S32G3 bootconfig through serial EEPROM
4,434 次查看
piaochunri
Hi experts,
About S32G3 bootconfig through serial EEPROM how can I obtain current bootconfigwords and fix it. Thank you!
4,374 次查看
alejandro_e
Hello @piaochunri,
To be able to boot from SerialRCON I recommend you check AN13456 [page 6, S32G3 Boot Process, Rev. 1, 02/2023]
You can also get more information in the S32G3 reference manual [page 1319, S32G3 Reference Manual, Rev. 4, 02/202]:
This means the 32bits used as boot configurations need to be already present in the EEPROM.
If it's possible I can recommend using EEPROM AT24C01C-XPD-T, which is used in the EVB3-Board which supports S32G3 chips.
Let me know if this information solved your question
8 回复数
4,413 次查看
alejandro_e
Hello @piaochunri ,
I’m assuming you are using the RDB3 board. Then the 32 bits (0 – 31) you see in the excel file represent the 4 dip switches present in your board:
You can check the schematic to see the order of the bytes [page 32, S32G-VNP-RDB3, SPF-53060.pdf] available in deseing files section of the S32G-VNP-RDB3 product page:
You can check the User Guide to learn more about the different switch configurations [Starting in page 3, Chapter 3, S32G-VNP-RDB3 Switch Setting, S32G-VNP-RDB3 User Guide, Rev. 1.0, 03/2023] available in de documentation section of the S32G-VNP-RDB3 product page:
Let me know if this information solved your question.
4,409 次查看
piaochunri
We are debugging a self-developed board with S32G399A. And our board only supports bootconfig through serial RCON not through parallel RCON. I want to known how can I set it.I have tried some commands during u-boot step.But I am not sure it is useful.
4,375 次查看
alejandro_e
Hello @piaochunri,
4,341 次查看
piaochunri
Yes.We are debugging a self-developed board of S32G399A.The scheme of boot mode part is referred to S32-VNP-RDB3. I was debugging Acore and the version of bsp is 40.0.And I followed the link HOWTO: Program Serial RCON using S32 Debug Probe S32G2xx - NXP Community t o debug it.
But when I runned the python script it could not pass the initialization whether I inserted the SD card or not.The result seems the same. What should I do?Thank you!
4,321 次查看
piaochunri
I have sovled the problem after I set the host name of s32g debug probe and I can config the EEPROM now. Thank you!
4,299 次查看
alejandro_e
I'm glad to know you were able to solve the problem! Thanks for marking the answer as accepted.
4,245 次查看
piaochunri
Thank you!Yes,I have read these documents.We are debugging a self-developed board of S32G399A. The designed scheme of boot mode is referred S32G-VNP-RDB3(RCON12 and RCON13).I also referred the link HOWTO: Program Serial RCON using S32 Debug Probe S32G2xx - NXP Community to debug the EEPROM.But it stopped during initialization.My A core bsp  version is 40.0.
I used S32 debug probe.Is it necessary to connect the debugger to my laptop through ethernet or USB connection is ok?The info of probe is as follows. And I runned the python script.It resulted in error.What should I do?Thank you!
4,168 次查看
alejandro_e
Hello @piaochunri,
Sorry for the late response, once you select a correct answer the topic is marked as closed and I stop receiving notifications. Please create a new post with your new problem as it is not completely related to the original post so one of my teammates or myself can help you.
Sorry again for the late response
%3CLINGO-SUB%20id%3D%22lingo-sub-1962626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%80%9A%E8%BF%87%E4%B8%B2%E8%A1%8CEEPROM%E8%BF%9B%E8%A1%8CS32G3%20bootconfig%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1962626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E4%B8%93%E5%AE%B6%E4%BB%AC%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%E9%80%9A%E8%BF%87%E4%B8%B2%E8%A1%8CEEPROM%E7%9A%84S32G3%20bootconfig%EF%BC%8C%E6%88%91%E5%A6%82%E4%BD%95%E8%8E%B7%E5%8F%96%E5%BD%93%E5%89%8D%E7%9A%84bootconfigwords%E5%B9%B6%E4%BF%AE%E5%A4%8D%E5%AE%83%E3%80%82%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%81%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22piaochunri_0-1727347815753.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22piaochunri_0-1727347815753.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301450i6772386A669FFA59%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22piaochunri_0-1727347815753.png%22%20alt%3D%22piaochunri_0-1727347815753.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1974556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%B2%E8%A1%8CEEPROM%E8%BF%9B%E8%A1%8CS32G3%20bootconfig%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1974556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F234458%22%20target%3D%22_blank%22%3E%40piaochunri%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3E%E6%8A%B1%E6%AD%89%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%EF%BC%8C%E4%B8%80%E6%97%A6%E6%82%A8%E9%80%89%E6%8B%A9%E4%BA%86%E6%AD%A3%E7%A1%AE%E7%9A%84%E7%AD%94%E6%A1%88%EF%BC%8C%E8%AF%A5%E4%B8%BB%E9%A2%98%E5%B0%B1%E4%BC%9A%E8%A2%AB%E6%A0%87%E8%AE%B0%E4%B8%BA%E5%85%B3%E9%97%AD%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%88%91%E5%B0%86%E4%B8%8D%E5%86%8D%E6%94%B6%E5%88%B0%E9%80%9A%E7%9F%A5%E3%80%82%E8%AF%B7%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%8C%85%E5%90%AB%E6%96%B0%E9%97%AE%E9%A2%98%E7%9A%84%E6%96%B0%E5%B8%96%E5%AD%90%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%B8%8E%E5%8E%9F%E5%A7%8B%E5%B8%96%E5%AD%90%E4%B8%8D%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%85%B3%EF%BC%8C%E8%BF%99%E6%A0%B7%E6%88%91%E7%9A%84%E4%B8%80%E4%BD%8D%E9%98%9F%E5%8F%8B%E6%88%96%E6%88%91%E8%87%AA%E5%B7%B1%E5%B0%B1%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%8A%A9%E6%82%A8%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%86%8D%E6%AC%A1%E6%8A%B1%E6%AD%89%E5%9B%9E%E5%A4%8D%E8%BF%9F%E4%BA%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1964631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%B2%E8%A1%8CEEPROM%E8%BF%9B%E8%A1%8CS32G3%20bootconfig%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1964631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%BE%88%E9%AB%98%E5%85%B4%E7%9F%A5%E9%81%93%E4%BD%A0%E8%83%BD%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%81%E6%84%9F%E8%B0%A2%E6%82%A8%E5%B0%86%E7%AD%94%E6%A1%88%E6%A0%87%E8%AE%B0%E4%B8%BA%E5%B7%B2%E6%8E%A5%E5%8F%97%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1964229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%B2%E8%A1%8CEEPROM%E8%BF%9B%E8%A1%8CS32G3%20bootconfig%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1964229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AE%BE%E7%BD%AE%20s32g%20%E8%B0%83%E8%AF%95%E6%8E%A2%E6%B5%8B%E5%99%A8%E7%9A%84%E4%B8%BB%E6%9C%BA%E5%90%8D%E5%90%8E%EF%BC%8C%E6%88%91%E8%A7%A3%E5%86%B3%E4%BA%86%E8%AF%A5%E9%97%AE%E9%A2%98%EF%BC%8C%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E9%85%8D%E7%BD%AE%20EEPROM%E3%80%82%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1963958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%B2%E8%A1%8CEEPROM%E8%BF%9B%E8%A1%8CS32G3%20bootconfig%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1963958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E8%B0%83%E8%AF%95%E4%B8%80%E5%9D%97S32G399A%E7%9A%84%E8%87%AA%E7%A0%94%E6%9D%BF%EF%BC%8C%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%E9%83%A8%E5%88%86%E7%9A%84%E6%96%B9%E6%A1%88%E5%8F%82%E8%80%83S32-VNP-RDB3%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E8%B0%83%E8%AF%95%20Acore%EF%BC%8Cbsp%20%E7%9A%84%E7%89%88%E6%9C%AC%E6%98%AF%2040.0%E3%80%82%E6%88%91%E6%8C%89%E7%85%A7%E9%93%BE%E6%8E%A5%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FHOWTO-Program-Serial-RCON-using-S32-Debug-Probe-S32G2xx%2Fta-p%2F1129496%22%20target%3D%22_blank%22%3EHOWTO%EF%BC%9A%E4%BD%BF%E7%94%A8%20S32%20%E8%B0%83%E8%AF%95%E6%8E%A2%E9%92%88%20S32G2xx%20-%20NXP%20%E7%A4%BE%E5%8C%BA%E5%AF%B9%E4%B8%B2%E8%A1%8C%20RCON%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%3C%2FA%3E%E6%9D%A5%E8%B0%83%E8%AF%95%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22piaochunri_0-1727594889200.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22piaochunri_0-1727594889200.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301815i46EF979545B1A1BA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22piaochunri_0-1727594889200.png%22%20alt%3D%22piaochunri_0-1727594889200.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E8%BF%90%E8%A1%8Cpython%E8%84%9A%E6%9C%AC%E6%97%B6%EF%BC%8C%E6%97%A0%E8%AE%BA%E6%88%91%E6%98%AF%E5%90%A6%E6%8F%92%E5%85%A5SD%E5%8D%A1%EF%BC%8C%E5%AE%83%E9%83%BD%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%E7%BB%93%E6%9E%9C%E4%BC%BC%E4%B9%8E%E7%9B%B8%E5%90%8C%E3%80%82%E6%88%91%E8%AF%A5%E6%80%8E%E4%B9%88%E5%8A%9E%EF%BC%9F%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22piaochunri_1-1727595008056.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22piaochunri_1-1727595008056.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301816iF4CBF33151962666%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22piaochunri_1-1727595008056.png%22%20alt%3D%22piaochunri_1-1727595008056.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22piaochunri_2-1727595017128.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22piaochunri_2-1727595017128.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301817iB4E0C744378CC3FB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22piaochunri_2-1727595017128.png%22%20alt%3D%22piaochunri_2-1727595017128.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22piaochunri_3-1727595030200.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22piaochunri_3-1727595030200.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301818i06D8E13517AEA2AD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22piaochunri_3-1727595030200.png%22%20alt%3D%22piaochunri_3-1727595030200.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22piaochunri_4-1727595040068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22piaochunri_4-1727595040068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301819i7410C109D1BD161D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22piaochunri_4-1727595040068.png%22%20alt%3D%22piaochunri_4-1727595040068.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1963918%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%B2%E8%A1%8CEEPROM%E8%BF%9B%E8%A1%8CS32G3%20bootconfig%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1963918%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E9%98%85%E8%AF%BB%E4%BA%86%E8%BF%99%E4%BA%9B%E6%96%87%E6%A1%A3%E3%80%82%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E8%B0%83%E8%AF%95%E4%B8%80%E5%9D%97%E8%87%AA%E4%B8%BB%E5%BC%80%E5%8F%91%E7%9A%84S32G399A%E6%9D%BF%E3%80%82%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%E7%9A%84%E8%AE%BE%E8%AE%A1%E6%96%B9%E6%A1%88%E5%8F%82%E8%80%83%E4%BA%86S32G-VNP-RDB3%EF%BC%88RCON12%E5%92%8CRCON13%EF%BC%89%E3%80%82%E6%88%91%E8%BF%98%E5%8F%82%E8%80%83%E4%BA%86%E9%93%BE%E6%8E%A5%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FHOWTO-Program-Serial-RCON-using-S32-Debug-Probe-S32G2xx%2Fta-p%2F1129496%22%20target%3D%22_blank%22%3EHOWTO%EF%BC%9A%E4%BD%BF%E7%94%A8S32%E8%B0%83%E8%AF%95%E6%8E%A2%E9%92%88S32G2xx%20-%20NXP%E7%A4%BE%E5%8C%BA%E5%AF%B9%E4%B8%B2%E8%A1%8CRCON%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%3C%2FA%3E%E6%9D%A5%E8%B0%83%E8%AF%95EEPROM%E3%80%82%E4%BD%86%E5%AE%83%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E6%9C%9F%E9%97%B4%E5%81%9C%E6%AD%A2%E4%BA%86%E3%80%82%E6%88%91%E7%9A%84A%E6%A0%B8bsp%E7%89%88%E6%9C%AC%E6%98%AF40.0%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22piaochunri_0-1727588203882.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22piaochunri_0-1727588203882.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301805i18281CC5E91FCE79%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22piaochunri_0-1727588203882.png%22%20alt%3D%22piaochunri_0-1727588203882.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%20S32%20%E8%B0%83%E8%AF%95%E6%8E%A2%E9%92%88%E3%80%82%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E9%80%9A%E8%BF%87%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%88%96%20USB%20%E8%BF%9E%E6%8E%A5%E5%B0%86%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%88%91%E7%9A%84%E7%AC%94%E8%AE%B0%E6%9C%AC%E7%94%B5%E8%84%91%EF%BC%9F%E6%8E%A2%E9%92%88%E7%9A%84%E4%BF%A1%E6%81%AF%E5%A6%82%E4%B8%8B%E3%80%82%E6%88%91%E8%BF%90%E8%A1%8C%E4%BA%86%20python%20%E8%84%9A%E6%9C%AC%E3%80%82%E7%BB%93%E6%9E%9C%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%E8%AF%A5%E6%80%8E%E4%B9%88%E5%8A%9E%EF%BC%9F%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22piaochunri_1-1727589505515.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22piaochunri_1-1727589505515.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301807i176BE776B346CB0D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22piaochunri_1-1727589505515.png%22%20alt%3D%22piaochunri_1-1727589505515.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22piaochunri_4-1727589704942.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22piaochunri_4-1727589704942.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301810i14A2CED39D3B343C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22piaochunri_4-1727589704942.png%22%20alt%3D%22piaochunri_4-1727589704942.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22piaochunri_2-1727589600147.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22piaochunri_2-1727589600147.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301808iF64CE50ABCB250D2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22piaochunri_2-1727589600147.png%22%20alt%3D%22piaochunri_2-1727589600147.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22piaochunri_5-1727589756099.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22piaochunri_5-1727589756099.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301811i74378CE6465AA19C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22piaochunri_5-1727589756099.png%22%20alt%3D%22piaochunri_5-1727589756099.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1963778%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%B2%E8%A1%8CEEPROM%E8%BF%9B%E8%A1%8CS32G3%20bootconfig%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1963778%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F234458%22%20target%3D%22_blank%22%3E%40piaochunri%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3E%E4%B8%BA%E4%BA%86%E8%83%BD%E5%A4%9F%E4%BB%8E%20SerialRCON%20%E5%90%AF%E5%8A%A8%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E6%9F%A5%E7%9C%8B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13456.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN13456%3C%2FA%3E%20%5B%E7%AC%AC%206%20%E9%A1%B5%EF%BC%8CS32G3%20%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%EF%BC%8C%E4%BF%AE%E8%AE%A2%E7%89%88%201%EF%BC%8C2023%20%E5%B9%B4%202%20%E6%9C%88%5D%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_4-1727475717188.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_4-1727475717188.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301779i582DF7065407FE87%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_4-1727475717188.png%22%20alt%3D%22alejandro_e_4-1727475717188.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E5%9C%A8%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DRMS32G3%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32G3%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%3C%2FA%3E%5B%E7%AC%AC%201319%20%E9%A1%B5%EF%BC%8CS32G3%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%EF%BC%8C%E4%BF%AE%E8%AE%A2%E7%89%88%204%EF%BC%8C02%2F202%5D%E4%B8%AD%E8%8E%B7%E5%BE%97%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_1-1727475394939.png%22%20style%3D%22width%3A%20472px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_1-1727475394939.png%22%20style%3D%22width%3A%20472px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301776iFCFAD873BC461B40%2Fimage-dimensions%2F472x329%3Fv%3Dv2%22%20width%3D%22472%22%20height%3D%22329%22%20role%3D%22button%22%20title%3D%22alejandro_e_1-1727475394939.png%22%20alt%3D%22alejandro_e_1-1727475394939.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E7%94%A8%E4%BD%9C%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%2032%20%E4%BD%8D%E9%9C%80%E8%A6%81%E5%B7%B2%E7%BB%8F%E5%AD%98%E5%9C%A8%E4%BA%8E%20EEPROM%20%E4%B8%AD%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E5%8F%AF%E8%83%BD%E7%9A%84%E8%AF%9D%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%20EEPROM%20%3CSTRONG%3EAT24C01C-XPD-T%3C%2FSTRONG%3E%20%EF%BC%8C%E5%AE%83%E7%94%A8%E4%BA%8E%E6%94%AF%E6%8C%81%20S32G3%20%E8%8A%AF%E7%89%87%E7%9A%84%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2Fautomotive-development-platforms%2Fs32g-auto-hardware-platforms%2Fs32g-vehicle-network-processing-evaluation-board-3%3AS32G-VNP-EVB3%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EEVB3-Board%3C%2FA%3E%20%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_2-1727475510102.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_2-1727475510102.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301777iFC44AF0DBD898A39%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_2-1727475510102.png%22%20alt%3D%22alejandro_e_2-1727475510102.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E6%98%AF%E5%90%A6%E8%A7%A3%E5%86%B3%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1963045%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%B2%E8%A1%8CEEPROM%E8%BF%9B%E8%A1%8CS32G3%20bootconfig%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1963045%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E8%B0%83%E8%AF%95%E4%B8%80%E5%9D%97%E5%B8%A6%E6%9C%89S32G399A%E7%9A%84%E8%87%AA%E7%A0%94%E6%9D%BF%E3%80%82%E8%80%8C%E4%B8%94%E6%88%91%E4%BB%AC%E7%9A%84%E4%B8%BB%E6%9D%BF%E4%BB%85%E6%94%AF%E6%8C%81%E9%80%9A%E8%BF%87%3CSPAN%3E%E4%B8%B2%E8%A1%8C%20RCON%20%E8%BF%9B%E8%A1%8C%20bootconfig%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%94%AF%E6%8C%81%E9%80%9A%E8%BF%87%E5%B9%B6%E8%A1%8C%20RCON%20%E8%BF%9B%E8%A1%8C%20bootconfig%E3%80%82%3C%2FSPAN%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E8%AE%BE%E7%BD%AE%E5%AE%83%E3%80%82%E6%88%91%E5%9C%A8%20u-boot%20%E6%AD%A5%E9%AA%A4%E4%B8%AD%E5%B0%9D%E8%AF%95%E4%BA%86%E4%B8%80%E4%BA%9B%E5%91%BD%E4%BB%A4%E3%80%82%E4%BD%86%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E5%AE%83%E6%98%AF%E5%90%A6%E6%9C%89%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22piaochunri_0-1727397982339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22piaochunri_0-1727397982339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301567i6CC263391967466E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22piaochunri_0-1727397982339.png%22%20alt%3D%22piaochunri_0-1727397982339.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22piaochunri_1-1727398020927.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22piaochunri_1-1727398020927.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301568iD5883DB9523A49F5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22piaochunri_1-1727398020927.png%22%20alt%3D%22piaochunri_1-1727398020927.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1963005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%B2%E8%A1%8CEEPROM%E8%BF%9B%E8%A1%8CS32G3%20bootconfig%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1963005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F234458%22%20target%3D%22_blank%22%3E%40piaochunri%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%81%87%E8%AE%BE%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20RDB3%20%E6%9D%BF%E3%80%82%E7%84%B6%E5%90%8E%EF%BC%8C%E6%82%A8%E5%9C%A8%20excel%20%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9C%8B%E5%88%B0%E7%9A%84%2032%20%E4%BD%8D%EF%BC%880%20%E2%80%93%2031%EF%BC%89%E4%BB%A3%E8%A1%A8%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%AD%E5%AD%98%E5%9C%A8%E7%9A%84%3CSTRONG%3E4%20%E4%B8%AA%20dip%20%E5%BC%80%E5%85%B3%3C%2FSTRONG%3E%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_0-1727390519595.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1727390519595.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301548i25C0B08AEEF63DEE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_0-1727390519595.jpeg%22%20alt%3D%22alejandro_e_0-1727390519595.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%9F%A5%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DS32G-VNP-RDB3-DESIGN-FILES%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E7%A4%BA%E6%84%8F%E5%9B%BE%3C%2FA%3E%E6%9D%A5%E6%9F%A5%E7%9C%8B%E5%AD%97%E8%8A%82%E7%9A%84%E9%A1%BA%E5%BA%8F%5B%E7%AC%AC32%E9%A1%B5%EF%BC%8CS32G-VNP-RDB3%EF%BC%8CSPF-53060.pdf%5D%E5%8F%AF%E5%9C%A8%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2Fs32g3-vehicle-networking-reference-design%3AS32G-VNP-RDB3%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32G-VNP-RDB3%3C%2FA%3E%E4%BA%A7%E5%93%81%E9%A1%B5%E9%9D%A2%E7%9A%84%E8%AE%BE%E8%AE%A1%E6%96%87%E4%BB%B6%E9%83%A8%E5%88%86%E6%89%BE%E5%88%B0%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_8-1727390728840.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_8-1727390728840.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301554i855F3D470EBEEA98%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_8-1727390728840.png%22%20alt%3D%22alejandro_e_8-1727390728840.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%9F%A5%E7%9C%8B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUGS32G-VNP-RDB3%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FA%3E%EF%BC%8C%E4%BA%86%E8%A7%A3%E6%9C%89%E5%85%B3%E4%B8%8D%E5%90%8C%E4%BA%A4%E6%8D%A2%E6%9C%BA%E9%85%8D%E7%BD%AE%E7%9A%84%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%5B%E4%BB%8E%E7%AC%AC%203%20%E9%A1%B5%E7%AC%AC%203%20%E7%AB%A0%20S32G-VNP-RDB3%20%E4%BA%A4%E6%8D%A2%E6%9C%BA%E8%AE%BE%E7%BD%AE%E5%BC%80%E5%A7%8B%EF%BC%8CS32G-VNP-RDB3%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%EF%BC%8C%E4%BF%AE%E8%AE%A2%E7%89%88%201.0%EF%BC%8C03%2F2023%5D%EF%BC%8C%E5%8F%AF%E5%9C%A8%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2Fs32g3-vehicle-networking-reference-design%3AS32G-VNP-RDB3%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32G-VNP-RDB3%3C%2FA%3E%E4%BA%A7%E5%93%81%E9%A1%B5%E9%9D%A2%E7%9A%84%E6%96%87%E6%A1%A3%E9%83%A8%E5%88%86%E4%B8%AD%E6%89%BE%E5%88%B0%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_2-1727390519797.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_2-1727390519797.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301547i7A1109FA3C8CBB11%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_2-1727390519797.png%22%20alt%3D%22alejandro_e_2-1727390519797.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_3-1727390519958.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_3-1727390519958.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301549iD825B4FA554E765A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_3-1727390519958.png%22%20alt%3D%22alejandro_e_3-1727390519958.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_4-1727390520109.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_4-1727390520109.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301551iEC66E32FDA18B24C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_4-1727390520109.png%22%20alt%3D%22alejandro_e_4-1727390520109.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_5-1727390520248.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_5-1727390520248.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301550iBCB1DC07E45F0D0C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_5-1727390520248.png%22%20alt%3D%22alejandro_e_5-1727390520248.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_6-1727390520393.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_6-1727390520393.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301552i5294A4A42E4B47F7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_6-1727390520393.png%22%20alt%3D%22alejandro_e_6-1727390520393.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_7-1727390520506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_7-1727390520506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301553iE7956F8D211C4217%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_7-1727390520506.png%22%20alt%3D%22alejandro_e_7-1727390520506.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E6%98%AF%E5%90%A6%E8%A7%A3%E5%86%B3%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
