Linux BSP provisioned by NXP(TFA, U-boot, Linux, etc.), while the JBN37 mentioned is part of the name of certain version QNX BSP release(BSP_nxp-s32g-evb_br-710_be-710_SVN950423_JBN37) provisioned by Blackberry, they are different.
According to the release notes, the QNX PFE Driver 1.4 was developed and tested with the following QNX release:  QNX® SDP 7.1 BuildID 472 (BSP_nxp-s32g-evb_br-710_be-710_SVN950423_JBN37), so I suggest firstly checking with your testing setup if the correct QNX version is used.
However, as shared from your previous reply, BSP_nxp-s32g-rdb3_br-710_be-710_SVN996606_JBN10 was used, which does not match the requirement.
Chenyin
3,508 次查看
Seneca
Greetings,
you recommend a BSP_nxp-s32g-evb* release which looks like for the evb board will this even work with an rdb3 board like mine? Is there a driver compatible with rdb3?
Edit: The only driver version I can find at the moment that lists rdb3 at the moment is 1.9.0 which lists a BSP_nxp-s32g-rdb3_be-800_SVN1011366_JBN153.zip but only for QNX SDP 8.0 not for 7.1.
Are you aware of a package that works with rdb3 and QNX SDP 7.1?
3,502 次查看
chenyin_h
Hello, @Seneca
If not focused on certain version PFE QNX drivers, I suggest trying PFE QNX driver 1.8 with FW 1.11
1. It is compatible with  QNX® SDP 7.1 BSP for NXP - BuildID 51 (BSP_nxp-s32g-evb_br-710_be-710_SVN984052_JBN51)
2. It was developed and tested with S32G-VNP-RDB3(although named with ...-evb....)
Which fulfill your requirements.
Chenyin
3,467 次查看
Seneca
Ok, so I downloaded the
package you mentioned, modified the .build file and add the
as_add_containing(0x80000000,0x80000000 + 0x4000000 - 1,AS_ATTR_RAM, "pfe_ddr","ram");
to
src/hardware/startup/boards/s32g/s32g399a-rdb/s32g_init_raminfo.c and replace my ifs file with the resulting ifs-s32g399a-rdb.ui.
Unfortunately, it doesn't seem to execute the pfe_ddr allocation from above.
Is there anything I need to modify for the uboot parameters or else for this new image to work?
3,176 次查看
chenyin_h
Hello, @Seneca
I suggest referencing the integration manual strictly, refer to the part you mentioned, the following need to be modified before building the QNX BSP.
Chenyin
3,495 次查看
Seneca
I shall try that, tx.
Can you name me the exact package name in the QNX Software Center? All packages with EVB I see are marked with S32G274A and I don't know if these work with a S32G3 board.
Btw: Some manuals put the *.fw files on the root of the sd card so that uboot can load them with pfeng* commands but it is not part of the integration manuals I have read so far. Is this really necessary or is loading the firmware via io-pkt* enough?
3,486 次查看
chenyin_h
Hello, @Seneca
Sorry that since QNX is 3rd product, we may not be aware of the BSP details/changes released, my feedback is based on available NXP documents.
1. I have just checked the QNX PFE driver 1.7 and 1.8, and found that the integration manual is actually based on QNX PFE driver 1.7, so this version is also correct for your test.
2. From the corresponding document, for QNX PFE driver 1.7, it is compatible with FW 1.10
While the name of the QNX BSP is:
3. From my previous experience, since there would be some differences across different version QNX PFE drivers, I suggest firstly following the integration manual that is found from certain QNX PFE driver used.
For other details of QNX BSP itself, I suggest directly contacting QNX support portal
Sorry for your inconvenience
Chenyin
2,395 次查看
Seneca
Hello Chenyin,
can you tell me which NXP BSP Version was used by the person who tested the PFE Driver 1.7.0 with the QNXJBN51?
2,388 次查看
chenyin_h
Hello, @Seneca
The tested BSP version is BSP39 combine with QNX driver version 1.7.0 and QNX SDP 7.1 BSP JBN51
Chenyin
2,383 次查看
Seneca
And what was the PFE firmware version used?
JBN51 needs NXP BSP39 which comes with PFE Firmware 1.8.0. But section 2.1.3 of the Pfe Driver 1.7.0 release notes states that only PFW FW 1.10.0 was tested with this release.
2,628 次查看
Seneca
Greetings,
do you know if NXP provides SDCard images that already have the uboot modifications necessary for PFE as in board_cleanup_before_linux?
I don't know what packages like binaries_auto_linux_bsp37.0_s32g3_pfe do.
2,441 次查看
chenyin_h
Hello, @Seneca
Sorry that there are not such images for publicly downloaded.
For "binaries_auto_linux_bsp37.0_s32g3_pfe", seems it is the name of the tgz file from:
If so, it includes the pre-built binaries of Linux BSP provisioned by NXP, there are not any QNX related images included.
Chenyin
2,315 次查看
Seneca
Now I built the uboot myself according to the integration manual. I added the modifications from section 2.10.2 form the PFE Driver 1.7.0 Integration manual. There seem to be some errors during startup:
board_cleanup_before_linux: QNX PFE code.
ethernet@4033c000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
phy_startup() failed: -110FAILED: -110
Found PFE version 0x0101 (S32G3)
pfe2 Waiting for PHY auto negotiation to complete......... TIMEOUT !
pfeng_netif pfe1: Failed to establish XPCS link on PFE1
Is this normal?
%3CLINGO-SUB%20id%3D%22lingo-sub-2385092%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G399A-RDB3%20QNX%20PFE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385092%22%20slang%3D%22en-US%22%20mode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gmac0%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3Eio%20%E5%8C%85%E8%B0%83%E7%94%A8%EF%BC%9A%3C%2FP%3E%3CP%3Eio-pkt-v6-hc%20-p%20tcpip%20-d%20pfe-2%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cno_reset%2Cmode0%3Dsgmii%2Cphy0%3D0%2Cmode1%3Dsgmii%2Cphy1%3D1%3C%2FP%3E%3CP%3EUboot%E5%8F%82%E6%95%B0%EF%BC%9A%3C%2FP%3E%3CP%3EUboot%20%E4%B8%8E%20Linux%20sdcard%20%E9%95%9C%E5%83%8F%E4%B8%AD%E7%9A%84%20Uboot%20%E7%9B%B8%E5%90%8C%EF%BC%8C%E5%8F%AA%E6%98%AF%E4%BF%AE%E6%94%B9%E4%BA%86%20qnx%20%E5%90%AF%E5%8A%A8%E7%9A%84%E5%8F%82%E6%95%B0%E3%80%82%3C%2FP%3E%3CP%3Esetenv%20hwconfig%20%22pcie0%3Amode%3Drc%2Cclock%3Dext%3Bpcie1%3Amode%3Dsgmii%2Cclock%3Dext%2Cfmhz%3D125%2Cxpcs_mode%3D2G5%22%3CBR%20%2F%3E%20setenv%20pfeng_mode%20'enable%2Csgmii%2Csgmii%2Crgmii'%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%20s32cc_gmac_mode%20%E4%B8%BA%E7%A6%81%E7%94%A8%3CBR%20%2F%3Esetenv%20pfeng%20enable%3B%20s32ccgmac%20disable%3B%20s32ccgmac%20enable%3B%3CBR%20%2F%3E%20setenv%20boot_qnx_atf%20'mmc%20dev%200%3B%20fatload%20mmc%200%3A1%200x83e00000%20s32g399a-rdb3.dtb%3Bpfeng%20%E5%90%AF%E7%94%A8%EF%BC%9Bs32ccgmac%20%E7%A6%81%E7%94%A8%EF%BC%9Bs32ccgmac%20%E5%90%AF%E7%94%A8%EF%BC%9Bfatload%20mmc%200%3A1%200x80080000%20ifs-s32g399a-rdb.ui%EF%BC%9Bbootm%200x80080000%20-%200x83E00000'%3CBR%20%2F%3E%20setenv%20bootcmd%20'run%20boot_qnx_atf'%3CBR%20%2F%3E%E4%BF%9D%E5%AD%98%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FP%3E%3CDIV%3EU-Boot%202020.04%2Bg156b168010%EF%BC%882023%E5%B9%B46%E6%9C%889%E6%97%A5%2010%3A14%3A25%20%2B0000%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECPU%EF%BC%9ANXP%20S32G399A%20rev.1.1%3C%2FDIV%3E%3CDIV%3E%E5%9E%8B%E5%8F%B7%EF%BC%9ANXP%20S32G399A-RDB3%3C%2FDIV%3E%3CDIV%3E%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(DRAM)%EF%BC%9A3.5%20GiB%3C%2FDIV%3E%3CDIV%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%3C%2FDIV%3E%3CDIV%3E%E4%BB%8EMMC%E5%8A%A0%E8%BD%BD%E7%8E%AF%E5%A2%83...%20%E6%88%90%E5%8A%9F%3C%2FDIV%3E%3CDIV%3E%E5%B0%86%20PCIe0%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E6%A0%B9%E5%A4%8D%E5%90%88%E4%BD%93%3C%2FDIV%3E%3CDIV%3EPCIe0%EF%BC%9A%E8%BF%9E%E6%8E%A5%E5%A4%B1%E8%B4%A5%3C%2FDIV%3E%3CDIV%3EPCI%EF%BC%9A%E8%87%AA%E5%8A%A8%E9%85%8D%E7%BD%AE%E5%A4%B1%E8%B4%A5%EF%BC%8C%E7%AC%AC%201c%20%E6%9D%A1%3C%2FDIV%3E%3CDIV%3E%E8%BE%93%E5%85%A5%EF%BC%9Aserial%40401c8000%3C%2FDIV%3E%3CDIV%3E%E8%BE%93%E5%87%BA%EF%BC%9Aserial%40401c8000%3C%2FDIV%3E%3CDIV%3E%E9%94%99%E8%AF%AF%EF%BC%9Aserial%40401c8000%3C%2FDIV%3E%3CDIV%3E%E6%9D%BF%E4%BF%AE%E8%AE%A2%EF%BC%9ARDB3%20%E4%BF%AE%E8%AE%A2%E7%89%88%20F%3C%2FDIV%3E%3CDIV%3E%E7%BD%91%E7%BB%9C%EF%BC%9AEQOS%20phy%EF%BC%9Argmii%20%40%201%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%AD%A6%E5%91%8A%EF%BC%9Aeth_eqos%20(eth0)%20%E4%BD%BF%E7%94%A8%E9%9A%8F%E6%9C%BA%20MAC%20%E5%9C%B0%E5%9D%80%20-%2026%3Ae4%3Ae6%3A43%3A15%3Aad%3C%2FDIV%3E%3CDIV%3Eeth0%EF%BC%9Aeth_eqos%20%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20emac1_xpcs%20%E7%9A%84%20XPCS%20%E9%80%9F%E5%BA%A6%20PFE%EF%BC%9Aemac0%EF%BC%9Asgmii%20emac1%EF%BC%9Asgmii%20emac2%EF%BC%9Argmii%3C%2FDIV%3E%3CDIV%3E%EF%BC%8Ceth1%EF%BC%9Aeth_pfeng%3C%2FDIV%3E%3CDIV%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A3%202%201%200%3C%2FDIV%3E%3CDIV%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%88%86%E5%8C%BA%20%230%EF%BC%8C%E7%A1%AE%E5%AE%9A%3C%2FDIV%3E%3CDIV%3Emmc0%20is%20current%20device%3C%2FDIV%3E%3CDIV%3E%E8%AF%BB%E5%8F%9650640%E5%AD%97%E8%8A%82%E8%80%97%E6%97%B617%E6%AF%AB%E7%A7%92%EF%BC%882.8%20MiB%2Fs%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%E8%AF%BB%E5%8F%96%E4%BA%86%2011948752%20%E5%AD%97%E8%8A%82%EF%BC%8C%E8%80%97%E6%97%B6%20540%20%E6%AF%AB%E7%A7%92%EF%BC%8821.1%20MiB%2Fs%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%23%23%20%E4%BB%8E%E4%BD%8D%E4%BA%8E%2080080000%20%E7%9A%84%E4%BC%A0%E7%BB%9F%E6%98%A0%E5%83%8F%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FDIV%3E%3CDIV%3E%E5%9B%BE%E7%89%87%E5%90%8D%E7%A7%B0%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E%E9%95%9C%E5%83%8F%E7%B1%BB%E5%9E%8B%EF%BC%9AAArch64%20Linux%20%E5%86%85%E6%A0%B8%E9%95%9C%E5%83%8F%EF%BC%88%E6%9C%AA%E5%8E%8B%E7%BC%A9%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%EF%BC%9A11948688%20%E5%AD%97%E8%8A%82%20%3D%2011.4MiB%3C%2FDIV%3E%3CDIV%3E%E5%8A%A0%E8%BD%BD%E5%9C%B0%E5%9D%80%EF%BC%9A80080000%3C%2FDIV%3E%3CDIV%3E%E5%85%A5%E5%8F%A3%E7%82%B9%EF%BC%9A80080000%3C%2FDIV%3E%3CDIV%3E%E6%A0%A1%E9%AA%8C%E5%92%8C%E9%AA%8C%E8%AF%81%E4%B8%AD...%20%E6%88%90%E5%8A%9F%3C%2FDIV%3E%3CDIV%3E%23%23%20%E4%BD%8D%E4%BA%8E%2083e00000%20%E7%9A%84%E6%89%81%E5%B9%B3%E5%8C%96%E8%AE%BE%E5%A4%87%E6%A0%91%20blob%3C%2FDIV%3E%3CDIV%3E%E4%BD%BF%E7%94%A8%E4%BD%8D%E4%BA%8E%200x83e00000%20%E7%9A%84%20fdt%20blob%20%E5%90%AF%E5%8A%A8%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%3C%2FDIV%3E%3CDIV%3E%E4%BD%BF%E7%94%A8%E4%BD%8D%E4%BA%8E%200000000083e00000%20%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%EF%BC%8C%E7%BB%93%E6%9D%9F%E4%BA%8E%200000000083e0f5cf%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E5%A4%8D%EF%BC%9Apfe0%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%2000%3A01%3Abe%3Abe%3Aef%3A11%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E5%A4%8D%EF%BC%9Apfe1%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%2000%3A01%3Abe%3Abe%3Aef%3A22%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E5%A4%8D%EF%BC%9Apfe1%EF%BC%9A%E5%B0%86%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%E6%9B%B4%E6%96%B0%E4%B8%BA%200x8%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E5%A4%8D%EF%BC%9Apfe2%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%2000%3A01%3Abe%3Abe%3Aef%3A33%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E5%9C%A8%20EVB%2FRDB%20%E4%B8%8A%E4%B8%BA%20PFE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BF%9D%E7%95%99%20RAM%20%E5%8C%BA%E5%9F%9F%3C%2FDIV%3E%3CDIV%3E%E5%AE%8C%E6%88%90%E3%80%82%3C%2FDIV%3E%3CDIV%3EClockCycles%20%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E0%2043600679%3C%2FDIV%3E%3CDIV%3E1%2043600679%3C%2FDIV%3E%3CDIV%3E2%2043600678%3C%2FDIV%3E%3CDIV%3E3%2043600679%3C%2FDIV%3E%3CDIV%3E4%2043600678%3C%2FDIV%3E%3CDIV%3E5%2043600678%3C%2FDIV%3E%3CDIV%3E6%2043600678%3C%2FDIV%3E%3CDIV%3E7%2043600679%3C%2FDIV%3E%3CDIV%3E%E6%89%80%E6%9C%89%E6%97%B6%E9%92%9F%E5%91%A8%E6%9C%9F%E5%81%8F%E7%A7%BB%E5%9D%87%E5%9C%A8%E5%AE%B9%E5%B7%AE%E8%8C%83%E5%9B%B4%E5%86%85%3C%2FDIV%3E%3CDIV%3E%E6%AC%A2%E8%BF%8E%E4%BD%BF%E7%94%A8%20QNX%20Neutrino%207.1.0%E5%9C%A8%20NXP%20S32G399A%20RDB%20%E6%9D%BF%E4%B8%8A%EF%BC%81%3C%2FDIV%3E%3CDIV%3E%E5%90%AF%E5%8A%A8%E7%9B%91%E7%9D%A3%E6%9C%BA%E5%88%B6%E2%80%A6%E2%80%A6%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E4%B8%B2%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E7%BD%91%E7%BB%9C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%2Fdev%2Fsocket%EF%BC%89...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%204107%20(ifconfig)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%2010%20(sh)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%209%20(dhclient)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3Ecp%EF%BC%9A%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E6%BA%90%E6%96%87%E4%BB%B6%E3%80%82%EF%BC%88%2Fproc%2Fboot%2Flibfci_cli%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%2020489%20(cp)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D1%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20SPI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%2Fdev%2Fspi0%2C1%2C2%2C3%2C4%2C5%EF%BC%89...%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20I2C%200%2F1%2F2%2F3%2F4%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20(%2Fdev%2Fi2c0%2C1%2C2%2C3%2C4)...%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20USDHC0%20%E5%AD%98%E5%82%A8%E5%8D%A1%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3C%2FDIV%3E%3CDIV%3E%5B00%5D%20SIM%3D%22SDMMC%22%20HBA%3D%22imx%22%3C%2FDIV%3E%3CDIV%3E%5B00%2C0%2C0%5D%20type%3D00%20ver%3D05%20resp%3D00%20SDMMC%3A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%2024596%20(chkqnx6fs)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%2028692%20(mount)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8QSPI%20Flash%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3C%2FDIV%3E%3CDIV%3E%E5%90%AF%E5%8A%A8%20USB%20%E4%B8%BB%E6%9C%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20(%2Fdev%2Fusb%2F*)%3C%2FDIV%3E%3CDIV%3E%E6%A3%80%E6%B5%8B%E5%88%B0%20QSPI%20Flash%EF%BC%9AMacronix%20MX25UW512%EF%BC%8CJEDEC%200xC2%20-%200x813A%EF%BC%8C%E5%AE%B9%E9%87%8F%EF%BC%9A0x4000000%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E4%B8%BA%20%2Fdev%2Fusb%2F*%20%E5%90%AF%E5%8A%A8%20devb-umass%20...%3C%2FDIV%3E%3CDIV%3E%23%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%2036891%EF%BC%88%E7%9D%A1%E7%9C%A0%EF%BC%89%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3Esh%3A%20%2Fvar%2Fcetitec2%2Fstartup.sh%3A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%2045081%20(sh)%20%E7%BB%88%E6%AD%A2%20signo%3D0%20code%3D0%20%E7%94%B1%E8%BF%9B%E7%A8%8B%200%20value%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3Eslog2info%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.023%E9%9A%8F%E6%9C%BA.4low*%200%20qcrypto%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E2%80%9C%2Fetc%2Fqcrypto.conf%E2%80%9D%5Bqcrypto_common.c(190)%5D%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.024random.4..0%20slog*%20700%20Random%20%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20Fortuna%20%E4%BC%AA%E9%9A%8F%E6%9C%BA%E6%95%B0%E7%94%9F%E6%88%90%E5%99%A8%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.031%E9%9A%8F%E6%9C%BA.4low%200%20qcrypto%3A%20'openssl'%20%E6%8F%92%E4%BB%B6%E5%B7%B2%E5%8A%A0%E8%BD%BD%20%5Bqcrypto_plugins.c(354)%5D%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.031random.4..0%20slog%20700%20%E9%80%89%E6%8B%A9%E8%AE%A1%E6%97%B6%E5%99%A8%E4%BD%9C%E4%B8%BA%E7%86%B5%E6%BA%90%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.032random.4..0%20slog%20700%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E8%B7%AF%E5%BE%84%E5%90%8D%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.032random.4..0%20slog%20700%20random%3A%20%E5%BC%80%E5%A7%8B%20resmgr%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.032random.4..0%20slog%20700%20random%EF%BC%9A%E8%BF%9B%E7%A8%8B%E5%B7%B2%E5%AE%88%E6%8A%A4%E5%8C%96%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.042devc_serlinflexd.7slog*%200%20serlinflexd_interrupt_attach%3A%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%AD%E6%96%AD%20114%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.047iopkt.8%E4%B8%BB%E7%BC%93%E5%86%B2%E5%8C%BA*%200%20TCP%2FIP%20%E5%BC%80%E5%A7%8B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.047iopkt.8main_buffer%200%20smmu%20%E6%94%AF%E6%8C%81%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.049iopkt.8main_buffer%200%20%E6%AD%A3%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%20IPsec...%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.049iopkt.8%E4%B8%BB%E7%BC%93%E5%86%B2%E5%8C%BA%200%20%E5%AE%8C%E6%88%90%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.049iopkt.8main_buffer%200%20IPsec%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E5%85%B3%E8%81%94%E5%A4%84%E7%90%86%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.051iopkt.8main_buffer%200%20devnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cpfe0_mode%3Dsgmii%2Cpfe0_phy%3D0%2Cpfe1_mode%3Dsgmii%2Cpfe1_phy%3D1%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.052io_pkt_v6_hc.8slog*%200%20INF%5Bsrc%2Fpfe_drv.c%3A1377%5D%3A%E7%89%88%E6%9C%AC%E4%BF%A1%E6%81%AF%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%EF%BC%9A1.4.0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8F%90%E4%BA%A4%E5%93%88%E5%B8%8C%E5%80%BC%EF%BC%9A2f3265a49ac18f94ba5e48254c8f870fe7bfc511%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_MULTI_INSTANCE_SUPPORT%3A%200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_LOCAL_IF%EF%BC%9A6%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_MASTER_IF%EF%BC%9A6%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_SC_HIF%EF%BC%9A1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_HIF_RING_LENGTH%3A%20256%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_PFE0_PROMISC%3A%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_PFE1_PROMISC%3A%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_PFE2_PROMISC%3A%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.052io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1384%5D%3A---%20%E5%AE%89%E5%85%A8%E4%B8%AD%E6%96%AD%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%E4%B8%8D%E5%85%81%E8%AE%B8%E4%BD%BF%E7%94%A8%20InterruptAttach()%20%E6%88%96%20InterruptAttach_r()%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.052io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A83%5D%3A%E8%AF%BB%E5%8F%96%2042792%20%E5%AD%97%E8%8A%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.053io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A89%5D%3A%E5%B7%B2%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%E6%96%87%E4%BB%B6%EF%BC%9A%2Fproc%2Fboot%2Fs32g_pfe_class.fw%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.053io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe0%2FEMAC0%20%E7%9A%84%20MII%20%E6%A8%A1%E5%BC%8F%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%20SGMII%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.053io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe1%2FEMAC1%20%E7%9A%84%20MII%20%E6%A8%A1%E5%BC%8F%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%20SGMII%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.053io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe2%2FEMAC2%20%E7%9A%84%20MII%20%E6%A8%A1%E5%BC%8F%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%20RGMII%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.053io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1495%5D%3A%E5%8F%91%E5%87%BA%20PFE%20%E5%A4%96%E8%AE%BE%20RESET%20%E6%8C%87%E4%BB%A4...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.274io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1496%5D%3APFE%20RESET%20OK.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.274io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3519%5D%3APFE%20CBUS%20p0x46000000%20%E6%98%A0%E5%B0%84%E5%88%B0%20v0x38f2e23000%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.274io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3524%5D%3A%E7%A1%AC%E4%BB%B6%E7%89%88%E6%9C%AC%200x101%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.274io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hw_feature.c%3A95%5D%3A%20Silicon%20S32G3%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.274io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3536%5D%3A%E6%95%85%E9%9A%9C%E5%81%9C%E6%AD%A2%E6%A8%A1%E5%BC%8F%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2687%5D%3APFE_ERRORS%EF%BC%9A%E5%B7%B2%E5%88%9B%E5%BB%BA%20Parity%20%E5%AE%9E%E4%BE%8B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2702%5D%3APFE_ERRORS%EF%BC%9A%E5%B7%B2%E5%88%9B%E5%BB%BA%E7%9B%91%E8%A7%86%E7%A8%8B%E5%BA%8F%E5%AE%9E%E4%BE%8B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2718%5D%3APFE_ERRORS%EF%BC%9A%E6%80%BB%E7%BA%BF%E9%94%99%E8%AF%AF%E5%AE%9E%E4%BE%8B%E5%B7%B2%E5%88%9B%E5%BB%BA%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2731%5D%3APFE_ERRORS%EF%BC%9AFW%20%E6%95%85%E9%9A%9C%E5%81%9C%E6%AD%A2%E5%AE%9E%E4%BE%8B%E5%B7%B2%E5%88%9B%E5%BB%BA%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2744%5D%3APFE_ERRORS%EF%BC%9A%E4%B8%BB%E6%9C%BA%E6%95%85%E9%9A%9C%E5%81%9C%E6%AD%A2%E5%AE%9E%E4%BE%8B%E5%B7%B2%E5%88%9B%E5%BB%BA%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2757%5D%3APFE_ERRORS%EF%BC%9A%E5%B7%B2%E5%88%9B%E5%BB%BA%E6%95%85%E9%9A%9C%E5%81%9C%E6%AD%A2%E5%AE%9E%E4%BE%8B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2770%5D%3APFE_ERRORS%EF%BC%9AECC%20%E9%94%99%E8%AF%AF%E5%AE%9E%E4%BE%8B%E5%B7%B2%E5%88%9B%E5%BB%BA%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1766%5D%3ABMU1%20%E7%BC%93%E5%86%B2%E5%8C%BA%E5%9F%BA%E5%9D%80%EF%BC%9Ap0xc0000000%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.277io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1810%5D%3ABMU2%20%E7%BC%93%E5%86%B2%E5%8C%BA%E5%9F%BA%E5%9D%80%EF%BC%9Ap0x83000000%EF%BC%880x200000%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.279io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3APFE%20BMU%20IRQ%20%E5%B7%A5%E4%BD%9C%E8%BF%9B%E7%A8%8B%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%88IRQ%20ID%EF%BC%9A226%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.279io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2194%5D%3A%E9%80%89%E9%A1%B9%E2%80%9Cg2_ordered_class_writes%E2%80%9D%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.279io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x88000)%E3%80%82%E6%B3%B3%E6%B1%A0%E5%B7%B2%E5%87%86%E5%A4%87%E5%B0%B1%E7%BB%AA%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.279io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x8c000)%E3%80%82%E6%B3%B3%E6%B1%A0%E5%B7%B2%E5%87%86%E5%A4%87%E5%B0%B1%E7%BB%AA%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.281io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2239%5D%3A%E5%9B%BA%E4%BB%B6%20.elf%E6%A3%80%E6%B5%8B%E5%88%B0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.281io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2248%5D%3A%E6%AD%A3%E5%9C%A8%E4%B8%8A%E4%BC%A0%20CLASS%20%E5%9B%BA%E4%BB%B6%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.281io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A609%5D%3A%E9%80%89%E6%8B%A9%E5%9B%BA%E4%BB%B6%E5%8A%A0%E8%BD%BD%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%B9%B6%E8%A1%8C%E5%8A%A0%E8%BD%BD%208%20%E4%B8%AA%20PE%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.285io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A1945%5D%3Apfe_ct.h%E6%96%87%E4%BB%B6%E7%89%88%E6%9C%AC%E2%80%9C92367c0e25f21f49217a9b08168ad2c8%E2%80%9D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.288io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A2422%5D%3A%5B%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%5D%201.7.0%E6%9E%84%E5%BB%BA%E7%89%88%E6%9C%AC%EF%BC%9A2023%E5%B9%B46%E6%9C%882%E6%97%A5%2013%3A48%3A57%20(nogitaaa)%EF%BC%8CID%EF%BC%9A0x31454650%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.406io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2312%5D%3AVLAN%20ID%20%E4%B8%8D%E6%AD%A3%E7%A1%AE%E6%88%96%E6%9C%AA%E8%AE%BE%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%20VLAN%20ID%20%3D%200x01%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.406io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2318%5D%3AVLAN%E7%BB%9F%E8%AE%A1%E4%BF%A1%E6%81%AF%E5%A4%A7%E5%B0%8F%E4%B8%8D%E6%AD%A3%E7%A1%AE%E6%88%96%E6%9C%AA%E8%AE%BE%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%20VLAN%20%E7%BB%9F%E8%AE%A1%E4%BF%A1%E6%81%AF%E5%A4%A7%E5%B0%8F%20%3D%2020%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.406io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1181%5D%3A%E8%BD%AF%E4%BB%B6%20VLAN%20%E5%93%88%E5%B8%8C%E8%A1%A8%20%40%20p0x20001228%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.406io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1286%5D%3A%E5%A4%87%E7%94%A8%E6%A1%A5%E6%8E%A5%E5%8A%9F%E8%83%BD%E5%9F%9F%20%40%200x20000a7c%EF%BC%88%E7%B1%BB%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.406io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1287%5D%3A%E9%BB%98%E8%AE%A4%E6%A1%A5%E6%8E%A5%E5%8A%9F%E8%83%BD%E5%9F%9F%20%40%200x20000a74%EF%BC%88%E7%B1%BB%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.406io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2412%5D%3A%E8%B7%AF%E7%94%B1%E8%A1%A8%E5%B7%B2%E5%88%9B%E5%BB%BA%EF%BC%8C%E5%93%88%E5%B8%8C%E8%A1%A8%E4%BD%8D%E4%BA%8E%20p0x80014000%EF%BC%8C%E6%B1%A0%E4%BD%8D%E4%BA%8E%20p0x8001c000%EF%BC%8865536%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.407io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20%E5%88%9D%E5%A7%8B%E5%8C%96%20RX%20%E7%BC%93%E5%86%B2%E6%B1%A0%E3%80%82%E6%B7%B1%E5%BA%A6%EF%BC%9A256%EF%BC%9B%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%EF%BC%9A2048%EF%BC%9B%E7%BC%93%E5%AD%98%E8%A1%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A64%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.408io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20%E5%88%9D%E5%A7%8B%E5%8C%96%20RX%20%E7%BC%93%E5%86%B2%E6%B1%A0%E3%80%82%E6%B7%B1%E5%BA%A6%EF%BC%9A256%EF%BC%9B%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%EF%BC%9A2048%EF%BC%9B%E7%BC%93%E5%AD%98%E8%A1%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A64%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.409io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20%E5%88%9D%E5%A7%8B%E5%8C%96%20RX%20%E7%BC%93%E5%86%B2%E6%B1%A0%E3%80%82%E6%B7%B1%E5%BA%A6%EF%BC%9A256%EF%BC%9B%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%EF%BC%9A2048%EF%BC%9B%E7%BC%93%E5%AD%98%E8%A1%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A64%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.508io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3705%5D%3A%E5%8A%9F%E8%83%BD%E9%94%99%E8%AF%AF%20err051211_workaround%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.509iopkt.8%E4%B8%BB%E7%BC%93%E5%86%B2%E5%8C%BA%200%20pfe0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.509io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2152%5D%3Apfe0%EF%BC%9A%E4%BD%BF%E7%94%A8%20PHY%20%E6%A8%A1%E5%BC%8F%EF%BC%9AMDIO%3D0%EF%BC%8CADDR%3D0%EF%BC%8CCLAUSE%3D0%EF%BC%8CRESET%3D0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.509io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3APFE%20HIF0%20IRQ%20%E5%B7%A5%E4%BD%9C%E8%BF%9B%E7%A8%8B%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%88IRQ%20ID%EF%BC%9A222%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.509io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%E5%B0%86%2000%3A0a%3A0b%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20pfe0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511iopkt.8%E4%B8%BB%E7%BC%93%E5%86%B2%E5%8C%BA%200%20pfe1%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe0%20%E7%9A%84%E9%80%9F%E5%BA%A6%2F%E5%8F%8C%E5%B7%A5%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%201%20Gbps%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20%E5%B0%9D%E8%AF%95%E6%B3%A8%E5%86%8C%20HIF%20%E5%AE%A2%E6%88%B7%E7%AB%AF%EF%BC%9A0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%90%AF%E5%8A%A8%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0PFE%E8%AE%BE%E5%A4%87%EF%BC%9A0%EF%BC%8CID%EF%BC%9A0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2152%5D%3Apfe1%EF%BC%9A%E4%BD%BF%E7%94%A8%20PHY%20%E6%A8%A1%E5%BC%8F%EF%BC%9AMDIO%3D1%EF%BC%8CADDR%3D0%EF%BC%8CCLAUSE%3D0%EF%BC%8CRESET%3D0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3APFE%20HIF1%20IRQ%20%E5%B7%A5%E4%BD%9C%E8%BF%9B%E7%A8%8B%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%88IRQ%20ID%EF%BC%9A223%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%E5%B0%86%2000%3A1a%3A1b%3A1c%3A1d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20pfe1%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513iopkt.8%E4%B8%BB%E7%BC%93%E5%86%B2%E5%8C%BA%200%20pfe2%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe1%20%E7%9A%84%E9%80%9F%E5%BA%A6%2F%E5%8F%8C%E5%B7%A5%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%201%20Gbps%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20%E5%B0%9D%E8%AF%95%E6%B3%A8%E5%86%8C%20HIF%20%E5%AE%A2%E6%88%B7%E7%AB%AF%EF%BC%9A1%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%90%AF%E5%8A%A8%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0%E7%9A%84PFE%E8%AE%BE%E5%A4%87%EF%BC%9A1%EF%BC%8CID%EF%BC%9A2%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3Apfe2%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%9D%99%E6%80%81%20PHY%20%E6%A8%A1%E5%BC%8F%EF%BC%8CRESET%3D0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3APFE%20HIF2%20IRQ%20%E5%B7%A5%E4%BD%9C%E8%BF%9B%E7%A8%8B%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%88IRQ%20ID%EF%BC%9A224%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%E5%B0%86%2000%3A2a%3A2b%3A2c%3A2d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20pfe2%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.515io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe2%20%E7%9A%84%E9%80%9F%E5%BA%A6%2F%E5%8F%8C%E5%B7%A5%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%201%20Gbps%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.515io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20%E5%B0%9D%E8%AF%95%E6%B3%A8%E5%86%8C%20HIF%20%E5%AE%A2%E6%88%B7%E7%AB%AF%EF%BC%9A2%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.515io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%90%AF%E5%8A%A8%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.515io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0%E5%9E%8BPFE%E8%AE%BE%E5%A4%87%EF%BC%9A2%EF%BC%8CID%EF%BC%9A4%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.530io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2702%5D%3A%E5%B0%86%2000%3A0a%3A0b%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20pfe0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.530io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2707%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%20MAC%20%E5%9C%B0%E5%9D%80%2000%3A0a%3A0b%3A0c%3A0d%3A66%20%E5%88%86%E9%85%8D%E7%BB%99%20pfe0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.530io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.538io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_mdio.c%3A427%5D%EF%BC%9Apfe0%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E6%80%BB%E7%BA%BF%200%20%E5%9C%B0%E5%9D%80%200%20%E4%B8%8A%E7%9A%84%20PHY%E3%80%82%E5%88%87%E6%8D%A2%E5%88%B0%E9%9D%99%E6%80%81%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.538io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3A%E7%9B%AE%E5%89%8D%E4%B8%8D%E6%94%AF%E6%8C%81%20SGMII%20%E7%9A%84%20EMAC%20%E9%80%9F%E5%BA%A6%E6%9B%B4%E6%94%B9%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.538io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.540io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.540io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3A%E7%9B%AE%E5%89%8D%E4%B8%8D%E6%94%AF%E6%8C%81%20SGMII%20%E7%9A%84%20EMAC%20%E9%80%9F%E5%BA%A6%E6%9B%B4%E6%94%B9%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2001%3A00%3A5e%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.544io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.544io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.544io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.544io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.544io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.554spi_master.24585%20normal*%200%20%E5%90%AF%E5%8A%A8%20spi-master%20%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.558spi_master.24587%20normal*%200%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20spi-master%20%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.561spi_master.24588%20normal*%200%20%E5%90%AF%E5%8A%A8%20spi-master%20%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.565spi_master.24589%20normal*%200%20%E5%90%AF%E5%8A%A8%20spi-master%20%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.582devb_sdmmc_mx8x.24595%20slog*%201800%20devb-sdmmc-mx8x%201.00A%20(2026%E5%B9%B46%E6%9C%8823%E6%97%A5%2009%3A45%3A48)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.583devb_sdmmc_mx8x.24595%20slog%200%20libcam.so%20(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A15)%20bver%207010003%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.594devb_sdmmc_mx8x.24595%20slog%201800%20sdio_cd%3A%20%E6%8F%92%E5%85%A5%E8%B7%AF%E5%BE%84%200%EF%BC%8Ccd%20%E7%8A%B6%E6%80%81%200x1%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20SD%20CID%3A%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20MID%200x27%EF%BC%8COID%200x5048%EF%BC%8CPNM%20SD32G%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20PRV%200x62%EF%BC%8CPSN%200x6c62d132%EF%BC%8CMDT%204-2023%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20SD%20CSD%3A%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20CSD_STRUCTURE%201%2C%20SPEC_VERS%200%2C%20CCC%200x5b5%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20TAAC%2014%2C%20NSAC%200%2C%20TRAN_SPEED%2050%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20C_SIZE%2059023%2C%20C_SIZE_MULT%200%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20READ_BL_LEN%209%2C%20WRITE_BL_LEN%209%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20ERASE%20GRP_SIZE%200%2C%20GRP_MULT%200%2C%20SIZE%20127%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20blksz%20512%EF%BC%8C%E6%89%87%E5%8C%BA%E6%95%B0%2060440576%EF%BC%8Cdtr%2025000000%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20SD%20SW%20CAPS%3A%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20%E6%80%BB%E7%BA%BF%E6%A8%A1%E5%BC%8F%200x3%EF%BC%8C%E5%91%BD%E4%BB%A4%E7%B3%BB%E7%BB%9F%200x1%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20%E9%A9%B1%E5%8A%A8%E7%B1%BB%E5%9E%8B%200x1%EF%BC%8C%E5%BD%93%E5%89%8D%E9%99%90%E5%88%B6%200x1%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20dtr%2050000000%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20CFG%EF%BC%9A%E6%97%B6%E5%BA%8F%20HS%EF%BC%8CDTR%2050000000%EF%BC%8C%E6%80%BB%E7%BA%BF%E5%AE%BD%E5%BA%A6%204%20%E4%BD%8D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.645devb_sdmmc_mx8x.24595%20slog%20100%20cam-disk.so%20(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A17)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.647devb_sdmmc_mx8x.24595%20slog%200%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%20cam_status%3Dc4%2C%20scsi_status%3D2%2C%20flag%3D00000040%2C%20vuflag%3D0008%2C%20cmd%3D1a%2C%20error%3D70%2C%20%E6%84%9F%E7%9F%A5%3D5%2C%20asc%3D24%2C%20ascq%3D0%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.647devb_sdmmc_mx8x.24595%20slog%200%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%20cam_status%3Dc4%2C%20scsi_status%3D2%2C%20flag%3D00000040%2C%20vuflag%3D0008%2C%20cmd%3D5a%2C%20error%3D70%2C%20%E6%84%9F%E7%9F%A5%3D5%2C%20asc%3D24%2C%20ascq%3D0%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.647devb_sdmmc_mx8x.24595%20slog%200%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%20cam_status%3Dc4%2C%20scsi_status%3D2%2C%20flag%3D00000040%2C%20vuflag%3D0008%2C%20cmd%3D5a%2C%20error%3D70%2C%20%E6%84%9F%E7%9F%A5%3D5%2C%20asc%3D24%2C%20ascq%3D0%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.827devb_sdmmc_mx8x.24595%20slog%201000%20fs-qnx6%EF%BC%9A%E5%88%86%E9%85%8D%E7%AD%96%E7%95%A5%200%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.827devb_sdmmc_mx8x.24595%20slog%201000%20fs-qnx6%EF%BC%9A%E4%BD%BF%E7%94%A8%20btree%20%E7%9B%AE%E5%BD%95%200%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.828devb_sdmmc_mx8x.24595%20slog%201000%20fs-qnx6%3A%20fs-qnx6%3A%20%E6%9C%AA%E8%AF%B7%E6%B1%82%20trim%20(0%2C1048576%2C2)%EF%BC%8C%E4%B8%94%E4%B8%8D%E6%94%AF%E6%8C%81%E6%AD%A4%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.833io_usb_otg.36885%20slog*%200%20main(453)%5Btid%3A1%5D%3A%20io-usb-otg%20(2020%E5%B9%B46%E6%9C%8813%E6%97%A5%2020%3A10%3A17)%20%E5%8F%82%E6%95%B0%3A%20-d%20hcd-ehci-mx28%20ioport%3D0x44064100%2Cirq%3D243%2Culpi%2Cno_stream%2Cverbose%3D5%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.835devf_qspi_s32g.36884%20slog*%200%20(devf%20t1%3A%3Af3s_qspi_ident%3A73)%20%E9%A1%B5%E9%9D%A2%E5%A4%A7%E5%B0%8F%EF%BC%9A256%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.835devf_qspi_s32g.36884%20slog%200%20(devf%20t1%3A%3Af3s_qspi_ident%3A74)%20%E6%80%BB%E8%8A%AF%E7%89%87%E5%A4%A7%E5%B0%8F%EF%BC%9A0x4000000%EF%BC%8C%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A0x10000%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.839io_usb_otg.36885%20slog%200%20ehci_init%3A%20%E4%BD%BF%E7%94%A8%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%89%88%E6%9C%AC%202%20%E8%BF%9B%E8%A1%8C%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.839io_usb_otg.36885%20slog%200%20ehci_controller_init(4303)%3A%20devu-hcd-ehci-mx28.so%20(2024%E5%B9%B44%E6%9C%8819%E6%97%A5%2013%3A44%3A54)%3A%20args%20ulpi%2Cno_stream%2Cverbose%3D5%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.840io_usb_otg.36885%20slog%208%20usb_enum_port(94)%5Btid%3A1%5D%3A%20%E6%80%BB%E7%BA%BF%E5%8F%B7%200%EF%BC%8C%E7%88%B6%E7%BA%A7%20-1%EF%BC%8C%E7%AB%AF%E5%8F%A3%200%EF%BC%8C%E9%AB%98%E9%80%9F%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.840io_usb_otg.36885%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E7%B1%BB%E5%9E%8B%201%EF%BC%8C%E7%B4%A2%E5%BC%95%200%EF%BC%8C%E9%95%BF%E5%BA%A6%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.840io_usb_otg.36885%20slog%2012%20usb_device_set_address(245)%5Btid%3A1%5D%3A%20b%3A0%20devno%200%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.840io_usb_otg.36885%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E7%B1%BB%E5%9E%8B%201%EF%BC%8C%E7%B4%A2%E5%BC%95%200%EF%BC%8C%E9%95%BF%E5%BA%A6%2018)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.841io_usb_otg.36885%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E7%B1%BB%E5%9E%8B%202%EF%BC%8C%E7%B4%A2%E5%BC%95%200%EF%BC%8C%E9%95%BF%E5%BA%A6%209)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.841io_usb_otg.36885%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E7%B1%BB%E5%9E%8B%202%EF%BC%8C%E7%B4%A2%E5%BC%95%200%EF%BC%8C%E9%95%BF%E5%BA%A6%2025)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.841io_usb_otg.36885%20slog%208%20usb_enum_port(141)%5Btid%3A1%5D%3A%20vid%200x0000%2C%20did%200x0000%20enumerated(busno%200%2C%20devno%200%3A0)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.841io_usb_otg.36885%20slog%2011%20hub_state_inserted(569)%5Btid%3A1%5D%3A%20bdentry%200%2C%20dentry%200%200%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.841io_usb_otg.36885%20slog%2013%20hub_configuration_enable(263)%5Btid%3A1%5D%3A%201%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.943io_usb_otg.36885%20slog%200%20usbh_timeout_init(203)%5Btid%3A1%5D%3A%20%E5%AE%8C%E6%88%90%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.954io_usb_otg.36885%20slog%200%20read_vid_pid%3A%20ULPI%20VID%200x0424%20PID%200x0009%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.954io_usb_otg.36885%20slog%200%20s32g_phy_set_vbus%3A%20%E8%AE%BE%E7%BD%AE%20vbus%20%E5%85%B3%E9%97%AD%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.968io_usb_otg.36885%20slog%200%20s32g_phy_set_vbus%3A%20set_vbus%20on%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.979io_usb_otg.36885%20slog%200%20ehci_get_port_status(3568%200x44064100)%3A%20port%3D0%2C%20tpstatus%2010100%20e_pstatus%208c001000%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.979io_usb_otg.36885%20slog%208%20usb_enum_port_extract(172)%5Btid%3A7%5D%3A%20(%E6%80%BB%E7%BA%BF%E5%8F%B7%200%EF%BC%8C%E8%AE%BE%E5%A4%87%E5%8F%B7%200%EF%BC%8C%E7%AB%AF%E5%8F%A3%E5%8F%B7%201)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.979io_usb_otg.36885%20slog%208%20usb_enum_port_extract(192)%5Btid%3A7%5D%3A%20%E7%8A%B6%E6%80%81%20(2)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.983devb_umass.36886%20slog*%20900%20devb-umass%201.00A%20(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A41)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.984devb_umass.36886%20slog%200%20libcam.so%20(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A15)%20bver%207010003%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.985io_usb_otg.36885%20slog%200%20usbdi_client_connect(58)%5Btid%3A5%5D%3A%20pid%2036886%20proc%3Dproc%2F%E5%90%AF%E5%8A%A8%2Fdevb-umass%20usbdi_client%2032eebb9a80%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.986io_usb_otg.36885%20slog%200%20usbdi_resmgr_connect(310)%5Btid%3A5%5D%3A%20usbdi_resmgr_connect%3A%20pid%2036886%20usbdi_client%2032eebb9a80%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.986devb_umass.36886%20slog%200%20usbdi%20%E8%B0%83%E8%AF%95%E8%B7%AF%E5%BE%84%20%2Fpps%2Fusb%2Fdebug%2F%20%E4%B8%8D%E5%AD%98%E5%9C%A8%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%2049177%20(slog2info)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3E%23%20ifconfig%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Elo0%EF%BC%9A%E6%A0%87%E5%BF%97%3D8049%3CUP%3E%20mtu%2033136%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%20127.0.0.1%20%E5%AD%90%E7%BD%91%E6%8E%A9%E7%A0%81%200xff000000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20%3A%3A1%20prefixlen%20128%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A1%25lo0%20prefixlen%2064%20scopeid%200x1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe0%EF%BC%9A%E6%A0%87%E5%BF%97%3D8843%3CUP%3E%20mtu%201500%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%B7%B2%E5%90%AF%E7%94%A8%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%EF%BC%9A00%3A0a%3A0b%3A0c%3A0d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BB%8B%E8%B4%A8%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%97%A0%EF%BC%881000baseT%20%E5%85%A8%E5%8F%8C%E5%B7%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%EF%BC%9A%E6%B4%BB%E8%B7%83%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%200.0.0.0%20netmask%200xff000000%20broadcast%20255.255.255.255%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A20a%3Abff%3Afe0c%3Ad66%25pfe0%20prefixlen%2064%20scopeid%200x11%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe1%EF%BC%9A%E6%A0%87%E5%BF%97%3D8802%20mtu%201500%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%B7%B2%E5%90%AF%E7%94%A8%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%EF%BC%9A00%3A1a%3A1b%3A1c%3A1d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BB%8B%E8%B4%A8%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%97%A0%EF%BC%881000baseT%20%E5%85%A8%E5%8F%8C%E5%B7%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%EF%BC%9A%E6%97%A0%E6%89%BF%E8%BF%90%E5%95%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe2%EF%BC%9A%E6%A0%87%E5%BF%97%3D8802%20mtu%201500%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%B7%B2%E5%90%AF%E7%94%A8%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%EF%BC%9A00%3A2a%3A2b%3A2c%3A2d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BB%8B%E8%B4%A8%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%97%A0%EF%BC%881000baseT%20%E5%85%A8%E5%8F%8C%E5%B7%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%EF%BC%9A%E6%97%A0%E6%89%BF%E8%BF%90%E5%95%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%2057369%20(ifconfig)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3E%23%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2385521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E5%B0%86%20s32g_pfe_class.fw%20%E5%92%8C%20s32g_pfe_util.fw%20%E6%9B%BF%E6%8D%A2%E6%88%90%E4%BA%86%3CSPAN%3EPFE-FW_S32G_1.6.0.zip%20%E4%B8%AD%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D14074877%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D14074877%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EUboot%E5%8F%82%E6%95%B0%EF%BC%9A%3C%2FP%3E%3CP%3Esetenv%20boot_qnx_atf%20'mmc%20dev%200%3B%20fatload%20mmc%200%3A1%200x83e00000%20s32g399a-rdb3.dtb%3B%E8%BF%90%E8%A1%8C%20atf_fdt_0to3%EF%BC%9B%E8%BF%90%E8%A1%8C%20atf_fdt_4to7%EF%BC%9B%E5%8A%A0%E8%BD%BD%20mmc%200%3A1%200x80080000%20ifs-s32g399a-rdb.ui%EF%BC%9Bpfeng%20%E5%90%AF%E7%94%A8%EF%BC%9Bs32ccgmac%20%E7%A6%81%E7%94%A8%EF%BC%9Bs32ccgmac%20%E5%90%AF%E7%94%A8%EF%BC%9Bbootm%200x80080000%20-%200x83E00000'%3CBR%20%2F%3E%20setenv%20atf_fdt_0to3%20'fdt%20addr%200x83e00000%3B%20fdt%20resize%3B%20fdt%20set%20%2Fcpus%2Fcpu%401%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40100%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40101%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B'%3CBR%20%2F%3E%20setenv%20atf_fdt_4to7%20'fdt%20set%20%2Fcpus%2Fcpu%402%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%403%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40102%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40103%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B'%3CBR%20%2F%3E%20setenv%20release_cpus%20'run%20cpu_trap%3B%20mp%201%20release%200xa0000000%3B%20mp%202%20release%200xa0000000%3B%20mp%203%20release%200xa0000000%3B%20mp%204%20release%200xa0000000%3B%20mp%205%20release%200xa0000000%3B%20mp%206%20release%200xa0000000%3B%20mp%207%20release%200xa0000000%3B'%3CBR%20%2F%3E%20setenv%20cpu_trap%20'dcache%20off%3B%20mw.l%200xa0000000%200xd503205f%3B%20mw.l%200xa0000004%200x58000060%3B%20mw.l%200xa0000008%200xb4ffffc0%3B%20mw.l%200xa000000C%200xd61f0000%3B%20mw.q%200xa0000010%200x00000000%3B%20dcache%20on%3B'%3CBR%20%2F%3E%20setenv%20bootcmd%20'run%20boot_qnx_atf'%3CBR%20%2F%3E%20setenv%20hwconfig%20%22pcie0%3Amode%3Drc%2Cclock%3Dext%3Bpcie1%3Amode%3Dsgmii%2Cclock%3Dext%2Cfmhz%3D125%2Cxpcs_mode%3D2G5%22%3CBR%20%2F%3E%20setenv%20pfeng_mode%20'enable%2Csgmii%2Csgmii%2Crgmii'%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%20s32cc_gmac_mode%20%E4%B8%BA%E7%A6%81%E7%94%A8%3CBR%20%2F%3E%E4%BF%9D%E5%AD%98%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%88%91%E4%BB%8E%20boot_qnx_atf%20%E4%B8%AD%E5%88%A0%E9%99%A4%E4%BA%86%20release_cpus%20%E5%91%BD%E4%BB%A4%EF%BC%8C%E5%9B%A0%E4%B8%BA%E9%82%A3%E6%A0%B7%E4%BC%9A%E5%AF%BC%E8%87%B4%20CPU%201%20%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9C%8B%E6%9D%A5%EF%BC%8C%E6%83%85%E5%86%B5%E5%B9%B6%E6%B2%A1%E6%9C%89%E5%A5%BD%E8%BD%AC%E5%A4%9A%E5%B0%91%EF%BC%9A%3C%2FP%3E%3CDIV%3E%E6%B3%A8%E6%84%8F%EF%BC%9ABL2%EF%BC%9Av2.5%EF%BC%88%E7%89%88%E6%9C%AC%EF%BC%89%EF%BC%9Absp37.0_rc6-2.5%3C%2FDIV%3E%3CDIV%3E%E9%80%9A%E7%9F%A5%EF%BC%9ABL2%EF%BC%9A%E7%89%88%E6%9C%AC%EF%BC%9A2023%E5%B9%B46%E6%9C%8813%E6%97%A5%2009%3A12%3A21%3C%2FDIV%3E%3CDIV%3E%E6%B3%A8%E6%84%8F%EF%BC%9ABL2%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20BL31%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EU-Boot%202020.04%2Bg156b168010%EF%BC%882023%E5%B9%B46%E6%9C%889%E6%97%A5%2010%3A14%3A25%20%2B0000%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECPU%EF%BC%9ANXP%20S32G399A%20rev.1.1%3C%2FDIV%3E%3CDIV%3E%E5%9E%8B%E5%8F%B7%EF%BC%9ANXP%20S32G399A-RDB3%3C%2FDIV%3E%3CDIV%3E%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(DRAM)%EF%BC%9A3.5%20GiB%3C%2FDIV%3E%3CDIV%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%3C%2FDIV%3E%3CDIV%3E%E4%BB%8EMMC%E5%8A%A0%E8%BD%BD%E7%8E%AF%E5%A2%83...%20%E6%88%90%E5%8A%9F%3C%2FDIV%3E%3CDIV%3E%E5%B0%86%20PCIe0%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E6%A0%B9%E5%A4%8D%E5%90%88%E4%BD%93%3C%2FDIV%3E%3CDIV%3EPCIe0%EF%BC%9A%E8%BF%9E%E6%8E%A5%E5%A4%B1%E8%B4%A5%3C%2FDIV%3E%3CDIV%3EPCI%EF%BC%9A%E8%87%AA%E5%8A%A8%E9%85%8D%E7%BD%AE%E5%A4%B1%E8%B4%A5%EF%BC%8C%E7%AC%AC%201c%20%E6%9D%A1%3C%2FDIV%3E%3CDIV%3E%E8%BE%93%E5%85%A5%EF%BC%9Aserial%40401c8000%3C%2FDIV%3E%3CDIV%3E%E8%BE%93%E5%87%BA%EF%BC%9Aserial%40401c8000%3C%2FDIV%3E%3CDIV%3E%E9%94%99%E8%AF%AF%EF%BC%9Aserial%40401c8000%3C%2FDIV%3E%3CDIV%3E%E6%9D%BF%E4%BF%AE%E8%AE%A2%EF%BC%9ARDB3%20%E4%BF%AE%E8%AE%A2%E7%89%88%20F%3C%2FDIV%3E%3CDIV%3E%E7%BD%91%E7%BB%9C%EF%BC%9AEQOS%20phy%EF%BC%9Argmii%20%40%201%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%AD%A6%E5%91%8A%EF%BC%9Aeth_eqos%20(eth0)%20%E4%BD%BF%E7%94%A8%E9%9A%8F%E6%9C%BA%20MAC%20%E5%9C%B0%E5%9D%80%20-%2016%3Aec%3Aa0%3A4e%3A1d%3A7c%3C%2FDIV%3E%3CDIV%3Eeth0%EF%BC%9Aeth_eqos%20%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20emac1_xpcs%20%E7%9A%84%20XPCS%20%E9%80%9F%E5%BA%A6%20PFE%EF%BC%9Aemac0%EF%BC%9Asgmii%20emac1%EF%BC%9Asgmii%20emac2%EF%BC%9Argmii%3C%2FDIV%3E%3CDIV%3E%EF%BC%8Ceth1%EF%BC%9Aeth_pfeng%3C%2FDIV%3E%3CDIV%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A3%202%201%200%3C%2FDIV%3E%3CDIV%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%88%86%E5%8C%BA%20%230%EF%BC%8C%E7%A1%AE%E5%AE%9A%3C%2FDIV%3E%3CDIV%3Emmc0%20is%20current%20device%3C%2FDIV%3E%3CDIV%3E%E8%AF%BB%E5%8F%9650640%E5%AD%97%E8%8A%82%E8%80%97%E6%97%B617%E6%AF%AB%E7%A7%92%EF%BC%882.8%20MiB%2Fs%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%E8%AF%BB%E5%8F%96%E4%BA%86%2011950600%20%E5%AD%97%E8%8A%82%EF%BC%8C%E8%80%97%E6%97%B6%20534%20%E6%AF%AB%E7%A7%92%EF%BC%8821.3%20MiB%2Fs%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%23%23%20%E4%BB%8E%E4%BD%8D%E4%BA%8E%2080080000%20%E7%9A%84%E4%BC%A0%E7%BB%9F%E6%98%A0%E5%83%8F%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FDIV%3E%3CDIV%3E%E5%9B%BE%E7%89%87%E5%90%8D%E7%A7%B0%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E%E9%95%9C%E5%83%8F%E7%B1%BB%E5%9E%8B%EF%BC%9AAArch64%20Linux%20%E5%86%85%E6%A0%B8%E9%95%9C%E5%83%8F%EF%BC%88%E6%9C%AA%E5%8E%8B%E7%BC%A9%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%EF%BC%9A11950536%20%E5%AD%97%E8%8A%82%20%3D%2011.4MiB%3C%2FDIV%3E%3CDIV%3E%E5%8A%A0%E8%BD%BD%E5%9C%B0%E5%9D%80%EF%BC%9A80080000%3C%2FDIV%3E%3CDIV%3E%E5%85%A5%E5%8F%A3%E7%82%B9%EF%BC%9A80080000%3C%2FDIV%3E%3CDIV%3E%E6%A0%A1%E9%AA%8C%E5%92%8C%E9%AA%8C%E8%AF%81%E4%B8%AD...%20%E6%88%90%E5%8A%9F%3C%2FDIV%3E%3CDIV%3E%23%23%20%E4%BD%8D%E4%BA%8E%2083e00000%20%E7%9A%84%E6%89%81%E5%B9%B3%E5%8C%96%E8%AE%BE%E5%A4%87%E6%A0%91%20blob%3C%2FDIV%3E%3CDIV%3E%E4%BD%BF%E7%94%A8%E4%BD%8D%E4%BA%8E%200x83e00000%20%E7%9A%84%20fdt%20blob%20%E5%90%AF%E5%8A%A8%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%3C%2FDIV%3E%3CDIV%3E%E4%BD%BF%E7%94%A8%E4%BD%8D%E4%BA%8E%200000000083e00000%20%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%EF%BC%8C%E7%BB%93%E6%9D%9F%E4%BA%8E%200000000083e0ffff%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E5%A4%8D%EF%BC%9Apfe0%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%2000%3A01%3Abe%3Abe%3Aef%3A11%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E5%A4%8D%EF%BC%9Apfe1%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%2000%3A01%3Abe%3Abe%3Aef%3A22%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E5%A4%8D%EF%BC%9Apfe1%EF%BC%9A%E5%B0%86%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%E6%9B%B4%E6%96%B0%E4%B8%BA%200x8%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E5%A4%8D%EF%BC%9Apfe2%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%2000%3A01%3Abe%3Abe%3Aef%3A33%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E5%9C%A8%20EVB%2FRDB%20%E4%B8%8A%E4%B8%BA%20PFE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BF%9D%E7%95%99%20RAM%20%E5%8C%BA%E5%9F%9F%3C%2FDIV%3E%3CDIV%3E%E5%AE%8C%E6%88%90%E3%80%82%3C%2FDIV%3E%3CDIV%3EClockCycles%20%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E0%2043642864%3C%2FDIV%3E%3CDIV%3E1%2043642864%3C%2FDIV%3E%3CDIV%3E2%2043642864%3C%2FDIV%3E%3CDIV%3E3%2043642864%3C%2FDIV%3E%3CDIV%3E4%2043642864%3C%2FDIV%3E%3CDIV%3E5%2043642864%3C%2FDIV%3E%3CDIV%3E6%2043642864%3C%2FDIV%3E%3CDIV%3E7%2043642864%3C%2FDIV%3E%3CDIV%3E%E6%89%80%E6%9C%89%E6%97%B6%E9%92%9F%E5%91%A8%E6%9C%9F%E5%81%8F%E7%A7%BB%E5%9D%87%E5%9C%A8%E5%AE%B9%E5%B7%AE%E8%8C%83%E5%9B%B4%E5%86%85%3C%2FDIV%3E%3CDIV%3E%E6%AC%A2%E8%BF%8E%E4%BD%BF%E7%94%A8%20QNX%20Neutrino%207.1.0%E5%9C%A8%20NXP%20S32G399A%20RDB%20%E6%9D%BF%E4%B8%8A%EF%BC%81%3C%2FDIV%3E%3CDIV%3E%E5%90%AF%E5%8A%A8%E7%9B%91%E7%9D%A3%E6%9C%BA%E5%88%B6%E2%80%A6%E2%80%A6%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E4%B8%B2%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E7%BD%91%E7%BB%9C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%2Fdev%2Fsocket%EF%BC%89...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%204107%20(ifconfig)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%2010%20(sh)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%209%20(dhclient)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3Ecp%EF%BC%9A%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E6%BA%90%E6%96%87%E4%BB%B6%E3%80%82%EF%BC%88%2Fproc%2Fboot%2Flibfci_cli%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%2020489%20(cp)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D1%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20SPI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%2Fdev%2Fspi0%2C1%2C2%2C3%2C4%2C5%EF%BC%89...%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20I2C%200%2F1%2F2%2F3%2F4%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20(%2Fdev%2Fi2c0%2C1%2C2%2C3%2C4)...%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20USDHC0%20%E5%AD%98%E5%82%A8%E5%8D%A1%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3C%2FDIV%3E%3CDIV%3E%5B00%5D%20SIM%3D%22SDMMC%22%20HBA%3D%22imx%22%3C%2FDIV%3E%3CDIV%3E%5B00%2C0%2C0%5D%20type%3D00%20ver%3D05%20resp%3D00%20SDMMC%3A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%2024596%20(chkqnx6fs)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%2028692%20(mount)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8QSPI%20Flash%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3C%2FDIV%3E%3CDIV%3E%E5%90%AF%E5%8A%A8%20USB%20%E4%B8%BB%E6%9C%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20(%2Fdev%2Fusb%2F*)%3C%2FDIV%3E%3CDIV%3E%E6%A3%80%E6%B5%8B%E5%88%B0%20QSPI%20Flash%EF%BC%9AMacronix%20MX25UW512%EF%BC%8CJEDEC%200xC2%20-%200x813A%EF%BC%8C%E5%AE%B9%E9%87%8F%EF%BC%9A0x4000000%3C%2FDIV%3E%3CDIV%3E%E6%AD%A3%E5%9C%A8%E4%B8%BA%20%2Fdev%2Fusb%2F*%20%E5%90%AF%E5%8A%A8%20devb-umass%20...%3C%2FDIV%3E%3CDIV%3E%23%20ifconfig%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Elo0%EF%BC%9A%E6%A0%87%E5%BF%97%3D8049%3CUP%3E%20mtu%2033136%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%20127.0.0.1%20%E5%AD%90%E7%BD%91%E6%8E%A9%E7%A0%81%200xff000000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20%3A%3A1%20prefixlen%20128%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A1%25lo0%20prefixlen%2064%20scopeid%200x1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe0%EF%BC%9A%E6%A0%87%E5%BF%97%3D8843%3CUP%3E%20mtu%201500%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%B7%B2%E5%90%AF%E7%94%A8%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%EF%BC%9A00%3A0a%3A0b%3A0c%3A0d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BB%8B%E8%B4%A8%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%97%A0%EF%BC%881000baseT%20%E5%85%A8%E5%8F%8C%E5%B7%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%EF%BC%9A%E6%B4%BB%E8%B7%83%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%200.0.0.0%20netmask%200xff000000%20broadcast%20255.255.255.255%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A20a%3Abff%3Afe0c%3Ad66%25pfe0%20prefixlen%2064%20scopeid%200x11%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe1%EF%BC%9A%E6%A0%87%E5%BF%97%3D8802%20mtu%201500%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%B7%B2%E5%90%AF%E7%94%A8%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%EF%BC%9A00%3A1a%3A1b%3A1c%3A1d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BB%8B%E8%B4%A8%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%97%A0%EF%BC%881000baseT%20%E5%85%A8%E5%8F%8C%E5%B7%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%EF%BC%9A%E6%97%A0%E6%89%BF%E8%BF%90%E5%95%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe2%EF%BC%9A%E6%A0%87%E5%BF%97%3D8802%20mtu%201500%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%B7%B2%E5%90%AF%E7%94%A8%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%EF%BC%9A00%3A2a%3A2b%3A2c%3A2d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BB%8B%E8%B4%A8%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%97%A0%EF%BC%881000baseT%20%E5%85%A8%E5%8F%8C%E5%B7%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%EF%BC%9A%E6%97%A0%E6%89%BF%E8%BF%90%E5%95%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%2040985%20(ifconfig)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3E%23%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%2036891%EF%BC%88%E7%9D%A1%E7%9C%A0%EF%BC%89%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3Esh%3A%20%2Fvar%2Fcetitec2%2Fstartup.sh%3A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%9B%E7%A8%8B%2053273%20(sh)%20%E7%BB%88%E6%AD%A2%20signo%3D0%20code%3D0%20%E7%94%B1%E8%BF%9B%E7%A8%8B%200%20value%3D0%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%23%20ifconfig%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Elo0%EF%BC%9A%E6%A0%87%E5%BF%97%3D8049%3CUP%3E%20mtu%2033136%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%20127.0.0.1%20%E5%AD%90%E7%BD%91%E6%8E%A9%E7%A0%81%200xff000000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20%3A%3A1%20prefixlen%20128%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A1%25lo0%20prefixlen%2064%20scopeid%200x1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe0%EF%BC%9A%E6%A0%87%E5%BF%97%3D8843%3CUP%3E%20mtu%201500%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%B7%B2%E5%90%AF%E7%94%A8%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%EF%BC%9A00%3A0a%3A0b%3A0c%3A0d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BB%8B%E8%B4%A8%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%97%A0%EF%BC%881000baseT%20%E5%85%A8%E5%8F%8C%E5%B7%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%EF%BC%9A%E6%B4%BB%E8%B7%83%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%200.0.0.0%20netmask%200xff000000%20broadcast%20255.255.255.255%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A20a%3Abff%3Afe0c%3Ad66%25pfe0%20prefixlen%2064%20scopeid%200x11%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe1%EF%BC%9A%E6%A0%87%E5%BF%97%3D8802%20mtu%201500%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%B7%B2%E5%90%AF%E7%94%A8%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%EF%BC%9A00%3A1a%3A1b%3A1c%3A1d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BB%8B%E8%B4%A8%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%97%A0%EF%BC%881000baseT%20%E5%85%A8%E5%8F%8C%E5%B7%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%EF%BC%9A%E6%97%A0%E6%89%BF%E8%BF%90%E5%95%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe2%EF%BC%9A%E6%A0%87%E5%BF%97%3D8802%20mtu%201500%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3CIP4CSUM%3E%3C%2FIP4CSUM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%B7%B2%E5%90%AF%E7%94%A8%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%EF%BC%9A00%3A2a%3A2b%3A2c%3A2d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BB%8B%E8%B4%A8%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%97%A0%EF%BC%881000baseT%20%E5%85%A8%E5%8F%8C%E5%B7%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%EF%BC%9A%E6%97%A0%E6%89%BF%E8%BF%90%E5%95%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CP%3E%23%20slog2info%20%7C%20grep%20pfe%3C%2FP%3E%3CP%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.051%20iopkt.8main_buffer%200%20devnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog*%200%20INF%5Bsrc%2Fpfe_drv.c%3A1377%5D%3A%E7%89%88%E6%9C%AC%E4%BF%A1%E6%81%AF%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1384%5D%3A---%20%E5%AE%89%E5%85%A8%E4%B8%AD%E6%96%AD%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%E4%B8%8D%E5%85%81%E8%AE%B8%E4%BD%BF%E7%94%A8%20InterruptAttach()%20%E6%88%96%20InterruptAttach_r()%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A83%5D%3A%E8%AF%BB%E5%8F%96%2049480%20%E5%AD%97%E8%8A%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A89%5D%3A%E5%B7%B2%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%E6%96%87%E4%BB%B6%EF%BC%9A%2Fproc%2Fboot%2Fs32g_pfe_class.fw%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe0%2FEMAC0%20%E7%9A%84%20MII%20%E6%A8%A1%E5%BC%8F%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%20SGMII%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe1%2FEMAC1%20%E7%9A%84%20MII%20%E6%A8%A1%E5%BC%8F%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%20SGMII%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe2%2FEMAC2%20%E7%9A%84%20MII%20%E6%A8%A1%E5%BC%8F%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%20RGMII%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1495%5D%3A%E5%8F%91%E5%87%BA%20PFE%20%E5%A4%96%E8%AE%BE%E5%A4%8D%E4%BD%8D%E6%8C%87%E4%BB%A4...%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1496%5D%3APFE%E9%87%8D%E7%BD%AE%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3519%5D%3APFE%20CBUS%20p0x46000000%20%E6%98%A0%E5%B0%84%E5%88%B0%20v0x1abef95000%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3524%5D%3A%E7%A1%AC%E4%BB%B6%E7%89%88%E6%9C%AC%200x101%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hw_feature.c%3A95%5D%3A%20Silicon%20S32G3%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3536%5D%3A%E6%95%85%E9%9A%9C%E5%81%9C%E6%AD%A2%E6%A8%A1%E5%BC%8F%E5%B7%B2%E7%A6%81%E7%94%A8%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2687%5D%3APFE_ERRORS%EF%BC%9A%E5%B7%B2%E5%88%9B%E5%BB%BA%20Parity%20%E5%AE%9E%E4%BE%8B%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2702%5D%3APFE_ERRORS%EF%BC%9A%E5%B7%B2%E5%88%9B%E5%BB%BA%E7%9B%91%E8%A7%86%E7%A8%8B%E5%BA%8F%E5%AE%9E%E4%BE%8B%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2718%5D%3APFE_ERRORS%EF%BC%9A%E6%80%BB%E7%BA%BF%E9%94%99%E8%AF%AF%E5%AE%9E%E4%BE%8B%E5%B7%B2%E5%88%9B%E5%BB%BA%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2731%5D%3APFE_ERRORS%EF%BC%9AFW%20%E6%95%85%E9%9A%9C%E5%81%9C%E6%AD%A2%E5%AE%9E%E4%BE%8B%E5%B7%B2%E5%88%9B%E5%BB%BA%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2744%5D%3APFE_ERRORS%EF%BC%9A%E4%B8%BB%E6%9C%BA%E6%95%85%E9%9A%9C%E5%81%9C%E6%AD%A2%E5%AE%9E%E4%BE%8B%E5%B7%B2%E5%88%9B%E5%BB%BA%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2757%5D%3APFE_ERRORS%EF%BC%9A%E5%B7%B2%E5%88%9B%E5%BB%BA%E6%95%85%E9%9A%9C%E5%81%9C%E6%AD%A2%E5%AE%9E%E4%BE%8B%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2770%5D%3APFE_ERRORS%EF%BC%9AECC%20%E9%94%99%E8%AF%AF%E5%AE%9E%E4%BE%8B%E5%B7%B2%E5%88%9B%E5%BB%BA%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1766%5D%3ABMU1%20%E7%BC%93%E5%86%B2%E5%8C%BA%E5%9F%BA%E5%9D%80%EF%BC%9Ap0xc0000000%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.277%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1810%5D%3ABMU2%20%E7%BC%93%E5%86%B2%E5%8C%BA%E5%9F%BA%E5%9D%80%EF%BC%9Ap0x83000000%EF%BC%880x200000%20%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.279%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2194%5D%3A%E9%80%89%E9%A1%B9%E2%80%9Cg2_ordered_class_writes%E2%80%9D%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.279%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x88000)%E3%80%82%E6%B3%B3%E6%B1%A0%E5%B7%B2%E5%87%86%E5%A4%87%E5%B0%B1%E7%BB%AA%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.279%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x8c000)%E3%80%82%E6%B3%B3%E6%B1%A0%E5%B7%B2%E5%87%86%E5%A4%87%E5%B0%B1%E7%BB%AA%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.281%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2239%5D%3A%E5%9B%BA%E4%BB%B6%20.elf%E6%A3%80%E6%B5%8B%E5%88%B0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.281%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2248%5D%3A%E6%AD%A3%E5%9C%A8%E4%B8%8A%E4%BC%A0%20CLASS%20%E5%9B%BA%E4%BB%B6%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.281%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A609%5D%3A%E9%80%89%E6%8B%A9%E5%9B%BA%E4%BB%B6%E5%8A%A0%E8%BD%BD%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%B9%B6%E8%A1%8C%E5%8A%A0%E8%BD%BD%208%20%E4%B8%AA%20PE%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.285%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A1945%5D%3Apfe_ct.h%E6%96%87%E4%BB%B6%E7%89%88%E6%9C%AC%E2%80%9C92367c0e25f21f49217a9b08168ad2c8%E2%80%9D%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.288%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A2422%5D%3A%5B%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%5D%201.6.0%E6%9E%84%E5%BB%BA%E7%89%88%E6%9C%AC%EF%BC%9A2023%E5%B9%B43%E6%9C%8815%E6%97%A5%2012%3A37%3A54%20()%EF%BC%8CID%EF%BC%9A0x31454650%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2312%5D%3AVLAN%20ID%20%E4%B8%8D%E6%AD%A3%E7%A1%AE%E6%88%96%E6%9C%AA%E8%AE%BE%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%20VLAN%20ID%20%3D%200x01%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2318%5D%3AVLAN%E7%BB%9F%E8%AE%A1%E4%BF%A1%E6%81%AF%E5%A4%A7%E5%B0%8F%E4%B8%8D%E6%AD%A3%E7%A1%AE%E6%88%96%E6%9C%AA%E8%AE%BE%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%20VLAN%20%E7%BB%9F%E8%AE%A1%E4%BF%A1%E6%81%AF%E5%A4%A7%E5%B0%8F%20%3D%2020%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1181%5D%3A%E8%BD%AF%E4%BB%B6%20VLAN%20%E5%93%88%E5%B8%8C%E8%A1%A8%20%40%20p0x20001208%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1286%5D%3A%E5%A4%87%E7%94%A8%E6%A1%A5%E6%8E%A5%E5%9F%9F%20%40%200x20000a44%EF%BC%88%E7%B1%BB%EF%BC%89%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1287%5D%3A%E9%BB%98%E8%AE%A4%E6%A1%A5%E6%8E%A5%E5%8A%9F%E8%83%BD%E5%9F%9F%20%40%200x20000a3c%EF%BC%88%E7%B1%BB%EF%BC%89%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2412%5D%3A%E8%B7%AF%E7%94%B1%E8%A1%A8%E5%B7%B2%E5%88%9B%E5%BB%BA%EF%BC%8C%E5%93%88%E5%B8%8C%E8%A1%A8%E4%BD%8D%E4%BA%8E%20p0x80014000%EF%BC%8C%E6%B1%A0%E4%BD%8D%E4%BA%8E%20p0x8001c000%EF%BC%8865536%20%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.407%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20%E5%88%9D%E5%A7%8B%E5%8C%96%20RX%20%E7%BC%93%E5%86%B2%E6%B1%A0%E3%80%82%E6%B7%B1%E5%BA%A6%EF%BC%9A256%EF%BC%9B%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%EF%BC%9A2048%EF%BC%9B%E7%BC%93%E5%AD%98%E8%A1%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A64%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.408%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20%E5%88%9D%E5%A7%8B%E5%8C%96%20RX%20%E7%BC%93%E5%86%B2%E6%B1%A0%E3%80%82%E6%B7%B1%E5%BA%A6%EF%BC%9A256%EF%BC%9B%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%EF%BC%9A2048%EF%BC%9B%E7%BC%93%E5%AD%98%E8%A1%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A64%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.409%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20%E5%88%9D%E5%A7%8B%E5%8C%96%20RX%20%E7%BC%93%E5%86%B2%E6%B1%A0%E3%80%82%E6%B7%B1%E5%BA%A6%EF%BC%9A256%EF%BC%9B%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%EF%BC%9A2048%EF%BC%9B%E7%BC%93%E5%AD%98%E8%A1%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A64%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.508%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3705%5D%3A%E5%8A%9F%E8%83%BD%E9%94%99%E8%AF%AF%20err051211_workaround%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.509%20iopkt.8%E4%B8%BB%E7%BC%93%E5%86%B2%E5%8C%BA%200%20pfe0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.509%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3Apfe0%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%9D%99%E6%80%81%20PHY%20%E6%A8%A1%E5%BC%8F%EF%BC%8CRESET%3D0%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.510%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%E5%B0%86%2000%3A0a%3A0b%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20pfe0%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A00.512%20iopkt.8%E4%B8%BB%E7%BC%93%E5%86%B2%E5%8C%BA%200%20pfe1%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe0%20%E7%9A%84%E9%80%9F%E5%BA%A6%2F%E5%8F%8C%E5%B7%A5%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%201%20Gbps%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20%E5%B0%9D%E8%AF%95%E6%B3%A8%E5%86%8C%20HIF%20%E5%AE%A2%E6%88%B7%E7%AB%AF%EF%BC%9A0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0PFE%E8%AE%BE%E5%A4%87%EF%BC%9A0%EF%BC%8CID%EF%BC%9A0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3Apfe1%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%9D%99%E6%80%81%20PHY%20%E6%A8%A1%E5%BC%8F%EF%BC%8CRESET%3D0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%E5%B0%86%2000%3A1a%3A1b%3A1c%3A1d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20pfe1%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A00.514%20iopkt.8%E4%B8%BB%E7%BC%93%E5%86%B2%E5%8C%BA%200%20pfe2%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe1%20%E7%9A%84%E9%80%9F%E5%BA%A6%2F%E5%8F%8C%E5%B7%A5%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%201%20Gbps%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20%E5%B0%9D%E8%AF%95%E6%B3%A8%E5%86%8C%20HIF%20%E5%AE%A2%E6%88%B7%E7%AB%AF%EF%BC%9A1%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0%E7%9A%84PFE%E8%AE%BE%E5%A4%87%EF%BC%9A1%EF%BC%8CID%EF%BC%9A2%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3Apfe2%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%9D%99%E6%80%81%20PHY%20%E6%A8%A1%E5%BC%8F%EF%BC%8CRESET%3D0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%E5%B0%86%2000%3A2a%3A2b%3A2c%3A2d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20pfe2%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe2%20%E7%9A%84%E9%80%9F%E5%BA%A6%2F%E5%8F%8C%E5%B7%A5%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%201%20Gbps%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20%E5%B0%9D%E8%AF%95%E6%B3%A8%E5%86%8C%20HIF%20%E5%AE%A2%E6%88%B7%E7%AB%AF%EF%BC%9A2%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0%E5%9E%8BPFE%E8%AE%BE%E5%A4%87%EF%BC%9A2%EF%BC%8CID%EF%BC%9A4%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2702%5D%3A%E5%B0%86%2000%3A0a%3A0b%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20pfe0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2707%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%20MAC%20%E5%9C%B0%E5%9D%80%2000%3A0a%3A0b%3A0c%3A0d%3A66%20%E5%88%86%E9%85%8D%E7%BB%99%20pfe0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3A%E7%9B%AE%E5%89%8D%E4%B8%8D%E6%94%AF%E6%8C%81%20SGMII%20%E7%9A%84%20EMAC%20%E9%80%9F%E5%BA%A6%E6%9B%B4%E6%94%B9%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.532%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.534%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.534%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3A%E7%9B%AE%E5%89%8D%E4%B8%8D%E6%94%AF%E6%8C%81%20SGMII%20%E7%9A%84%20EMAC%20%E9%80%9F%E5%BA%A6%E6%9B%B4%E6%94%B9%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2001%3A00%3A5e%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%23%20slog2info%20%7C%20grep%20io_pkt_v6_hc%3C%2FP%3E%3CP%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog*%200%20INF%5Bsrc%2Fpfe_drv.c%3A1377%5D%3A%E7%89%88%E6%9C%AC%E4%BF%A1%E6%81%AF%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1384%5D%3A---%20%E5%AE%89%E5%85%A8%E4%B8%AD%E6%96%AD%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%E4%B8%8D%E5%85%81%E8%AE%B8%E4%BD%BF%E7%94%A8%20InterruptAttach()%20%E6%88%96%20InterruptAttach_r()%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A83%5D%3A%E8%AF%BB%E5%8F%96%2049480%20%E5%AD%97%E8%8A%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A89%5D%3A%E5%B7%B2%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%E6%96%87%E4%BB%B6%EF%BC%9A%2Fproc%2Fboot%2Fs32g_pfe_class.fw%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe0%2FEMAC0%20%E7%9A%84%20MII%20%E6%A8%A1%E5%BC%8F%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%20SGMII%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe1%2FEMAC1%20%E7%9A%84%20MII%20%E6%A8%A1%E5%BC%8F%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%20SGMII%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe2%2FEMAC2%20%E7%9A%84%20MII%20%E6%A8%A1%E5%BC%8F%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%20RGMII%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1495%5D%3A%E5%8F%91%E5%87%BA%20PFE%20%E5%A4%96%E8%AE%BE%E5%A4%8D%E4%BD%8D%E6%8C%87%E4%BB%A4...%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1496%5D%3APFE%E9%87%8D%E7%BD%AE%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3519%5D%3APFE%20CBUS%20p0x46000000%20%E6%98%A0%E5%B0%84%E5%88%B0%20v0x1abef95000%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3524%5D%3A%E7%A1%AC%E4%BB%B6%E7%89%88%E6%9C%AC%200x101%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hw_feature.c%3A95%5D%3A%20Silicon%20S32G3%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3536%5D%3A%E6%95%85%E9%9A%9C%E5%81%9C%E6%AD%A2%E6%A8%A1%E5%BC%8F%E5%B7%B2%E7%A6%81%E7%94%A8%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2687%5D%3APFE_ERRORS%EF%BC%9A%E5%B7%B2%E5%88%9B%E5%BB%BA%20Parity%20%E5%AE%9E%E4%BE%8B%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2702%5D%3APFE_ERRORS%EF%BC%9A%E5%B7%B2%E5%88%9B%E5%BB%BA%E7%9B%91%E8%A7%86%E7%A8%8B%E5%BA%8F%E5%AE%9E%E4%BE%8B%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2718%5D%3APFE_ERRORS%EF%BC%9A%E6%80%BB%E7%BA%BF%E9%94%99%E8%AF%AF%E5%AE%9E%E4%BE%8B%E5%B7%B2%E5%88%9B%E5%BB%BA%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2731%5D%3APFE_ERRORS%EF%BC%9AFW%20%E6%95%85%E9%9A%9C%E5%81%9C%E6%AD%A2%E5%AE%9E%E4%BE%8B%E5%B7%B2%E5%88%9B%E5%BB%BA%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2744%5D%3APFE_ERRORS%EF%BC%9A%E4%B8%BB%E6%9C%BA%E6%95%85%E9%9A%9C%E5%81%9C%E6%AD%A2%E5%AE%9E%E4%BE%8B%E5%B7%B2%E5%88%9B%E5%BB%BA%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2757%5D%3APFE_ERRORS%EF%BC%9A%E5%B7%B2%E5%88%9B%E5%BB%BA%E6%95%85%E9%9A%9C%E5%81%9C%E6%AD%A2%E5%AE%9E%E4%BE%8B%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2770%5D%3APFE_ERRORS%EF%BC%9AECC%20%E9%94%99%E8%AF%AF%E5%AE%9E%E4%BE%8B%E5%B7%B2%E5%88%9B%E5%BB%BA%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1766%5D%3ABMU1%20%E7%BC%93%E5%86%B2%E5%8C%BA%E5%9F%BA%E5%9D%80%EF%BC%9Ap0xc0000000%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.277%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1810%5D%3ABMU2%20%E7%BC%93%E5%86%B2%E5%8C%BA%E5%9F%BA%E5%9D%80%EF%BC%9Ap0x83000000%EF%BC%880x200000%20%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.279%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2194%5D%3A%E9%80%89%E9%A1%B9%E2%80%9Cg2_ordered_class_writes%E2%80%9D%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.279%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20BMU%20IRQ%20%E5%B7%A5%E4%BD%9C%E8%BF%9B%E7%A8%8B%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%88IRQ%20ID%EF%BC%9A226%EF%BC%89%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.279%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x88000)%E3%80%82%E6%B3%B3%E6%B1%A0%E5%B7%B2%E5%87%86%E5%A4%87%E5%B0%B1%E7%BB%AA%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.279%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x8c000)%E3%80%82%E6%B3%B3%E6%B1%A0%E5%B7%B2%E5%87%86%E5%A4%87%E5%B0%B1%E7%BB%AA%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.281%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2239%5D%3A%E5%9B%BA%E4%BB%B6%20.elf%E6%A3%80%E6%B5%8B%E5%88%B0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.281%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2248%5D%3A%E6%AD%A3%E5%9C%A8%E4%B8%8A%E4%BC%A0%20CLASS%20%E5%9B%BA%E4%BB%B6%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.281%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A609%5D%3A%E9%80%89%E6%8B%A9%E5%9B%BA%E4%BB%B6%E5%8A%A0%E8%BD%BD%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%B9%B6%E8%A1%8C%E5%8A%A0%E8%BD%BD%208%20%E4%B8%AA%20PE%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.285%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A1945%5D%3Apfe_ct.h%E6%96%87%E4%BB%B6%E7%89%88%E6%9C%AC%E2%80%9C92367c0e25f21f49217a9b08168ad2c8%E2%80%9D%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.288%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A2422%5D%3A%5B%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%5D%201.6.0%E6%9E%84%E5%BB%BA%E7%89%88%E6%9C%AC%EF%BC%9A2023%E5%B9%B43%E6%9C%8815%E6%97%A5%2012%3A37%3A54%20()%EF%BC%8CID%EF%BC%9A0x31454650%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2312%5D%3AVLAN%20ID%20%E4%B8%8D%E6%AD%A3%E7%A1%AE%E6%88%96%E6%9C%AA%E8%AE%BE%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%20VLAN%20ID%20%3D%200x01%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2318%5D%3AVLAN%E7%BB%9F%E8%AE%A1%E4%BF%A1%E6%81%AF%E5%A4%A7%E5%B0%8F%E4%B8%8D%E6%AD%A3%E7%A1%AE%E6%88%96%E6%9C%AA%E8%AE%BE%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%20VLAN%20%E7%BB%9F%E8%AE%A1%E4%BF%A1%E6%81%AF%E5%A4%A7%E5%B0%8F%20%3D%2020%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1181%5D%3A%E8%BD%AF%E4%BB%B6%20VLAN%20%E5%93%88%E5%B8%8C%E8%A1%A8%20%40%20p0x20001208%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1286%5D%3A%E5%A4%87%E7%94%A8%E6%A1%A5%E6%8E%A5%E5%9F%9F%20%40%200x20000a44%EF%BC%88%E7%B1%BB%EF%BC%89%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1287%5D%3A%E9%BB%98%E8%AE%A4%E6%A1%A5%E6%8E%A5%E5%8A%9F%E8%83%BD%E5%9F%9F%20%40%200x20000a3c%EF%BC%88%E7%B1%BB%EF%BC%89%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2412%5D%3A%E8%B7%AF%E7%94%B1%E8%A1%A8%E5%B7%B2%E5%88%9B%E5%BB%BA%EF%BC%8C%E5%93%88%E5%B8%8C%E8%A1%A8%E4%BD%8D%E4%BA%8E%20p0x80014000%EF%BC%8C%E6%B1%A0%E4%BD%8D%E4%BA%8E%20p0x8001c000%EF%BC%8865536%20%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.407%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20%E5%88%9D%E5%A7%8B%E5%8C%96%20RX%20%E7%BC%93%E5%86%B2%E6%B1%A0%E3%80%82%E6%B7%B1%E5%BA%A6%EF%BC%9A256%EF%BC%9B%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%EF%BC%9A2048%EF%BC%9B%E7%BC%93%E5%AD%98%E8%A1%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A64%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.408%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20%E5%88%9D%E5%A7%8B%E5%8C%96%20RX%20%E7%BC%93%E5%86%B2%E6%B1%A0%E3%80%82%E6%B7%B1%E5%BA%A6%EF%BC%9A256%EF%BC%9B%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%EF%BC%9A2048%EF%BC%9B%E7%BC%93%E5%AD%98%E8%A1%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A64%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.409%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20%E5%88%9D%E5%A7%8B%E5%8C%96%20RX%20%E7%BC%93%E5%86%B2%E6%B1%A0%E3%80%82%E6%B7%B1%E5%BA%A6%EF%BC%9A256%EF%BC%9B%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%EF%BC%9A2048%EF%BC%9B%E7%BC%93%E5%AD%98%E8%A1%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A64%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.508%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3705%5D%3A%E5%8A%9F%E8%83%BD%E9%94%99%E8%AF%AF%20err051211_workaround%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.509%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3Apfe0%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%9D%99%E6%80%81%20PHY%20%E6%A8%A1%E5%BC%8F%EF%BC%8CRESET%3D0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.509%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20HIF0%20IRQ%20%E5%B7%A5%E4%BD%9C%E8%BF%9B%E7%A8%8B%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%88IRQ%20ID%EF%BC%9A222%EF%BC%89%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.510%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%E5%B0%86%2000%3A0a%3A0b%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20pfe0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe0%20%E7%9A%84%E9%80%9F%E5%BA%A6%2F%E5%8F%8C%E5%B7%A5%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%201%20Gbps%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20%E5%B0%9D%E8%AF%95%E6%B3%A8%E5%86%8C%20HIF%20%E5%AE%A2%E6%88%B7%E7%AB%AF%EF%BC%9A0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0PFE%E8%AE%BE%E5%A4%87%EF%BC%9A0%EF%BC%8CID%EF%BC%9A0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3Apfe1%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%9D%99%E6%80%81%20PHY%20%E6%A8%A1%E5%BC%8F%EF%BC%8CRESET%3D0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20HIF1%20IRQ%20%E5%B7%A5%E4%BD%9C%E8%BF%9B%E7%A8%8B%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%88IRQ%20ID%EF%BC%9A223%EF%BC%89%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%E5%B0%86%2000%3A1a%3A1b%3A1c%3A1d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20pfe1%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe1%20%E7%9A%84%E9%80%9F%E5%BA%A6%2F%E5%8F%8C%E5%B7%A5%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%201%20Gbps%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20%E5%B0%9D%E8%AF%95%E6%B3%A8%E5%86%8C%20HIF%20%E5%AE%A2%E6%88%B7%E7%AB%AF%EF%BC%9A1%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0%E7%9A%84PFE%E8%AE%BE%E5%A4%87%EF%BC%9A1%EF%BC%8CID%EF%BC%9A2%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3Apfe2%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%9D%99%E6%80%81%20PHY%20%E6%A8%A1%E5%BC%8F%EF%BC%8CRESET%3D0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20HIF2%20IRQ%20%E5%B7%A5%E4%BD%9C%E8%BF%9B%E7%A8%8B%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%88IRQ%20ID%EF%BC%9A224%EF%BC%89%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3A%E5%B0%86%2000%3A2a%3A2b%3A2c%3A2d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20pfe2%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe2%20%E7%9A%84%E9%80%9F%E5%BA%A6%2F%E5%8F%8C%E5%B7%A5%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%201%20Gbps%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20%E5%B0%9D%E8%AF%95%E6%B3%A8%E5%86%8C%20HIF%20%E5%AE%A2%E6%88%B7%E7%AB%AF%EF%BC%9A2%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0%E5%9E%8BPFE%E8%AE%BE%E5%A4%87%EF%BC%9A2%EF%BC%8CID%EF%BC%9A4%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2702%5D%3A%E5%B0%86%2000%3A0a%3A0b%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20pfe0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2707%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%20MAC%20%E5%9C%B0%E5%9D%80%2000%3A0a%3A0b%3A0c%3A0d%3A66%20%E5%88%86%E9%85%8D%E7%BB%99%20pfe0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3A%E7%9B%AE%E5%89%8D%E4%B8%8D%E6%94%AF%E6%8C%81%20SGMII%20%E7%9A%84%20EMAC%20%E9%80%9F%E5%BA%A6%E6%9B%B4%E6%94%B9%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.532%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.534%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.534%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3A%E7%9B%AE%E5%89%8D%E4%B8%8D%E6%94%AF%E6%8C%81%20SGMII%20%E7%9A%84%20EMAC%20%E9%80%9F%E5%BA%A6%E6%9B%B4%E6%94%B9%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2001%3A00%3A5e%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3E%E8%BF%9B%E7%A8%8B%20172057%20(slog2info)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A01%3A01.630%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A01%3A01.630%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3A00%3A00%3A00%3A01%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A01%3A01.630%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3A%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A01%3A01.630%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3A%E6%97%A0%E6%B3%95%E5%B0%86%2033%3A33%3Aff%3A0c%3A0d%3A66%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20emac0%3A%2017%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A01%3A01.630%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2495%5D%3A%E4%BB%8E%20emac0%20%E4%B8%AD%E7%A7%BB%E9%99%A4%2001%3A00%3A5e%3A00%3A00%3A01%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A01%3A01.632%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_phy_if.c%3A2716%5D%3A%E5%9C%B0%E5%9D%80%2001%3A00%3A5e%3A00%3A00%3A01%20%E5%B7%B2%E4%BB%8E%20emac0%20%E4%B8%AD%E7%A7%BB%E9%99%A4%3CBR%20%2F%3E%E4%B8%80%E6%9C%88%2001%2000%3A01%3A01.632%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2385407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%20%3CSPAN%3ES32G%20PFE%20QNX%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%201.4.0%20%E4%B8%8E%20S32G%20PFE%20%E5%9B%BA%E4%BB%B6%E6%A0%87%E5%87%86%E7%89%88%E6%9C%AC%201.6.0%20%E5%85%BC%E5%AE%B9%EF%BC%8C%E6%82%A8%E8%83%BD%E5%90%A6%E4%BD%BF%E7%94%A8%E6%AD%A4%20PFE%20%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%E5%86%8D%E6%AC%A1%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E9%99%88%E9%93%B6%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2386380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2386380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E4%B8%8B%E8%BD%BD%E4%BA%86%3C%2FP%3E%3CP%3EBSP_nxp-s32g-evb_br-710_be-710_SVN984052_JBN51%3C%2FP%3E%3CP%3E%E6%82%A8%E6%8F%90%E5%88%B0%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%E4%BF%AE%E6%94%B9%E4%BA%86%20.build%20%E6%96%87%E4%BB%B6%E3%80%82%E6%96%87%E4%BB%B6%E5%B9%B6%E6%B7%BB%E5%8A%A0%3C%2FP%3E%3CP%3Ekprintf(%22%E4%B8%BA%20EVB%2FRDB%20%E4%B8%8A%E7%9A%84%20PFE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BF%9D%E7%95%99%20RAM%20%E5%8C%BA%E5%9F%9F%5Cn%22)%3B%3CBR%20%2F%3E%20as_add_containing(0x80000000%2C0x80000000%20%2B%200x4000000%20-%201%2CAS_ATTR_RAM%2C%20%22pfe_ddr%22%2C%22ram%22)%3B%3C%2FP%3E%3CP%3E%E8%87%B3%3C%2FP%3E%3CP%3Esrc%2Fhardware%2Fstartup%2Fboards%2Fs32g%2Fs32g399a-rdb%2Fs32g_init_raminfo.c%20%E5%B9%B6%E5%B0%86%E6%88%91%E7%9A%84%20ifs%20%E6%96%87%E4%BB%B6%E6%9B%BF%E6%8D%A2%E4%B8%BA%E7%94%9F%E6%88%90%E7%9A%84%20ifs-s32g399a-rdb.ui%E3%80%82%3C%2FP%3E%3CP%3E%E9%81%97%E6%86%BE%E7%9A%84%E6%98%AF%EF%BC%8C%E5%AE%83%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E6%89%A7%E8%A1%8C%E4%B8%8A%E9%9D%A2%E7%9A%84%20pfe_ddr%20%E5%88%86%E9%85%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%20uboot%20%E5%8F%82%E6%95%B0%E6%88%96%E5%85%B6%E4%BB%96%E4%BB%80%E4%B9%88%E8%AE%BE%E7%BD%AE%E6%89%8D%E8%83%BD%E8%AE%A9%E8%BF%99%E4%B8%AA%E6%96%B0%E9%95%9C%E5%83%8F%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2386663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2386663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E4%B8%A5%E6%A0%BC%E5%8F%82%E8%80%83%E9%9B%86%E6%88%90%E6%89%8B%E5%86%8C%EF%BC%8C%E5%8F%82%E8%80%83%E4%BD%A0%E6%8F%90%E5%88%B0%E7%9A%84%E9%83%A8%E5%88%86%EF%BC%8C%E5%9C%A8%E6%9E%84%E5%BB%BA%20QNX%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E4%B9%8B%E5%89%8D%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F390231i1339D06D28BE6C6B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1782443542271.png%22%20alt%3D%22chenyin_h_0-1782443542271.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3E%E4%BD%A0%E7%9F%A5%E9%81%93NXP%E6%98%AF%E5%90%A6%E6%8F%90%E4%BE%9B%E5%B7%B2%E7%BB%8F%E5%8C%85%E5%90%ABPFE%EF%BC%88%E5%A6%82board_cleanup_before_linux%EF%BC%89%E6%89%80%E9%9C%80%E7%9A%84uboot%E4%BF%AE%E6%94%B9%E7%9A%84SD%E5%8D%A1%E9%95%9C%E5%83%8F%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%83%8F%20binaries_auto_linux_bsp37.0_s32g3_pfe%20%E8%BF%99%E6%A0%B7%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%E6%98%AF%E5%81%9A%E4%BB%80%E4%B9%88%E7%94%A8%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%89%93%E7%AE%97%E5%B0%9D%E8%AF%95%E4%BB%A5%E4%B8%8B%E7%BB%84%E5%90%88%EF%BC%9A%3C%2FP%3E%3CP%3EBSP%2033%3C%2FP%3E%3CP%3EPFE%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F1.2.0%3C%2FP%3E%3CP%3EPFE%20%E5%9B%BA%E4%BB%B6%201.3.0%3C%2FP%3E%3CP%3E%E5%AE%98%E6%96%B9%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%E6%AD%A4%E5%8A%9F%E8%83%BD%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%89%93%E7%AE%97%E5%B0%9D%E8%AF%95%E4%BB%A5%E4%B8%8B%E7%BB%84%E5%90%88%EF%BC%9A%3C%2FP%3E%3CP%3EBSP%2033%3C%2FP%3E%3CP%3EPFE%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F1.2.0%3C%2FP%3E%3CP%3EPFE%20%E5%9B%BA%E4%BB%B6%201.3.0%3C%2FP%3E%3CP%3E%E5%AE%98%E6%96%B9%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%E6%AD%A4%E5%8A%9F%E8%83%BD%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E5%B7%B2%E7%BB%8F%E6%8C%89%E7%85%A7%E9%9B%86%E6%88%90%E6%89%8B%E5%86%8C%E8%87%AA%E8%A1%8C%E6%9E%84%E5%BB%BA%E4%BA%86%20uboot%E3%80%82%E6%88%91%E6%B7%BB%E5%8A%A0%E4%BA%86%20PFE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%201.7.0%20%E7%89%88%E6%9C%AC%202.10.2%20%E8%8A%82%E4%B8%AD%E7%9A%84%E4%BF%AE%E6%94%B9%E3%80%82%E9%9B%86%E6%88%90%E6%89%8B%E5%86%8C%E3%80%82%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E4%B8%AD%E4%BC%BC%E4%B9%8E%E5%87%BA%E7%8E%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Eboard_cleanup_before_linux%3A%20QNX%20PFE%20%E4%BB%A3%E7%A0%81%E3%80%82%3CBR%20%2F%3Eethernet%404033c000%20%E7%AD%89%E5%BE%85%20PHY%20%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%E5%AE%8C%E6%88%90.........%20%E8%B6%85%E6%97%B6%EF%BC%81%3CBR%20%2F%3E%20phy_startup()%20%E5%A4%B1%E8%B4%A5%EF%BC%9A-110%20%E5%A4%B1%E8%B4%A5%EF%BC%9A-110%3CBR%20%2F%3E%E6%89%BE%E5%88%B0%20PFE%20%E7%89%88%E6%9C%AC%200x0101%20(S32G3)%3C%2FP%3E%3CP%3E%E6%89%BE%E5%88%B0%20PFE%20%E7%89%88%E6%9C%AC%200x0101%20(S32G3)%3CBR%20%2F%3E%20pfe2%20%E7%AD%89%E5%BE%85%20PHY%20%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%E5%AE%8C%E6%88%90.........%20%E8%B6%85%E6%97%B6%EF%BC%81%3CBR%20%2F%3E%20pfeng_netif%20pfe1%EF%BC%9A%E5%9C%A8%20PFE1%20%E4%B8%8A%E5%BB%BA%E7%AB%8B%20XPCS%20%E8%BF%9E%E6%8E%A5%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E6%AD%A3%E5%B8%B8%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40%E5%A1%9E%E5%86%85%E5%8D%A1%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%E5%AF%B9%E4%BA%8E%E7%BB%84%E5%90%88%E6%96%B9%E5%BC%8F%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E7%9B%B4%E6%8E%A5%E5%8F%82%E8%80%83%20QNX%20PFE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E5%8C%85%E5%90%AB%E7%9A%84%E6%96%87%E6%A1%A3%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E5%90%AB%E6%8E%A8%E8%8D%90%2F%E6%B5%8B%E8%AF%95%E8%BF%87%E7%9A%84%E7%BB%84%E5%90%88%E6%96%B9%E5%BC%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%85%B6%E4%BB%96%E7%BB%84%E5%90%88%E5%8F%AF%E8%83%BD%E6%9C%89%E6%95%88%E4%B9%9F%E5%8F%AF%E8%83%BD%E6%97%A0%E6%95%88%EF%BC%8C%E5%A6%82%E6%9C%89%E9%9C%80%E8%A6%81%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%BF%9B%E8%A1%8C%E7%9B%B8%E5%BA%94%E7%9A%84%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20%E6%A0%B9%E6%8D%AE%E7%8E%B0%E6%9C%89%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%AF%B9%E4%BA%8E%20QNX%20PFE%20%E9%A9%B1%E5%8A%A8%E5%99%A8%201.2%EF%BC%8C%E6%94%AF%E6%8C%81%E7%9A%84%20PFE%20%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%E4%B8%BA%201.2%EF%BC%8C%E6%B5%8B%E8%AF%95%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20BSP30%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%B5%8B%E8%AF%95%E7%9A%84%20BSP%20%E7%89%88%E6%9C%AC%E4%B8%BA%20BSP39%EF%BC%8C%E6%90%AD%E9%85%8D%20QNX%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%201.7.0%20%E5%92%8C%20QNX%20SDP%207.1%20BSP%20JBN51%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%89%80%E4%BD%BF%E7%94%A8%E7%9A%84PFE%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%E6%98%AF%E5%A4%9A%E5%B0%91%EF%BC%9F%3C%2FP%3E%3CP%3EJBN51%20%E9%9C%80%E8%A6%81%20NXP%20BSP39%EF%BC%8C%E8%AF%A5%20BSP39%20%E9%99%84%E5%B8%A6%20PFE%20%E5%9B%BA%E4%BB%B6%201.8.0%E3%80%82%E4%BD%86%20Pfe%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%201.7.0%20%E5%8F%91%E8%A1%8C%E8%AF%B4%E6%98%8E%E7%9A%84%202.1.3%20%E8%8A%82%E6%8C%87%E5%87%BA%EF%BC%8C%E6%AD%A4%E7%89%88%E6%9C%AC%E4%BB%85%E6%B5%8B%E8%AF%95%E4%BA%86%20PFW%20%E5%9B%BA%E4%BB%B6%201.10.0%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F390945iAC23A6EE62F0B101%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Seneca_0-1782903766239.png%22%20alt%3D%22Seneca_0-1782903766239.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E7%9B%AE%E5%89%8D%E6%B2%A1%E6%9C%89%E5%8F%AF%E4%BE%9B%E5%85%AC%E5%BC%80%E4%B8%8B%E8%BD%BD%E7%9A%84%E6%AD%A4%E7%B1%BB%E5%9B%BE%E7%89%87%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E2%80%9C%20%3CSPAN%3Ebinaries_auto_linux_bsp37.0_s32g3_pfe%3C%2FSPAN%3E%20%E2%80%9D%EF%BC%8C%E5%AE%83%E4%BC%BC%E4%B9%8E%E6%98%AF%E6%9D%A5%E8%87%AA%E4%BB%A5%E4%B8%8B%E4%BD%8D%E7%BD%AE%E7%9A%84%20tgz%20%E6%96%87%E4%BB%B6%E7%9A%84%E5%90%8D%E7%A7%B0%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F390855iCCB52D1818442408%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1782879234963.png%22%20alt%3D%22chenyin_h_0-1782879234963.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%98%AF%E8%BF%99%E6%A0%B7%EF%BC%8C%E5%AE%83%E5%8C%85%E5%90%AB%E4%BA%86%20NXP%20%E9%85%8D%E7%BD%AE%E7%9A%84%20Linux%20BSP%20%E7%9A%84%E9%A2%84%E6%9E%84%E5%BB%BA%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%8C%E4%B8%8D%E5%8C%85%E5%90%AB%E4%BB%BB%E4%BD%95%20QNX%20%E7%9B%B8%E5%85%B3%E9%95%9C%E5%83%8F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%99%88%E9%9F%B3%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AE%E6%B5%8B%E8%AF%95%20PFE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%201.7.0%20%E4%B8%8E%20QNXJBN51%20%E7%9A%84%E9%82%A3%E4%BD%8D%E7%94%A8%E6%88%B7%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%20NXP%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%20%E7%89%88%E6%9C%AC%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E5%AE%8C%E6%95%B4%E7%9A%84%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%EF%BC%8C%E5%8C%85%E6%8B%AC%E6%89%80%E6%9C%89%20u-boot%20%E7%8E%AF%E5%A2%83%E4%BF%A1%E6%81%AF%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E4%BB%AC%E8%BF%9B%E4%B8%80%E6%AD%A5%E6%A3%80%E6%9F%A5%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9Apfe0%20%E5%92%8C%20pfe2%20%E4%B8%8D%E8%83%BD%E5%90%8C%E6%97%B6%E5%B7%A5%E4%BD%9C%E3%80%82%E5%BD%93%E6%88%91%E4%BB%8E%E5%A4%96%E9%83%A8%E6%9C%BA%E5%99%A8%20ping%20%E4%BB%96%E4%BB%AC%E6%97%B6%EF%BC%8C%E5%AE%83%E4%BC%9A%E7%BB%99%20pfe0%20%E5%88%86%E9%85%8D%E4%B8%80%E4%B8%AA%E5%A5%87%E6%80%AA%E7%9A%84%20MAC%20%E5%9C%B0%E5%9D%80%EF%BC%9A%3C%2FP%3E%3CP%3Earp%20-a%20%7C%20grep%20192%3CBR%20%2F%3E%20%EF%BC%9F(192.168.0.200)%20%E4%BA%8E%2022%3A33%3A44%3A55%3A66%3A77%20%5B%E4%BB%A5%E5%A4%AA%E7%BD%91%5D%20%E5%9C%A8%20enx00e04c680383%20%E4%B8%8A%3CBR%20%2F%3E%EF%BC%9F(192.168.0.202)%20%E5%9C%A8%20%3CINCOMPLETE%3E%20%E4%B8%8A%EF%BC%8Cenx00e04c680383%3C%2FINCOMPLETE%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%9D%A5%E8%87%AA%20qnx%20slog2info%20%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A58.251%20iopkt.4121%20main_buffer%200%20%E9%87%8D%E5%A4%8D%20IP%20%E5%9C%B0%E5%9D%80%20192.168.0.200%20%E5%8F%91%E9%80%81%E8%87%AA%E9%93%BE%E8%B7%AF%E5%9C%B0%E5%9D%80%2022%3A33%3A44%3A55%3A66%3A77%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%88%86%E4%BA%AB%E6%97%A5%E5%BF%97%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%90%AF%E5%8A%A8%E9%98%B6%E6%AE%B5%E4%BC%BC%E4%B9%8E%E5%AD%98%E5%9C%A8%E5%BA%8F%E5%88%97%E5%8C%96%E5%99%A8%2F%E8%A7%A3%E4%B8%B2%E5%99%A8%20(serdes)%20%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E9%97%AE%E6%82%A8%E6%98%AF%E5%90%A6%E8%BF%9B%E8%A1%8C%E8%BF%87%E4%BB%A5%E4%B8%8B%E4%BF%AE%E6%94%B9%EF%BC%9F%EF%BC%88%E6%B3%A8%E9%87%8A%E6%8E%89%20init_serdes()%20%E5%87%BD%E6%95%B0%EF%BC%89%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391062i0603F69D828AD2F3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1782977121730.png%22%20alt%3D%22chenyin_h_0-1782977121730.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9Aio%20pkt%20%E7%9B%AE%E5%89%8D%E5%B0%9A%E6%9C%AA%E5%90%AF%E5%8A%A8%E3%80%82%E5%90%AF%E5%8A%A8%E5%AE%83%E5%B9%B6%E4%B8%8D%E8%83%BD%E8%A7%A3%E5%86%B3%E6%97%A0%E8%BD%BD%E6%B3%A2%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EU-Boot%202022.04%EF%BC%882026%20%E5%B9%B4%207%20%E6%9C%88%201%20%E6%97%A5%20-%2016%3A53%3A39%20%2B0200%EF%BC%89%3C%2FP%3E%3CP%3ESoC%EF%BC%9ANXP%20S32G399A%20rev.1.1%3CBR%20%2F%3ECPU%EF%BC%9AARM%20Cortex-A53%20r0p4%20%40%20%E6%9C%80%E9%AB%98%201300%20MHz%3CBR%20%2F%3E%E5%9E%8B%E5%8F%B7%EF%BC%9ANXP%20S32G399A-RDB3%3CBR%20%2F%3E%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(DRAM)%EF%BC%9A3.5%20GiB%3CBR%20%2F%3E%E6%A0%B8%E5%BF%83%EF%BC%9A306%20%E4%B8%AA%E8%AE%BE%E5%A4%87%EF%BC%8C25%20%E4%B8%AA%E5%BE%AE%E7%B1%BB%EF%BC%8C%E8%AE%BE%E5%A4%87%E6%A0%91%EF%BC%9A%E6%9D%BF%3CBR%20%2F%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%3CBR%20%2F%3E%E4%BB%8EMMC%E5%8A%A0%E8%BD%BD%E7%8E%AF%E5%A2%83...%20%E6%88%90%E5%8A%9F%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9Aserial%40401c8000%3CBR%20%2F%3E%E8%BE%93%E5%87%BA%EF%BC%9Aserial%40401c8000%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Aserial%40401c8000%3CBR%20%2F%3E%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%BF%AE%E8%AE%A2%EF%BC%9ARDB3%20%E4%BF%AE%E8%AE%A2%E7%89%88%20F%3CBR%20%2F%3EPCIe%EF%BC%9A%E6%80%BB%E7%BA%BF%E8%AE%BE%E5%A4%87%E5%8A%9F%E8%83%BD%20%E4%BE%9B%E5%BA%94%E5%95%86%20ID%20%E8%AE%BE%E5%A4%87%20ID%20%E8%AE%BE%E5%A4%87%E7%B1%BB%20%E5%AD%90%E7%B1%BB%3CBR%20%2F%3E__________________________________________________________________________%3CBR%20%2F%3Epcie%4040400000%20%E6%A0%B9%E5%A4%8D%E5%90%88%E4%BD%93%3CBR%20%2F%3E%7C%20%60--%2001%3A00.00%200x1957%200x4300%20%E6%A1%A5%E6%8E%A5%E8%AE%BE%E5%A4%87%200x04%3CBR%20%2F%3E%E7%BD%91%E7%BB%9C%EF%BC%9Aeth0%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%404033c000%3CBR%20%2F%3E%E6%89%BE%E5%88%B0%20PFE%20%E7%89%88%E6%9C%AC%200x0101%20(S32G3)%3CBR%20%2F%3E%EF%BC%8Ceth1%EF%BC%9Apfe0%EF%BC%8Ceth2%EF%BC%9Apfe1%EF%BC%8Ceth3%EF%BC%9Apfe2%3CBR%20%2F%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A2%201%200%3CBR%20%2F%3E%3D%26gt%3B%20printenv%3CBR%20%2F%3Eatf_fdt_0to3%3Dfdt%20addr%200x83e00000%3B%20fdt%20resize%3B%20fdt%20set%20%2Fcpus%2Fcpu%401%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40100%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40101%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%3CBR%20%2F%3Eatf_fdt_4to7%3Dfdt%20set%20%2Fcpus%2Fcpu%402%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%403%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40102%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40103%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%3CBR%20%2F%3E%E6%B3%A2%E7%89%B9%E7%8E%87%3D115200%3CBR%20%2F%3E%E6%9D%BF%E4%BF%AE%E8%AE%A2%3DF%3CBR%20%2F%3Eboot_mtd%3Dbooti%3CBR%20%2F%3Eboot_qnx_atf%3Dmmc%20dev%200%3B%20fatload%20mmc%200%3A1%200x83e00000%20s32g399a-rdb3.dtb%3B%E8%BF%90%E8%A1%8C%20atf_fdt_0to3%EF%BC%9B%E8%BF%90%E8%A1%8C%20atf_fdt_4to7%EF%BC%9B%E5%8A%A0%E8%BD%BD%20mmc%200%3A1%200x80080000%20ifs-s32g399a-rdb.ui%EF%BC%9Bbootm%200x80080000%20-%200x83E00000%3CBR%20%2F%3E%20bootargs%3Droot%3D%2Fdev%2Fram%20rw%20earlycon%20loglevel%3D7%3CBR%20%2F%3E%20bootcmd%3D%E8%BF%90%E8%A1%8C%20boot_qnx_atf%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%E5%BB%B6%E8%BF%9F%3D2%3CBR%20%2F%3E%20console%3DttyLF0%3CBR%20%2F%3E%20cpu_trap%3Ddcache%20%E5%85%B3%E9%97%AD%EF%BC%9Bmw.l%200xa0000000%200xd503205f%EF%BC%9Bmw.l%200xa0000004%200x58000060%EF%BC%9Bmw.l%200xa0000008%200xb4ffffc0%EF%BC%9Bmw.l%200xa000000C%200xd61f0000%EF%BC%9Bmw.q%200xa0000010%200x00000000%EF%BC%9Bdcache%20%E5%BC%80%E5%90%AF%EF%BC%9B%3CBR%20%2F%3E%20eth1addr%3D00%3A04%3A9f%3Abe%3Aef%3A00%3CBR%20%2F%3E%20eth2addr%3D00%3A04%3A9f%3Abe%3Aef%3A01%3CBR%20%2F%3E%20eth3addr%3D00%3A04%3A9f%3Abe%3Aef%3A02%3CBR%20%2F%3E%20ethaddr%3D0e%3A46%3A58%3A92%3A0b%3A68%3CBR%20%2F%3E%20fdt_addr%3D0x83000000%3CBR%20%2F%3E%20fdt_enable_hs400es%3Dfdt%20addr%20%24%7Bfdt_addr%7D%20%3B%20fdt%20rm%20%2Fsoc%2Fmmc%20no-1-8-v%3B%20fdt%20resize%3B%3CBR%20%2F%3E%20fdt_file%3Ds32g399a-rdb3.dtb%3CBR%20%2F%3E%20fdt_high%3D0xffffffffffffffff%3CBR%20%2F%3E%20fdt_override%3D%3B%3CBR%20%2F%3E%20fdtcontroladdr%3Dffa96000%3CBR%20%2F%3E%20flashboot%3Decho%20%E4%BB%8E%E9%97%AA%E5%AD%98%E5%90%AF%E5%8A%A8...%3B%20run%20flashbootargs%3Bmtd%20%E8%AF%BB%E5%8F%96%E5%86%85%E6%A0%B8%24%7Bloadaddr%7D%20%3Bmtd%20%E8%AF%BB%E5%8F%96%20DTB%20%24%7Bfdt_addr%7D%20%3Bmtd%20%E8%AF%BB%E5%8F%96%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%24%7Bramdisk_addr%7D%20%3B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20%24%7Bramdisk_addr%7D%20%24%7Bfdt_addr%7D%20%3B%3CBR%20%2F%3E%20flashbootargs%3Dsetenv%20bootargs%20console%3D%20%24%7Bconsole%7D%20%2C%20%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fram%20rw%20earlycon%20%3Bsetenv%20flashsize%200x04000000%3B%3CBR%20%2F%3E%20hwconfig%3Dserdes0%3Amode%3Dpcie%2Cclock%3Dext%3Bpcie0%3Amode%3Drc%3Bserdes1%3Amode%3Dxpcs0%26amp%3Bxpcs1%2Cclock%3Dext%2Cfmhz%3D125%3Bxpcs1_0%3Aspeed%3D2G5%3Bxpcs1_1%3Aspeed%3D1G%3CBR%20%2F%3E%E5%9B%BE%E7%89%87%3D%E5%9B%BE%E7%89%87%3CBR%20%2F%3Einitrd_high%20%3D%200xffffffffffffffff%3CBR%20%2F%3E%20IP%E5%9C%B0%E5%9D%80%3D10.0.0.100%3CBR%20%2F%3E%E5%8A%A0%E8%BD%BD%E5%9C%B0%E5%9D%80%3D0x80000000%3CBR%20%2F%3E%20loadfdt%3Dfatload%20mmc%20%24%7Bmmcdev%7D%20%3A%20%24%7Bmmcpart%7D%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%20%3B%20%E8%BF%90%E8%A1%8C%20fdt_override%3B%3CBR%20%2F%3E%20loadimage%3Dfatload%20mmc%20%24%7Bmmcdev%7D%20%3A%20%24%7Bmmcpart%7D%20%24%7Bloadaddr%7D%20%24%7Bimage%7D%3CBR%20%2F%3E%20loadtftpfdt%3Dtftp%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%20%3B%3CBR%20%2F%3E%20loadtftpimage%3Dtftp%20%24%7Bloadaddr%7D%20%24%7Bimage%7D%20%3B%3CBR%20%2F%3E%20mmcargs%3Dsetenv%20bootargs%20console%3D%20%24%7Bconsole%7D%20%2C%20%24%7Bbaudrate%7D%20root%3D%20%24%7Bmmcroot%7D%20earlycon%3CBR%20%2F%3E%20mmcboot%3Decho%20%E4%BB%8E%20mmc%20%E5%90%AF%E5%8A%A8...%3B%20%E8%BF%90%E8%A1%8C%20mmcargs%3B%20%E5%A6%82%E6%9E%9C%E8%BF%90%E8%A1%8C%20loadfdt%3B%20%E5%88%99%E8%BF%90%E8%A1%8C%20fdt_fixups%3B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%20%3B%20%E5%90%A6%E5%88%99%20echo%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%20DT%3B%20fi%3B%3CBR%20%2F%3E%20mmcdev%3D0%3CBR%20%2F%3E%20mmcpart%3D1%3CBR%20%2F%3E%20mmcroot%3D%2Fdev%2Fmmcblk0p2%20rootwait%20rw%3CBR%20%2F%3E%20netargs%3Dsetenv%20bootargs%20console%3D%20%24%7Bconsole%7D%20%2C%20%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fnfs%20ip%3Ddhcp%20nfsroot%3D%20%24%7Bserverip%7D%20%3A%20%24%7Bnfsroot%7D%20%2Cv3%2Ctcp%20earlycon%3CBR%20%2F%3E%20netboot%3Decho%20%E4%BB%8E%E7%BD%91%E7%BB%9C%E5%90%AF%E5%8A%A8...%3B%20run%20netargs%3B%20if%20test%20%24%7Bip_dyn%7D%20%3D%20yes%3B%20then%20setenv%20get_cmd%20dhcp%3B%20else%20setenv%20get_cmd%20tftp%3B%20fi%3B%20%24%7Bget_cmd%7D%20%24%7Bimage%7D%20%3B%20if%20test%20%24%7Bboot_fdt%7D%20%3D%20yes%20%7C%7C%20test%20%24%7Bboot_fdt%7D%20%3D%20try%3B%20then%20if%20%24%7Bget_cmd%7D%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%20%3B%20then%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%20%3B%20else%20if%20test%20%24%7Bboot_fdt%7D%20%3D%20try%3B%20then%20%24%7Bboot_mtd%7D%20%3B%20else%20echo%20WARN%3A%20%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%20DT%3B%20fi%3B%20fi%3B%20else%20%24%7Bboot_mtd%7D%20%3B%20fi%3B%3CBR%20%2F%3E%E5%AD%90%E7%BD%91%E6%8E%A9%E7%A0%81%3D255.255.255.0%3CBR%20%2F%3Enfsboot%3Decho%20%E4%BD%BF%E7%94%A8%20tftp%20%E5%92%8C%20nfs%20%E4%BB%8E%E7%BD%91%E7%BB%9C%E5%90%AF%E5%8A%A8...%3B%20%E8%BF%90%E8%A1%8C%20nfsbootargs%3B%20%E8%BF%90%E8%A1%8C%20loadtftpimage%3B%20%E8%BF%90%E8%A1%8C%20loadtftpfdt%3B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%20%3B%3CBR%20%2F%3E%20nfsbootargs%3Dsetenv%20bootargs%20console%3D%20%24%7Bconsole%7D%20%2C%20%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fnfs%20rw%20ip%3D%20%24%7Bipaddr%7D%20%3A%20%24%7Bserverip%7D%20%3A%3A%20%24%7Bnetmask%7D%20%3A%3Aeth0%3Aoff%20nfsroot%3D%20%24%7Bserverip%7D%20%3A%2Ftftpboot%2Frfs%2Cnolock%2Cv3%2Ctcp%20earlycon%3CBR%20%2F%3E%20pfe1_phy_addr%3D8%3CBR%20%2F%3E%20pfeng_mode%3D%E5%90%AF%E7%94%A8%2Csgmii%2Csgmii%2Crgmii%3CBR%20%2F%3E%20ramdisk_addr%3D0x90000000%3CBR%20%2F%3E%20release_cpus%3Drun%20cpu_trap%3B%20mp%201%20release%200xa0000000%3B%20mp%202%20release%200xa0000000%3B%20mp%203%20release%200xa0000000%3B%20mp%204%20release%200xa0000000%3B%20mp%205%20release%200xa0000000%3B%20mp%206%20release%200xa0000000%3B%20mp%207%20release%200xa0000000%3B%3CBR%20%2F%3E%E8%84%9A%E6%9C%AC%3Dboot.scr%3CBR%20%2F%3E%E6%9C%8D%E5%8A%A1%E5%99%A8IP%E5%9C%B0%E5%9D%80%3D10.0.0.1%3CBR%20%2F%3E%20skip_scmi_reset_agent%3D1%3CBR%20%2F%3E%20stderr%3Dserial%40401c8000%3CBR%20%2F%3E%E6%A0%87%E5%87%86%E8%BE%93%E5%85%A5%3Dserial%40401c8000%3CBR%20%2F%3E%E6%A0%87%E5%87%86%E8%BE%93%E5%87%BA%3Dserial%40401c8000%3C%2FP%3E%3CP%3E%E7%8E%AF%E5%A2%83%E5%A4%A7%E5%B0%8F%EF%BC%9A3581%2F8188%20%E5%AD%97%E8%8A%82%3CBR%20%2F%3E%3D%26gt%3B%20%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%88%86%E5%8C%BA%20%230%EF%BC%8C%E7%A1%AE%E5%AE%9A%3CBR%20%2F%3Emmc0%20%E6%98%AF%E5%BD%93%E5%89%8D%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E7%20%E6%AF%AB%E7%A7%92%E5%86%85%E8%AF%BB%E5%8F%96%E4%BA%86%2059970%20%E5%AD%97%E8%8A%82%EF%BC%888.2%20MiB%2Fs%EF%BC%89%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96%E4%BA%86%209362112%20%E5%AD%97%E8%8A%82%EF%BC%8C%E8%80%97%E6%97%B6%20394%20%E6%AF%AB%E7%A7%92%EF%BC%8822.7%20MiB%2Fs%EF%BC%89%3CBR%20%2F%3E%20%23%23%20Booting%20kernel%20from%20Legacy%20Image%20at%2080080000%20...%3CBR%20%2F%3EImage%20Name%3A%3CBR%20%2F%3EImage%20Type%3A%20AArch64%20Linux%20Kernel%20Image%20(uncompressed)%3CBR%20%2F%3EData%20Size%3A%209362048%20Bytes%20%3D%208.9%20MiB%3CBR%20%2F%3ELoad%20Address%3A%2080080000%3CBR%20%2F%3EEntry%20Point%3A%2080080000%3CBR%20%2F%3EVerifying%20Checksum%20...%20OK%3CBR%20%2F%3E%23%23%E4%BD%8D%E4%BA%8E%2083e00000%20%E7%9A%84%E6%89%81%E5%B9%B3%E5%8C%96%E8%AE%BE%E5%A4%87%E6%A0%91%20blob%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E4%BD%8D%E4%BA%8E%200x83e00000%20%E7%9A%84%20fdt%20blob%20%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E4%BD%8D%E4%BA%8E%200000000083e00000%20%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%EF%BC%8C%E7%BB%93%E6%9D%9F%E4%BA%8E%200000000083e11fff%3CBR%20%2F%3E%E4%BF%AE%E5%A4%8D%EF%BC%9Apfe1%EF%BC%9A%E5%B0%86%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%E6%9B%B4%E6%96%B0%E4%B8%BA%200x8%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FP%3E%3CP%3Eboard_cleanup_before_linux%3A%20QNX%20PFE%20%E4%BB%A3%E7%A0%81%E3%80%82%3CBR%20%2F%3Eethernet%404033c000%20%E7%AD%89%E5%BE%85%20PHY%20%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%E5%AE%8C%E6%88%90.........%20%E8%B6%85%E6%97%B6%EF%BC%81%3CBR%20%2F%3E%20phy_startup()%20%E5%A4%B1%E8%B4%A5%EF%BC%9A-110%20%E5%A4%B1%E8%B4%A5%EF%BC%9A-110%3CBR%20%2F%3E%E6%89%BE%E5%88%B0%20PFE%20%E7%89%88%E6%9C%AC%200x0101%20(S32G3)%3C%2FP%3E%3CP%3E%E6%89%BE%E5%88%B0%20PFE%20%E7%89%88%E6%9C%AC%200x0101%20(S32G3)%3CBR%20%2F%3E%20pfe2%20%E7%AD%89%E5%BE%85%20PHY%20%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%E5%AE%8C%E6%88%90.........%20%E8%B6%85%E6%97%B6%EF%BC%81%3CBR%20%2F%3E%20pfeng_netif%20pfe1%EF%BC%9A%E5%9C%A8%20PFE1%20%E4%B8%8A%E5%BB%BA%E7%AB%8B%20XPCS%20%E8%BF%9E%E6%8E%A5%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3E%23%23%20Setting%20pfe_ts%20clock%20...%3CBR%20%2F%3E%23%23%E8%AE%BE%E7%BD%AE%20ftm0_sys%20%E6%97%B6%E9%92%9F...%3CBR%20%2F%3E%20%23%23%20Setting%20ftm0_ext%20clock%20...%3CBR%20%2F%3E%23%23%E8%AE%BE%E7%BD%AE%20ftm1_sys%20%E6%97%B6%E9%92%9F...%3CBR%20%2F%3E%20%23%23%20%E8%AE%BE%E7%BD%AE%20ftm1_ext%20%E6%97%B6%E9%92%9F...%3CBR%20%2F%3E%E5%9C%A8%20EVB%2FRDB%20%E4%B8%8A%E4%B8%BA%20PFE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BF%9D%E7%95%99%20RAM%20%E5%8C%BA%E5%9F%9F%3CBR%20%2F%3EClockCycles%20%E7%A4%BA%E4%BE%8B%EF%BC%9A%3CBR%20%2F%3E%200%20166386615%3CBR%20%2F%3E%201%20166386614%3CBR%20%2F%3E%202%20166386615%3CBR%20%2F%3E%203%20166386615%3CBR%20%2F%3E%204%20166386615%3CBR%20%2F%3E%205%20166386615%3CBR%20%2F%3E%206%20166386616%3CBR%20%2F%3E%207%20166386615%3CBR%20%2F%3E%E6%89%80%E6%9C%89%E6%97%B6%E9%92%9F%E5%91%A8%E6%9C%9F%E5%81%8F%E7%A7%BB%E5%9D%87%E5%9C%A8%E5%AE%B9%E5%B7%AE%E8%8C%83%E5%9B%B4%E5%86%85%3CBR%20%2F%3E%E6%AC%A2%E8%BF%8E%E4%BD%BF%E7%94%A8%20QNX%20Neutrino%207.1.0%E5%9C%A8%20NXP%20S32G399A%20RDB%20%E6%9D%BF%E4%B8%8A%EF%BC%81%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%E7%9B%91%E7%9D%A3%E6%9C%BA%E5%88%B6%E2%80%A6%E2%80%A6%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E4%B8%B2%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E7%BD%91%E7%BB%9C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%2Fdev%2Fsocket%EF%BC%89...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%8F%91%20SPI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20(%2Fdev%2Fspi0%2C1%2C2%2C3%2C4%2C5)...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20I2C%200%2F1%2F2%2F3%2F4%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20(%2Fdev%2Fi2c0%2C1%2C2%2C3%2C4)...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20USDHC0%20%E5%AD%98%E5%82%A8%E5%8D%A1%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3CBR%20%2F%3E%20%5B00%5D%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20QSPI%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3CBR%20%2F%3E%20SIM%3D%22SDMMC%22%20HBA%3D%22imx%22%3CBR%20%2F%3E%20%5B00%2C0%2C0%5D%20type%3D00%20ver%3D05%20resp%3D00%20SDMMC%3A%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%20USB%20%E4%B8%BB%E6%9C%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20(%2Fdev%2Fusb%2F*)%3CBR%20%2F%3E%E6%A3%80%E6%B5%8B%E5%88%B0%20QSPI%20Flash%EF%BC%9AMacronix%20MX25UW512%EF%BC%8CJEDEC%200xC2%20-%200x813A%EF%BC%8C%E5%AE%B9%E9%87%8F%EF%BC%9A0x4000000%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E4%B8%BA%20%2Fdev%2Fusb%2F*%20%E5%90%AF%E5%8A%A8%20devb-umass%20...%3CBR%20%2F%3E%20U%23%20slogi%202info%3C%2FP%3E%3CP%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.022%20random.4low*%200%20qcrypto%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E2%80%9C%2Fetc%2Fqcrypto.conf%E2%80%9D%5Bqcrypto_common.c(190)%5D%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.023%20random.4..0%20slog*%20700%20%E9%9A%8F%E6%9C%BA%E6%95%B0%E7%94%9F%E6%88%90%E5%99%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20Fortuna%20%E4%BC%AA%E9%9A%8F%E6%9C%BA%E6%95%B0%E7%94%9F%E6%88%90%E5%99%A8%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.031%20random.4low%200%20qcrypto%3A%20'openssl'%20%E6%8F%92%E4%BB%B6%E5%B7%B2%E5%8A%A0%E8%BD%BD%20%5Bqcrypto_plugins.c(354)%5D%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.031%20random.4..0%20slog%20700%20%E9%80%89%E6%8B%A9%E8%AE%A1%E6%97%B6%E5%99%A8%E4%BD%9C%E4%B8%BA%E7%86%B5%E6%BA%90%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.031%20random.4..0%20slog%20700%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E8%B7%AF%E5%BE%84%E5%90%8D%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.031%20random.4..0%20slog%20700%20random%3A%20%E5%90%AF%E5%8A%A8%20resmgr%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A00.031%20random.4..0%20slog%20700%20random%3A%20%E8%BF%9B%E7%A8%8B%E5%AE%88%E6%8A%A4%E5%8C%96%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.041%20devc_serlinflexd.7%20slog*%200%20serlinflexd_interrupt_attach%3A%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%AD%E6%96%AD%20114%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.146%20spi_master.8%20normal*%200%20%E5%90%AF%E5%8A%A8%20spi-master%20%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.149%20spi_master.9%20normal*%200%20%E5%90%AF%E5%8A%A8%20spi-master%20%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.152%20spi_master.10%20normal*%200%20%E5%90%AF%E5%8A%A8%20spi-master%20%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.155%20spi_master.11%20normal*%200%20%E5%90%AF%E5%8A%A8%20spi-master%20%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.158%20spi_master.12%20normal*%200%20%E5%90%AF%E5%8A%A8%20spi-master%20%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.161%20spi_master.13%20normal*%200%20%E5%90%AF%E5%8A%A8%20spi-master%20%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.177%20devb_sdmmc_mx8x.19%20slog*%201800%20devb-sdmmc-mx8x%201.00A%20(2026%E5%B9%B47%E6%9C%881%E6%97%A5%2014%3A10%3A37)%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.178%20devb_sdmmc_mx8x.19%20slog%200%20libcam.so%20(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A15)%20bver%207010003%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.189%20devb_sdmmc_mx8x.19%20slog%201800%20sdio_cd%3A%20%E6%8F%92%E5%85%A5%E8%B7%AF%E5%BE%84%200%EF%BC%8Ccd%20%E7%8A%B6%E6%80%81%200x1%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20SD%20CID%3A%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20MID%200x27%2C%20OID%200x5048%2C%20PNM%20SD32G%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20PRV%200x62%2C%20PSN%200x6c62d196%2C%20MDT%204-2023%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20SD%20CSD%3A%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20CSD_STRUCTURE%201%2C%20SPEC_VERS%200%2C%20CCC%200x5b5%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20TAAC%2014%2C%20NSAC%200%2C%20TRAN_SPEED%2050%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20C_SIZE%2059023%2C%20C_SIZE_MULT%200%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20READ_BL_LEN%209%2C%20WRITE_BL_LEN%209%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20ERASE%20GRP_SIZE%200%2C%20GRP_MULT%200%2C%20SIZE%20127%3CBR%20%2F%3E%201%E6%9C%8801%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20blksz%20512%2C%20sectors%2060440576%2C%20dtr%2025000000%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20SD%20SW%20CAPS%3A%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20%E6%80%BB%E7%BA%BF%E6%A8%A1%E5%BC%8F%200x3%EF%BC%8C%E5%91%BD%E4%BB%A4%E7%B3%BB%E7%BB%9F%200x1%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20%E9%A9%B1%E5%8A%A8%E7%B1%BB%E5%9E%8B%200x1%EF%BC%8C%E5%BD%93%E5%89%8D%E9%99%90%E5%88%B6%200x1%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20dtr%2050000000%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20CFG%3A%20%E6%97%B6%E5%BA%8F%20HS%EF%BC%8CDTR%2050000000%EF%BC%8C%E6%80%BB%E7%BA%BF%E5%AE%BD%E5%BA%A6%204%20%E4%BD%8D%3C%2FP%3E%3CP%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.240%20devb_sdmmc_mx8x.19%20slog%20100%20cam-disk.so%20(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A17)%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.242%20devb_sdmmc_mx8x.19%20slog%200%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%20cam_status%3Dc4%2C%20scsi_status%3D2%2C%20flag%3D00000040%2C%20vuflag%3D0008%2C%20cmd%3D1a%2C%20error%3D70%2C%20%E6%84%9F%E7%9F%A5%3D5%2C%20asc%3D24%2C%20ascq%3D0%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.242%20devb_sdmmc_mx8x.19%20slog%200%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%20cam_status%3Dc4%2C%20scsi_status%3D2%2C%20flag%3D00000040%2C%20vuflag%3D0008%2C%20cmd%3D5a%2C%20error%3D70%2C%20%E6%84%9F%E7%9F%A5%3D5%2C%20asc%3D24%2C%20ascq%3D0%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.242%20devb_sdmmc_mx8x.19%20slog%200%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%20cam_status%3Dc4%2C%20scsi_status%3D2%2C%20flag%3D00000040%2C%20vuflag%3D0008%2C%20cmd%3D5a%2C%20error%3D70%2C%20%E6%84%9F%E7%9F%A5%3D5%2C%20asc%3D24%2C%20ascq%3D0%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.248%20io_usb_otg.21%20slog*%200%20main(453)%5Btid%3A1%5D%3A%20io-usb-otg%20(2020%E5%B9%B46%E6%9C%8813%E6%97%A5%2020%3A10%3A17)%20%E5%8F%82%E6%95%B0%3A%20-d%20hcd-ehci-mx28%20ioport%3D0x44064100%2Cirq%3D243%2Culpi%2Cno_stream%2Cverbose%3D5%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.250%20devf_qspi_s32g.20%20slog*%200%20(devf%20t1%3A%3Af3s_qspi_ident%3A73)%20%E9%A1%B5%E9%9D%A2%E5%A4%A7%E5%B0%8F%EF%BC%9A256%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.250%20devf_qspi_s32g.20%20slog%200%20(devf%20t1%3A%3Af3s_qspi_ident%3A74)%20%E6%80%BB%E8%8A%AF%E7%89%87%E5%A4%A7%E5%B0%8F%EF%BC%9A0x4000000%EF%BC%8C%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A0x10000%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.254%20io_usb_otg.21%20slog%200%20ehci_init%3A%20%E4%BD%BF%E7%94%A8%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%89%88%E6%9C%AC%202%20%E8%BF%9B%E8%A1%8C%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EJan%2001%2000%3A00%3A10.254%20io_usb_otg.21%20slog%200%20ehci_controller_init(4292)%3A%20devu-hcd-ehci-mx28.so%20(2023%20%E5%B9%B4%208%20%E6%9C%88%2015%20%E6%97%A5%2016%3A44%3A48)%3A%20args%20ulpi%2Cno_stream%2Cverbose%3D5%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.254%20io_usb_otg.21%20slog%208%20usb_enum_port(94)%5Btid%3A1%5D%3A%20%E6%80%BB%E7%BA%BF%E5%8F%B7%200%EF%BC%8C%E7%88%B6%E7%BA%A7%20-1%EF%BC%8C%E7%AB%AF%E5%8F%A3%200%EF%BC%8C%E9%AB%98%E9%80%9F%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.255%20io_usb_otg.21%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E7%B1%BB%E5%9E%8B%201%EF%BC%8C%E7%B4%A2%E5%BC%95%200%EF%BC%8C%E9%95%BF%E5%BA%A6%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.255%20io_usb_otg.21%20slog%2012%20usb_device_set_address(245)%5Btid%3A1%5D%3A%20b%3A0%20devno%200%3CBR%20%2F%3E%201%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A10.255%20io_usb_otg.21%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E7%B1%BB%E5%9E%8B%201%EF%BC%8C%E7%B4%A2%E5%BC%95%200%EF%BC%8C%E9%95%BF%E5%BA%A6%2018)%3CBR%20%2F%3E%201%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A10.255%20io_usb_otg.21%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E7%B1%BB%E5%9E%8B%202%EF%BC%8C%E7%B4%A2%E5%BC%95%200%EF%BC%8C%E9%95%BF%E5%BA%A6%209)%3CBR%20%2F%3E%201%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A10.255%20io_usb_otg.21%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E7%B1%BB%E5%9E%8B%202%EF%BC%8C%E7%B4%A2%E5%BC%95%200%EF%BC%8C%E9%95%BF%E5%BA%A6%2025)%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.256%20io_usb_otg.21%20slog%208%20usb_enum_port(141)%5Btid%3A1%5D%3A%20vid%200x0000%2C%20did%200x0000%20enumerated(busno%200%2C%20devno%200%3A0)%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.256%20io_usb_otg.21%20slog%2011%20hub_state_inserted(569)%5Btid%3A1%5D%3A%20bdentry%200%2C%20dentry%200%200%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.256%20io_usb_otg.21%20slog%2013%20hub_configuration_enable(263)%5Btid%3A1%5D%3A%201%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.358%20io_usb_otg.21%20slog%200%20usbh_timeout_init(203)%5Btid%3A1%5D%3A%20%E5%AE%8C%E6%88%90%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.369%20io_usb_otg.21%20slog%200%20read_vid_pid%3A%20ULPI%20VID%200x0424%20PID%200x0009%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.369%20io_usb_otg.21%20slog%200%20s32g_phy_set_vbus%3A%20%E8%AE%BE%E7%BD%AE%20V-Bus%20%E5%85%B3%E9%97%AD%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.383%20io_usb_otg.21%20slog%200%20s32g_phy_set_vbus%3A%20set_vbus%20on%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.394%20io_usb_otg.21%20slog%200%20ehci_get_port_status(3557%200x44064100)%3A%20port%3D0%2C%20tpstatus%2010100%20e_pstatus%208c001000%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.394%20io_usb_otg.21%20slog%208%20usb_enum_port_extract(172)%5Btid%3A7%5D%3A%20(%E6%80%BB%E7%BA%BF%E5%8F%B7%200%EF%BC%8C%E8%AE%BE%E5%A4%87%E5%8F%B7%200%EF%BC%8C%E7%AB%AF%E5%8F%A3%E5%8F%B7%201)%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.394%20io_usb_otg.21%20slog%208%20usb_enum_port_extract(192)%5Btid%3A7%5D%3A%20%E7%8A%B6%E6%80%81%20(2)%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.398%20devb_umass.22%20slog*%20900%20devb-umass%201.00A%20(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A41)%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.399%20devb_umass.22%20slog%200%20libcam.so%20(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A15)%20bver%207010003%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.400%20io_usb_otg.21%20slog%200%20usbdi_client_connect(58)%5Btid%3A5%5D%3A%20pid%2022%20proc%3Dproc%2Fboot%2Fdevb-umass%20usbdi_client%2051ba29fa80%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.400%20io_usb_otg.21%20slog%200%20usbdi_resmgr_connect(310)%5Btid%3A5%5D%3A%20usbdi_resmgr_connect%3A%20pid%2022%20usbdi_client%2051ba29fa80%3CBR%20%2F%3E%201%E6%9C%881%E6%97%A5%2000%3A00%3A10.400%20devb_umass.22%20slog%200%20usbdi%20%E8%B0%83%E8%AF%95%E8%B7%AF%E5%BE%84%20%2Fpps%2Fusb%2Fdebug%2F%20%E4%B8%8D%E5%AD%98%E5%9C%A8%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A14.507%20qconn.24%20slog*%200%20%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%E7%9B%91%E5%90%AC%E6%9C%8D%E5%8A%A1%EF%BC%9Atcp%EF%BC%88%E5%8D%8F%E8%AE%AE%E6%97%8F%E4%B8%8D%E6%94%AF%E6%8C%81%E6%AD%A4%E5%9C%B0%E5%9D%80%E6%97%8F%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3Einit_serdes()%3B%3C%2FP%3E%3CP%3E%E5%B7%B2%E4%BB%8E%20s32g399a-rdb%20main.c%20%E4%B8%AD%E6%B3%A8%E9%87%8A%E6%8E%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E8%BF%98%E6%9C%89%E4%B8%80%E4%BA%9B%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E6%89%8B%E5%8A%A8%E5%90%AF%E5%8A%A8%E7%BD%91%E7%BB%9C%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%97%B6%3C%2FP%3E%3CP%3Eio-pkt-v6-hc%20-p%20tcpip%20pkt_typed_mem%3Dpfe_ddr%20-d%20%2Fproc%2Fboot%2Fdevnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cutil_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_util.fw%3C%2FP%3E%3CP%3E%E5%B9%B6%E4%B8%BA%20pfe0%20%E8%AE%BE%E7%BD%AE%E9%9D%99%E6%80%81%20IP%20%E5%9C%B0%E5%9D%80%3C%2FP%3E%3CP%3Eifconfig%20pfe0%20192.168.0.200%20netmask%20255.255.255.0%3C%2FP%3E%3CP%3Eifconfig%20pfe0%20down%3C%2FP%3E%3CP%3Eifconfig%20pfe0%20up%3C%2FP%3E%3CP%3E%E6%88%91%E7%A1%AE%E5%AE%9E%E5%8F%AF%E4%BB%A5%20ping%20%E9%80%9A%E4%B8%80%E4%B8%AA%E5%A4%96%E9%83%A8%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E5%9C%A8%20ifconfig%20%E4%B8%AD%20pfe0%20%E4%BB%8D%E7%84%B6%E6%98%BE%E7%A4%BA%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%97%A0%E8%BF%9E%E6%8E%A5%E3%80%82%E5%9C%A8%E6%88%91%E7%9C%8B%E6%9D%A5%EF%BC%8C%E5%8D%8F%E5%95%86%E6%8E%A5%E5%8F%A3%E9%80%9F%E5%BA%A6%E6%96%B9%E9%9D%A2%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%23%20slog2info%20%7C%20grep%20pfe0%3C%2FP%3E%3CP%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A25.515%20iopkt.4121%20main_buffer%200%20%2Fproc%2F%E5%90%AF%E5%8A%A8%2Fdevnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2F%E5%90%AF%E5%8A%A8%2Fs32g_pfe_class.fw%2Cutil_fw%3D%2Fproc%2F%E5%90%AF%E5%8A%A8%2Fs32g_pfe_util.fw%3CBR%20%2F%3EJan%2001%2000%3A00%3A25.517%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1460%5D%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe0%2FEMAC0%20%E7%9A%84%20MII%20%E6%A8%A1%E5%BC%8F%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%20SGMII%E3%80%82%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A25.647%20iopkt.4121%20main_buffer%200%20pfe0%3C%2FP%3E%3CP%3E%E8%BF%9B%E7%A8%8B%2098332%20(slog2info)%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3D0%E3%80%82%3CBR%20%2F%3EJan%2001%2000%3A00%3A25.647%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2124%5D%EF%BC%9Apfe0%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%9D%99%E6%80%81%20PHY%20%E6%A8%A1%E5%BC%8F%EF%BC%8CRESET%3D0%3CBR%20%2F%3E%20Jan%2001%2000%3A00%3A25.647%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2286%5D%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%20pfe0%20%E7%9A%84%E9%80%9F%E5%BA%A6%2F%E5%8F%8C%E5%B7%A5%E9%85%8D%E7%BD%AE%E3%80%82%E4%BD%BF%E7%94%A8%201%20Gbps%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%E3%80%82%3CBR%20%2F%3EJan%2001%2000%3A00%3A58.251%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2606%5D%EF%BC%9Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3EJan%2001%2000%3A00%3A58.251%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2606%5D%EF%BC%9Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3EJan%2001%2000%3A00%3A58.251%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2606%5D%EF%BC%9Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3EJan%2001%2000%3A00%3A58.251%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2606%5D%EF%BC%9Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3EJan%2001%2000%3A01%3A05.966%20io_pkt_v6_hc.4121%20slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2606%5D%EF%BC%9Apfe0%EF%BC%9A%E7%A6%81%E7%94%A8%E6%B7%B7%E6%9D%82%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%AF%B9%E4%BA%8E%20Pfe2%EF%BC%8C%E5%AE%83%E5%8F%AF%E8%83%BD%E5%B7%B2%E7%BB%8F%E5%9C%A8%20uboot%20%E7%9A%84%20board_cleanup_before_linux%20%E9%98%B6%E6%AE%B5%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3Epfe2%20%E7%AD%89%E5%BE%85%20PHY%20%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%E5%AE%8C%E6%88%90.........%20%E8%B6%85%E6%97%B6%EF%BC%81%3C%2FP%3E%3CP%3E%E7%BC%96%E8%BE%91%EF%BC%9A%E6%88%91%E4%B9%9F%E5%8F%AF%E4%BB%A5%E4%BB%8E%20pfe2%20%E8%8E%B7%E5%8F%96%20ping%20%E5%80%BC%EF%BC%8C%E4%BD%86%E5%AE%83%E4%BC%BC%E4%B9%8E%E5%9C%A8%E5%8D%8F%E5%95%86%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%80%9F%E5%BA%A6%E6%96%B9%E9%9D%A2%E4%B9%9F%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E4%B8%8A%E8%BF%B0%E8%B6%85%E6%97%B6%E6%97%B6%E9%97%B4%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E5%B8%8C%E6%9C%9B%E8%BF%99%E4%BA%9B%E9%97%AE%E9%A2%98%E8%83%BD%E5%B8%AE%E5%8A%A9%E6%88%91%E6%8E%A5%E8%BF%91%E7%BB%88%E7%82%B9%EF%BC%9A%3C%2FP%3E%3CP%3E-%20%E6%88%91%E5%BA%94%E8%AF%A5%E5%A6%82%E4%BD%95%E8%AE%BE%E7%BD%AE%20pfe0%20%E5%92%8C%20pfe2%20%E7%9A%84%20MAC%20%E5%9C%B0%E5%9D%80%EF%BC%9F%E6%88%91%E4%BA%86%E8%A7%A3%E5%88%B0%E6%9C%89%E4%BA%BA%E5%B0%9D%E8%AF%95%E9%80%9A%E8%BF%87%20io%20%E5%8C%85%E6%9D%A5%E8%AE%BE%E7%BD%AE%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3Eio-pkt-v6-hc%20-p%20tcpip%20pkt_typed_mem%3Dpfe_ddr%20-d%20%2Fproc%2Fboot%2Fdevnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cutil_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_util.fw%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E4%BB%8E%E5%A4%96%E9%83%A8%E6%9C%BA%E5%99%A8%20ping%20pfe0%20%E6%97%B6%EF%BC%8C%E8%AF%A5%E6%9C%BA%E5%99%A8%E7%9A%84%20ARP%20%E8%A1%A8%E4%B8%AD%E6%98%BE%E7%A4%BA%E7%9A%84%E5%9C%B0%E5%9D%80%E6%98%AF%E9%94%99%E8%AF%AF%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3F%20(192.168.0.200)%20%E4%BA%8E%2022%3A33%3A44%3A55%3A66%3A77%20%5Bether%5D%20%E5%9C%A8%20enx00e04c680383%20%E4%B8%8A%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%A4%96%E9%83%A8%E6%9C%BA%E5%99%A8%E4%B8%8A%EF%BC%8Ctcpdump%20%E6%98%BE%E7%A4%BA%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E6%9D%A5%E8%87%AA%20pfe0%EF%BC%88IP%20%E5%9C%B0%E5%9D%80%E4%B8%BA%20192.168.0.200%EF%BC%89%E7%9A%84%20ARP%20%E5%93%8D%E5%BA%94%EF%BC%9A%3C%2FP%3E%3CP%3E08%3A53%3A11.208021%20IP6%20%E7%94%A8%E6%88%B7-Precision-7510%20%26gt%3B%20ff02%3A%3A16%3A%20HBH%20ICMP6%EF%BC%8C%E7%BB%84%E6%92%AD%E7%9B%91%E5%90%AC%E5%99%A8%E6%8A%A5%E5%91%8A%20v2%EF%BC%8C2%20%E6%9D%A1%E7%BB%84%E8%AE%B0%E5%BD%95%EF%BC%8C%E9%95%BF%E5%BA%A6%2048%3CBR%20%2F%3E%2008%3A53%3A11.394038%20IP6%20%E7%94%A8%E6%88%B7-Precision-7510%20%26gt%3B%20ff02%3A%3A16%3A%20HBH%20ICMP6%EF%BC%8C%E7%BB%84%E6%92%AD%E7%9B%91%E5%90%AC%E5%99%A8%E6%8A%A5%E5%91%8A%20v2%EF%BC%8C2%20%E6%9D%A1%E7%BB%84%E8%AE%B0%E5%BD%95%EF%BC%8C%E9%95%BF%E5%BA%A6%2048%3CBR%20%2F%3E%2008%3A53%3A25.750284%20ARP%EF%BC%8C%E8%AF%B7%E6%B1%82%20who-has%20192.168.0.200%20tell%20192.168.0.200%EF%BC%8C%E9%95%BF%E5%BA%A6%2046%3CBR%20%2F%3E%2008%3A53%3A26.641915%20IP6%20%3A%3A%20%26gt%3B%20ff02%3A%3A1%3Aff0c%3Ad66%3A%20HBH%20ICMP6%EF%BC%8C%E7%BB%84%E6%92%AD%E7%9B%91%E5%90%AC%E5%99%A8%E6%8A%A5%E5%91%8A%E6%9C%80%E5%A4%A7%E5%93%8D%E5%BA%94%E5%BB%B6%E8%BF%9F%EF%BC%9A0%20%E5%9C%B0%E5%9D%80%EF%BC%9Aff02%3A%3A1%3Aff0c%3Ad66%EF%BC%8C%E9%95%BF%E5%BA%A6%2024%3CBR%20%2F%3E%2008%3A53%3A26.692011%20IP6%20%3A%3A%20%26gt%3B%20ff02%3A%3A1%3Aff0c%3Ad66%3A%20ICMP6%EF%BC%8C%E9%82%BB%E5%B1%85%E8%AF%B7%E6%B1%82%EF%BC%8C%E8%B0%81%E6%8B%A5%E6%9C%89%20fe80%3A%3A20a%3Abff%3Afe0c%3Ad66%EF%BC%8C%E9%95%BF%E5%BA%A6%2024%3CBR%20%2F%3E%2008%3A53%3A32.742005%20IP6%20fe80%3A%3A20a%3Abff%3Afe0c%3Ad66%20%26gt%3B%20ff02%3A%3A1%3Aff0c%3Ad66%3A%20HBH%20ICMP6%EF%BC%8C%E7%BB%84%E6%92%AD%E7%9B%91%E5%90%AC%E5%99%A8%E6%8A%A5%E5%91%8A%E6%9C%80%E5%A4%A7%E5%93%8D%E5%BA%94%E5%BB%B6%E8%BF%9F%EF%BC%9A0%20%E5%9C%B0%E5%9D%80%EF%BC%9Aff02%3A%3A1%3Aff0c%3Ad66%EF%BC%8C%E9%95%BF%E5%BA%A6%2024%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E4%BB%8E%E5%A4%96%E9%83%A8%E6%9C%BA%E5%99%A8%E5%86%8D%E6%AC%A1%E5%8F%91%E9%80%81%20ping%20%E8%AF%B7%E6%B1%82%E6%97%B6%EF%BC%8C%E7%BB%88%E4%BA%8E%E6%94%B6%E5%88%B0%E4%BA%86%E5%93%8D%E5%BA%94%EF%BC%9A%3C%2FP%3E%3CP%3E08%3A59%3A22.118282%20ARP%EF%BC%8C%E8%AF%B7%E6%B1%82%20who-has%20192.168.0.200%20tell%20user-Precision-7510%EF%BC%8C%E9%95%BF%E5%BA%A6%2028%3CBR%20%2F%3E%2008%3A59%3A22.118553%20ARP%EF%BC%8C%E5%9B%9E%E5%A4%8D%20192.168.0.200%20%E4%BD%8D%E4%BA%8E%2022%3A33%3A44%3A55%3A66%3A77%20(oui%20%E6%9C%AA%E7%9F%A5)%EF%BC%8C%E9%95%BF%E5%BA%A6%2046%3CBR%20%2F%3E%2008%3A59%3A22.118569%20IP%20%E7%94%A8%E6%88%B7-Precision-7510%20%26gt%3B%20192.168.0.200%3AICMP%20%E5%9B%9E%E6%98%BE%E8%AF%B7%E6%B1%82%EF%BC%8CID%201%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%201%EF%BC%8C%E9%95%BF%E5%BA%A6%2064%3CBR%20%2F%3E%2008%3A59%3A22.118554%20ARP%EF%BC%8C%E5%9B%9E%E5%A4%8D%20192.168.0.200%20%E5%9C%B0%E5%9D%80%E4%B8%BA%2000%3A0a%3A0b%3A0c%3A0d%3A66%20(oui%20%E6%9C%AA%E7%9F%A5)%EF%BC%8C%E9%95%BF%E5%BA%A6%2046%3C%2FP%3E%3CP%3E00%3A0a%3A0b%3A0c%3A0d%3A66%20%E6%89%8D%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%20MAC%20%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E5%A4%96%E9%83%A8%E6%9C%BA%E5%99%A8%E7%9A%84ARP%E8%A1%A8%E4%BB%8D%E7%84%B6%E6%98%BE%E7%A4%BA%E9%94%99%E8%AF%AF%E7%9A%84%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FP%3E%3CP%3Earp%20-a%3C%2FP%3E%3CP%3E%3F%20(192.168.0.200)%20%E4%BA%8E%2022%3A33%3A44%3A55%3A66%3A77%20%5Bether%5D%20%E5%9C%A8%20enx00e04c680383%20%E4%B8%8A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E9%A6%96%E5%85%88%E6%83%B3%E5%88%B0%E7%9A%84%E6%96%B9%E6%B3%95%E6%98%AF%E6%89%8B%E5%8A%A8%E5%9C%A8%20uboot%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%E5%AE%83%E4%BB%AC%EF%BC%8C%E4%BD%86%E6%88%91%E6%B2%A1%E6%9C%89%E5%9C%A8%E9%9B%86%E6%88%90%E6%89%8B%E5%86%8C%E4%B8%AD%E6%89%BE%E5%88%B0%E4%BB%BB%E4%BD%95%E5%BB%BA%E8%AE%AE%E8%BF%99%E6%A0%B7%E5%81%9A%E7%9A%84%E7%AB%A0%E8%8A%82%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E-%20%E4%BD%BF%E7%94%A8%E2%80%9C%E5%9B%BA%E5%AE%9A%E9%93%BE%E6%8E%A5%E2%80%9D%E7%9A%84%E5%91%BD%E4%BB%A4%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%20%E6%98%AF%E7%9A%84%EF%BC%8C%E5%AE%83%E9%80%9A%E5%B8%B8%E6%98%AF%E6%89%80%E8%BF%9E%E6%8E%A5%E4%BA%A4%E6%8D%A2%E6%9C%BA%E7%9A%84%E9%BB%98%E8%AE%A4%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20%E6%88%91%E8%AE%A4%E4%B8%BA%E4%BD%A0%E6%8F%90%E5%88%B0%E7%9A%84%E6%96%B0%20IP%20%E5%9C%B0%E5%9D%80%E5%AF%B9%E4%BA%8E%E6%B5%8B%E8%AF%95%E6%9D%A5%E8%AF%B4%E6%B2%A1%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%98%8E%E7%99%BD%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%20uboot%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%E4%BA%86%20ethaddr%E3%80%81eth1addr%E3%80%81eth2addr%E3%80%81eth3addr%EF%BC%8C%E4%BD%86%E8%BF%99%E4%B8%8D%E8%B6%B3%E4%BB%A5%E9%98%BB%E6%AD%A2%20pfe0%20%E5%87%BA%E7%8E%B0%E5%A5%87%E6%80%AA%E7%9A%84%20MAC%20%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E5%8F%82%E6%95%B0%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%3CSPAN%20class%3D%22fontstyle0%22%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%E8%A6%81%E8%AE%BE%E7%BD%AE%20MAC%20%E5%9C%B0%E5%9D%80%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E2%80%9Cio-pkt-v6-hc%20-p%20tcpip%20-d%20%3CDRIVER%3E%20%5C%20pfe1_mac%3D000a0b0c0d0e%2Cpfe2_mac%3D001a1b1c1d1e%E2%80%9D%E3%80%82%3C%2FDRIVER%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2.%20%E7%94%B1%E4%BA%8E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20RDB3%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%9C%A8%E6%82%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E8%AE%BE%E7%BD%AE%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E8%BF%9E%E6%8E%A5%E5%88%B0%20SJA1110%20%E4%BA%A4%E6%8D%A2%E6%9C%BA%E7%9A%84%20PFE0%20%E9%80%9A%E5%B8%B8%E7%94%B1%20SJA1110%20SDK%20%E5%86%85%E9%83%A8%E8%AE%BE%E7%BD%AE%20IP%20%E5%9C%B0%E5%9D%80%E4%B8%BA%20192.168.0.200%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E4%B8%8D%E8%A6%81%E4%BD%BF%E7%94%A8%E6%AD%A4%20IP%20%E5%9C%B0%E5%9D%80%E6%B5%8B%E8%AF%95%20PFE0%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E4%B8%BA%20PFE0%20%E8%AE%BE%E7%BD%AE%E5%85%B6%E4%BB%96%20IP%20%E5%9C%B0%E5%9D%80%EF%BC%8C%E4%BE%8B%E5%A6%82%20192.168.1.X%E3%80%82%3C%2FP%3E%0A%3CP%3E3.%20%E5%9C%A8%20u-boot%20%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E2%80%9Csetenv%20ethaddr%2Feth1addr%2Feth2addr%20xxxx%E2%80%9D%E4%B8%BA%E6%AF%8F%E4%B8%AA%20MAC%20%E8%AE%BE%E7%BD%AE%20MAC%20%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%BE%88%E9%AB%98%E5%85%B4PFE%E8%83%BD%E4%B8%8E%E5%A4%96%E9%83%A8%E6%9C%BA%E5%99%A8%E6%AD%A3%E7%A1%AEping%E9%80%9A%E3%80%82%3C%2FP%3E%0A%3CP%3EQNX%20%E4%B8%AD%E7%9A%84%20PFE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%AD%98%E5%9C%A8%E4%B8%80%E4%BA%9B%E9%99%90%E5%88%B6%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391145i0C1C82024E1B820A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1783044213433.png%22%20alt%3D%22chenyin_h_0-1783044213433.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%E5%9B%BA%E5%AE%9A%E9%93%BE%E8%B7%AF%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%94%AF%E6%8C%81%E9%80%9A%E8%BF%87%20AN%20%E8%A7%A6%E5%8F%91%E7%9A%84%E9%80%9F%E5%BA%A6%E5%8F%98%E5%8C%96%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%88%91%E5%8F%AA%E6%98%AF%E6%83%B3%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%E6%88%91%E7%9A%84%E7%90%86%E8%A7%A3%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%E8%BF%98%E6%9C%89%E5%8F%A6%E4%B8%80%E4%B8%AA%E5%85%83%E5%99%A8%E4%BB%B6%E6%81%B0%E5%A5%BD%E4%BD%BF%E7%94%A8%E4%BA%86%20192.168.0.200%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E4%BD%BF%E7%94%A8%20192.168.1.200%E5%AF%B9%E4%BA%8E%20pfe0%EF%BC%8C%E6%88%91%E5%BA%94%E8%AF%A5%E6%B2%A1%E9%97%AE%E9%A2%98%E5%90%A7%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%99%88%E9%9F%B3%EF%BC%8C%E4%BD%A0%E5%A5%BD%EF%BC%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%89%93%E7%AE%97%E4%BD%BF%E7%94%A8%E4%BB%A5%E5%A4%AA%E7%BD%91%E7%AB%AF%E5%8F%A3%20gmac0%E3%80%81pfe0%E3%80%81pfe2%20%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%A1%A5%E6%8E%A5%E6%8E%A5%E5%8F%A3%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.qnx.com%2Fdevelopers%2Fdocs%2F7.0.0%2Findex.html%23com.qnx.doc.neutrino.utilities%2Ftopic%2Fb%2Fbrconfig.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.qnx.com%2Fdevelopers%2Fdocs%2F7.0.0%2Findex.html%23com.qnx.doc.neutrino.utilities%2Ftopic%2Fb%2Fbrconfig.html%3C%2FA%3E%3C%2FP%3E%3CP%3E%E8%BF%9E%E6%8E%A5%E7%9A%84%E5%AE%A2%E6%88%B7%E7%AB%AF%E5%BA%94%E4%BD%8D%E4%BA%8E%E5%AD%90%E7%BD%91%20192.168.0.X%EF%BC%8C%E5%AD%90%E7%BD%91%E6%8E%A9%E7%A0%81%E4%B8%BA%20255.255.255.0%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E4%BC%9A%E4%B8%8E%20192.168.0.200%20%E6%88%96%E5%85%B6%E4%BB%96%E4%BB%BB%E4%BD%95%E5%86%85%E5%AE%B9%E5%86%B2%E7%AA%81%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E7%A1%AE%E5%AE%9E%E6%83%B3%E4%BD%BF%E7%94%A8%20192.168.0.x%20%E5%AD%90%E7%BD%91%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%B2%A1%E6%9C%89%E5%B0%86%20192.168.0.200%20%E5%90%8C%E6%97%B6%E5%88%86%E9%85%8D%E7%BB%99%20PFE0%20%E5%92%8C%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%BA%A4%E6%8D%A2%E6%9C%BA%E7%9A%84%E5%A4%96%E9%83%A8%E8%AE%BE%E5%A4%87%EF%BC%8C%E9%82%A3%E4%B9%88%E5%BD%93%E6%82%A8%E5%B0%9D%E8%AF%95%E4%BB%8E%E5%A4%96%E9%83%A8%20ping%20PFE0%20%E6%88%96%E5%8F%8D%E4%B9%8B%E4%BA%A6%E7%84%B6%E6%97%B6%EF%BC%8C%E7%BD%91%E7%BB%9C%E8%BF%9E%E6%8E%A5%E5%B0%86%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2391085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2391085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AE192.168.0.200%E6%98%AF%E5%90%A6%E4%BC%9A%E7%9B%91%E5%90%AC%E5%B9%BF%E6%92%AD%E5%91%BC%E5%8F%AB%E4%B9%8B%E7%B1%BB%E7%9A%84%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%86%85%E9%83%A8%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%EF%BC%9F192.168.0.200%20%E6%9C%89%E4%BB%80%E4%B9%88%E5%8A%9F%E8%83%BD%E9%9C%80%E8%A6%81%E5%AE%83%E6%8B%A5%E6%9C%89%E5%AD%90%E7%BD%91%E7%9A%84%E7%8B%AC%E5%AE%B6%E6%8E%A7%E5%88%B6%E6%9D%83%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%8D%AE%E6%88%91%E4%BA%86%E8%A7%A3%EF%BC%8C%E4%B8%8D%E4%BD%BF%E7%94%A8%20192.168.0.200%20%E5%B0%B1%E4%B8%8D%E4%BC%9A%E6%9C%89%E5%86%B2%E7%AA%81%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%8F%AF%E8%83%BD%E7%9A%84%E8%AF%9D%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E5%85%B6%E4%BB%96%E5%AD%90%E7%BD%91%E6%9D%A5%E9%81%BF%E5%85%8D%E5%8F%AF%E8%83%BD%E5%87%BA%E7%8E%B0%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2391371%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2391371%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%A5IP%E5%9C%B0%E5%9D%80%E5%8F%AF%E4%BB%A5%E6%8E%A5%E6%94%B6%E6%9D%A5%E8%87%AA%E8%BF%9E%E6%8E%A5%E8%AE%BE%E5%A4%87%E7%9A%84%E5%B9%BF%E6%92%AD%E6%95%B0%E6%8D%AE%E5%8C%85%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2392451%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2392451%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%99%88%E9%9F%B3%EF%BC%8C%E4%BD%A0%E5%A5%BD%EF%BC%81%3C%2FP%3E%3CP%3E%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E9%97%AE%E9%A2%98%E5%87%BA%E7%8E%B0%E4%BA%86%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%86%20TC387%20%2F%20FreeRTOS%20%E7%9B%AE%E6%A0%87%E8%BF%9E%E6%8E%A5%E5%88%B0%20pfe_mac2%20%E6%97%B6%EF%BC%8CARP%20%E6%8F%A1%E6%89%8B%E5%A4%B1%E8%B4%A5%E3%80%82%E5%AE%83%E5%8F%AF%E4%BB%A5%E4%B8%8E%E6%99%AE%E9%80%9A%E7%9A%84Linux%E6%9C%BA%E5%99%A8%E9%85%8D%E5%90%88%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2392810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2392810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%94%B1%E4%BA%8E%20PFE2%20%E5%8F%AF%E4%BB%A5%E5%9C%A8%20Linux%20%E6%9C%BA%E5%99%A8%E4%B8%8A%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8CS32G%20%E7%AB%AF%E5%8F%AF%E8%83%BD%E6%B2%A1%E6%9C%89%E5%A4%AA%E5%A4%A7%E9%97%AE%E9%A2%98%E3%80%82%E4%B8%BA%E4%BA%86%E8%A7%A3%E5%86%B3%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E6%A3%80%E6%9F%A5%E9%93%BE%E8%B7%AF%E7%8A%B6%E6%80%81%EF%BC%8C%E6%9F%A5%E7%9C%8B%E4%B8%A4%E7%AB%AF%E4%B9%8B%E9%97%B4%E5%8F%91%E9%80%81%E7%9A%84%E6%AF%8F%E4%B8%AA%E5%B8%A7%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BF%9B%E8%A1%8C%E5%88%86%E6%9E%90%E3%80%82%E5%BE%88%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E5%AF%B9%E6%82%A8%E7%9A%84%E8%8B%B1%E9%A3%9E%E5%87%8C%E6%9D%BF%E4%B8%8A%E7%9A%84%E8%BD%AF%E4%BB%B6%E6%A0%88%E4%BA%86%E8%A7%A3%E4%B8%8D%E5%A4%9A%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2392765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2392765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%8F%AA%E5%87%BA%E7%8E%B0%E5%9C%A8pfe2%E7%AB%AF%E5%8F%A3%E4%B8%8A%E3%80%82%E5%B0%86%20TC387%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20pfe0%20%E6%88%96%20gmac0%20%E5%B0%B1%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2392719%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2392719%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%94%B1%E4%BA%8E%E5%90%8C%E6%A0%B7%E7%9A%84%E8%AE%BE%E7%BD%AE%E5%9C%A8%20Linux%20%E6%9C%BA%E5%99%A8%E4%B8%8A%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E5%9B%A0%E6%AD%A4%E9%97%AE%E9%A2%98%E6%9B%B4%E6%9C%89%E5%8F%AF%E8%83%BD%E5%87%BA%E5%9C%A8%20TC387%20%E7%AB%AF%EF%BC%88%E4%BB%A5%E5%A4%AA%E7%BD%91%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%81TCP%2FIP%20%E5%8D%8F%E8%AE%AE%E6%A0%88%E9%85%8D%E7%BD%AE%E6%88%96%E7%9B%B8%E5%85%B3%E5%AE%9E%E7%8E%B0%EF%BC%89%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20MAC%20%E7%AB%AF%E3%80%82%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E8%BF%9B%E4%B8%80%E6%AD%A5%E7%9A%84%E6%95%B0%E6%8D%AE%E5%8C%85%E7%BA%A7%E5%88%86%E6%9E%90%E6%89%8D%E8%83%BD%E7%A1%AE%E8%AE%A4%E7%A1%AE%E5%88%87%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%86%20TC387%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%88%91%E7%9A%84%20Linux%20%E6%A1%8C%E9%9D%A2%E6%97%B6%EF%BC%8C%E7%AB%8B%E5%8D%B3%E4%BA%A7%E7%94%9F%E4%BA%86%E5%A4%A7%E9%87%8F%E7%9A%84%20arp%2Ficmp%20%E6%B6%88%E6%81%AF%E3%80%82%E5%BD%93%E6%88%91%E5%B0%86%20S32G%20pfe2%20%E7%AB%AF%E5%8F%A3%E8%BF%9E%E6%8E%A5%E5%88%B0%20Linux%20%E6%A1%8C%E9%9D%A2%E6%97%B6%EF%BC%8C%E4%B9%9F%E4%BC%9A%E5%87%BA%E7%8E%B0%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%B0%86%20TC387%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20S32G%20pfe2%20%E7%AB%AF%E5%8F%A3%E6%97%B6%EF%BC%8C%E6%88%91%E5%AE%8C%E5%85%A8%E6%94%B6%E4%B8%8D%E5%88%B0%20arp%20%E6%88%96%20icmp%20%E6%B6%88%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%BA%94%E8%AF%A5%E6%9F%A5%E7%9C%8B%E5%93%AA%E4%BA%9B%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%99%88%E9%9F%B3%EF%BC%8C%E4%BD%A0%E5%A5%BD%EF%BC%81%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AE%E6%82%A8%E8%83%BD%E5%90%A6%E5%86%8D%E6%AC%A1%E5%91%8A%E7%9F%A5%E6%88%91%E7%9B%AE%E6%A0%87%E4%B8%BB%E6%9C%BA%20s32g399Ardb3%20%E4%B8%8A%E7%9A%84%20pfe0%20%E5%92%8C%20pfe2%20%E5%88%86%E5%88%AB%E5%AF%B9%E5%BA%94%E5%93%AA%E4%BA%9B%E7%AB%AF%E5%8F%A3%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E5%81%87%E8%AE%BE%20pfe0%20%E6%98%AF%E4%B8%89%E4%B8%AA%E5%A0%86%E5%8F%A0%E7%AB%AF%E5%8F%A3%E4%B8%AD%E5%B7%A6%E4%BE%A7%E7%9A%84%E7%AB%AF%E5%8F%A3%EF%BC%8Cpfe2%20%E6%98%AF%E9%A1%B6%E9%83%A8%E4%B8%AD%E9%97%B4%E7%9A%84%E7%AB%AF%E5%8F%A3%EF%BC%8C%E8%BF%99%E6%A0%B7%E7%90%86%E8%A7%A3%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%B7%B7%E5%90%88%E4%BD%BF%E7%94%A8pfe%E5%92%8Cgmac%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E5%B7%B2%E7%9F%A5%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395256%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395256%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%98%E6%9C%89%E4%B8%80%E4%BB%B6%E4%BA%8B%E3%80%82%E9%9B%86%E6%88%90%E6%89%8B%E5%86%8C%E4%B8%AD%E6%98%AF%E5%90%A6%E6%8E%A8%E8%8D%90%E4%BD%BF%E7%94%A8%E8%BF%99%E6%9D%A1%20uboot%20%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9F%3C%2FP%3E%3CP%3Ehwconfig%20%22serdes0%3Amode%3Dpcie%2Cclock%3Dext%3Bpcie0%3Amode%3Drc%3Bserdes1%3Amode%3Dxpcs0%26amp%3Bxpcs1%2Cclock%3Dext%2Cfmhz%3D125%3Bxpcs1_0%3Aspeed%3D2G5%3Bxpcs1_1%3Aspeed%3D1G%22%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9C%9F%E6%AD%A3%E5%90%AF%E7%94%A8%20gmac0%E3%80%81pfe0%20%E5%92%8C%20pfe2%20%E8%BF%99%E4%B8%89%E4%B8%AA%E6%8E%A5%E5%8F%A3%EF%BC%8C%E8%BF%98%E6%98%AF%E5%8F%AA%E5%90%AF%E7%94%A8%E5%85%B6%E4%B8%AD%E4%B8%A4%E4%B8%AA%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E6%88%91%E5%BB%BA%E8%AE%AE%E5%8F%82%E8%80%83%E4%B8%8B%E5%9B%BE%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392313iB58AFA9F989B7423%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1784081687384.png%22%20alt%3D%22chenyin_h_0-1784081687384.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPFE0%20%E4%B8%8E%20SJA1110%20%E8%BF%9E%E6%8E%A5%EF%BC%8C%E8%BF%9E%E6%8E%A5%E5%88%B0%20P1%2F2%2F3%20%E7%9A%84%E7%94%B5%E7%BC%86%E5%8F%AF%E4%BB%A5%E4%B8%8E%20PFE0%20%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FP%3E%0A%3CP%3EGMAC%E5%8F%AF%E4%BB%A5%E4%B8%8EPFE%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3E%E7%BB%8F%E8%BF%87%E8%BF%9B%E4%B8%80%E6%AD%A5%E7%A0%94%E7%A9%B6%EF%BC%8C%E4%BC%BC%E4%B9%8E%20pfe_mac2%20%E7%89%B9%E5%88%AB%E4%B8%8E%E6%88%91%E4%BB%AC%E7%9A%84%20100T1%20%E4%BB%A5%E5%A4%AA%E7%BD%91%E9%80%82%E9%85%8D%E5%99%A8%E5%AD%98%E5%9C%A8%E5%85%BC%E5%AE%B9%E6%80%A7%E9%97%AE%E9%A2%98%E3%80%82%E4%BD%BF%E7%94%A8%20USB%20%E4%BB%A5%E5%A4%AA%E7%BD%91%E8%BF%9E%E6%8E%A5%20Linux%20%E7%AC%94%E8%AE%B0%E6%9C%AC%E7%94%B5%E8%84%91%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E7%9F%A5%E9%81%93%20pfe_mac2%20%E8%83%BD%E5%90%A6%E6%AD%A3%E7%A1%AE%E8%BF%9E%E6%8E%A5%E5%88%B0%E8%BF%99%E7%A7%8D%E9%80%82%E9%85%8D%E5%99%A8%E7%B1%BB%E5%9E%8B%E5%90%97%EF%BC%9F%E6%88%91%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E4%B8%80%E4%BA%9B%E7%89%B9%E6%AE%8A%E8%AE%BE%E7%BD%AE%E6%89%8D%E8%83%BD%E4%BD%BF%E5%85%B6%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395272%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395272%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%20QNX%20%E4%B8%8A%E8%AE%BE%E7%BD%AE%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%80%9F%E5%BA%A6%EF%BC%8C%E4%BE%8B%E5%A6%82%E4%BD%BF%E7%94%A8%E7%B1%BB%E4%BC%BC%E8%BF%99%E6%A0%B7%E7%9A%84%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Eifconfig%20pfe2%20media%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E100%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3EbaseTX%20mediaopt%20full-duplex%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E8%BF%99%E8%BF%98%E4%B8%8D%E5%A4%9F%E3%80%82%E6%88%91%E8%BF%98%E9%9C%80%E8%A6%81%E5%81%9A%E5%85%B6%E4%BB%96%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%8C%E6%AF%94%E5%A6%82%E5%9C%A8%20uboot%20%E5%8F%82%E6%95%B0%E9%87%8C%E5%81%9A%E4%BA%9B%E8%B0%83%E6%95%B4%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%E5%AF%B9%E4%BA%8E%E6%82%A8%E6%8F%90%E5%88%B0%E7%9A%84%20hwconfig%EF%BC%8C%E5%BD%93%E5%9C%A8%20RDB3%20%E4%B8%8A%E4%BD%BF%E7%94%A8%E6%97%B6%EF%BC%8C%E8%BF%99%203%20%E4%B8%AA%20MAC%20%E5%9C%B0%E5%9D%80%E9%83%BD%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20%E5%AF%B9%E4%BA%8E%E6%82%A8%E5%88%86%E4%BA%AB%E7%9A%84%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%EF%BC%8C%E5%BE%88%E6%8A%B1%E6%AD%89%E6%88%91%E4%BB%AC%E9%80%9A%E5%B8%B8%E4%B8%8D%E7%9B%B4%E6%8E%A5%E6%94%AF%E6%8C%81%20QNX%20%E5%91%BD%E4%BB%A4%E3%80%82%E6%A0%B9%E6%8D%AE%E6%88%91%E7%9A%84%E4%B8%AA%E4%BA%BA%E7%BB%8F%E9%AA%8C%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E6%98%AF%E7%94%B1%E4%BA%8E%E6%89%80%E4%BD%BF%E7%94%A8%E7%9A%84%E5%91%BD%E4%BB%A4%E6%9C%AC%E8%BA%AB%E5%BC%95%E8%B5%B7%E7%9A%84%E3%80%82%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E6%A0%B9%E6%8D%AE%20QNX%20%E6%96%87%E6%A1%A3%E9%87%8D%E6%96%B0%E6%A3%80%E6%9F%A5%E5%91%BD%E4%BB%A4%E7%9A%84%E8%AF%AD%E6%B3%95%E3%80%82%3C%2FP%3E%0A%3CP%3E3.%20%E5%9C%A8%20QNX%20%E4%B8%8B%EF%BC%8CPFE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9C%89%E4%B8%80%E4%BA%9B%E9%99%90%E5%88%B6%EF%BC%8C%E4%B8%8D%E6%94%AF%E6%8C%81%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%82%A8%E5%8F%AF%E4%BB%A5%E7%A1%AE%E4%BF%9D%E5%8F%8C%E6%96%B9%E4%BB%A5%E7%9B%B8%E5%90%8C%E7%9A%84%E9%80%9F%E5%BA%A6%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1784104171784.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784104171784.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784104171784.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784104171784.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392340i9DFDF7D21F4AC640%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1784104171784.png%22%20alt%3D%22chenyin_h_0-1784104171784.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E5%BA%94%E8%AF%A5%E8%83%BD%E5%A4%9F%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%89%E4%B8%AA%E5%A0%86%E5%8F%A0%E7%AB%AF%E5%8F%A3%E4%B8%AD%E7%9A%84%E5%B7%A6%E4%BE%A7%E7%AB%AF%E5%8F%A3%E4%BD%9C%E4%B8%BA%20pfe0%EF%BC%8C%E9%A1%B6%E9%83%A8%E4%B8%AD%E9%97%B4%E7%9A%84%E7%AB%AF%E5%8F%A3%E4%BD%9C%E4%B8%BA%20pfe2%E3%80%82gmac0%20%E7%9A%84%E5%BA%95%E9%83%A8%E4%B8%AD%E5%BF%83%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%20io%20pkt%20%E8%AF%AD%E6%B3%95%E4%BB%A5%E6%A1%A5%E6%8E%A5%E6%A8%A1%E5%BC%8F%E5%90%AF%E5%8A%A8%E6%8E%A5%E5%8F%A3%EF%BC%88%E6%B3%A8%E6%84%8F%20tcp%20ip%20%E5%90%8E%E9%9D%A2%E7%9A%84%20bridge%20%E5%8F%82%E6%95%B0%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3Eio-pkt-v6-hc%20-p%20tcpip%20bridge%20pkt_typed_mem%3Dpfe_ddr%20-d%20dwceqos-s32g%20mac%3D%60genmac-random%20-m%60%2Cptp_off%2Cverbose%3D5%20-d%20%2Fproc%2Fboot%2Fdevnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cutil_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_util.fw%3CBR%20%2F%3Eifconfig%20dwc0%20192.168.10.100%20up%3CBR%20%2F%3E%20ifconfig%20pfe0%200.0.0.0%20up%3CBR%20%2F%3E%20ifconfig%20pfe2%200.0.0.0%20up%3CBR%20%2F%3E%20ifconfig%20bridge0%20%E5%88%9B%E5%BB%BA%3CBR%20%2F%3Eifconfig%20bridge0%20add%20dwc0%20add%20pfe0%20add%20pfe2%20up%3C%2FP%3E%3CP%3E%E8%BF%99%E5%B0%86%E5%AF%BC%E8%87%B4%20slog2info%20%E4%B8%AD%E5%87%BA%E7%8E%B0%E5%A4%A7%E9%87%8F%E5%86%85%E5%AD%98%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3EJan%2001%2000%3A04%3A37.485%20io_pkt_v6_hc.159753%20slog%200%20ERR%5Bsrc%2Fpfe_drv.c%3A2996%5D%EF%BC%9A%EF%BC%88%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%89%E4%BA%8B%E4%BB%B6%201%20-%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%BF%90%E8%A1%8C%E6%97%B6%E9%94%99%E8%AF%AF%EF%BC%9AMbuf%20%E5%9C%B0%E5%9D%80%E8%B6%85%E5%87%BA%2032%20%E4%BD%8D%E8%8C%83%E5%9B%B4%E3%80%82%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%EF%BC%9Ap0x8df239b58%20%E7%BB%93%E6%9D%9F%E5%9C%B0%E5%9D%80%EF%BC%9Ap0x8df239b82%3C%2FP%3E%3CP%3EJan%2001%2000%3A04%3A38.485%20io_pkt_v6_hc.159753%20slog%200%20ERR%5Bsrc%2Fpfe_drv.c%3A2996%5D%EF%BC%9A%EF%BC%88%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%89%E4%BA%8B%E4%BB%B6%201%20-%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%BF%90%E8%A1%8C%E6%97%B6%E9%94%99%E8%AF%AF%EF%BC%9AMbuf%20%E5%9C%B0%E5%9D%80%E8%B6%85%E5%87%BA%2032%20%E4%BD%8D%E8%8C%83%E5%9B%B4%E3%80%82%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%EF%BC%9Ap0x8df239558%20%E7%BB%93%E6%9D%9F%E5%9C%B0%E5%9D%80%EF%BC%9Ap0x8df239582%3C%2FP%3E%3CP%3EJan%2001%2000%3A04%3A38.485%20io_pkt_v6_hc.159753%20slog%200%20ERR%5Bsrc%2Fpfe_drv.c%3A2996%5D%EF%BC%9A%EF%BC%88%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%89%E4%BA%8B%E4%BB%B6%201%20-%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%BF%90%E8%A1%8C%E6%97%B6%E9%94%99%E8%AF%AF%EF%BC%9AMbuf%20%E5%9C%B0%E5%9D%80%E8%B6%85%E5%87%BA%2032%20%E4%BD%8D%E8%8C%83%E5%9B%B4%E3%80%82%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%EF%BC%9Ap0x8df239558%20%E7%BB%93%E6%9D%9F%E5%9C%B0%E5%9D%80%EF%BC%9Ap0x8df239582%3C%2FP%3E%3CP%3EJan%2001%2000%3A04%3A39.451%20io_pkt_v6_hc.159753%20slog%200%20ERR%5Bsrc%2Fpfe_drv.c%3A2996%5D%EF%BC%9A%EF%BC%88%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%89%E4%BA%8B%E4%BB%B6%201%20-%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%BF%90%E8%A1%8C%E6%97%B6%E9%94%99%E8%AF%AF%EF%BC%9AMbuf%20%E5%9C%B0%E5%9D%80%E8%B6%85%E5%87%BA%2032%20%E4%BD%8D%E8%8C%83%E5%9B%B4%E3%80%82%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%EF%BC%9Ap0x8df239b58%20%E7%BB%93%E6%9D%9F%E5%9C%B0%E5%9D%80%EF%BC%9Ap0x8df239b82%3C%2FP%3E%3CP%3EJan%2001%2000%3A04%3A39.451%20io_pkt_v6_hc.159753%20slog%200%20ERR%5Bsrc%2Fpfe_drv.c%3A2996%5D%EF%BC%9A%EF%BC%88%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%89%E4%BA%8B%E4%BB%B6%201%20-%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%BF%90%E8%A1%8C%E6%97%B6%E9%94%99%E8%AF%AF%EF%BC%9AMbuf%20%E5%9C%B0%E5%9D%80%E8%B6%85%E5%87%BA%2032%20%E4%BD%8D%E8%8C%83%E5%9B%B4%E3%80%82%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%EF%BC%9Ap0x8df239b58%20%E7%BB%93%E6%9D%9F%E5%9C%B0%E5%9D%80%EF%BC%9Ap0x8df239b82%3C%2FP%3E%3CP%3Eio-pkt-v6-hc%20%E8%B0%83%E7%94%A8%E4%B8%AD%E7%9A%84%E6%A1%A5%E6%8E%A5%E5%8F%82%E6%95%B0%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9B%86%E6%88%90%E6%89%8B%E5%86%8C%E4%B8%AD%E7%9A%84%E8%BF%99%E4%B8%AA%E5%88%86%E9%85%8D%EF%BC%8C%E7%94%A8%E4%BA%8E%20gmac0%20%E5%92%8C%20pfe%EF%BC%8C%E8%BF%99%E5%8F%AF%E4%BB%A5%E4%BB%8E%20io-pkt-v6-hc%20%E8%B0%83%E7%94%A8%E4%B8%AD%E7%9C%8B%E5%88%B0%E3%80%82%E8%BF%99%E6%98%AF%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3Ekprintf(%22%E4%B8%BA%20EVB%2FRDB%20%E4%B8%8A%E7%9A%84%20PFE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BF%9D%E7%95%99%20RAM%20%E5%8C%BA%E5%9F%9F%5Cn%22)%3B%3CBR%20%2F%3E%20as_add_containing(0x80000000%2C0x80000000%20%2B%200x4000000%20-%201%2CAS_ATTR_RAM%2C%20%22pfe_ddr%22%2C%22ram%22)%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%E6%88%91%E5%8F%AF%E4%BB%A5%E7%A1%AE%E8%AE%A4%EF%BC%8C%E5%9C%A8%20NXP%20%E9%85%8D%E7%BD%AE%E7%9A%84%20Linux%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E3%80%82%E4%B8%8B%EF%BC%8CRDB3%20%E4%B8%8A%E7%9A%84%20PFE2%20%E7%AB%AF%E5%8F%A3%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20100base-TX%26lt%3B-%26gt%3B100base-T1%20%E5%8F%98%E6%B5%81%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%20100T1%20%E7%BD%91%E7%BB%9C%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%9A%20%3CSPAN%20class%3D%22fontstyle0%22%3Eio-pkt-v6-hc%20-p%20tcpip%20-d%20pfe2_link%3D100-1-2%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%BD%86%E6%88%91%E4%B8%8D%E5%A4%AA%E7%A1%AE%E5%AE%9A%E8%BF%99%E4%BA%9B%E8%AE%BE%E7%BD%AE%E6%98%AF%E5%90%A6%E9%80%82%E7%94%A8%E4%BA%8E%20QNX%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E8%B6%85%E5%87%BA%E4%BA%86%E6%88%91%E4%BB%AC%20S32G%20%E7%A4%BE%E5%8C%BA%E7%9A%84%E6%94%AF%E6%8C%81%E8%8C%83%E5%9B%B4%EF%BC%8C%E7%BB%99%E6%82%A8%E5%B8%A6%E6%9D%A5%E7%9A%84%E4%B8%8D%E4%BE%BF%E6%95%AC%E8%AF%B7%E8%B0%85%E8%A7%A3%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EBR%3C%2FP%3E%0A%3CP%3E%E9%99%88%E9%93%B6%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
