S32K142_48 SDK LinStack BUG
2,711 次查看
zhengjianfei1
Hi ,
      I found a bug in S32K SDK V3.0.0.   When I choose S32K142_48 as my porcessor,i cannot use LinStack component .The fault is as follows.Hope for your help,thanks!
标记 (3)
2,529 次查看
victorjimenez
Hello, zheng jianfei
The SDK team confirmed that this behavior will be fixed in the next revision of the SDK.
Victor
4 回复数
2,529 次查看
victorjimenez
Sorry for the late response. I'm currently checking with the applications engineer what might be the root cause of this behavior. I will give you an update as soon as possible.
Victor
2,529 次查看
zhengjianfei1
Hi Victor ,
      Is there any update ? Thanks!
2,529 次查看
victorjimenez
Sorry that this is taking too long. This behavior is related to the SDK, so now the SDK team is checking it, I will give you an update as soon as possible.
Victor
2,530 次查看
victorjimenez
Victor
