S32G-VNP-RDB3 IPCF communication Error
2,613件の閲覧回数
Kulkarni_v
I am working on Goldbox S32G-VNP-RDB3
I am using Linux BSP 40 downloaded from the software center
and using the following version of IPCF, RTD and FreeRTOS
NXP RTD 4.0.2_P04 D2312
NXP RTOS 0.4.0 D2309
FreeRTOS 4.0.2 D2306
NXP Linux BSP40 D2403
And used the following commands
# 1. Disable data cache
=> dcache off
# 2. Clear IPCF shared memory
=> mw.q 0x34100000 0x0 0x40000
# 3. Load M7 binary from SD card into temporary DDR
=> fatload mmc 0:1 0x80000000 IPCF_FreeRTOS_S32G399A_M7_0.bin
# 4. Copy firmware to M7 SRAM
=> cp.b 0x80000000 0x34300000 0x300000
# 5. Start M7 core at vector address
=> startm7 0x34500400
# 6. Boot Linux normally (if not already)
=> boot
# 1. Mount boot partition (optional, verify M7 binary)
mkdir -p /mnt/s32g_boot
mount /dev/mmcblk0p1 /mnt/s32g_boot
ls /mnt/s32g_boot
# Should see: IPCF_FreeRTOS_S32G399A_M7_0_1_2.bin
# 2. Load IPCF Linux kernel modules
insmod /lib/modules/$(uname -r)/extra/ipc-shm-dev.ko
insmod /lib/modules/$(uname -r)/extra/ipc-shm-sample.ko
# 3. Verify modules
lsmod | grep ipc
# 4. Clear previous ping (optional)
echo 0 > /sys/kernel/ipc-shm-sample/ping
# 5. Test IPCF communication (channel 0)
echo 10 > /sys/kernel/ipc-shm-sample/ping
# 6. Monitor kernel messages
dmesg | tail -20 | grep -i ipc
But getting an error of
root@s32g399ardb3:~# dmesg | tail -20 | grep -i ipc
[ 81.689010] ipc-shm-sample: starting demo...
[ 81.689029] ipc-shm-sample: ch 0 >> 19 bytes: SENDING MESSAGES: 0
[ 91.808767] ipc-shm-sample: starting demo...
[ 91.808771] ipc-shm-sample: ch 0 >> 20 bytes: SENDING MESSAGES: 10
[ 91.808778] ipc-shm-sample: send_data_msg(): failed to get buffer for channe2
Please guide which versions of different software and Linux BSP I should use for my board
2,505件の閲覧回数
chenyin_h
Hello, @Kulkarni_v
Thanks for your reply.
From the information you share, you are using 4.10 on M core side, but using default images in BSP40 on A core side.
By default, the IPCF images in BSP40 is not the 4.10 version, so the code on both side does not match.
As a result, the following method may solve your issue:
1. Manually build IPCF 4.10 images on BSP40, and use it to communicate with M core side you had built.
2. Another way is to build IPCF4.9 on your M core side, and then use the default images in BSP40 to communicate.
You may choose either of the methods provided according to your own requirements.
Chenyin
6 返答(返信)
2,557件の閲覧回数
chenyin_h
Hello, @Kulkarni_v
Thanks for your reply,
I feel sorry that still I do not see the IPCF version you used on M core side, the IPCF version may like the following:
Chenyin
2,534件の閲覧回数
Kulkarni_v
@chenyin_h
Yes I am using IPCF version 4.10.10Screenshot 2025-10-10 225736.pngScreenshot 2025-10-10 225736.png
2,506件の閲覧回数
chenyin_h
Hello, @Kulkarni_v
Chenyin
2,410件の閲覧回数
Kulkarni_v
Hello@chenyin_h
    Thank you for your continuous support. I tried with the M-core side build for version 4.9.0, along with the Linux BSP 40 downloaded from the NXP software download, and it worked as expected.
2,584件の閲覧回数
chenyin_h
Hello, @Kulkarni_v
Thanks for your post.
1. Which version IPCF you are using for building the M core binaries?
2. Have you build the IPCF A core side manually or directly using the IPCF modules existed in BSP 40 rootfs?
Chenyin
2,578件の閲覧回数
Kulkarni_v
At M-core side I have used above versions and I am using BSP40 downloaded from software support(https://nxp.flexnetoperations.com/control/frse/download?agree=Accept&element=3993158). I have not built it separately.
%3CLINGO-SUB%20id%3D%22lingo-sub-2181634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G-VNP-RDB3%20IPCF%E9%80%9A%E4%BF%A1%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFGoldbox%20S32G-VNP-RDB3%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%BB%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9FLinux%20BSP%2040%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AEIPCF%E3%80%81RTD%E3%80%81FreeRTOS%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3ENXP%20RTD%204.0.2_P04D2312%3CBR%20%2F%3E%20NXP%20RTOS%200.4.0D2309%3CBR%20%2F%3E%E3%83%95%E3%83%AA%E3%83%BCRTOS%204.0.2D2306%3CBR%20%2F%3E%20NXP%20Linux%20BSP40%20D2403%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%23%201.%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3D%26gt%3B%20dcache%20%E3%82%AA%E3%83%95%3C%2FP%3E%3CP%3E%23%202.%20IPCF%E5%85%B1%E6%9C%89%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3D%26gt%3B%20mw.q%200x34100000%200x0%200x40000%3C%2FP%3E%3CP%3E%23%203.%20SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89M7%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E4%B8%80%E6%99%82DDR%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%83%83%E3%83%88%E3%83%AD%E3%83%BC%E3%83%89%20mmc%200%3A1%200x80000000%20IPCF_FreeRTOS_S32G399A_M7_0.bin%3C%2FP%3E%3CP%3E%23%204.%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92M7%20SRAM%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3D%26gt%3B%20cp.b%200x80000000%200x34300000%200x300000%3C%2FP%3E%3CP%3E%23%205.%20M7%E3%82%B3%E3%82%A2%E3%82%92%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A7%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3D%26gt%3B%20%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88m7%200x34500400%3C%2FP%3E%3CP%3E%23%206.%20Linux%E3%82%92%E9%80%9A%E5%B8%B8%E9%80%9A%E3%82%8A%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%EF%BC%88%E3%81%BE%E3%81%A0%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%EF%BC%89%3CBR%20%2F%3E%20%3D%26gt%3B%20%E3%83%96%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3E%23%201.%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%99%E3%82%8B%EF%BC%88%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%81M7%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E6%A4%9C%E8%A8%BC%EF%BC%89%3CBR%20%2F%3E%20mkdir%20-p%20%2Fmnt%2Fs32g_boot%3CBR%20%2F%3E%20%2Fdev%2Fmmcblk0p1%20%2Fmnt%2Fs32g_boot%20%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20ls%20%2Fmnt%2Fs32g_boot%3CBR%20%2F%3E%20%23%20%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E5%86%85%E5%AE%B9%3A%20IPCF_FreeRTOS_S32G399A_M7_0_1_2.bin%3C%2FP%3E%3CP%3E%23%202.%20IPCF%20Linux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%3CBR%20%2F%3Einsmod%20%2Flib%2Fmodules%2F%24(uname%20-r)%2Fextra%2Fipc-shm-dev.ko%3CBR%20%2F%3Einsmod%20%2Flib%2Fmodules%2F%24(uname%20-r)%2Fextra%2Fipc-shm-sample.ko%3C%2FP%3E%3CP%3E%23%203.%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%3CBR%20%2F%3Elsmod%20%7C%20grep%20ipc%3C%2FP%3E%3CP%3E%23%204.%20%E4%BB%A5%E5%89%8D%E3%81%AEping%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%EF%BC%88%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%89%3CBR%20%2F%3E%E3%82%A8%E3%82%B3%E3%83%BC%200%20%26gt%3B%20%2Fsys%2Fkernel%2Fipc-shm-sample%2Fping%3C%2FP%3E%3CP%3E%23%205.%20IPCF%E9%80%9A%E4%BF%A1%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%EF%BC%88%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB0%EF%BC%89%3CBR%20%2F%3E%E3%82%A8%E3%82%B3%E3%83%BC%2010%20%26gt%3B%20%2Fsys%2Fkernel%2Fipc-shm-sample%2Fping%3C%2FP%3E%3CP%3E%23%206.%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E7%9B%A3%E8%A6%96%E3%81%99%E3%82%8B%3CBR%20%2F%3Edmesg%20%7C%20tail%20-20%20%7C%20grep%20-i%20ipc%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%3CBR%20%2F%3Eroot%40s32g399ardb3%3A~%23%20dmesg%20%7C%20tail%20-20%20%7C%20grep%20-i%20ipc%3CBR%20%2F%3E%20%5B%2081.689010%5D%20ipc-shm-sample%3A%20%E3%83%87%E3%83%A2%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20%5B%2081.689029%5D%20ipc-shm-sample%3A%20ch%200%20%26gt%3B%26gt%3B%2019%20%E3%83%90%E3%82%A4%E3%83%88%3A%20%E9%80%81%E4%BF%A1%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%3A%200%3CBR%20%2F%3E%20%5B%2091.808767%5D%20ipc-shm-sample%3A%20%E3%83%87%E3%83%A2%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20%5B%2091.808771%5D%20ipc-shm-sample%3A%20ch%200%20%26gt%3B%26gt%3B%2020%20%E3%83%90%E3%82%A4%E3%83%88%3A%20%E9%80%81%E4%BF%A1%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%3A%2010%3CBR%20%2F%3E%20%5B%2091.808778%5D%20ipc-shm-sample%3A%20send_data_msg()%3A%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB2%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E5%8F%96%E5%BE%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%20Linux%20BSP%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24163%22%20target%3D%22_blank%22%3E%40chenyin_h%3C%2FA%3E%3CBR%20%2F%3E%E4%BB%8A%E5%BE%8C%E3%81%A8%E3%82%82%E5%A4%89%E3%82%8F%E3%82%89%E3%81%AC%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%B3%9C%E3%82%8A%E3%81%BE%E3%81%99%E3%82%88%E3%81%86%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%204.9.0%20%E3%81%AE%20M-core%20%E5%81%B4%E3%83%93%E3%83%AB%E3%83%89%E3%81%A8%E3%80%81NXP%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%20Linux%20BSP%2040%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255175%22%20target%3D%22_blank%22%3E%40Kulkarni_v%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E6%83%85%E5%A0%B1%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81M%20%E3%82%B3%E3%82%A2%E5%81%B4%E3%81%A7%E3%81%AF%204.10%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81A%20%E3%82%B3%E3%82%A2%E5%81%B4%E3%81%A7%E3%81%AF%20BSP40%20%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81BSP40%20%E3%81%AE%20IPCF%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%204.10%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84SO%E3%80%81%E4%B8%A1%E5%81%B4%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%81%E6%AC%A1%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%20BSP40%20%E4%B8%8A%E3%81%A7%20IPCF%204.10%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%9F%20M%20%E3%82%B3%E3%82%A2%E5%81%B4%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20%E5%88%A5%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81M%20%E3%82%B3%E3%82%A2%E5%81%B4%E3%81%A7%20IPCF4.9%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81BSP40%20%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E9%80%9A%E4%BF%A1%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%87%AA%E8%BA%AB%E3%81%AE%E8%A6%81%E4%BB%B6%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%80%81%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24163%22%20target%3D%22_blank%22%3E%40chenyin_h%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81IPCF%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.10.10%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22Screenshot%202025-10-10%20225736.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-10-10%20225736.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360294iF14B5049551A4BD4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-10-10%20225736.png%22%20alt%3D%22Screenshot%202025-10-10%20225736.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%202025-10-10%20225736.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255175%22%20target%3D%22_blank%22%3E%40Kulkarni_v%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81M%20%E3%82%B3%E3%82%A2%E5%81%B4%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20IPCF%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%BE%E3%81%A0%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82IPCF%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1760065816841.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1760065816841.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360167i214C39A320FE5A9E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1760065816841.png%22%20alt%3D%22chenyin_h_0-1760065816841.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Echenyin_h_0-1760065816841.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22Screenshot%202025-09-30%20125831.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-09-30%20125831.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359997i7E53B5D795A8F57B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-09-30%20125831.png%22%20alt%3D%22Screenshot%202025-09-30%20125831.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%202025-09-30%20125831.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EM-core%20%E5%81%B4%E3%81%A7%E3%81%AF%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20(%20%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D3993158%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D3993158%3C%2FA%3E%20)%20%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%20BSP40%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%88%A5%E9%80%94%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22shared%20image%20(1).jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(1).jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360000i9B189E9EEAAC822E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22shared%20image%20(1).jpg%22%20alt%3D%22shared%20image%20(1).jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eshared%20image%20(1).jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22shared%20image.jpg%22%20style%3D%22width%3A%20800px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image.jpg%22%20style%3D%22width%3A%20800px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359999i7F7C9D995FD25A5A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22shared%20image.jpg%22%20alt%3D%22shared%20image.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eshared%20image.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255175%22%20target%3D%22_blank%22%3E%40Kulkarni_v%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%20M%20%E3%82%B3%E3%82%A2%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AE%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%20IPCF%20%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E2.%20IPCF%20A%20%E3%82%B3%E3%82%A2%E5%81%B4%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%20BSP%2040%20rootfs%20%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%20IPCF%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%9B%B4%E6%8E%A5%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E
