How to dynamically allocate memory on S32 DS?
1,161 次查看
Jeff-CF-Huang
Hi Sir,
Could you provide an example of allocating & releasing memory on S32DS?
1,123 次查看
Daniel-Aguirre
Are you referring to the usage of malloc() and free() functions?
If so, we do not see any specific implementation for it. You should be able to use it just by adding the required library, as shown below:
Please, let us know.
1,124 次查看
Daniel-Aguirre
