LPUART issue on S32k116
zzkk
hello,
I am using SDK3.0.0 for a LIN communication .
I got a problem when I want to turn off peripherals.
The program is stuck in LIN_DRV_Deinit(INST_LIN1)➡LIN_LPUART_DRV_Deinit(uint32_t instance)➡
LPUART_SetReceiverCmd(base, false).
The LPUART_CRTL_RE is 1.When I reset it in Debug,program will runnig normally.
This fault occurred sporadically when the mcu powered on.
I have changed the clock source of LIN from SIRC to SOSC,This fault has been resolved.
I want to know the reason about this.
If you have any ideas,please  answer in the comments,Thank you very much.
lukaszadrapa
It's not available for S32DS for Arm (which is version 2.2). It's available for new S32DS:
https://www.nxp.com/design/software/development-software/s32-design-studio-ide/s32-design-studio-for...
Newest version is 3.5. The SDK can be installed using: Help -> S32DS Extensions and Updates.
Lukas
lukaszadrapa
zzkk
Thank  you for your help Lukas. Where can I get SDK 4.0.3 ?
I am using s32ds for arm but I found that i can not add it in.
Do you have a website links about it?
Best Regard,
zzkk
lukaszadrapa
Lukas
zzkk
Thanks so much
