i have a quesiton, if want to generate waveform like this,
i see there have dead time enable, can the dead time can set longer time, is there have parameter set ?
another questions, it seems only Adjacent channel(n and n+1) can set the dead time,
does ch0 and ch7 or some other random channel combination with dead time set ?
third question is can different FTM channel generate same waveform
with dead time, like FTM0 ch0-ch1 waveform ?
