Enable LLCE support for Linux on S32G( Goldbox)
2,108 次查看
rital123
We would like to use CAN2ETH feature of LLCE. So need a few information on this:
1>Is this feature enabled for the same?It would be great if you can provide us with guide to use the existing CAN2ETH feature?
2>If No, please let us know how could it be done?
Are there any BSP changes to be done.
1,806 次查看
salimmulla2021
@Bio_TICFSL
Is LLCE supported on Linux operating system? If yes where we will get the BSP driver for same?
2,099 次查看
Bio_TICFSL
Hello rital123,
You can view this appnote for reference:
https://www.nxp.com/docs/en/application-note/AN13423.pdf
regards
2,096 次查看
Aishwarya
@Bio_TICFSL
CANtoETH process given in this pdf will be used for linux bsp installed Goldbox?
