Configure FTM output channel state retention
795件の閲覧回数
superbird
I am using the S32K146 and want to control a PWM signal via RTD version V2.0.
In principle the behavior is as expected, but I can't find any option in S32DS to configure the behavior “FTM output channel state retention” via SIM_MISCTRL0[FTMx_OBE_CTRL].
It actually seems to be the case that the RTD PWM initialization code always sets the corresponding FTMx_OBE_CTRL bits to '1b', but this is not suitable for my application. In my application, I want the initial state of the channel to be a tristate state (in case of no clock condition). Is there any way to configure this and still use the RTD driver?
Thank you very much for your support.
タグ(1)
693件の閲覧回数
danielmartynek
Hello @superbird,
I'm sorry for the delay.
The feature is not implemented in the RTD.
A change request has been submitted to the RTD development team.
It might be fixed in a future revision.
