S32K142_48 SDK LinStack BUG
zhengjianfei1
Hi ,
      I found a bug in S32K SDK V3.0.0.   When I choose S32K142_48 as my porcessor,i cannot use LinStack component .The fault is as follows.Hope for your help,thanks!
Tags (3)
victorjimenez
Hello, zheng jianfei
The SDK team confirmed that this behavior will be fixed in the next revision of the SDK.
Victor
victorjimenez
Sorry for the late response. I'm currently checking with the applications engineer what might be the root cause of this behavior. I will give you an update as soon as possible.
Victor
zhengjianfei1
Hi Victor ,
      Is there any update ? Thanks!
victorjimenez
Sorry that this is taking too long. This behavior is related to the SDK, so now the SDK team is checking it, I will give you an update as soon as possible.
Victor
victorjimenez
Victor
