Enthernet not working for MPC5748G
1,286 次查看
rafakath
I have S32DS version 2017.R1 [Board DEVKIT-MPC5748G]and I have selected example code from sdk for enet_ping and lwip both are not able to generate code showing component configuration error.
In configuration Inspector-ethernet1 --> not able to select MII configuration [Mode , Speed , Duplex] all are by default -1 and not able to change it.
1,205 次查看
veronicavelciu
Hello Mohammad,
Which version of the SDK are you using? Did you try to restart S32DS?
Veronica
