SDK zip file
SDK zip file
1,151件の閲覧回数
marco-passoni
I kindly ask zip file for SDK of S32K144 to be used with S32DS 3.6.2.
1,124件の閲覧回数
Julián_AragónM
Hi @marco-passoni
SDK is no longer supported by the newest S32DS versions. In fact, the latest SDK released was v4.0.3 and it is only supported in S32DS v3.4.
The SDK has been replaced by the RTD package. You can see a bit more in-depth explanation in this community post: Solved: difference between s32k1 sdk and s32k1 rtd - NXP Community.
If you are going to develop in S32DS v3.6.2, then please try installing RTD instead. It can be downloaded here: https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=SW32K1-RTD44-D
Latest version is 2.0.0. Each SW package contains release notes pdf file which specifies supported versions, changes and how to install it.
Here you can find how to install the RTD: https://www.nxp.com/document/guide/getting-started-with-the-real-time-drivers-rtd:GS-AUTOMOTIVE-RTD.
Julián
