How to add component PIT in PE
2,710 次查看
everkimage
   My IDE is S32DS and create an example project from stm_periodic_interrupt,then i add one component PIT and enable it's "Enable Standard timers",the PE prompt me:"Please configure the PIT clock source by clock manager!"
   But i can't find where i can config it.please help.
2,510 次查看
martin_kovar
could you please clarify, which microcontroller you use and which version of S32DS and SDK you use?
Martin
2,510 次查看
everkimage
Hi,thanks for your reply.
I'm using the DEVKIT-MPC5744P;
my IDE is S32DS for Power Architecture 2017.R1;
SDK V0.8.2;
When i enable a "Enable Standard timers" in the PIT config framework,ide prompt me the message.
2,510 次查看
martin_kovar
it is a bug in the example. Please remove the clock manager component from example and insert it once again.
Now it will work correct. I will also report this bug into our defect system.
Martin
