Is there any way to control (modify/enable) clock on Linux?
Jeff-CF-Huang
Hi Sir,
chenyin_h
 Hello, @Jeff-CF-Huang
Thanks for the feedback
From the BSP perspective, seems no such functions in Linux, sorry for your inconvenience.
Best Regards
Chenyin
chenyin_h
Best Regards
Chenyin
chenyin_h
For what we are able to see, the clocks seem to be enabled under ATF(From BSP view). We are not seeing anything under Linux to modify/enable clocks.
Best Regards
Chenyin
Jeff-CF-Huang
We want to configure the clock dynamically in the Linux kernel, including enabling, disabling, and changing the rate.
chenyin_h
Thanks for the questions。
Sorry that I am not quite catching you, would you please help to clarify the questions? Which clock you were referring to?
Best Regards
Chenyin
Jeff-CF-Huang
I can get the clk summary at /sys/kernel/debug/clk.
enable prepare protect duty hardware
clock count count count rate accuracy phase cycle enable
pcf85063-clkout 0 0 0 0 0 0 50000 Y
llce_per 0 0 0 80000000 0 0 50000 Y
llce_sys 0 0 0 198309214 0 0 50000 Y
But, I can't find a file node to enable/disable the clock.
For example:
I want to enable the clk of qspi_flash1x & qspi_flash2x.
