S32G-VNP-RDB3 IPCF communication Error
2,868 次查看
Kulkarni_v
I am working on Goldbox S32G-VNP-RDB3
I am using Linux BSP 40 downloaded from the software center
and using the following version of IPCF, RTD and FreeRTOS
NXP RTD 4.0.2_P04 D2312
NXP RTOS 0.4.0 D2309
FreeRTOS 4.0.2 D2306
NXP Linux BSP40 D2403
And used the following commands
# 1. Disable data cache
=> dcache off
# 2. Clear IPCF shared memory
=> mw.q 0x34100000 0x0 0x40000
# 3. Load M7 binary from SD card into temporary DDR
=> fatload mmc 0:1 0x80000000 IPCF_FreeRTOS_S32G399A_M7_0.bin
# 4. Copy firmware to M7 SRAM
=> cp.b 0x80000000 0x34300000 0x300000
# 5. Start M7 core at vector address
=> startm7 0x34500400
# 6. Boot Linux normally (if not already)
=> boot
# 1. Mount boot partition (optional, verify M7 binary)
mkdir -p /mnt/s32g_boot
mount /dev/mmcblk0p1 /mnt/s32g_boot
ls /mnt/s32g_boot
# Should see: IPCF_FreeRTOS_S32G399A_M7_0_1_2.bin
# 2. Load IPCF Linux kernel modules
insmod /lib/modules/$(uname -r)/extra/ipc-shm-dev.ko
insmod /lib/modules/$(uname -r)/extra/ipc-shm-sample.ko
# 3. Verify modules
lsmod | grep ipc
# 4. Clear previous ping (optional)
echo 0 > /sys/kernel/ipc-shm-sample/ping
# 5. Test IPCF communication (channel 0)
echo 10 > /sys/kernel/ipc-shm-sample/ping
# 6. Monitor kernel messages
dmesg | tail -20 | grep -i ipc
But getting an error of
root@s32g399ardb3:~# dmesg | tail -20 | grep -i ipc
[ 81.689010] ipc-shm-sample: starting demo...
[ 81.689029] ipc-shm-sample: ch 0 >> 19 bytes: SENDING MESSAGES: 0
[ 91.808767] ipc-shm-sample: starting demo...
[ 91.808771] ipc-shm-sample: ch 0 >> 20 bytes: SENDING MESSAGES: 10
[ 91.808778] ipc-shm-sample: send_data_msg(): failed to get buffer for channe2
Please guide which versions of different software and Linux BSP I should use for my board
2,760 次查看
chenyin_h
Hello, @Kulkarni_v
Thanks for your reply.
From the information you share, you are using 4.10 on M core side, but using default images in BSP40 on A core side.
By default, the IPCF images in BSP40 is not the 4.10 version, so the code on both side does not match.
As a result, the following method may solve your issue:
1. Manually build IPCF 4.10 images on BSP40, and use it to communicate with M core side you had built.
2. Another way is to build IPCF4.9 on your M core side, and then use the default images in BSP40 to communicate.
You may choose either of the methods provided according to your own requirements.
Chenyin
6 回复数
2,812 次查看
chenyin_h
Hello, @Kulkarni_v
Thanks for your reply,
I feel sorry that still I do not see the IPCF version you used on M core side, the IPCF version may like the following:
Chenyin
2,789 次查看
Kulkarni_v
@chenyin_h
2,761 次查看
chenyin_h
Hello, @Kulkarni_v
Chenyin
2,665 次查看
Kulkarni_v
Hello@chenyin_h
    Thank you for your continuous support. I tried with the M-core side build for version 4.9.0, along with the Linux BSP 40 downloaded from the NXP software download, and it worked as expected.
2,839 次查看
chenyin_h
Hello, @Kulkarni_v
Thanks for your post.
1. Which version IPCF you are using for building the M core binaries?
2. Have you build the IPCF A core side manually or directly using the IPCF modules existed in BSP 40 rootfs?
Chenyin
2,833 次查看
Kulkarni_v
At M-core side I have used above versions and I am using BSP40 downloaded from software support(https://nxp.flexnetoperations.com/control/frse/download?agree=Accept&element=3993158). I have not built it separately.
%3CLINGO-SUB%20id%3D%22lingo-sub-2181634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G-VNP-RDB3%20IPCF%20%E9%80%9A%E4%BF%A1%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%8F%91%20Goldbox%20S32G-VNP-RDB3%20%3CBR%20%2F%3E%20%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E4%BB%8E%E8%BD%AF%E4%BB%B6%E4%B8%AD%E5%BF%83%E4%B8%8B%E8%BD%BD%E7%9A%84%20Linux%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%204.0%EF%BC%8C%3CBR%20%2F%3E%E5%B9%B6%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E7%89%88%E6%9C%AC%E7%9A%84%20IPCF%E3%80%81RTD%20%E5%92%8C%20FreeRTOS%20NXP%20RTD%204.0.2_P04%20%3CBR%20%2F%3Ed2312%3CBR%20%2F%3Enxp%20rtos%200.4.0D2309%3CBR%20%2F%3EFreeRTOS%204.0.2D2306%3CBR%20%2F%3ENXP%20Linux%20BSP40%20D2403%3C%2FP%3E%3CP%3E%E5%B9%B6%E4%BD%BF%E7%94%A8%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%3C%2FP%3E%3CP%3E%23%201.%E7%A6%81%E7%94%A8%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%3CBR%20%2F%3E%3D%26gt%3B%20dcache%20off%3C%2FP%3E%3CP%3E%23%202.%E6%B8%85%E9%99%A4%20IPCF%20%E5%85%B1%E4%BA%AB%E5%86%85%E5%AD%98%3CBR%20%2F%3E%3D%26gt%3B%20mw.q%200x34100000%200x0%200x40000%3C%2FP%3E%3CP%3E%23%203%E3%80%82%E5%B0%86%20M7%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E4%BB%8E%20SD%20%E5%8D%A1%E5%8A%A0%E8%BD%BD%E5%88%B0%E4%B8%B4%E6%97%B6%20DDR%20%3CBR%20%2F%3E%20%3D%20%26gt%3B%20fatload%20mmc%200%3A1%200x80000000%20IPCF_FreeRTOS_S32G399A_M7_0.bin%3C%2FP%3E%3CP%3E%23%204.%E5%B0%86%E5%9B%BA%E4%BB%B6%E5%A4%8D%E5%88%B6%E5%88%B0%20M7%20SRAM%3CBR%20%2F%3E%3D%26gt%3B%20cp.b%200x80000000%200x34300000%200x300000%3C%2FP%3E%3CP%3E%23%205.%E5%9C%A8%E5%90%91%E9%87%8F%E5%9C%B0%E5%9D%80%E5%90%AF%E5%8A%A8%20M7%20%E5%86%85%E6%A0%B8%3CBR%20%2F%3E%3D%26gt%3B%20startm7%200x34500400%3C%2FP%3E%3CP%3E%23%206%E3%80%82%E5%90%AF%E5%8A%A8%20Linux%EF%BC%88%E5%A6%82%E6%9E%9C%E8%BF%98%E6%B2%A1%E6%9C%89%EF%BC%89%3CBR%20%2F%3E%3D%20%26gt%3B%20%E5%90%AF%E5%8A%A8%3C%2FP%3E%3CP%3E%23%201.%20%E8%A3%85%E5%85%A5%E5%90%AF%E5%8A%A8%E5%88%86%E5%8C%BA%EF%BC%88%E5%8F%AF%E9%80%89%E7%9A%84%EF%BC%8C%E9%AA%8C%E8%AF%81%20M7%20%E4%BA%8C%E8%BF%9B%E5%88%B6%EF%BC%89%3CBR%20%2F%3Emkdir%20-p%20%2Fmnt%2Fs32g_boot%3CBR%20%2F%3Emount%20%2Fdev%2Fmmcblk0p1%20%2Fmnt%2Fs32g_boot%3CBR%20%2F%3Els%20%2Fmnt%2Fs32g_boot%3CBR%20%2F%3E%23%20%E5%BA%94%E8%AF%A5%E7%9C%8B%E5%88%B0%EF%BC%9AIPCF_FreeRTOS_S32G399A_M7_0_1_2.bin%3C%2FP%3E%3CP%3E%23%202.%E5%8A%A0%E8%BD%BD%20IPCF%20Linux%20%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%3CBR%20%2F%3Einsmod%20%2Flib%2Fmodules%2F%24(uname%20-r)%2Fextra%2Fipc-shm-dev.ko%3CBR%20%2F%3Einsmod%20%2Flib%2Fmodules%2F%24(uname%20-r)%2Fextra%2Fipc-shm-sample.ko%3C%2FP%3E%3CP%3E%23%203.%E9%AA%8C%E8%AF%81%E6%A8%A1%E5%9D%97%3CBR%20%2F%3Elsmod%20%7C%20grep%20ipc%3C%2FP%3E%3CP%3E%23%204%E3%80%82%E6%B8%85%E9%99%A4%E4%B9%8B%E5%89%8D%E7%9A%84%20ping%EF%BC%88%E5%8F%AF%E9%80%89%E7%9A%84%EF%BC%89%3CBR%20%2F%3Eecho%200%20%26gt%3B%20%2Fsys%2Fkernel%2Fipc-shm-sample%2Fping%3C%2FP%3E%3CP%3E%23%205.%E6%B5%8B%E8%AF%95%20IPCF%20%E9%80%9A%E4%BF%A1%EF%BC%88%E9%80%9A%E9%81%93%200%EF%BC%89%3CBR%20%2F%3Eecho%2010%26gt%3B%20%2Fsys%2Fkernel%2Fipc-shm-sample%2Fping%3C%2FP%3E%3CP%3E%23%206%E3%80%82%E7%9B%91%E6%B5%8B%E5%86%85%E6%A0%B8%E6%B6%88%E6%81%AF%20%3CBR%20%2F%3E%20dmesg%20%7C%20tail%20-20%20%7C%20grep-i%20ipc%20%3CBR%20%2F%3E%20%E4%BD%86%E6%98%AF%E5%87%BA%E7%8E%B0%E4%BA%86%20%3CBR%20%2F%3E%20root%20%E9%94%99%E8%AF%AF%20%40s32g399ardb3%EF%BC%9A~%23%20dmesg%20%7C%20tail%20-20%20%7C%20grep-i%20ipc%20%5B81.689010%5D%20ipc-shm-sample%EF%BC%9A%E5%BC%80%E5%A7%8B%E6%BC%94%E7%A4%BA...%20%3CBR%20%2F%3E%3CBR%20%2F%3E%5B81.689029%5D%20ipc-shm-sample%EF%BC%9Ach%200%20%26gt%3B%20%26gt%3B%2019%20%E5%AD%97%E8%8A%82%EF%BC%9A%E5%8F%91%E9%80%81%E6%B6%88%E6%81%AF%EF%BC%9A0%20%5B91.808767%5D%20ipc-shm-sample%EF%BC%9A%E5%BC%80%E5%A7%8B%E6%BC%94%E7%A4%BA...%20%3CBR%20%2F%3E%3CBR%20%2F%3E%5B91.808771%5D%20ipc-shm-sample%EF%BC%9Ach%200%20%26gt%3B%20%26gt%3B%2020%20%E5%AD%97%E8%8A%82%EF%BC%9A%E5%8F%91%E9%80%81%E6%B6%88%E6%81%AF%EF%BC%9A10%20%3CBR%20%2F%3E%20%5B91.808778%5D%20ipc-shm-sample%EF%BC%9Asend_data_msg%20()%EF%BC%9A%E6%97%A0%E6%B3%95%E4%B8%BA%20channe2%20%E8%8E%B7%E5%8F%96%E7%BC%93%E5%86%B2%E5%8C%BA%E8%AF%B7%E6%8C%87%E5%AF%BC%E6%88%91%E7%9A%84%E6%9D%BF%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%E4%B8%8D%E5%90%8C%E8%BD%AF%E4%BB%B6%E5%92%8C%20Linux%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%40%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24163%22%20target%3D%22_blank%22%3Echenyin%3C%2FA%3E_h%3CBR%20%2F%3E%20%E6%84%9F%E8%B0%A2%E6%82%A8%E4%B8%80%E7%9B%B4%E4%BB%A5%E6%9D%A5%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E7%89%88%E6%9C%AC4.9.0%E7%9A%84M-core%E4%BE%A7%E9%9D%A2%E7%89%88%E6%9C%AC%EF%BC%8C%E4%BB%A5%E5%8F%8A%E4%BB%8E%E6%81%A9%E6%99%BA%E6%B5%A6%E8%BD%AF%E4%BB%B6%E4%B8%8B%E8%BD%BD%E4%B8%AD%E4%B8%8B%E8%BD%BD%E7%9A%84Linux%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%2040%EF%BC%8C%E5%AE%83%E6%8C%89%E9%A2%84%E6%9C%9F%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255175%22%20target%3D%22_blank%22%3E%40Kulkarni_v%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%8E%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%E6%9D%A5%E7%9C%8B%EF%BC%8C%E6%82%A8%E5%9C%A8%20M%20%E5%86%85%E6%A0%B8%E4%B8%8A%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%204.10%20%E7%89%88%EF%BC%8C%E4%BD%86%E5%9C%A8%20A%20%E5%86%85%E6%A0%B8%E4%B8%8A%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20BSP40%20%E4%B8%AD%E7%9A%84%E9%BB%98%E8%AE%A4%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8CBSP40%20%E4%B8%AD%E7%9A%84%20IPCF%20%E6%98%A0%E5%83%8F%E4%B8%8D%E6%98%AF%204.10%20%E7%89%88%E6%9C%AC%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%8F%8C%E6%96%B9%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B8%8D%E5%8C%B9%E9%85%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E4%BB%A5%E4%B8%8B%E6%96%B9%E6%B3%95%E5%8F%AF%E8%83%BD%E4%BC%9A%E8%A7%A3%E5%86%B3%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%0A%3CP%3E1%E3%80%82%E5%9C%A8%20BSP40%20%E4%B8%8A%E6%89%8B%E5%8A%A8%E7%89%88%E6%9C%AC%20IPCF%204.10%20%E6%98%A0%E5%83%8F%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%E5%AE%83%E4%B8%8E%E4%BD%A0%E7%89%88%E6%9C%AC%20%E7%9A%84%20M%20%E6%A0%B8%E5%BF%83%E7%AB%AF%E9%80%9A%E4%BF%A1%E3%80%82%3C%2FP%3E%0A%3CP%3E2%E3%80%82%E5%8F%A6%E4%B8%80%E7%A7%8D%E6%96%B9%E6%B3%95%E6%98%AF%E5%9C%A8%E4%BD%A0%E7%9A%84%20M%20%E6%A0%B8%E5%BF%83%E7%AB%AF%E7%89%88%E6%9C%AC%20IPCF4.9%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BD%BF%E7%94%A8%20BSP40%20%E4%B8%AD%E7%9A%84%E9%BB%98%E8%AE%A4%E9%95%9C%E5%83%8F%E8%BF%9B%E8%A1%8C%E9%80%9A%E4%BF%A1%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%A0%B9%E6%8D%AE%E8%87%AA%E5%B7%B1%E7%9A%84%E8%A6%81%E6%B1%82%E9%80%89%E6%8B%A9%E5%85%B6%E4%B8%AD%E4%B8%80%E7%A7%8D%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%88%87%E5%AE%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24163%22%20target%3D%22_blank%22%3E%40chenyin_h%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20IPCF%204.10.10%20%E7%89%88%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22Screenshot%202025-10-10%20225736.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-10-10%20225736.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360294iF14B5049551A4BD4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-10-10%20225736.png%22%20alt%3D%22Screenshot%202025-10-10%20225736.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255175%22%20target%3D%22_blank%22%3E%40Kulkarni_v%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E4%BB%8D%E7%84%B6%E6%B2%A1%E6%9C%89%E7%9C%8B%E5%88%B0%E6%82%A8%E5%9C%A8%20M%20core%20%E4%B8%8A%E4%BD%BF%E7%94%A8%E7%9A%84%20IPCF%20%E7%89%88%E6%9C%AC%EF%BC%8CIPCF%20%E7%89%88%E6%9C%AC%E5%8F%AF%E8%83%BD%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1760065816841.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1760065816841.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360167i214C39A320FE5A9E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1760065816841.png%22%20alt%3D%22chenyin_h_0-1760065816841.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%88%87%E5%AE%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22Screenshot%202025-09-30%20125831.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-09-30%20125831.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359997i7E53B5D795A8F57B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-09-30%20125831.png%22%20alt%3D%22Screenshot%202025-09-30%20125831.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%20M-core%20%E6%96%B9%E9%9D%A2%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E4%B8%8A%E8%BF%B0%E7%89%88%E6%9C%AC%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E4%BB%8E%E8%BD%AF%E4%BB%B6%E6%94%AF%E6%8C%81%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D3993158%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%88https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D3993158%3C%2FA%3E%EF%BC%89%E4%B8%8B%E8%BD%BD%E7%9A%84%20BSP40%E3%80%82%E6%88%91%E6%B2%A1%E6%9C%89%E5%8D%95%E7%8B%AC%E7%89%88%E6%9C%AC%E5%AE%83%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22shared%20image%20(1).jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(1).jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360000i9B189E9EEAAC822E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22shared%20image%20(1).jpg%22%20alt%3D%22shared%20image%20(1).jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22shared%20image.jpg%22%20style%3D%22width%3A%20800px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image.jpg%22%20style%3D%22width%3A%20800px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359999i7F7C9D995FD25A5A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22shared%20image.jpg%22%20alt%3D%22shared%20image.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255175%22%20target%3D%22_blank%22%3E%40Kulkarni_v%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%0A%3CP%3E1%E3%80%82%E4%BD%A0%E4%BD%BF%E7%94%A8%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%20IPCF%20%E6%9D%A5%E6%9E%84%E5%BB%BA%20M%20%E6%A0%B8%E5%BF%83%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%0A%3CP%3E2%E3%80%82%E4%BD%A0%E6%98%AF%E4%BD%BF%E7%94%A8%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%2040%20rootfs%20%E4%B8%AD%E5%AD%98%E5%9C%A8%E7%9A%84%20IPCF%20%E6%A8%A1%E5%9D%97%E6%89%8B%E5%8A%A8%E8%BF%98%E6%98%AF%E7%9B%B4%E6%8E%A5%20%E7%89%88%E6%9C%AC%20IPCF%20A%20%E6%A0%B8%E5%BF%83%E7%AB%AF%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%88%87%E5%AE%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
