Debug Eb tressos goldVIP package using S32 Debug Probe
2,015 次查看
Karthik_7
Is it possible to debug the Eb tressos  Goldvip package via S32 Debug Probe
If yes What is the procedure ,
5 回复数
1,994 次查看
Daniel-Aguirre
Can you let us know which GoldVIP version are you using?
Please, let us know.
1,993 次查看
Karthik_7
Hello @Daniel-Aguirre ,
I am using GoldVIP-S32G3-1.11.0
1,979 次查看
Daniel-Aguirre
Thanks for your feedback. We understand that the available debugging scripts are those provided for Trace32, as mentioned under the GoldVIP Developer Guide [Page 4, rev1.11.0]:
On regards of S32 Debug Probe, we don't see any available configurations/scripts for GoldVIP. We do apologize.
1,962 次查看
Karthik_7
Hello ,
@Daniel-Aguirre  thanks for the feedback,
Is there any way to configure it and make it suitable for debugging using s32 debug probe using design studio
1,957 次查看
Daniel-Aguirre
For the available documentation, we understand that this is not intended.
As on how to do it, we understand that you should be able to change the *.elf file under the available debug configurations for the RTD examples (i.e. Siul2_Dio_ToggleLed_S32G274A_M7) and the debugger will load the *.elf you are pointing to:
But again, this is not intended.
