S32G-VNP-RDB3 IPCF communication Error
Kulkarni_v
I am working on Goldbox S32G-VNP-RDB3
I am using Linux BSP 40 downloaded from the software center
and using the following version of IPCF, RTD and FreeRTOS
NXP RTD 4.0.2_P04 D2312
NXP RTOS 0.4.0 D2309
FreeRTOS 4.0.2 D2306
NXP Linux BSP40 D2403
And used the following commands
# 1. Disable data cache
=> dcache off
# 2. Clear IPCF shared memory
=> mw.q 0x34100000 0x0 0x40000
# 3. Load M7 binary from SD card into temporary DDR
=> fatload mmc 0:1 0x80000000 IPCF_FreeRTOS_S32G399A_M7_0.bin
# 4. Copy firmware to M7 SRAM
=> cp.b 0x80000000 0x34300000 0x300000
# 5. Start M7 core at vector address
=> startm7 0x34500400
# 6. Boot Linux normally (if not already)
=> boot
# 1. Mount boot partition (optional, verify M7 binary)
mkdir -p /mnt/s32g_boot
mount /dev/mmcblk0p1 /mnt/s32g_boot
ls /mnt/s32g_boot
# Should see: IPCF_FreeRTOS_S32G399A_M7_0_1_2.bin
# 2. Load IPCF Linux kernel modules
insmod /lib/modules/$(uname -r)/extra/ipc-shm-dev.ko
insmod /lib/modules/$(uname -r)/extra/ipc-shm-sample.ko
# 3. Verify modules
lsmod | grep ipc
# 4. Clear previous ping (optional)
echo 0 > /sys/kernel/ipc-shm-sample/ping
# 5. Test IPCF communication (channel 0)
echo 10 > /sys/kernel/ipc-shm-sample/ping
# 6. Monitor kernel messages
dmesg | tail -20 | grep -i ipc
But getting an error of
root@s32g399ardb3:~# dmesg | tail -20 | grep -i ipc
[ 81.689010] ipc-shm-sample: starting demo...
[ 81.689029] ipc-shm-sample: ch 0 >> 19 bytes: SENDING MESSAGES: 0
[ 91.808767] ipc-shm-sample: starting demo...
[ 91.808771] ipc-shm-sample: ch 0 >> 20 bytes: SENDING MESSAGES: 10
[ 91.808778] ipc-shm-sample: send_data_msg(): failed to get buffer for channe2
Please guide which versions of different software and Linux BSP I should use for my board
chenyin_h
Hello, @Kulkarni_v
Thanks for your reply.
From the information you share, you are using 4.10 on M core side, but using default images in BSP40 on A core side.
By default, the IPCF images in BSP40 is not the 4.10 version, so the code on both side does not match.
As a result, the following method may solve your issue:
1. Manually build IPCF 4.10 images on BSP40, and use it to communicate with M core side you had built.
2. Another way is to build IPCF4.9 on your M core side, and then use the default images in BSP40 to communicate.
You may choose either of the methods provided according to your own requirements.
Chenyin
chenyin_h
Hello, @Kulkarni_v
Thanks for your reply,
I feel sorry that still I do not see the IPCF version you used on M core side, the IPCF version may like the following:
Chenyin
Kulkarni_v
@chenyin_h
chenyin_h
Hello, @Kulkarni_v
Chenyin
Kulkarni_v
Hello@chenyin_h
    Thank you for your continuous support. I tried with the M-core side build for version 4.9.0, along with the Linux BSP 40 downloaded from the NXP software download, and it worked as expected.
chenyin_h
Hello, @Kulkarni_v
Thanks for your post.
1. Which version IPCF you are using for building the M core binaries?
2. Have you build the IPCF A core side manually or directly using the IPCF modules existed in BSP 40 rootfs?
Chenyin
Kulkarni_v
At M-core side I have used above versions and I am using BSP40 downloaded from software support(https://nxp.flexnetoperations.com/control/frse/download?agree=Accept&element=3993158). I have not built it separately.
%3CLINGO-SUB%20id%3D%22lingo-sub-2181634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20working%20on%20Goldbox%20S32G-VNP-RDB3%3CBR%20%2F%3EI%20am%20using%20Linux%20BSP%2040%20downloaded%20from%20the%20software%20center%3CBR%20%2F%3Eand%20using%20the%20following%20version%20of%20IPCF%2C%20RTD%20and%20FreeRTOS%3CBR%20%2F%3ENXP%20RTD%204.0.2_P04%20D2312%3CBR%20%2F%3ENXP%20RTOS%200.4.0%20D2309%3CBR%20%2F%3EFreeRTOS%204.0.2%20D2306%3CBR%20%2F%3ENXP%20Linux%20BSP40%20D2403%3C%2FP%3E%3CP%3EAnd%20used%20the%20following%20commands%3C%2FP%3E%3CP%3E%23%201.%20Disable%20data%20cache%3CBR%20%2F%3E%3D%26gt%3B%20dcache%20off%3C%2FP%3E%3CP%3E%23%202.%20Clear%20IPCF%20shared%20memory%3CBR%20%2F%3E%3D%26gt%3B%20mw.q%200x34100000%200x0%200x40000%3C%2FP%3E%3CP%3E%23%203.%20Load%20M7%20binary%20from%20SD%20card%20into%20temporary%20DDR%3CBR%20%2F%3E%3D%26gt%3B%20fatload%20mmc%200%3A1%200x80000000%20IPCF_FreeRTOS_S32G399A_M7_0.bin%3C%2FP%3E%3CP%3E%23%204.%20Copy%20firmware%20to%20M7%20SRAM%3CBR%20%2F%3E%3D%26gt%3B%20cp.b%200x80000000%200x34300000%200x300000%3C%2FP%3E%3CP%3E%23%205.%20Start%20M7%20core%20at%20vector%20address%3CBR%20%2F%3E%3D%26gt%3B%20startm7%200x34500400%3C%2FP%3E%3CP%3E%23%206.%20Boot%20Linux%20normally%20(if%20not%20already)%3CBR%20%2F%3E%3D%26gt%3B%20boot%3C%2FP%3E%3CP%3E%23%201.%20Mount%20boot%20partition%20(optional%2C%20verify%20M7%20binary)%3CBR%20%2F%3Emkdir%20-p%20%2Fmnt%2Fs32g_boot%3CBR%20%2F%3Emount%20%2Fdev%2Fmmcblk0p1%20%2Fmnt%2Fs32g_boot%3CBR%20%2F%3Els%20%2Fmnt%2Fs32g_boot%3CBR%20%2F%3E%23%20Should%20see%3A%20IPCF_FreeRTOS_S32G399A_M7_0_1_2.bin%3C%2FP%3E%3CP%3E%23%202.%20Load%20IPCF%20Linux%20kernel%20modules%3CBR%20%2F%3Einsmod%20%2Flib%2Fmodules%2F%24(uname%20-r)%2Fextra%2Fipc-shm-dev.ko%3CBR%20%2F%3Einsmod%20%2Flib%2Fmodules%2F%24(uname%20-r)%2Fextra%2Fipc-shm-sample.ko%3C%2FP%3E%3CP%3E%23%203.%20Verify%20modules%3CBR%20%2F%3Elsmod%20%7C%20grep%20ipc%3C%2FP%3E%3CP%3E%23%204.%20Clear%20previous%20ping%20(optional)%3CBR%20%2F%3Eecho%200%20%26gt%3B%20%2Fsys%2Fkernel%2Fipc-shm-sample%2Fping%3C%2FP%3E%3CP%3E%23%205.%20Test%20IPCF%20communication%20(channel%200)%3CBR%20%2F%3Eecho%2010%20%26gt%3B%20%2Fsys%2Fkernel%2Fipc-shm-sample%2Fping%3C%2FP%3E%3CP%3E%23%206.%20Monitor%20kernel%20messages%3CBR%20%2F%3Edmesg%20%7C%20tail%20-20%20%7C%20grep%20-i%20ipc%3CBR%20%2F%3EBut%20getting%20an%20error%20of%3CBR%20%2F%3Eroot%40s32g399ardb3%3A~%23%20dmesg%20%7C%20tail%20-20%20%7C%20grep%20-i%20ipc%3CBR%20%2F%3E%5B%2081.689010%5D%20ipc-shm-sample%3A%20starting%20demo...%3CBR%20%2F%3E%5B%2081.689029%5D%20ipc-shm-sample%3A%20ch%200%20%26gt%3B%26gt%3B%2019%20bytes%3A%20SENDING%20MESSAGES%3A%200%3CBR%20%2F%3E%5B%2091.808767%5D%20ipc-shm-sample%3A%20starting%20demo...%3CBR%20%2F%3E%5B%2091.808771%5D%20ipc-shm-sample%3A%20ch%200%20%26gt%3B%26gt%3B%2020%20bytes%3A%20SENDING%20MESSAGES%3A%2010%3CBR%20%2F%3E%5B%2091.808778%5D%20ipc-shm-sample%3A%20send_data_msg()%3A%20failed%20to%20get%20buffer%20for%20channe2%3CBR%20%2F%3E%3CBR%20%2F%3EPlease%20guide%20which%20versions%20of%20different%20software%20and%20Linux%20BSP%20I%20should%20use%20for%20my%20board%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24163%22%20target%3D%22_blank%22%3E%40chenyin_h%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Thank%20you%20for%20your%20continuous%20support.%20I%20tried%20with%20the%20M-core%20side%20build%20for%20version%204.9.0%2C%20along%20with%20the%20Linux%20BSP%2040%20downloaded%20from%20the%20NXP%20software%20download%2C%20and%20it%20worked%20as%20expected.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255175%22%20target%3D%22_blank%22%3E%40Kulkarni_v%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EFrom%20the%20information%20you%20share%2C%20you%20are%20using%204.10%20on%20M%20core%20side%2C%20but%20using%20default%20images%20in%20BSP40%20on%20A%20core%20side.%3C%2FP%3E%0A%3CP%3EBy%20default%2C%20the%20IPCF%20images%20in%20BSP40%20is%20not%20the%204.10%20version%2C%20so%20the%20code%20on%20both%20side%20does%20not%20match.%3C%2FP%3E%0A%3CP%3EAs%20a%20result%2C%20the%20following%20method%20may%20solve%20your%20issue%3A%3C%2FP%3E%0A%3CP%3E1.%20Manually%20build%20IPCF%204.10%20images%20on%20BSP40%2C%20and%20use%20it%20to%20communicate%20with%20M%20core%20side%20you%20had%20built.%3C%2FP%3E%0A%3CP%3E2.%20Another%20way%20is%20to%20build%20IPCF4.9%20on%20your%20M%20core%20side%2C%20and%20then%20use%20the%20default%20images%20in%20BSP40%20to%20communicate.%3C%2FP%3E%0A%3CP%3EYou%20may%20choose%20either%20of%20the%20methods%20provided%20according%20to%20your%20own%20requirements.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24163%22%20target%3D%22_blank%22%3E%40chenyin_h%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EYes%20I%20am%20using%20IPCF%20version%204.10.10%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22Screenshot%202025-10-10%20225736.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-10-10%20225736.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360294iF14B5049551A4BD4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-10-10%20225736.png%22%20alt%3D%22Screenshot%202025-10-10%20225736.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255175%22%20target%3D%22_blank%22%3E%40Kulkarni_v%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply%2C%3C%2FP%3E%0A%3CP%3EI%20feel%20sorry%20that%20still%20I%20do%20not%20see%20the%20IPCF%20version%20you%20used%20on%20M%20core%20side%2C%20the%20IPCF%20version%20may%20like%20the%20following%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1760065816841.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1760065816841.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360167i214C39A320FE5A9E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1760065816841.png%22%20alt%3D%22chenyin_h_0-1760065816841.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThanks%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22Screenshot%202025-09-30%20125831.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-09-30%20125831.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359997i7E53B5D795A8F57B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-09-30%20125831.png%22%20alt%3D%22Screenshot%202025-09-30%20125831.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAt%20M-core%20side%20I%20have%20used%20above%20versions%20and%20I%20am%20using%20BSP40%20downloaded%20from%20software%20support(%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D3993158%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D3993158%3C%2FA%3E).%20I%20have%20not%20built%20it%20separately.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22shared%20image%20(1).jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(1).jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360000i9B189E9EEAAC822E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22shared%20image%20(1).jpg%22%20alt%3D%22shared%20image%20(1).jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22shared%20image.jpg%22%20style%3D%22width%3A%20800px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image.jpg%22%20style%3D%22width%3A%20800px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359999i7F7C9D995FD25A5A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22shared%20image.jpg%22%20alt%3D%22shared%20image.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB3%20IPCF%20communication%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255175%22%20target%3D%22_blank%22%3E%40Kulkarni_v%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post.%3C%2FP%3E%0A%3CP%3E1.%20Which%20version%20IPCF%20you%20are%20using%20for%20building%20the%20M%20core%20binaries%3F%3C%2FP%3E%0A%3CP%3E2.%20Have%20you%20build%20the%20IPCF%20A%20core%20side%20manually%20or%20directly%20using%20the%20IPCF%20modules%20existed%20in%20BSP%2040%20rootfs%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E
