S32DS Debug error
S32DS Debug error
Wanyj
When I use S32DS for S32 Platform, the following error occurs when I use S32 Debug Probe for debugging.
Here is my configuration,I'm using the latest version S32DS for S32 Platform.
I tried to restart the software and development board, but nothing worked,Hope you can answer, thank you
Miguel04
Hi @Wanyj
From your other questions, I'll asume you are using the RDB2, is this correct?
I would like to discard that the boot mode is in the correct configuration
You can find this information on the following file, go to documentation and look for the user guide.
S32G-VNP-RDB2 reference design – User Guide
Help me verifying the configuration according to the chapters 3.1 Default Switch Setting and 3.6 Switch Setting for Serial Boot from the guide.
Please let me know.
Best Regards, Miguel.
Miguel04
Hi @Wanyj
Are you facing the same issue with another examples provided under the RTD? For example, a LED blinky project.
Please let us know.
Wanyj
Hi,Miguel04
Yes, I have tried other examples, each one has this problem, when I change the development board does not have this problem,Nothing else has been changed.
Is there some kind of unknown error with my development board? Something's wrong with me.
Looking forward to your reply, thank you
Miguel04
Hi @Wanyj
Please let me know.
